H3C SecPath F5000-AI-20[40] Firewalls Installation Guide-6W102
HomeSupportSecurityH3C SecPath F5000 FirewallInstall & UpgradeInstallation GuidesH3C SecPath F5000-AI-20[40] Firewalls Installation Guide-6W102
01-Text
01-Text 4.97 MB
1 Preparing for installation· 1-1
Safety recommendations· 1-1
Safety symbols· 1-1
General safety recommendations· 1-1
Electrical safety· 1-2
Laser safety· 1-2
Handling safety· 1-2
Examining the installation site· 1-3
Weight support 1-3
Temperature and humidity· 1-3
Cleanliness· 1-3
Cooling system·· 1-4
ESD prevention· 1-5
EMI 1-5
Lightning protection· 1-6
Power supply· 1-6
Installation tools· 1-6
Installation accessories· 1-7
Pre-installation checklist 1-7
2 Installing the firewall 2-9
Installation flow· 2-9
Grounding the firewall 2-9
Installing the firewall in a standard 19-inch rack· 2-10
Installing a power supply· 2-12
Installing a fan tray· 2-14
Installing an interface module· 2-15
Installing a drive· 2-15
Connecting Ethernet cables· 2-16
Connecting a copper Ethernet port 2-16
Connecting a fiber port 2-16
Connecting the power cord· 2-18
Connecting an AC power cord· 2-18
Connecting a DC power cord· 2-19
Verifying the installation· 2-20
3 Accessing the firewall for the first time· 3-21
Setting up the configuration environment 3-21
Powering on the firewall 3-21
Checking before power-on· 3-21
Checking after power-on· 3-21
Logging in to the firewall 3-23
Logging in from the console port 3-23
Logging in from the Web interface· 3-24
Logging in through Telnet 3-24
4 Hardware replacement 4-25
Replacing a fan tray· 4-25
Replacing a power supply· 4-25
Replacing an interface module· 4-26
Replacing a drive· 4-27
Replacing a transceiver module· 4-28
5 Hardware management and maintenance· 5-29
Displaying detailed information about the firewall 5-29
Displaying the software and hardware version information for the firewall 5-29
Displaying the electrical label information for the firewall 5-30
Displaying the CPU usage of the firewall 5-31
Displaying the memory usage of the firewall 5-31
Displaying the operational status of power supplies· 5-32
Displaying the operational status of fan trays· 5-32
Displaying the temperature information of the firewall 5-33
Displaying the operational statistics of the firewall 5-34
Displaying transceiver module information· 5-34
Rebooting the firewall 5-35
6 Troubleshooting· 6-36
Power supply failure· 6-36
Configuration terminal display problem·· 6-36
Password loss· 6-37
Cooling system failure· 6-37
Software loading failure· 6-37
7 Appendix A  Chassis views and technical specifications· 7-38
Chassis views· 7-38
F5000-AI-20/F5000-AI-40· 7-38
Interface modules· 7-39
Power supplies· 7-42
Fan trays· 7-43
Technical specifications· 7-44
Dimensions and weights· 7-44
Memory and storage media· 7-44
Power consumption· 7-45
Power supply specifications· 7-45
Fan tray specifications· 7-45
Drive specifications· 7-46
Port specifications· 7-46
8 Appendix B  LEDs· 8-52
Front panel and rear panel LEDs· 8-52
Interface module LEDs· 8-52
9 Appendix C  Cables· 9-54
Console cable· 9-54
Ethernet twisted pair cable· 9-54
Introduction· 9-54
Making an Ethernet twisted pair cable· 9-57
Optical fiber 9-58
H3C SecPath F5000-AI firewall series includes the F5000-AI-20 and F5000-AI-40 models.
To avoid any equipment damage or bodily injury, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
Safety symbols
When reading this document, note the following symbols:
WARNING WARNING means an alert that calls attention to important information that if not understood or followed can result in personal injury.
CAUTION CAUTION means an alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software.
·     Do not place the firewall on an unstable case or desk. The firewall might be severely damaged in case of a fall.
·     Make sure the ground is dry and flat and anti-slip measures are in place.
·     Keep the chassis and installation tools away from walk areas.
·     Keep the chassis clean and dust-free.
·     Do not place the firewall near water or in a damp environment. Prevent water or moisture from entering the firewall chassis.
·     Ensure good ventilation of the equipment room and keep the air inlet and outlet vents of the firewall free of obstruction.
·     Make sure the operating voltage is in the required range.
·     Use a screwdriver, rather than your fingers, to fasten screws.
·     Stack devices according to the sizes of and packing symbols on the packages.
Table1-1 Packing symbols
Symbol
Stored with a maximum stack of n units.
Transported and stored with the arrows up.
Transported and stored with care.
Transported and stored avoiding humidity, rains and wet floor.
Electrical safety
·     Carefully examine your work area for possible hazards such as moist floors, ungrounded power extension cables, and missing safety grounds.
·     Locate the emergency power-off switch in the room before installation. Shut the power off at once in case accident occurs.
·     Do not work alone when the firewall has power.
·     Always verify that the power has been disconnected.
Laser safety
WARNING
WARNING!
Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the switch is operating.
The firewall is a Class 1 laser device.
·     Before you disconnect the fiber connector, execute the shutdown command in interface view to disable the optical source.
·     Install dust caps to disconnected optical fiber connectors and ports on disconnected transceiver modules to avoid damage caused by built-up dust.
·     Insert a dust plug into empty fiber ports.
Handling safety
When you move the firewall, follow these guidelines:
·     Move and unpack the firewall carefully to avoid firewall damage.
·     Unpack the firewall at least half an hour and power on the firewall at least two hours after you move it from a place below 0°C (32°F) to the equipment room. This prevents condensation and even damage to the firewall.
·     Use a safety hand truck when you move multiple firewalls.
·     Before you move the firewall, remove all cables and mounting brackets.
·     For long-distance transportation, remove all the field-replaceable units (FRUs), such as power supplies and interface modules, and package them separately, and install the filler panels supplied with the firewall. For short-distance transportation, make sure all the FRUs are securely seated in the slots and the screws are fastened.
·     When you move or lift the firewall chassis, support the bottom of the chassis, rather than holding any FRU.
·     Make sure the accessories of the firewall are not lost or damaged during firewall moving.
The firewall can only be used indoors. To make sure the firewall operates correctly and to prolong its service lifetime, the installation site must meet the following requirements.
Weight support
Make sure the floor can support the total weight of the rack, chassis, modules, and all other components. For more information, see "Dimensions and weights."
Maintain appropriate temperature and humidity in the equipment room.
·     Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
·     Lasting low relative humidity can cause washer contraction and ESD and bring problems including loose captive screws and circuit failure.
·     High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the firewall.
For the temperature and humidity requirements of the firewall, see Table1-2.
Table1-2 Temperature/humidity requirements
Temperature
Relative humidity
·     Operating:
¡     Without drives: 0°C to 45°C (32°F to 113°F)
¡     With drives: 5°C to 40°C (41°F to 104°F)
·     Storage: –40°C to +70°C (–40°F to +158°F)
·     Operating:
¡     Without drives: 5% RH to 95% RH, noncondensing
¡     With drives: 10% RH to 90% RH, noncondensing
·     Storage: 5% RH to 95% RH, noncondensing
Cleanliness
Dust buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points, especially when indoor relative humidity is low. In the worst case, electrostatic adsorption can cause communication failure.
Table1-3 Dust concentration limit in the equipment room
Substance
Concentration limit (particles/m3)
Dust particles
≤ 3 × 104
(No visible dust on desk in three days)
Dust particle diameter ≥ 5 µm
The equipment room must also meet strict limits on salts, acids, and sulfides to eliminate corrosion and premature aging of components, as shown in Table1-4.
Table1-4 Harmful gas limits in an equipment room
Gas
Max. (mg/m3)
SO2
0.2
H2S
0.006
NH3
0.05
Cl2
0.01
NO2
0.04
Cooling system
For adequate heat dissipation of the device, follow these guidelines:
·     Make sure the installation site has a good cooling system.
·     Reserve a minimum clearance of 100 mm (3.94 in) around the air inlet and outlet vents.
·     Reserve a minimum clearance of 1 U (44.45 mm, 1.75 in) between the firewall and its adjacent devices when installing the firewall in a rack.
·     The firewall uses front-rear air isles. Select fan trays that match the airflow direction at the installation site for the firewall.
¡     The FAN-20F-2-A fan tray provides power supply-side intake and port-side exhaust airflows. It has a blue handle.
Figure1-1 Airflow direction of the firewall installed with FAN-20F-2-A fan trays
¡     The FAN-20B-2-A fan tray provides port-side intake and power supply-side exhaust airflow. It has a red handle.
Figure1-2 Airflow direction of the firewall installed with FAN-20B-2-A fan trays
ESD prevention
To prevent electrostatic discharge (ESD), use the following guidelines:
·     Make sure the firewall and the rack are reliably grounded.
·     Take dust-proof measures for the equipment room. Make sure the equipment room meets the dust control requirements described in "Cleanliness."
·     Maintain the humidity and temperature at acceptable levels. For more information, see "Temperature and humidity."
·     Put the removed interface modules away on an ESD workbench, with the PCB upward, or put them in ESD bags for future use.
·     Always wear ESD clothing, ESD gloves, and an ESD wrist strap when you install or remove a transceiver module.
No ESD wrist strap is provided with the firewall. Purchase one yourself.
Before you attach an ESD wrist strap, make sure the rack is reliably grounded.
To attach the ESD wrist strap:
1.     Wear the wrist strap on your wrist.
2.     Lock the wrist strap tight around your wrist to keep good contact with the skin.
3.     Secure the wrist strap lock and the alligator clip lock together.
4.     Attach the alligator clip to the rack.
Figure1-3 Attaching an ESD wrist strap
(1) ESD wrist strap
(2) Lock
(3) Alligator clip
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the firewall and application system, adversely affect the firewall in the following ways:
·     A conduction pattern of capacitance coupling.
·     Inductance coupling.
·     Electromagnetic wave radiation.
·     Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
·     If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid.
·     Keep the firewall far away from radio transmitting stations, radar stations, and high-frequency devices.
·     Use electromagnetic shielding, for example, shielded interface cables, when necessary.
·     To prevent signal ports from getting damaged by overvoltage or overcurrent caused by lightning strikes, route interface cables only indoors. If part of the network cable of an Ethernet port must be routed outdoors, connect a lightning arrester to the cable before you plug the cable into the port.
To protect the firewall from lightning better, do as follows:
·     Make sure the grounding cable of the chassis is reliably grounded.
·     Make sure the grounding terminal of the AC power receptacle is reliably grounded.
·     If an AC power cord is routed from outdoors for connecting to the firewall, connect the power cord first to a power lightning arrester before connecting it to the power receptacle on the firewall.
·     If a network cable is routed from outdoors for connecting to an Ethernet port on the firewall, connect the network cable first to a network port lightning arrester before connecting it to the port.
IMPORTANT
IMPORTANT:
No network port lightning arrester or AC power lightning arrester is provided with the firewall. Prepare them as required. For the technical specifications and installation instructions for the lightning protectors, see the documents shipped with them.
Power supply
Verify that the power system at the installation site meets the requirements of the power supplies, including the input method and rated input voltage. For more information, see "Appendix A Chassis views and technical specifications."
Installation tools
No installation tools are provided with the firewall. Prepare installation tools yourself as required.
Table1-5 Installation tools
Flathead screwdriver
Phillips screwdriver
Needle-nose pliers
Marker
Diagonal pliers
ESD wrist strap
Wire-stripping pliers
Crimping tool
Table1-6 Installation accessories
Mounting brackets with cable management brackets
Slide rails and chassis rails
M4 mounting bracket screw
M6 rack screw
Cage nut
Console cable
Grounding cable
Table1-7 Checklist before installation
Item
Requirements
Installation site
Ventilation
·     There is a minimum clearance of 100 mm (3.94 in) around the inlet and outlet air vents for heat dissipation of the firewall chassis.
·     A ventilation system is available at the installation site.
Temperature
·     Operating:
Relative humidity
·     Operating:
¡     With drives: 10% RH to 80% RH, noncondensing
Cleanness
·     Dust concentration ≤ 3 × 104 particles/m3
·     No dust on desk within three days
ESD prevention
·     The firewall and the rack are reliably grounded.
·     The equipment room is dust-proof.
·     The humidity and temperature are at an acceptable level.
·     Always wear ESD clothing, ESD gloves, and an ESD wrist strap and when you install and remove a transceiver module.
·     Put the removed interface modules on an ESD workbench, with the PCB upward, or put them in ESD bags for future use.
EMI prevention
·     Take effective measures to protect the power system from the power grid system.
·     Separate the protection ground of the firewall from the grounding device or lightning protection grounding device as far as possible.
·     Keep the firewall far away from radio stations, radar and high-frequency devices working in high current.
·     Use electromagnetic shielding when necessary.
·     The grounding cable of the chassis is reliably grounded.
·     The grounding terminal of the AC power receptacle is reliably grounded.
·     (Optional) A power lightning arrester is installed.
Power supply
Tools and accessories
·     Installation accessories supplied with the firewall
·     User supplied tools
Reference
·     Documents shipped with the firewall
·     Online documents
WARNING
WARNING!
Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact the local agent of H3C for permission. Otherwise, H3C shall not be liable for any consequence caused thereby.
The installation method is similar for the F5000-AI-20 and F5000-AI-40 firewalls. This section uses the F5000-AI-40 firewall as an example.
Installation flow
Table2-1 Installation flow for the firewall
Step
1.     Start
Before installation, make sure all requirements on the checklist are met and the firewall is powered off.
2.     Grounding the firewall
Before installation, make sure the firewall and rack are reliably grounded and you wear an ESD wrist strap.
3.     Installing the firewall in a standard 19-inch rack
The firewall is heavy. Both mounting brackets and slide rails are required to support the weight of the chassis.
4.     Installing a power supply
Before you install a power module, make sure the power module is not connected to any power source and the grounding cable of the firewall is connected reliably.
5.     Installing a fan tray
Install compatible fan trays on the firewall.
6.     Installing an interface module
No MPU or interface module is provided with the firewall. Purchase them as required.
7.     Installing a drive
Install compatible drives on the firewall.
8.     Connecting Ethernet cables
The firewall provides various ports. Choose compatible transceiver modules and cables as required. To avoid bodily injury or device damage, read the restrictions and guidelines carefully before connection.
9.     Connecting the power cord
Connect compatible power cords to the power modules.
10.     Verifying the installation
Verify that the firewall is installed securely and reliably grounded, and that the power modules are as required.
WARNING
WARNING!
·     Correctly connecting the firewall grounding cable is crucial to lightning protection and EMI protection. Before installing or using the firewall, connect the grounding cable to it correctly.
·     Do not connect the firewall grounding cable to a fire main or lightning rod.
As shown in Figure2-1, the firewall provides a primary grounding point at the rear panel and an auxiliary grounding point at the left side. The primary grounding point has a grounding sign and a grounding screw.
The grounding screw at the primary grounding point is also applicable to the auxiliary grounding point. To use the auxiliary grounding point, attach the grounding cable to the grounding point before you install the firewall in a rack.
The procedure is the same for connecting a grounding cable to the primary grounding point and the auxiliary grounding point. This section uses the primary grounding point as an example.
To connect the grounding cable:
1.     Remove the grounding screw from the primary grounding point at the firewall rear.
2.     Attach the grounding screw to the ring terminal of the grounding cable.
3.     Use a screwdriver to fasten the grounding screw into the grounding hole.
4.     Connect the other end of the grounding cable to the grounding strip on the rack.
Figure2-1 Grounding the firewall by using the primary grounding point
WARNING
WARNING!
To avoid bodily injury and firewall damage, at least two persons are required to install the firewall.
CAUTION
CAUTION:
·     Ensure a clearance of 1 RU (44.45 mm, or 1.75 in) between the firewall and walls or other devices for heat dissipation.
·     The mounting brackets and chassis rails are required to support the weight of the chassis.
To mount the firewall in a rack, make sure the rack meets the requirements described in Table2-2.
Table2-2 Firewall dimensions and rack requirements
Firewall dimensions
Rack requirements
·     Height—88.1 mm (3.47 in)
·     Width—440 mm (17.32 in)
·     Total depth—775.5 mm (30.53 in)
¡     660 mm (25.98 in) for the chassis
¡     90 mm (3.54 in) for the cable management bracket at the chassis front
¡     25.5 mm (1.00 in) for the power supply handle at the chassis rear
·     A minimum of 1 m (3.28 ft) in depth (recommended).
·     A minimum of 100 mm (3.94 in) between the front rack posts and the front door.
·     A minimum of 760 mm (29.92 in) between the front rack posts to the rear door.
·     518 mm (20.39 in) to 923 mm (36.34 in) from the front rack posts to the rear rack posts.
To install the firewall in a 19-inch rack:
1.     Make sure the rack is sturdy and reliably grounded.
2.     Wear an ESD wrist strap and unpack the firewall and accessories.
3.     Use a mounting bracket and a slide rail to mark the cage nut installation positions on the front and rear rack posts, respectively. Four cage nuts are required on each front rack post and two are required on each rear rack post.
4.     Install cages nuts at the marked positions.
5.     Use M6 screws to attach two slide rails to the rear rack posts.
Figure2-2 Installing cage nuts and slide rails
6.     Use the provided M4 screws to attach the mounting brackets and chassis rails to both sides of the firewall.
The firewall provides multiple installation positions for chassis rails. Install chassis rails to the appropriate positions and make sure the front ends of the slide rails can reach out of the chassis rails after the firewall is installed in the rack.
Figure2-3 Attaching the mounting brackets and chassis rails to the firewall
7.     One person supports the bottom of the firewall, align the chassis rails with the slide rails, and slide the slide rails into the chassis rails until the mounting brackets are flush with the front rack posts.
8.     Fasten the M6 rack screws with a Phillips screwdriver to secure the mounting brackets to the front rack posts.
Figure2-4 Mounting the firewall in the rack
CAUTION
CAUTION:
·     Make sure the power supply is powered off and the firewall is correctly grounded before installation.
·     Install a filler panel over an empty power supply slot to prevent dust and ensure good ventilation in the chassis.
·     Do not install both AC and DC power supplies on the same firewall.
No power supply is provided with the firewall. Purchase power supplies as required. The installation procedures for AC and DC power supplies are similar. The following procedure installs an AC power supply.
To install a power supply:
1.     To install the power supply in slot PWR1, remove the filler panel from the slot. To install the power supply in slot PWR2, skip this step.
Figure2-5 Removing the filler panel
2.     Install the power supply in a correct direction (with the power receptacle at right):
a.     Grasp the handle of the module with one hand and support the module bottom with the other.
b.     Push the power supply along the guide rails into the slot until it has firm contact with the slot.
Figure2-6 Installing an AC power supply
CAUTION
CAUTION:
·     Before installation, make sure the airflow direction provided by the fan tray meets the requirements for installation ventilation.
·     The firewall comes with both fan tray slots empty. To ensure good ventilation, you must install two fan trays of the same model before powering on the firewall.
·     If you start the firewall without fan trays installed, the firewall will shut down automatically. You must turn off power to the firewall and install fan trays for the firewall and then restart the firewall.
·     If one fan tray fails during the device operation, replace the fan tray immediately and keep the fan tray in the slot before the replacement. If both fan trays fail, replace one fan tray first immediately. Replace the other fan tray after the new fan tray operates correctly. Do not remove both fan trays at the same time. This operation can cause the device to power off.
·     To prevent damage to the fan tray and the connectors on the backplane, insert the fan tray gently. If you encounter any resistance while inserting the fan tray, pull out the fan tray, re-orient it, and then insert it again.
No fan tray is provided with the firewall. Purchase fan trays as required. The firewall supports the FAN-20B-2-A and FAN-20F-2-A fan trays. The firewall supports hot swapping of fan trays.
The installation procedures for the FAN-20B-2-A and the FAN-20F-2-A fan trays are similar. The following procedure installs a FAN-20B-2-A fan tray.
To install a fan tray:
1.     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2.     Orient the fan tray with the "TOP" mark on the top, grasp the fan tray handle with one hand, and support its bottom with the other hand. Slide the fan tray along the guide rails into the slot until it has a firm contact with the backplane.
Figure2-7 Installing a fan tray
CAUTION
CAUTION:
·     The firewall does not support hot swapping of interface modules.
·     To avoid module damage, do not touch the surface-mounted components on an interface module directly with your hands.
·     Install a filler panel in each empty interface module slot to prevent dust and ensure good ventilation in the chassis.
No interface modules are provided with the firewall. Purchase them as required.
To install an interface module:
2.     Remove the screws on the filler panel with a Phillips screwdriver and remove the filler panel.
Keep the filler panel for future use.
3.     Open the ejector levers on the module and slide the module steadily into the slot along the guide rails.
4.     Close the ejector levers until they touch the panel tightly and the module seats into the backplane.
5.     Fasten the captive screws on the module with a Phillips screwdriver.
Figure2-8 Installing an interface module
Installing a drive
CAUTION
CAUTION:
·     The firewall does not support hot swapping of drives.
·     Hold a drive by its sides. Do not touch drive components and do not squeeze, vibrate, or strike the drive.
·     Install a filler panel over empty drive slots to avoid damage caused by build-up dust.
·     Before using a drive, execute the fdisk and format commands from the CLI to partition and format the drive.
The firewall does not come with any drives and cannot recognize drives from other vendors. Purchase drives from H3C as needed.
To install a drive:
2.     Remove the filler panel over the drive slot.
3.     Press the red button on the drive panel to release the locking lever.
4.     Hold the locking lever, slide the drive into the slot along the guide rails, and then close the locking lever.
Figure2-9 Installing the drive
You can use either a straight-through or a cross-over network cable to connect a copper Ethernet port. For more information about Ethernet twisted pair cables, see "Ethernet twisted pair cable."
To connect a copper Ethernet port:
1.     Connect one end of the Ethernet cable to the copper Ethernet port of the firewall, and the other end to the Ethernet port of the peer device.
2.     Examine whether the LEDs of the Ethernet port are normal. For more information about LEDs, see "Appendix B LEDs."
After connecting the firewall to the network, you can use the ping or tracert command to examine network connectivity. For more information, see the related command reference.
WARNING
WARNING!
CAUTION
CAUTION:
·     Never bend or curve a fiber excessively. The bend radius of a fiber must be not less than 100 mm (3.94 in).
·     Keep the fiber end clean.
·     Make sure the fiber connector matches the transceiver module.
·     Before connecting a fiber, make sure the optical power at the receiving end does not exceed the transceiver module's upper threshold of the optical receive power. If the optical power at the receiving end exceeds the threshold, the transceiver module might be damaged.
·     Do not install a transceiver module connected with a fiber into a fiber port. To connect an optical fiber, first install the transceiver module in the fiber port and then connect the fiber.
·     Insert a dust plug into any open fiber port.
·     Make sure the Tx and Rx ports on a transceiver module are connected to the Rx and Tx ports on the peer end, respectively.
The firewall supports GE SFP transceiver modules, 10GE SFP+ transceiver modules, and 40GE QSFP+ transceiver modules. For the transceiver module specifications, see "GE fiber Ethernet port", "10 GE fiber Ethernet port" and "40 GE fiber Ethernet port."
No transceiver module is provided with the firewall. As a best practice, use H3C transceiver modules.
Figure2-10 GE SFP transceiver module
图-1副本
Figure2-11 10GE SFP+ transceiver module
Figure2-12 40GE QSFP+ transceiver module
To connect a fiber port:
1.     Remove the dust plug from the fiber port.
2.     Install a transceiver module. Pull the bail latch on the transceiver module upwards to catch the knob on the top of the transceiver module. Take the transceiver module by its two sides and push the end without the bail latch gently into the port until it snaps into place.
3.     Remove the dust cap from the optical fiber connector, and use dust free paper and absolute alcohol to clean the end face of the fiber connector.
4.     Identify the Rx and Tx ports on the transceiver module. Plug one end of the optical fiber into the transceiver module in the firewall, and plug the other end into the transceiver module in the peer device.
Make sure the Rx port and the Tx port are connected to the Tx port and the Rx port on the peer device, respectively.
Figure2-13 Connecting a fiber port
CAUTION
CAUTION:
Make sure the grounding cable of the firewall is correctly connected and the power source is powered off before connecting the power cord.
1.     Connect one end of the AC power cord to the AC-input power receptacle on the power supply.
2.     Use a removable cable tie to secure the AC power cord to the power supply handle.
3.     Connect the other end of the power cord to the AC power source.
Figure2-14 Connecting an AC power cord
1.     Correctly orient the DC power cord plug with the power receptacle on the power supply, and insert the plug into the receptacle.
2.     Use a removable cable tie to secure the DC power cord to the power supply handle.
3.     Connect the other end of the power cord to the DC power source.
Figure2-15 Connecting a DC power cord
After installation, verify that:
·     There is enough space for heat dissipation around the firewall, and the firewall is steady.
·     All screws are fastened.
·     The grounding cable and power cord are securely connected.
·     The correct power source is used.
To access the firewall for the first time, you can log in to the firewall from the console port or Web interface. To set up the configuration environment, see "Logging in from the console port" and "Logging in from the Web interface", respectively.
WARNING
WARNING!
Locate the emergency power-off switch in the room before power-on so you can quickly shut power off when an electrical accident occurs.
Before powering on the firewall, verify the following information:
·     The power cord and grounding cable are correctly connected.
·     The console cable is correctly connected, the terminal or PC used for configuration has started, and the configuration parameters have been correctly set.
·     The interface module (if any) is correctly installed.
Switch on the power source of the firewall.
After powering on the firewall, verify that:
·     The LEDs on the front panel indicate that the firewall is operating correctly. For more information about LEDs, see "Appendix B LEDs."
·     The fan blades are rotating and air is exhausted from the air outlet vents.
·     The configuration terminal displays the following:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test....
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing....Done.
*                   H3C SecPath BootWare, Version 1.03                     *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Mar 28 2017
Memory Type         : DDR3 SDRAM
Memory Size         : 32768MB
Flash Size          : 8MB
sda0 Size           : 3728MB
CPLD Version        : 1.0
PCB Version         : Ver.B
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
Loading file sda0:/Main-CMW710-SYSTEM-A9606P03.bin.......................
.........Done.
Loading file sda0:/Main-CMW710-BOOT-A9606P03.bin..........Done.
Image file sda0:/Main-CMW710-BOOT-A9606P03.bin is self-decompressing.....
Done.
System image is starting...
Cryptographic Algorithms Known-Answer Tests are running ...
CPU 0 of slot 1:
Starting Known-Answer tests in the user space.
Known-answer test for SHA1 passed.
Known-answer test for SHA224 passed.
Known-answer test for SHA256 passed.
Known-answer test for SHA384 passed.
Known-answer test for SHA512 passed.
Known-answer test for HMAC-SHA1 passed.
Known-answer test for HMAC-SHA224 passed.
Known-answer test for HMAC-SHA256 passed.
Known-answer test for HMAC-SHA384 passed.
Known-answer test for HMAC-SHA512 passed.
Known-answer test for AES passed.
Known-answer test for RSA(signature/verification) passed.
Known-answer test for RSA(encrypt/decrypt) passed.
Known-answer test for DSA(signature/verification) passed.
Known-answer test for random number generator passed.
Known-Answer tests in the user space passed.
Starting Known-Answer tests in the kernel.
Known-answer test for GCM passed.
Known-answer test for GMAC passed.
Known-Answer tests in the kernel passed.
Starting Known-Answer tests in the engine.
Known-Answer tests in the engine passed.
Cryptographic Algorithms Known-Answer Tests passed.
Line con0 is available.
Press ENTER to get started...
Press ENTER to access user view of the firewall.
To access the EXTENDED-BOOTWARE menu, press Ctrl + B within four seconds at the prompt "Press Ctrl+B to access EXTENDED-BOOTWARE MENU." If you do not press Ctrl+B at the prompt, the system starts to read and decompress program files. To enter the EXTENDED-BOOT menu afterwards, you need to reboot the firewall.
For more information about logging in to the firewall, see the configuration guides and command references for the firewall.
You can use the console port to access the firewall for the first time. The default console port login information is as follows:
·     Authentication methodscheme
·     Username—admin
·     Password—admin
To access the firewall from the console port:
1.     Use a console cable to connect the console port on the firewall to a configuration terminal, for example, a PC.
2.     Run a terminal emulator program, TeraTermPro or PuTTY, on your configuration terminal.
For more information about the terminal emulator programs, see the user guides for these programs.
3.     Configure the terminal settings as follows:
¡     Bits per second—9,600.
¡     Data bits—8.
¡     Stop bits—1.
¡     Parity—None.
¡     Flow control—None.
IMPORTANT
IMPORTANT:
After accessing the Web interface with the default account, modify the password of the default account or create a new administrator account and delete the default account as a best practice.
At the first login from the Web interface, you can use the default account or use an account created from the CLI.
Table3-1 provides the default Web interface login information.
Table3-1 Default Web interface login information
Item
Default configurations
Username
admin
Password
admin
Management Ethernet interface
GE1/0/0
IP address of the Ethernet management interface
192.168.0.1/24
To log in to the firewall from the Web interface by using the default account:
1.     Use an Ethernet cable to connect a PC to the Ethernet management interface on the firewall.
2.     Configure an IP address in subnet 192.168.0.0/24 for the PC. Make sure the PC and the firewall are reachable to each other.
The PC must use a different IP address than the Ethernet management interface.
3.     Start a browser, enter 192.168.0.1 in the address bar, and press Enter.
4.     Enter the default username admin and password admin and then click Login.
5.     Modify the login information.
At the first login from the Web interface, change the password as required in the pop-up window, and then click OK.
Keep the new password secure.
1.     Log in to the firewall through the console port, and enable the Telnet function in system view by using the telnet server enable command.
2.     Enter VTY user line view, and configure the authentication mode, user role, and common properties.
By default, the authentication mode is scheme, the username is admin, and the password is admin.
3.     Specify an IP address for the network port of the PC. Make sure the PC and the firewall are reachable to each other.
By default, the IP address of the Ethernet management interface on the firewall is 192.168.0.1/24.
4.     Run the Telnet client on the PC and enter the login information.
CAUTION
CAUTION:
Wear an ESD wrist strap or ESD gloves for hardware maintenance. They are not provided with the firewall. Prepare them yourself.
WARNING
WARNING!
·     To avoid bodily injury, do not touch an operating fan tray.
·     The device supports hot swapping of fan trays. Follow electrical safety instructions when you hot swap a fan tray.
CAUTION
CAUTION:
To prevent an unbalanced fan from causing loud noise, do not touch the fan blades and rotating axis even if they are not rotating.
To replace a fan tray:
1.     Holding the fan tray handle with one hand and supporting the fan tray bottom with the other, pull the fan tray out of the slot along the guide rails.
2.     Put the removed fan tray into an antistatic bag.
3.     Install a new fan tray. For the installation procedure, see "Installing a fan tray."
Figure4-1 Removing a fan tray
WARNING
WARNING!
Before removing a power supply, turn off the power source and remove the power cord.
The procedures for replacing AC and DC power supplies are similar. The following procedure replaces a DC power supply.
To replace a power supply:
1.     Turn off the power source and then remove the power cord from the power supply.
To remove a DC power cord, squeeze the upper and lower sides of the plug and then pull the plug out.
Figure4-2 Removing a power cord
2.     Holding the handle on the power supply with one hand, press the retaining latch on the power supply to the right with your thumb, and pull the power supply part way out of the slot.
3.     Supporting the power supply bottom with the other hand, slowly pull the power supply out of the slot. Then put the removed power supply into an antistatic bag.
Figure4-3 Removing a power supply
4.     Install a new power supply. For the installation procedure, see "Installing a power supply." If you are not to install a new power supply, install a filler panel in the power supply slot.
CAUTION
CAUTION:
The firewall does not support hot swapping of interface modules. Before replacing an interface module, first power off the firewall.
To replace an interface module:
1.     Power off the firewall.
2.     Use a Phillips screwdriver to loosen the captive screws on the module.
3.     Holding the ejector levers of the module with both hands, pull the ejector levers outward, and pull the module part way out of the slot along the guide rails.
4.     Supporting the bottom of the module with one hand, use the other hand to gently pull the module out of the slot.
5.     Put the removed module on an antistatic workbench or into an antistatic bag with the circuit board facing upward.
6.     Install a new module. For the installation procedure, see "Installing an interface module."
Figure4-4 Removing an interface module
Replacing a drive
CAUTION
CAUTION:
·     To avoid storage medium damage, execute the umount command from the CLI to unmount all the file systems before removing a drive.
·     The device does not support hot swapping of drives.
To replace a drive:
1.     Log in to the Web interface. Click the Unmount button on the Storage settings page.
2.     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
4.     Hold the locking lever and pull the drive out of the slot.
5.     Install a new drive. For the installation procedure, see "Installing a ."
Figure4-5 Removing a drive
WARNING
WARNING!
When you replace a transceiver module, make sure the two transceiver modules connected by the same optical fiber are the same type. Do not touch the golden plating of the transceiver module.
Figure4-6 Transceiver module golden plating
To replace a transceiver module:
1.     Use the shutdown command in interface view at the CLI to shut down the optical source before you remove the fiber connector.
2.     Remove the LC connectors with the optical fiber from the transceiver module, and install dust caps to the LC connectors.
3.     Pivot the clasp of the transceiver module down to the horizontal position, and gently pull the transceiver module out.
Figure4-7 Removing the transceiver module
4.     Install dust caps to the removed transceiver module, and put it into the package.
5.     Install a new transceiver module. For the installation procedure, see "Connecting a fiber port."
The output depends on your firewall model. For more information about the commands used in this chapter, see the corresponding configuration guides and command references.
Use the display device verbose command to display detailed information, including the running status and hardware version, about the firewall and its interface modules.
<Sysname> display device verbose
Slot 1 SubSlot 0 info:
Status           :   Normal
Type             :   RPU
PCB 1 Ver        :   VER.B
Software Ver     :   9606P03
CPU Ver          :   1.0
CPLD_A           :   1.0
CPLD_B           :   1.0
CFCard Num       :   0
Use the display version command to display software and hardware version information for the firewall.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Alpha 9606P03
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F5000-AI-40 uptime is 0 weeks, 0 days, 0 hours, 31 minutes
Boot image: sda0:/Main-CMW710-BOOT-A9606P03.bin
Boot image version: 7.1.064, Alpha 9606P03
  Compiled Apr 27 2017 16:00:00
System image: sda0:/Main-CMW710-SYSTEM-A9606P03.bin
System image version: 7.1.064, Alpha 9606P03
SLOT 1
CPU type:           Multi-core CPU
DDR3 SDRAM Memory:  32752M bytes
SD0:                3728M bytes
NSQ1MPBHA    PCB Version:  Ver.B
NSQ1MPBBHB   PCB Version:  Ver.A
NSQ1MPHDBHA  PCB Version:  Ver.A
NSQ1MPGC4BHA PCB Version:  Ver.A
NSQ1MPLEDBHA PCB Version:  Ver.A
CPLD_A           Version:  1.0
CPLD_B           Version:  1.0
Release          Version:SecPath F5000-AI-40-9606P03
Basic  BootWare  Version:1.03
Extend BootWare  Version:1.03
[SUBCARD 0] NSQ1MPBHA(Hardware)Ver.B, (Driver)1.0, (Cpld)1.0
Use the display device manuinfo command to display the electrical label information for the firewall.
<Sysname> display device manuinfo
Slot 1 CPU 0:
 DEVICE_NAME          : SecPath F5000-AI-40
 DEVICE_SERIAL_NUMBER : 210235A1XYH175000008
 MAC_ADDRESS          : 1CAB-3497-D7DE
 MANUFACTURING_DATE   : 2019-06-11
 VENDOR_NAME          : H3C
Fan 0:
The operation is not supported on the specified fan.
Fan 1:
Fan 2:
Fan 3:
Power 0:
The operation is not supported on the specified power.
Table5-1 Output description
DEVICE_NAME
Firewall name.
Firewall serial number.
MAC_ADDRESS
MAC address of the firewall.
MANUFACTURING_DATE
Manufacturing date of the firewall.
VENDOR_NAME
Vendor name.
Use the display cpu-usage command to display the CPU usage of the firewall.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       0% in last 5 seconds
       0% in last 1 minute
       0% in last 5 minutes
Table5-2 Output description
CPU 0 usage information for the interface module in slot 1.
Average CPU usage in the last 5 seconds. (After the firewall boots, the firewall calculates and records the average CPU usage at intervals of 5 seconds.)
0% in last 1 minute
Average CPU usage in the last minute. (After the firewall boots, the firewall calculates and records the average CPU usage at intervals of 1 minute.)
Average CPU usage in the last 5 minutes. (After the firewall boots, the firewall calculates and records the average CPU usage at intervals of 5 minutes.)
Use the display memory command to display the memory information of the firewall.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      32870736   4244812  28625924         0      2048    200756       87.1%
-/+ Buffers/Cache:   4042008  28828728
Swap:           0         0         0
Table5-3 Output description
Slot
Slot number of the interface module.
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is used for kernel codes, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Use the display power command to display the operational status of power supplies.
<Sysname> display power
Slot  1 Power  0     Status: Normal
Slot  1 Power  1     Status: Absent
Table5-4 Output description
Power
Number of the power supply.
Status
Power supply status:
·     Normal—The power supply is operating correctly.
·     Absent—No power supply is present.
·     Abnormal—The power supply is faulty.
Use the display fan command to display the operational status of fan trays.
<Sysname>display fan
SLOT 1 Fan 0-0      Status: Normal  Speed:7692
SLOT 1 Fan 0-1      Status: Normal  Speed:7894
SLOT 1 Fan 1-0      Status: Normal  Speed:7894
SLOT 1 Fan 1-1      Status: Normal  Speed:7692
Table5-5 Output description
SLOT 1
Member ID of the device.
Fan 0
Fan 1
Number of the fan tray.
Status
Fan tray status:
·     Absent—No fan tray is present.
·     Normal—The fan tray is operating correctly.
·     Faulty—The fan tray is faulty.
·     NoSupport—The fan tray is not supported.
·     FanDirectionFault—The fan tray airflow direction is inconsistent with the expected fan tray direction.
Speed
Fan tray speed.
The fan tray adjusts its speed automatically to adapt to the device temperature. Inflow and outflow temperature sensors are used to monitor the device temperature. To view device temperature information, execute the display environment command.
Use the display environment command to display the temperature information of the firewall.
<Sysname> display environment
System Temperature information (degree centigrade):
 Slot     Sensor   Temperature LowerLimit Warning-UpperLimit  Alarm-UpperLimit S
hutdown-UpperLimit
1      inflow  1      36          0              60                70
     NA
1      inflow  2      34          0              60                70
     NA
1      outflow 1      42          0              60                70
     NA
1      hotspot 1      62          0              80                92
     NA
Table5-6 Output description
Slot
Sensor
Temperature sensor:
·     inflow—Air inlet vent temperature sensor.
·     outflow—Air outlet vent temperature sensor.
·     hotspot—Hotspot temperature sensor.
Temperature
Current temperature.
LowerLimit
Low temperature alarm threshold.
Warning-UpperLimit
Warning-level high temperature alarm threshold.
Alarm-UpperLimit
Alarming-level high temperature alarm threshold.
Shutdown-UpperLimit
Shutdown-level high temperature alarm threshold. The firewall automatically powers off when the temperature exceeds this threshold.
When you perform routine maintenance or the system fails, you might need to view the operational information of each functional module for locating failures. Typically you need to run display commands one by one. To collect more information one time, you can execute the display diagnostic-information command in any view to display or save the operational statistics of multiple functional modules of the firewall.
·     Save the operational statistics of each functional module of the firewall:
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[sda0:/diag.gz]:
Diagnostic information is outputting to sda0:/diag.gz.
Please wait...
Save successfully.
To view the diag.gz file:
a.     Execute the tar extract archive-file diag.tar.gz command in user view to decompress the file.
b.     Execute the gunzip diag.gz command.
c.     Execute the more diag command.
d.     Press Page Up and Page Down.
·     Display the operational statistics for each functional module of the firewall:
17:22:11 UTC Mon 08/21/2017
Identifying transceiver modules
To identify transceiver modules, you can use the following command to view the key parameters of the transceiver modules. The key parameters include transceiver module type, connector type, central wavelength of the laser sent, transmission distance, and vendor name.
To display transceiver module information:
Remarks
Display key parameters of the transceiver module in a specific interface.
Available for all transceiver modules.
Troubleshooting transceiver modules
The system outputs alarm information for you to locate and troubleshoot faults of transceiver modules.
To display the alarming information or fault detection parameters of a transceiver module:
Remarks
Display the current alarm information of the transceiver module in a specific interface.
CAUTION
CAUTION:
·     If the main system software image file does not exist, do not use the reboot command to reboot the firewall. Specify the main system software image file first, and then reboot the firewall.
·     The precision of the rebooting timer is 1 minute. 1 minute before the rebooting time, the firewall prompts "REBOOT IN ONE MINUTE" and reboots in one minute.
·     If you are performing file operations when the firewall is to be rebooted, the system does not execute the reboot command for security.
To reboot a firewall, use one of the following methods:
·     Use the reboot command to reboot the firewall immediately.
·     Enable the scheduled reboot function at the CLI. You can set a time at which the firewall can automatically reboot, or set a delay so that the firewall can automatically reboot within the delay.
·     Power on the firewall after powering it off, which is also called hard reboot or cold start. As a best practice, do not use this method because it might cause data loss and hardware damages.
To reboot the firewall immediately:
Remarks
Reboot the firewall immediately.
reboot
Available in user view.
To enable the scheduled reboot function:
Remarks
Enable the scheduled reboot function and specify a specific reboot time and date
scheduler reboot at
·     Use either approach.
·     The scheduled reboot function is disabled by default.
·     Available in user view.
Enable the scheduled reboot function and specify a reboot waiting time
scheduler reboot delay
6 Troubleshooting
Symptom
The firewall cannot be powered on, and the power LED (PWR0/PWR1) on the front panel is off.
Solution
To solve the issue:
2.     Verify that the power supply is as required by the firewall.
3.     Verify that the power cords of the firewall are firmly connected.
4.     Verify that the power cords are not damaged.
5.     If the issue persists, contact your local sales agent.
Symptom
The configuration terminal displays nothing or garbled text when the firewall is powered on.
Solution
To solve the issue:
1.     Verify that the power supply system is operating correctly.
2.     Verify that the console cable is correctly connected.
3.     Verify that the console cable is connected to the serial port that is configured for the configuration terminal.
4.     Verify that the configuration terminal parameters are configured as follows:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Terminal emulation—VT100.
5.     Verify that the console cable is in good condition.
6.     If the issue persists, contact your local sales agent.
For information about serial port parameter setting, see "Logging in from the console port."
Password loss
For more information about dealing with the console port password loss, see the release notes for the firewall.
Symptom
The temperature of the firewall is higher than the normal operating temperature (45°C or 113°F).
Solution
To solve the issue:
1.     Verify that the fan trays are operating correctly.
2.     Verify that the operating environment of the firewall has good ventilation.
3.     If the following alarm information is generated, the temperature of the firewall has reached the warning-level high temperature alarm threshold,
Jul 6 11:16:15:872 2020 H3C DEV/4/TEMPERATURE_WARNING: -Context=1; Temp
erature is greater than the high-temperature warning threshold on slot
 1 sensor inflow 1. Current temperature is 74 degrees centigrade.
Use the display environment command to examine whether the temperature of the firewall keeps rising. If the temperature has reached the alarming-level high temperature alarm threshold, back up data immediately, power off the firewall, and contact your local sales agent.
Information about the firewall temperature in the display environment command output varies by firewall model.
4.     If the issue persists, contact your local sales agent.
Symptom
Software loading fails and the system runs the software of the previous version.
Solution
To solve the issue:
1.     Verify that the physical ports are correctly connected.
2.     Verify that no parameter is configured incorrectly during the loading process. You can examine the software loading process displayed on the HyperTerminal for configuration errors. The following errors can lead to software loading failure.
¡     When XMODEM is used to load software, a baud rate other than 9600 bps is selected, but the baud rate for the HyperTerminal is not reset.
¡     When TFTP is used to load software, an incorrect IP address, software name, or TFTP serve path is configured.
¡     When FTP is used to load software, an incorrect IP address, software name, username, or password is entered.
3.     If the issue persists, contact the local sales agent.
Chassis views
Front panel
The firewall provides eight interface module slots and two drive slots on the front panel.
Figure7-1 Front panel
(1) Interface module slots (slots 1 through 8)
(2) Drive slot HD0
(3) Drive slot HD1
(4) LEDs
Rear panel
The firewall provides the following ports and slots on the rear panel:
·     Four combo interfaces (including one management Ethernet port, three 10/100/1000BASE-T autosensing copper ports, and four 1000BASE-X fiber ports).
·     Two USB ports.
·     One console port.
·     Two fan tray slots
·     Two power supply slots.
Figure7-2 Rear panel
(1) 10/100/1000BASE-T copper port (combo interface)
(2) 1000BASE-X fiber port (combo interface)
(3) Console port
(4) USB port
(5) Fan tray slot FAN0
(6) Fan tray slot FAN1
(7) Power supply slot PWR0
(8) Grounding screw
(9) Power supply slot PWR1
(10) Management Ethernet port GE1/0/0
Interface numbering
The F5000-AI-20/F5000-AI-40 firewall provides multiple types of ports including console ports, management Ethernet ports, 10/100/1000BASE-T Ethernet copper ports, 1000BASE-X Ethernet fiber ports, 10GBASE-R Ethernet fiber ports, and 40GBASE-R Ethernet fiber ports.
The ports are numbered in the interface-type X/Y/Z format.
·     interface-typeInterface type.
·     XIRF member device ID.
·     YSubslot number. The value is 0 for fixed ports on the firewall rear panel. The interface modules slots are numbered from 1 to 8.
·     ZNumber marked for the port on the firewall real panel or interface module, starting from 0.
Example:
·     The fixed ports on the firewall rear panel are numbered from GigabitEthernet 1/0/0 to GigabitEthernet 1/0/3. The management Ethernet port is numbered GigabitEthernet 1/0/0.
·     If an NSQM1TG8A interface module is installed in slot 3 of the firewall, the ports on the interface module are numbered from Ten-GigabitEthernet 1/3/0 to Ten-GigabitEthernet 1/3/7.
Interface modules
CAUTION
CAUTION:
The device does not support hot swapping of interface modules.
Interface module compatibility with device slots
Table7-1 displays the slots available for interface module installation.
Table7-1 Interface module and device slot compatibility
Interface module
Available slots
NSQM1TG8A
Slots 1 to 3
NSQM1QG2A
Slots 1 to 3
NSQM1G4XS4
Slots 1 to 3
NSQM1GT8A
Slots 4 to 8
NSQM1GP8A
Slots 4 to 8
NSQM1GT4PFCA
Slots 4 to 8
·     To install GE transceiver modules on 10GE fiber ports of an NSQM1TG8A or NSQM1G4XS4 interface module, install the interface module in slot 3.
·     By default, autonegotiation is disabled on GE fiber ports of an NSQM1G4XS4 interface module. If you have to switch the port transmission speed or duplex mode because the autonegotiation mode is inconsistent with that on the peer device, install the NSQM1G4XS4 interface module in slot 3.
NSQM1TG8A
The NSQM1TG8A interface module provides eight 10GBASE-R fiber Ethernet ports.
Figure7-3 NSQM1TG8A front view
(1) LED
(2) 10GBASE-R fiber Ethernet ports
(3) Captive screw
(4) Ejector lever
NSQM1QG2A
The NSQM1QG2A interface module provides two 40GBASE-R fiber Ethernet ports.
Figure7-4 NSQM1QG2A front view
(1) LED
(2) 40GBASE-R fiber Ethernet ports
(3) Captive screw
(4) Ejector lever
NSQM1G4XS4
The NSQM1G4XS4 interface module provides four 10GBASE-R fiber Ethernet ports (10G-SR/LR) and four 1000BASE-X fiber Ethernet ports.
Figure7-5 NSQM1G4XS4 front view
(1) LED
(2) 1000BASE-X fiber Ethernet ports
(3) 10GBASE-R fiber Ethernet ports
(4) Captive screw
(5) Ejector lever
NSQM1GT8A
The NSQM1GT8A interface module provides eight 10/100/1000BASE-T copper ports.
Figure7-6 NSQM1GT8A front view
(1) LED
(2) 10/100/1000BASE-T copper Ethernet ports
(3) Captive screw
(4) Ejector lever
NSQM1GP8A
The NSQM1GP8A interface module provides eight 1000BASE-X fiber Ethernet ports.
Figure7-7 NSQM1GP8A front view
(1) LED
(3) Captive screw
(4) Ejector lever
NSQM1GT4PFCA
The NSQM1GT4PFCA interface module provides four 10/100/1000BASE-T copper Ethernet ports that support the bypass function.
Figure7-8 NSQM1GT4PFCA front view
(1) LED
(3) Captive screw
(4) Ejector lever
Power supplies
The firewall comes with power supply slot PWR0 installed with a filler panel and power supply slot PWR1 empty. You can install two power supplies to achieve 1+1 power redundancy or install only one power supply.
If two power supplies are installed, you can hot swap a power supply. If only one power supply is installed, power off the firewall before you remove the power supply.
AC power supply
Figure7-9 AC power supply front view
(1) Retaining latch
(2) Handle
(3) Power receptacle
DC power supply
Figure7-10 DC power supply front view
(1) Retaining latch
(2) Handle
Fan trays
The firewall provides two fan tray slots FAN0 and FAN1. No fan trays are provided with the firewall. Purchase fan trays for the firewall as required.
The FAN-20F-2-A and FAN-20B-2-A fan trays are available for the firewall. The FAN-20F-2-A fan tray provides power supply-side intake and port-side exhaust airflow. The FAN-20B-2-A fan tray provides port-side intake and power supply-side exhaust airflow. For the fan tray specifications, see "Fan tray specifications."
To ensure adequate heat dissipation, the firewall must have two fan trays of the same model installed when it is operating.
Figure7-11 FAN-20F-2-A fan tray
(1) Handle
(2) Alarm LED
Figure7-12 FAN-20B-2-A fan tray
(1) Handle
(2) Alarm LED
The weight of the firewall includes the chassis and its removable components, as shown in Table7-2.
Table7-2 Dimensions and weights
Model
Dimensions (H × W × D)
Weight
F5000-AI-20/F5000-AI-40 chassis (excluding rubber feet and mounting brackets)
88.1 × 440 × 660 mm (3.47 × 17.32 × 25.98 in) (excluding rubber feet and mounting brackets)
20.1 kg (44.31 lb)
NSQM1TG8A
19.8 × 189 × 212.4 mm (0.78 × 7.44 × 8.36 in)
0.55 kg (1.21 lb)
NSQM1QG2A
0.55 kg (1.21 lb)
NSQM1G4XS4
0.54 kg (1.19 lb)
NSQM1GT8A
0.55 kg (1.21 lb)
NSQM1GP8A
0.55 kg (1.21 lb)
NSQM1GT4PFCA
0.6 kg (1.32 lb)
Table7-3 Memory and storage media specifications
Firewall model
Flash
Memory
F5000-AI-20
4GB eMMC flash
16GB DDR3
F5000-AI-40
4GB eMMC flash
32GB DDR3
Power consumption
The power consumption of the firewall is the total power consumption of the chassis and removable components, as shown in Table7-4.
Table7-4 Power consumption
Item
Specification
191 W
NSQM1TG8A
12.96 W
NSQM1QG2A
6.40 W
NSQM1G4XS4
6.46 W
NSQM1GT8A
3.03 W
NSQM1GP8A
8.15 W
NSQM1GT4PFCA
5.78 W
Table7-5 AC power supply specifications
Item
Specification
Model
PSR650B-12A1
Rated input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
Maximum input current
5 A to 10 A
Maximum power
650 W
Table7-6 DC power supply specifications
Item
Specification
Model
PSR650B-12D1
–40 VDC to –60 VDC
12 A to 22 A
Maximum power
650 W
Table7-7 Fan tray specifications
Item
Specifications
Dimensions (H × W × D), excluding the handle
84.5 × 87 × 209 mm (3.33 × 3.43 × 8.23 in)
Airflow direction
FAN-20F-2-A: From the power supply side to the port side
FAN-20B-2-A: From the port side to the power supply side
Hot swapping
Supported
Max airflow volume
120 CFM
Max power consumption
57 W
Operating voltage
12 VDC
Table7-8 NS-SSD-480G-SATA-SFF specifications
Item
Specification
19 × 75.7 × 118.4 mm (0.75 × 2.98 × 4.66 in)
Weight
0.069 kg (0.15 lb)
Hot swapping
Not supported
Capacity
480 GB
Operating temperature
Power consumption
3 W
Port specifications
Console port
Table7-9 Console port specifications
Item
Specification
Connector
RJ-45
Standard compliant
RS-232
Baud rate
9600 bps (default) to 115200 bps
Cable type
Common asynchronous serial port cable
Transmission distance
≤ 15 m (49.21 ft)
Services
·     Connection to an ASCII terminal
·     Connection to the serial port of a local PC to run the terminal emulation program
·     CLI
For more information about transceiver modules, see H3C Transceiver Modules User Guide.
GE copper port
Table7-10 GE copper port specifications
Item
Specification
Connector
RJ-45
Standard compliance
802.3, 802.3u, and 802.3ab
Interface type
MDI/MDI-X autosensing
Cable type
Category 5 or higher twisted pair cable
100 m (328.08 ft)
Interface speed and duplex mode
10 Mbps, half/full-duplex
100 Mbps, half/full-duplex
1000 Mbps, full-duplex
The media dependent interface (MDI) standard is typically used on the Ethernet port of network adapters. The media dependent interface crossover (MDI-X) standard is typically used on hubs or LAN switches.
GE fiber port
Table7-11 GE fiber port specifications
Item
Specification
Connector type
LC
Transceiver module type
SFP
Standard compliance
1000BASE-X
Interface speed
1000 Mbps
Duplex mode
Full duplex
Table7-12 1000BASE-X SFP transceiver module specifications (1)
Transceiver module
Central wavelength (nm)
Fiber mode
Fiber diameter (µm)
Mode bandwidth (MHz*km)
SFP-GE-SX-MM850-A
850
MMF
50/125
500
400
62.5/125
200
160
160
SFP-GE-LX-SM1310-A
1310
SMF
9/125
N/A
MMF
50/125
500/400
62.5/125
500
SFP-GE-LH40-SM1310
1310
SMF
9/125
N/A
SFP-GE-LH40-SM1550
1550
SMF
9/125
N/A
SFP-GE-LH80-SM1550
1550
SMF
9/125
N/A
SFP-GE-LH100-SM1550
1550
SMF
9/125
N/A
Table7-13 1000BASE-X SFP transceiver module specifications (2)
Transceiver module
Transmitted optical power (dBm)
Received optical power (dBm)
SFP-GE-SX-MM850-A
550 m (1804.46 ft)
–9.5 to 0
–17 to –3
500 m (1640.42 ft)
275 m (902.23 ft)
220 m (721.78 ft)
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
10 km (6.21 miles)
–9.5 to –3
–20 to –3
550 m (1804.46 ft)
550 m (1804.46 ft)
SFP-GE-LH40-SM1310
40 km (24.85 miles)
–5 to +5
–22 to –3
SFP-GE-LH40-SM1550
40 km (24.85 miles)
–4 to +1
–21 to –3
SFP-GE-LH80-SM1550
80 km (49.71 miles)
–4 to +5
–22 to –3
SFP-GE-LH100-SM1550
100 km (62.14 miles)
0 to +5
–30 to –9
10 GE fiber port
Table7-14 10 GE fiber port specifications
Item
Specification
Connector type
LC
SFP+
Standard compliance
10GBASE-R
Interface speed
LAN PHY: 10 Gbps
Table7-15 SFP+ transceiver module specifications (1)
Transceiver module
Fiber mode
Fiber diameter (µm)
SFP-XG-SX-MM850-A
850
MMF
50/125
2000
500
400
62.5/125
200
160
160
SFP-XG-LX220-MM1310
1310
MMF
50/125
1500
500
400
62.5/125
200
160
SFP-XG-LX-SM1310
1310
SMF
9/125
N/A
SFP-XG-LH40-SM1550
1550
SMF
9/125
N/A
Table7-16 SFP+ transceiver module specifications (2)
Transceiver module
Transmission speed
SFP-XG-SX-MM850-A
300 m (984.25 ft)
10.31 Gbps
–7.3 to –1
–9.9 to +0.5
82 m (269.03 ft)
66 m (216.54 ft)
33 m (108.27 ft)
26 m (85.30 ft)
8 m (26.25 ft)
SFP-XG-LX220-MM1310
220 m (721.78 ft)
10.31 Gbps
–6.5 to +0.5
–6.5 to +1.5
220 m (721.78 ft)
100 m (328.08 ft)
220 m (721.78 ft)
220 m (721.78 ft)
SFP-XG-LX-SM1310
10 km (6.21 miles)
10.31 Gbps
–8.2 to +0.5
–14.4 to +0.5
SFP-XG-LH40-SM1550
40 km (24.85 miles)
10.31 Gbps
–4.7 to +4
–15.8 to –1
40 GE fiber port
Table7-17 40 GE fiber port specifications
Item
Specification
Connector type
MPO
QSFP+
Standard compliance
40GBASE-R
Interface speed
LAN PHY: 40 Gbps
Table7-18 QSFP+ transceiver module specifications (1)
Transceiver module
Fiber mode
Fiber diameter (µm)
QSFP-40G-SR4-MM850
850
MMF
50/125
2000
4700
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
SMF
9/125
N/A
QSFP-40G-CSR4-MM850
850
MMF
50/125
2000
4700
Table7-19 QSFP+ transceiver module specifications (2)
Transceiver module
Transmission speed
QSFP-40G-SR4-MM850
100 m (328.08 ft)
40 Gbps
–7.6 to 0
–9.5 to +2.4
150 m (492.13 ft)
10 km (6.21 miles)
40 Gbps
–7 to +2.3
–13.7 to +2.3
QSFP-40G-CSR4-MM850
300 m (984.25 ft)
40 Gbps
–7.6 to 0
–9.9 to +2.4
400 m (1312.34 ft)
8 Appendix B  LEDs
Front panel and rear panel LEDs
Table8-1 Front panel and rear panel LED description
LED
Mark
Status
System status LED
SYS
Flashing green (1 Hz)
The firewall is operating correctly.
Flashing green (8 Hz)
The system is starting or loading software.
Off
The firewall is not powered on or has failed.
Fan status LED
FAN0 and FAN1
Steady green
Off
The fan tray has failed.
Power supply LEDs
PWR0 and PWR1
Steady green
Off
The power supply is not in position or has failed.
Drive LEDs
HD0 and HD1
Flashing green
Data is being written in or read from the drive.
Steady green
The drive has finished the initialization and is operating correctly.
Off
The drive is not in position or has failed.
Ethernet copper port LED (combo interface)
10/100/1000BASE-T
Flashing green
The port is receiving or sending data.
Steady green
A link is present.
Off
No link is present.
Ethernet fiber port LED (combo interface)
1000BASE-X
Flashing green
The port is receiving or sending data at 1000 Mbps.
Steady green
A 1000 Mbps link is present.
Off
No link is present.
Interface module LEDs
Table8-2 Interface module LED description
LED
Mark
Status
Ready LED
READY
The system is operating correctly.
The system is starting.
Off
The system has failed.
Copper Ethernet port LED
10/100/1000BASE-T
Flashing green
Steady green
A link is present.
Off
No link is present.
Fiber Ethernet port LED
1000BASE-X
Flashing green
Steady green
Off
No link is present.
10GBASE-R
Flashing green
The port is receiving or sending data at 10 Gbps.
Steady green
A 10 Gbps link is present.
Off
No link is present.
40GBASE-R
Flashing green
The port is receiving or sending data at 40 Gbps.
Steady green
A 40 Gbps link is present.
Off
No link is present.
9 Appendix C  Cables
Console cable
A console cable is an 8-core shielded cable with a crimped RJ-45 connector at one end and a DB-9 female connector at the other end. The RJ-45 connector is for connecting to the console port of the firewall, and the DB-9 female connector is for connecting to the serial port on the configuration terminal.
Figure9-1 Console cable
Table9-1 Console cable connection
RJ-45
Signal
Direction
DB-9
1
RTS
7
2
DTR
4
3
TXD
3
4
CD
1
5
GND
5
6
RXD
2
7
DSR
6
8
CTS
8
Introduction
An Ethernet twisted pair cable consists of four pairs of insulated copper wires twisted together. Every wire uses a different color, and has a diameter of about 1 mm (0.04 in). A pair of twisted copper cables can cancel the electromagnetic radiation of each other, and reduce interference of external sources. An Ethernet twisted pair cable mainly transmits analog signals and is advantageous in transmitting data over shorter distances. It is the commonly used transmission media of the Ethernet. The maximum transmission distance of the Ethernet twisted pair cable is 100 m (328.08 ft). To extend the transmission distance, you can connect two twisted pair cable segments with a repeater. At most four repeaters can be added, which means five segments can be joined together to provide a transmission distance of 500 m (1640.42 ft).
Ethernet twisted pair cables can be classified into category 3, category 4, category 5, category 5e, category 6, and category 7 cables based on performance. In LANs, category 5, category 5e, and category 6 are commonly used.
Table9-2 Description for commonly used Ethernet twisted pair cables
Category 5
Suitable for data transmission at a maximum speed of 100 Mbps
Category 5e
Suitable for data transmission at a maximum speed of 1000 Mbps
Category 6
Suitable for data transmission at a speed higher than 1 Gbps
Based on whether a metal shielding is used, Ethernet twisted pair cables can be classified into shielded twisted pair (STP) and unshielded twisted pair (UTP). An STP cable provides a metallic braid between the twisted pairs and the outer jacket. This metallic braid helps reduce radiation, prevent information from being listened, and eliminate external electromagnetic interference (EMI) of external sources. STPs have strict application requirements and are expensive although they provide better EMI prevention performance than UTPs, so in most LANs, UTPs are commonly used.
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure9-2 shows the pinouts of an RJ-45 connector.
Figure9-2 RJ-45 connector pinout
The RJ-45 Ethernet ports of the firewall use category 5 or higher Ethernet twisted pair cables for connection.
EIA/TIA cabling specifications define two standards, 568A and 568B, for cable pinouts.
·     Standard 568A—pin 1: white/green stripe, pin 2: green solid, pin 3: white/orange stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: orange solid, pin 7: white/brown stripe, pin 8: brown solid.
·     Standard 568B—pin 1: white/orange stripe, pin 2: orange solid, pin 3: white/green stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: green solid, pin 7: white/brown stripe, pin 8: brown solid.
Ethernet twisted pair cables can be classified into straight-through and crossover cables based on their pinouts.
·     Straight-throughThe pinouts at both ends are T568B compliant, as shown in Figure9-3.
·     CrossoverThe pinouts are T568B compliant at one end and T568A compliant at the other end, as shown in Figure9-4.
Figure9-3 Straight-through cable
Figure9-4 Crossover cable
Select an Ethernet twisted pair cable according to the RJ-45 Ethernet port type on your device. An RJ-45 Ethernet port can be MDI (for routers and PCs) or MDIX (for switches). Table9-3 and Table9-4 show their pinouts.
Table9-3 RJ-45 MDI port pinouts
Pin
10Base-T/100Base-TX
1000Base-T
Signal
Function
Signal
Function
1
Tx+
Sends data
BIDA+
Bi-directional data cable A+
2
Tx-
Sends data
BIDA-
Bi-directional data cable A-
3
Rx+
Receives data
BIDB+
Bi-directional data cable B+
4
Reserved
N/A
BIDC+
Bi-directional data cable C+
5
Reserved
N/A
BIDC-
Bi-directional data cable C-
6
Rx-
Receives data
BIDB-
Bi-directional data cable B-
7
Reserved
N/A
BIDD+
Bi-directional data cable D+
8
Reserved
N/A
BIDD-
Bi-directional data cable D-
Table9-4 RJ-45 MDIX port pinouts
Pin
10Base-T/100Base-TX
1000Base-T
Signal
Function
Signal
Function
1
Rx+
Receives data
BIDB+
2
Rx-
Receives data
BIDB-
3
Tx+
Sends data
BIDA+
4
Reserved
N/A
BIDD+
5
Reserved
N/A
BIDD-
6
Tx-
Sends data
BIDA-
7
Reserved
N/A
BIDC+
8
Reserved
N/A
BIDC-
To ensure normal communication, the pins for sending data on one port must correspond to the pins for receiving data on the peer port. When both ports on the two devices are MDI or MDIX, use a crossover Ethernet cable; when one port is MDI and the other is MDIX, use a straight-through Ethernet cable. To summarize, straight-through and crossover cables connect the following devices:
·     Straight-through cables connect devices of different types—for example, router to PC and router to switch.
·     Crossover cables connect devices of the same type—for example, switch to switch, router to router, and PC to PC.
If an RJ-45 Ethernet port is enabled with MDI/MDIX autosensing, it can automatically negotiate pin roles.
The RJ-45 Ethernet ports on the firewall support MDI/MDIX autosensing.
Making an Ethernet twisted pair cable
1.     Cut the cable to a required length with the crimping tool.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lay flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another and insert the wires into the RJ-45 connector. Make sure the wires extend to the front of the RJ-45 connector and make good contact with the metal contacts in the RJ-45 connector and in the correct order.
5.     Crimp the RJ-45 connector with the crimping tool until you hear a click.
6.     Use a cable tester to verify the connectivity of the cable.
Optical fiber
Optical fibers feature low loss and long transmission distance.
Optical fibers can be classified into single mode fibers and multi-mode fibers. A single mode fiber (with yellow jacket) carries only a single ray of light; a multi-mode fiber (with orange jacket) carries multiple modes of lights.
Table9-5 Characteristics of single mode and multi-mode optical fibers
Item
Single mode fiber
Multi-mode fiber
Core
Small core (10 micrometers or less)
Larger core than single mode fiber (50 micrometers, 62.5 micrometers or greater)
Dispersion
Less dispersion
Allows greater dispersion and therefore, signal loss exists.
Light source and transmission distance
Uses lasers as the light source often within campus backbones for distance of several thousand meters
Uses LEDs as the light source often within LANs or distances of a couple hundred meters within a campus network
Table9-6 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient. There are multiple types of fiber connectors. Figure9-5 shows an LC connector.
Figure9-5 Appearance of an LC connector
Follow these guidelines when you connect an optical fiber:
·     Before connecting an optical fiber, make sure the connector and cable type match the interface module.
·     The fiber Ethernet port of the firewall supports only the LC connector.
·     Fiber connectors are fitted with dust caps. Keep the dust caps secure when the fiber connectors are in use. Install dust caps when the fiber connectors are not in use to avoid damage to their end face. Replace the dust cap if it is loose or polluted.
·     Before connecting an optical fiber, use dust free paper and absolute alcohol to clean the end face of the two fiber connectors. You can brush the end faces only in one direction.
·     Never bend or curve a fiber.
·     If the fiber has to pass through a metallic board hole or bend along the acute side of mechanical parts, the fiber must wear jackets or cushions.
