20-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5456)-6W10020-Network Management and Monitoring Command Reference
12-UCC commands
12-UCC commands 96.64 KB
UCC commands
The following compatibility matrixes show the support of hardware platforms for UCC:
Hardware series
Model
Product code
UCC compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
UCC compatibility
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
application enable
Support for this command depends on the device model.
Use application enable to enable UCC for an audio or video application.
Use undo application enable to disable UCC for an audio or video application.
application app-name enable
undo application app-name enable
UCC is disabled for audio and video applications.
UCC profile view
app-name: Specifies an application name.
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
This feature is available only in local forwarding mode.
# Enable UCC for Skype applications.
[Sysname] ucc profile ssidcompany
[Sysname-ucc-profile-ssidcompany] application skype enable
ucc profile
application flow-mark
Use application flow-mark to configure priority marking for traffic from an audio or video application.
Use undo application flow-mark to restore the default.
application app-name flow-mark
undo application app-name flow-mark
Priority marking is not configured for traffic from audio and video applications.
UCC profile view
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured.
# Configure priority marking for Tencent Meeting traffic.
[Sysname-ucc-profile-ssidcompany] application tencentmeeting flow-mark
ucc profile
display ucc profile
Use display ucc profile to display configuration information for UCC profiles.
display ucc profile [ profile-name ]
profile-name: Specifies a UCC profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a UCC profile, this command displays configuration information for all UCC profiles.
# Display configuration information for all UCC profiles.
<Sysname> display ucc profile
  UCC profile name: ssidcompany1
    SIP: Enabled
    Skype4B: Disabled
      App sharing DSCP priority   : 2
      App sharing 802.1p priority : 2
      Video DSCP priority         : 2
      Video 802.1p priority       : 2
      Voice DSCP priority         : 2
      Voice 802.1p priority       : 2
    UCC-enabled applications: tencentmeeting
                              qq
    Traffic-marking enabled applications: tencentmeeting
                                          qq
Total UCC profiles: 1
SIP
Status of SIP-based UCC for the UCC profile:
·     Enabled.
·     Disabled.
Skype4B
Status of Skype4B-based UCC for the UCC profile:
·     Enabled.
·     Disabled.
DSCP priority for Skype4B application sharing packets.
802.1p priority for Skype4B application sharing packets.
Video DSCP priority
DSCP priority for Skype4B video packets.
802.1p priority for Skype4B video packets.
Voice DSCP priority
DSCP priority for Skype4B voice packets.
802.1p priority for Skype4B voice packets.
application enable
sip enable
skype4b enable
display ucc table
Use display ucc table to display UCC entries.
display ucc table
# Display UCC entries.
<Sysname> display ucc table
UCC tuple5 entry info:
  Source IP/port           : 2.1.1.2/11111
  Destination IP/port      : 2.1.1.3/22222
  Transport layer protocol : UDP
  Flow type                : SIP
  Media type               : Audio
  Lifetime                 : 280
  Source IP/port           : 2.1.1.4/11113
  Destination IP/port      : 2.1.1.5/22224
  Flow type                : SIP
  Media type               : Video
  Lifetime                 : 260
UCC tuple3 entry info:
  Client IP/port           : 10.1.1.145/13454
  Transport layer protocol : TCP
  Flow type                : SKYPE4B
  Media type               : App-Share
  Lifetime                 : 62
  Client IP/port           : 10.1.1.155/8020
  Flow type                : SKYPE4B
  Lifetime                 : 62
Total tuple5 entries found : 2
Total tuple3 entries found : 2
Total entries found: 4
5-tuple entry information for UCC.
Source IP/port
Source IP address and port number in a UCC entry.
Destination IP/port
Destination IP address and port number in the UCC entry.
Flow type
Flow type:
·     SIP.
·     SKYPE4B.
Media type
Media type:
·     App-Share.
·     Audio.
·     Video.
Lifetime
Lifetime of the UCC entry, in seconds.
Triple entry information for UCC.
Client IP/port
Client IP address and port number in a UCC entry.
reset ucc table
sip enable
ucc profile
ucc-profile
display ucc whitelist ap
Use display ucc whitelist ap to display UCC AP white list.
# Display UCC AP white list.
<Sysname> display ucc whitelist ap
  AP Whitelist Entry Info:
    AP name: ap1, ap2, ap3
ucc whitelist ap
display ucc whitelist ap-group
Use to display UCC AP group white list.
# Display UCC AP group white list.
<Sysname> display ucc whitelist ap-group
  AP-group Whitelist Entry Info:
    Group name: apg1, apg2
reset ucc table
Use reset ucc table to clear UCC entries.
reset ucc table [ sip | skype4b ]
sip: Specifies the SIP protocol.
skype4b: Specifies the Skype4B protocol.
If you do not specify any keywords, this command clears all UCC entries.
# Clear all UCC entries.
<Sysname> reset ucc table
display ucc table
sip enable
Use sip enable to enable SIP-based UCC in a UCC profile.
Use undo sip enable to disable SIP-based UCC in a UCC profile.
sip enable
undo sip enable
SIP-based UCC is disabled in a UCC profile.
UCC profile view
With this command configured, the service template bound to a UCC profile can preferentially forward audio and video traffic to provide high-quality audio and video services.
This command takes effect only on audio and video services for wireless clients.
# Enable SIP-based UCC in UCC profile ssidcompany.
[Sysname-ucc-profile-ssidcompany] sip enable
ucc profile
skype4b app-share remark
Use skype4b app-share remark to configure priority marking for Skype4B application sharing packets.
Use undo skype4b app-share remark to restore the default.
skype4b app-share remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b app-share remark { dscp | dot1p }
Priority marking is not configured for Skype4B application sharing packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B application sharing packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B application sharing packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B application sharing packets.
# Mark DSCP priority 6 for Skype4B application sharing packets.
[Sysname-ucc-profile-ssidcompany] skype4b app-share remark dscp 6
skype4b enable
Use skype4b enable to enable Skype4B-based UCC.
Use undo skype4b enable to disable Skype4B-based UCC.
skype4b enable
undo skype4b enable
Skype4B-based UCC is disabled.
UCC profile view
This command enables the service template or Layer 3 interface bound to a UCC profile to preferentially forward audio, video, and application sharing traffic, providing high-quality audio, video, and application sharing services.
This command takes effect only on audio, video, and application sharing services for wireless clients.
# Enable Skype4B-based UCC.
[Sysname-ucc-profile-ssidcompany] skype4b enable
display ucc profile
ucc profile
skype4b listener
Use skype4b listener to enable the device to communicate with the Skype4B server and specify the port number.
Use undo skype4b listener to disable the device from communicating with the Skype4B server.
skype4b listener { http-port http-port-num | https-port https-port-num ssl-policy ssl-policy-name }
undo skype4b enable { http-port | https-port }
The device is disabled from communicating with the Skype4B server.
http-port http-port-num: Specifies the HTTP service port number in the range of 1025 to 55535.
https-port https-port-num: Specifies the HTTPS service port number in the range of 1025 to 55535.
ssl-policy ssl-policy-name: Specifies an SSL server policy name, a case-insensitive string of 1 to 31 characters.
You cannot use this command to edit the HTTP or HTTPS service port number or SSL server policy. To do so, you must execute the undo skype4b listener command first to disable the device from communicating with the Skype4B server.
If you specify both the HTTP and HTTPS services, make sure they use different port numbers.
# Enable the device to communicate with the Skype4B server and specify the port number as 3000.
[Sysname] skype4b listener http-port 3000
ssl server-policy (Security Command Reference)
skype4b video remark
Use skype4b video remark to configure priority marking for Skype4B video packets.
Use undo skype4b video remark to restore the default.
skype4b video remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b video remark { dscp | dot1p }
The DSCP value is 34 and the 802.1p priority is 4 for Skype4B video packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B video packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B video packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B video packets.
# Mark DSCP priority 6 for Skype4B video packets.
[Sysname-ucc-profile-ssidcompany] skype4b video remark dscp 6
skype4b voice remark
Use skype4b voice remark to configure priority marking for Skype4B voice packets.
Use undo skype4b voice remark to restore the default.
skype4b voice remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b voice remark { dscp | dot1p }
The DSCP value is 46 and the 802.1p priority is 6 for Skype4B voice packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B voice packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B voice packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B voice packets.
# Mark DSCP priority 6 for Skype4B voice packets.
[Sysname-ucc-profile-ssidcompany] skype4b voice remark dscp 6
ucc profile
Use ucc profile to create a UCC profile and enter its view, or enter the view of an existing UCC profile.
Use undo ucc profile to delete a UCC profile.
ucc profile profile-name
undo ucc profile profile-name
No UCC profiles exist.
profile-name: Specifies the name of a UCC profile, a case-insensitive string of 1 to 31 characters. The UCC profile name can contain hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create UCC profile ssidcompany and enter its view.
display ucc profile
ucc-profile
ucc whitelist ap
Use ucc whitelist ap to configure the UCC AP white list.
Use undo ucc whitelist ap to delete table entries from the UCC AP white list.
ucc whitelist ap ap-name
undo ucc whitelist ap [ ap-name ]
The UCC AP white list is not specified, and the UCC information of an AC can be reported to AC.
ap-name: Specifies an AP name, a case-sensitive string of 1 to 64 characters. Only letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), slashes (/), and hyphens (-) are allowed. If you do not specify this argument, this command deletes all table entries from the UCC AP white list.
Perform this task to allow only APs that belong to the UCC AP or AP group white list to collect and report UCC statistics to AC, reducing AC pressure from too many AP reports. In this way, pressure is also released for APs that do not belong to the UCC AP or AP group white list, because they no longer collect or report UCC statistics to AC.
Only UCC APs for audio and video traffic are restricted by the white list.
# Add AP ap1 to the UCC AP white list.
[Sysname] ucc whitelist ap ap1
Use ucc whitelist ap-group to configure the UCC AP group white list.
Use undo ucc whitelist ap-group to delete table entries from the UCC AP group white list.
ucc whitelist ap-group group-name
undo ucc whitelist ap-group [ group-name ]
UCC AP group white list is not specified.
group-name: Specifies an AP group name, a case-insensitive string of 1 to 31 characters. If you do not specify this argument, this command deletes all table entries from the UCC AP group white list.
# Add AP group apg1 to the UCC AP group white list.
[Sysname] ucc whitelist ap-group apg1
ucc whitelist ap
ucc-profile
Use ucc-profile to bind a UCC profile to a service template.
Use undo ucc-profile to unbind a UCC profile from a service template.
ucc-profile profile-name
undo ucc-profile
No UCC profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one UCC profile to a service template. To bind a different UCC profile to the service template, first unbind the existing UCC profile from the service template.
# Bind UCC profile ssidcompany to service template service.
[Sysname-ucc-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] ucc-profile ssidcompany
sip enable
ucc profile
