12-WLAN Advanced Features Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5456)-6W10012-WLAN Advanced Features Command Reference
02-Hotspot 2.0 commands
02-Hotspot 2.0 commands 156.05 KB
The AP models and serial numbers in this document are used only as examples. Support for AP models and serial numbers depends on the AC model.
3gpp-info
Use 3gpp-info to configure 3GPP information.
Use undo 3gpp-info to remove 3GPP information.
3gpp-info country-code mobile-country-code network-code mobile-network-code
undo 3gpp-info country-code mobile-country-code network-code mobile-network-code
No 3GPP information is configured.
Hotspot 2.0 policy view
mobile-country-code: Specifies a mobile country code (MCC). An MCC is a three-digit numeric code that uniquely identifies the country to which clients belong.
mobile-network-cod: Specifies a mobile network code (MNC). A mobile network code is a two-digit or three-digit numeric code that uniquely identifies the mobile network to which clients belong.
You can specify a maximum of 32 country code and mobile network code combinations in a Hotspot 2.0 policy.
One country code can be combined with multiple mobile network codes.
# Configure 3GPP information: set the country code to 460 and network code to 01.
[Sysname] wlan hotspot-policy 1
[Sysname-wlan-hs-1] 3gpp-info country-code 460 network-code 01
authentication-type
Use authentication-type to specify a network authentication type.
Use undo authentication-type to delete a network authentication type.
authentication-type { 0 [ redirect-url url ] | 1 | 2 redirect-url url | 3 }
undo authentication-type { 0 | 1 | 2 | 3 }
No network authentication type is specified.
0: Specifies acceptance of terms and conditions.
1: Specifies on-line enrollment.
2: Specifies HTTP/HTTPS redirection.
3: Specifies DNS redirection.
redirect-url url: Specifies a redirected URL address.
You can specify a maximum of four network authentication types in a Hotspot 2.0 policy.
# Specify a network authentication type.
[Sysname-wlan-hs-1] authentication-type 1
comeback-delay
Use comeback-delay to set the comeback delay for clients to send GAS comeback requests.
Use undo comeback-delay to restore the default.
comeback-delay value
undo comeback-delay
The comeback delay is 1 TU.
value: Specifies the comeback delay in the range of 1 to 1024 TUs. One TU is equal to 1024 μs.
This command can prevent clients from sending too many GAS comeback requests.
# Set the comeback delay to 10 TUs.
[Sysname-wlan-hs-1] comeback-delay 10
description
Use description to configure a description for an OSU server.
Use undo description to delete an OSU server description.
description description lang-code lang-code
undo description description lang-code lang-code
No description is configured for an OSU server.
OSU server view
description: Specifies a description, a case-sensitive string of 1 to 252 characters.
lang-code: Specifies a language code. The device supports the general international standards.
This command is available only for version 2 of Hotspot 2.0.
You can configure a maximum of 32 descriptions for an OSU server. A client displays one description that is in the same language as the client system.
# Configure a description for OSU server 1.
[Sysname] wlan osu-provider 1
[Sysname-wlan-osu-1] description "Free service for test purpose" lang-code eng
dgaf enable
Use dgaf enable to enable Downstream Group-Addressed Forwarding (DGAF).
Use undo dgaf enable to disable DGAF.
dgaf enable
undo dgaf enable
DGAF is enabled.
DGAF enables an AP to forward all downstream wireless broadcast ARP packets and wireless multicast packets. To prevent spoofing attacks by using downstream multicasts, you can disable DGAF for the AP.
Before disabling DGAF, make sure all service templates bound to the Hotspot 2.0 policy are disabled.
To avoid packet loss, enable proxy ARP and multicast optimization before disabling DGAF. For more information about proxy ARP, see Layer 3—IP Services Configuration Guide.
# Disable DGAF.
[Sysname-wlan-hs-1] undo dgaf enable
display wlan hotspot uploaded-osu-icon
Use display wlan hotspot uploaded-osu-icon to display the list of uploaded OSU server icons.
# Display the list of uploaded OSU server icons.
<Sysname> display wlan hotspot uploaded-osu-icon
Total uploaded osu icon count: 1
Icon name                                 Icon type
college.png                               png
icon-file
wlan hotspot osu-icon upload
domain-name
Use domain-name to set a domain name.
Use undo domain-name to delete a domain name.
domain-name domain-name
undo domain-name domain-name
No domain name is set.
domain-name: Specifies a domain name, a case-sensitive string of 1 to 255 characters.
You can set a maximum of 32 domain names in one Hotspot 2.0 policy.
# Set the domain name to college in Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] domain-name college
friendly-name
Use friendly-name to set a name for an OSU server.
Use undo friendly-name to delete the specified OSU server name.
friendly-name friendly-name lang-code lang-code
undo friendly-name friendly-name lang-code lang-code
No name is set for an OSU server.
OSU server view
You can configure a maximum of 32 names for an OSU server. A client will display one name that is in the same language as the client system.
If an OSU server is already bound to a Hotspot 2.0 policy, you cannot delete the most recent name specified for the server.
# Set a name for OSU server 1.
[Sysname-wlan-osu-1] friendly-name osu1 lang-code en
gas-limit
Use gas-limit to set the maximum number of GAS initial requests that the AC can receive within the specified interval.
Use undo gas-limit to restore the default.
gas-limit number number interval interval
undo gas-limit
The number of GAS initial requests that the AC can receive is not limited.
number number: Specifies the maximum number of GAS initial requests that the AC can receive, in the range of 10 to 60.
interval interval: Specifies the interval at which the AC receive GAS initial requests, in the range of 10 to 60 seconds.
If the number of GAS initial requests received by the AC exceeds the limit, the exceeded frames will be discarded.
# Set the maximum number of GAS initial requests that the AC can receive within 15 seconds to 50.
[Sysname-wlan-hs-1] gas-limit number 50 interval 15
hessid
Use hessid to set a homogenous ESS identifier (HESSID).
Use undo hessid to restore the default.
hessid hessid
undo hessid
No HESSID is set.
hessid: Specifies an HESSID that uniquely identifies a homogeneous ESS, in the H-H-H format. The value cannot be all zeros.
Make sure all service templates bound to the Hotspot 2.0 policy are disabled before you set an HESSID.
# Set the HESSID to 0021-1bea-3660 in Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] hessid 0021-1bea-3660
hotspot-policy
Use hotspot-policy to bind a Hotspot 2.0 policy to a service template.
Use undo hotspot-policy to restore the default.
hotspot-policy policy-number
undo hotspot-policy
No Hotspot 2.0 policy is bound to a service template.
Service template view
policy-number: Specifies the number of a Hotspot 2.0 policy, in the range of 1 to 32.
When you bind a Hotspot 2.0 policy to a service template, follow these guidelines:
·     Make sure the Hotspot 2.0 policy exists and the service template is disabled.
·     Make sure the following settings are configured for the service template:
¡     802.1X authentication and key management mode.
¡     RSN IE.
¡     AES-CCMP cipher suite.
# Bind Hotspot 2.0 policy 1 to service template 1.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] hotspot-policy 1
icon-file
Use icon-file to specify an icon for an OSU server.
Use undo icon-file to delete the specified icon for an OSU server.
icon-file filename lang-code lang-code icon-type icon-type
undo icon-file filename
No icon is specified for an OSU server.
OSU server view
filename: Specifies an icon file by its name, a case-sensitive string of 1 to 63 characters.
lang-code lang-code: Specifies a language code. The device supports the general international standards.
icon-type icon-type: Specifies the type of the icon file, a case-sensitive string of 1 to 15 characters.
The device loads the specified icon when the command is executed. You can specify a maximum of six icons for an OSU server. A client displays an icon that is in the same language as the client system.
When you specify an icon for an OSU server, follow these restrictions and guidelines:
·     Create a directory named icon in the root directory where the version files are saved, and use FTP or TFTP to download icon files to the folder before executing the command.
·     If the specified icon file does not exist in the icon directory, the command cannot load the icon file. To load the icon file, save the icon file in the icon directory, and then execute the wlan hotspot osu-icon upload command.
·     The file size cannot exceed 64 KB.
·     Make sure the file type specified in the command is the same as the actual file type.
·     If an OSU server is already bound to a Hotspot 2.0 policy, you cannot delete the most recently specified OSU server icon.
# Specify an icon for OSU server 1.
[Sysname-wlan-osu-1] icon-file wifi_icon lang-code eng icon-type png
ip-protocol
Use ip-protocol to set the port status for an IP protocol.
Use undo ip-protocol to remove the configuration.
ip-protocol { esp | icmp | tcp | udp } port-number port-number { closed | open | unknown }
undo ip-protocol { esp | icmp | tcp | udp } port-number port-number
The port status is not set for an IP protocol.
esp: Specifies the ESP protocol.
icmp: Specifies the ICMP protocol.
tcp: Specifies the TCP protocol.
udp: Specifies the UDP protocol.
port-number: Specifies a port by its number.
Table 1 Port number and protocol type
Protocol type
Port number
ICMP
0
ICMP, used for diagnostics
TCP
20
FTP
TCP
22
SSH
TCP
80
HTTP
TCP
443
Used by TLS VPNs
TCP
1723
Used by Point to Point
Tunneling Protocol VPNs
TCP
5060
VoIP
UDP
500
Used by IKEv2 (IPSec VPN)
UDP
5060
VoIP
UDP
4500
May be used by IKEv2 (IPSec VPN)
ESP
0
ESP, used by IPSec VPNs
closed: Specifies the port status as closed.
open: Specifies the port status as open.
unknown: Specifies the port status as unknown.
# Set the port number to 20 and the port status to open for TCP.
[Sysname-wlan-hs-1] ip-protocol tcp port-number 20 open
ip-type
Use ip-type to configure IP address availability.
Use undo ip-type to restore the default.
ip-type ipv4 ipv4-type ipv6 ipv6-type
undo ip-type
The availability is 1 for IPv4 addresses and 2 for IPv6 addresses.
ipv4-type: Specifies the availability for an IPv4 address, in the range of 0 to 7.
Table 2 IPv4 address availability
Address value
0
Address type not available
1
Public IPv4 address available
2
Port-restricted IPv4 address available
3
Single NATed private IPv4 address available
4
Double NATed private IPv4 address available
5
Port-restricted IPv4 address and single NATed IPv4 address available
6
Port-restricted IPv4 address and double NATed IPv4 address available
7
Availability of the address type is not known
ipv6-type: Specifies the availability for an IPv6 address, in the range of 0 to 2.
Table 3 IPv6 address availability
Address value
0
1
Address type available
2
Availability of the address type not known
# Set the availability to 2 for IPv4 addresses and 1 for IPv6 addresses.
[Sysname-wlan-hs-1] ip-type ipv4 2 ipv6 1
method
Use method to specify a protocol for clients to communicate with the OSU server.
Use undo method to delete the specified protocol for clients to communicate with the OSU server.
method method-id
undo method method-id
No protocol is specified for clients to communicate with an OSU server.
OSU server view
method-id: Specifies the protocol ID:
·     0—Specifies OMA-DM.
·     1—Specifies SOAP-XML SPP.
You can specify both protocols. Clients will choose one protocol to communicate with the OSU server.
If an OSU server is already bound to a Hotspot 2.0 policy, you cannot delete the most recent specified protocol for clients to communicate with the OSU server.
# Specify a protocol for clients to communicate with the OSU server.
[Sysname-wlan-osu-1] method 0
nai
Use nai to configure a Network Access Identifier (NAI) for an OSU server.
Use undo nai to delete the configured NAI for an OSU server.
nai nai
undo nai
No NAI is configured for an OSU server.
OSU server view
nai: Specifies an NAI, a case-sensitive string of 1 to 252 characters.
If an NAI is configured for an OSU server, clients connect to the OSU AP through OSEN OSU. If no NAI is configured for an OSU server, clients connects to the OSU AP through Open OSU.
# Configure an NAI for OSU server 1.
[Sysname-wlan-osu-1] nai [email protected]
nai-realm
Use nai-realm to create an NAI realm and specify an authentication type for the NAI realm.
Use undo nai-realm to delete an NAI realm.
nai-realm realm-name eap-method eap-method-id auth-method auth-method-id authentication authentication
undo nai-realm realm-name [ eap-method eap-method [ auth-method auth-method [ authentication authentication ] ] ]
No NAI realm exists.
realm-name: Specifies an NAI realm name, a case-sensitive string of 1 to 255 characters.
eap-method eap-method-id: Specifies an EAP authentication method by its ID.
Table 4 EAP authentication method
eap-method-id
1
EAP-Transport Layer Security (EAP-TLS)
2
Lightweight Extensible Authentication Protocol (LEAP)
3
EAP for GSM Subscriber Identity Module (EAP-SIM)
4
EAP-Tunneled Transport Layer Security (EAP-TTLS)
5
EAP-Authentication and Key Agreement(EAP-AKA)
6
Protected EAP (PEAP)
auth-method auth-method-id: Specifies an authentication method by its ID.
authentication authentication: Specifies an authentication parameter by its ID.
Table 5 Authentication method and authentication parameter
auth-method-id
auth-method-type
authentication
2
Non-EAP Inner Authentication Type
·     1—PAP.
·     2—CHAP.
·     3—MSCHAP.
·     4—MSCHAPV2.
5
Credential Type
·     1—SIM.
·     2—USIM.
·     3—NFC Secure Element.
·     4—Hardware Token.
·     5—Softoken.
·     6—Certificate.
·     7—username/password.
·     8—none*.
6
Tunneled EAP Method Credential Type
·     1—SIM.
·     2—USIM.
·     4—Hardware Token.
·     5—Softoken.
·     6—Certificate.
·     8—Reserved.
·     9—Anonymous.
When you use the undo nai-realm command, follow these guidelines:
·     The undo nai-realm realm-name command deletes all NAI realms that use the same name.
·     The undo nai-realm realm-name eap-method eap-method-id command deletes all NAI realms that use the same name and EAP authentication method.
·     The undo nai-realm realm-name eap-method eap-method-id auth-method auth-method-id command deletes all NAI realms that use the same name, EAP authentication method, and authentication method.
·     The undo nai-realm realm-name eap-method eap-method-id auth-method auth-method-id authentication authentication command deletes all NAI realms that use the same name, EAP authentication method, authentication method, and authentication parameter.
You can configure a maximum of 32 NAI realm names in a Hotspot 2.0 policy.
# Specify the authentication type for NAI realm wifi in Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] nai-realm wifi eap-method 2 auth-method 5 authentication 1
network-type
Use network-type to set the access network type.
Use undo network-type to restore the default.
network-type network-type [ access-internet ]
undo network-type
The access network type is not set.
network-type: Specifies a network type in the range of 0 to 5, 14, and 15.
Table 6 Access network type
Value
0
Private network
1
Private network with guest access
2
Chargeable public network
3
Free public network
4
Personal device network
5
Emergency services only network
14
Test or experimental
15
Wildcard
access-internet: Enables access to the Internet. If you do not specify this keyword, the Internet is not accessible.
Make sure all service templates bound to the Hotspot 2.0 policy are disabled before you set the access network type.
# Set the access network type to 1 and enable access to the Internet.
[Sysname-wlan-hs-1] network-type 1 access-internet
operator-name
Use operator-name to set service provider information.
Use undo operator-name to delete service provider information.
operator-name operator-name lang-code lang-code
undo operator-name operator-name lang-code lang-code
No service provider information is set.
operator-name: Specifies a service provider name, a case-sensitive string of 1 to 252 characters.
lang-code: Specifies a language code. The device supports both the ISO-639-1 and ISO-639-2 standards.
You can configure a maximum of 32 service provider and language code combinations in a Hotspot 2.0 policy.
# Set the language code to en for service provider cmcc.
[Sysname-wlan-hs-1] operator-name cmcc lang-code en
osu-provider
Use osu-provider to bind an OSU server to a Hotspot 2.0 policy.
Use undo osu-provider to unbind an OSU server from a Hotspot 2.0 policy.
osu-provider osu-provider-number
undo osu-provider osu-provider-number
No OSU server is bound to a Hotspot 2.0 policy.
Hotspot policy view
osu-provider-number: Specifies an OSU server by its number, in the range of 1 to 32. The specified OSU server must exist.
You can bind a maximum of 32 OSU servers to a Hotspot 2.0 policy.
Before binding an OSU server to a Hotspot 2.0 policy, make sure you have finished the following configuration:
·     Set a name for the OSU server.
·     Specify a URI for the OSU server.
·     Specify a protocol for clients to communicate with the OSU server.
·     Specify an icon for the OSU server.
# Bind OSU server 1 to Hotspot 2.0 policy 1.
[Sysname-wlan-hs-1] osu-provider 1
friendly-name
icon-file
method
uri
wlan osu-provider
osu-ssid
Use osu-ssid to set an SSID for online signup services.
Use undo osu-ssid to delete the configured SSID for online signup services.
osu-ssid ssid-name
undo osu-ssid
No SSID is set for online signup services.
Hotspot policy view
ssid-name: Specifies an SSID name, a case-sensitive string of 1 to 32 characters.
Make sure the configured SSID for online signup services is the same as the SSID for the online signup service template.
# Set the SSID for online signup services to osu.
[Sysname-wlan-hs-1] osu-ssid osu
policy-name
Use policy-name to set a name for a Hotspot 2.0 policy.
Use undo policy-name to restore the default.
policy-name name
undo policy-name
A Hotspot 2.0 policy does not have a name.
name: Specifies a Hotspot 2.0 policy name, a case-insensitive string of 1 to 32 characters.
# Set the name of Hotspot 2.0 policy 1 to market.
[Sysname-wlan-hs-1] policy-name market
roam-oi
Use roam-oi to set an organization identifier (OI).
Use undo roam-oi to delete an OI.
roam-oi oi [ in-beacon ]
undo roam-oi oi
No OI is set.
oi: Specifies an OI that can uniquely identify a roaming consortium, a six-digit or ten-digit hexadecimal code.
in-beacon: Adds an OI to beacons. As a best practice, specify this keyword for clients to get OIs.
Make sure all service templates bound to the Hotspot 2.0 policy are disabled before you set an OI.
You can configure a maximum of 32 OIs in a Hotspot 2.0 policy, and can add a maximum of three OIs to beacons.
# Set the OI to 004096 and add the OI to beacons.
[Sysname-wlan-hs-1] roam-oi 004096 in-beacon
uri
Use uri to specify the URI of an OSU server.
Use undo uri to delete the configured URI of an OSU server.
uri uri
undo uri
No URI is specified for an OSU server.
OSU server view
uri: Specifies the URI of an OSU server, a case-sensitive string of 1 to 255 characters.
Clients use the configured URI to visit the OSU server and perform online signup.
If an OSU server is already bound to a Hotspot 2.0 policy, you cannot delete the configured URI of the server.
# Specify the URI of OSU server 1.
[Sysname-wlan-osu-1] uri https://osu-server.r2-testbed.wi-fi.org/
venue group
Use venue group to set venue group information for an AP.
Use undo venue group to restore the default.
venue group venue-group-number type venue-type-number
undo venue group
No venue group information is set for an AP.
AP view
venue-group-number: Specifies a venue group by its number, in the range of 1 to 11.
Table 7 Venue group number and description
Number
1
Assembly
2
Business
3
Educational
4
Factory
5
Institutional
6
Mercantile
7
Residential
8
Storage
9
Utility
10
Vehicular
11
Outdoor
venue-type-number: Specifies a venue type by its number. The value depends on the venue group number. For more information, see Table 8.
Table 8 Venue type number and description
Venue group number
Venue type number
Venue description
1
0
Unspecified
1
1
Arena
1
2
Stadium
1
3
Passenger Terminal
1
4
Amphitheater
1
5
Amusement Park
1
6
Place of Worship
1
7
Convention Center
1
8
Library
1
9
Museum
1
10
Restaurant
1
11
Theater
1
12
Bar
1
13
Coffee Shop
1
14
Zoo or Aquarium
1
15
Emergency Coordination Center
2
0
Unspecified
2
1
Doctor or Dentist office
2
2
Bank
2
3
Fire Station
2
4
Police Station
2
6
Post Office
2
7
Professional Office
2
8
Research and Development Facility
2
9
Attorney Office
3
0
Unspecified
3
1
School Primary
3
2
School Secondary
3
3
University or College
4
0
Unspecified
4
1
Factory
5
0
Unspecified
5
1
Hospital
5
2
Long-Term Care Facility
5
3
Alcohol and Drug Rehabilitation Center
5
4
Group Home
5
5
Prison or Jail
6
0
Unspecified
6
1
Retail Store
6
2
Grocery Market
6
3
Automotive Service Station
6
4
Shopping Mall
6
5
Gas Station
7
0
Unspecified
7
1
Private Residence
7
2
Hotel or Motel
7
3
Dormitory
7
4
Boarding House
8
0
Unspecified
9
0
Unspecified
10
0
Unspecified
10
1
Automobile or Truck
10
2
Airplane
10
3
Bus
10
4
Ferry
10
5
Ship or Boat
10
6
Train
10
7
Motor Bike
11
0
Unspecified
11
1
Muni-mesh Network
11
2
City Park
11
3
Rest Area
11
4
Traffic Control
11
5
Bus Stop
11
6
Kiosk
# Specify venue group 1 and venue type 1 for AP ap3.
[Sysname] wlan ap ap3 model WA6320
[Sysname-wlan-ap-ap3] venue group 1 type 1
venue name
Use venue name to set a venue name for an AP.
Use undo venue name to delete a venue name.
venue name venue-name lang-code lang-code
undo venue name venue-name lang-code lang-code
No venue name is set for an AP.
AP view
venue-name: Specifies a venue name, a case-sensitive string of 1 to 252 characters.
lang-code: Specifies the language code for a venue. The device supports both the ISO-639-1 and ISO-639-2 standards.
One venue can have multiple language codes.
You can configure a maximum of 32 venue name and language code combinations for an AP.
# Set the venue name to office and language codes to en for AP ap3.
[Sysname-wlan-ap-ap3] venue name office lang-code en
wan-metrics
Use wan-metrics to set WAN link status parameters.
Use undo wan-metrics to restore the default.
wan-metrics { link-down | link-test | link-up } [ asymmetric downlink-speed downlink-speed uplink-speed uplink-speed | symmetric link-speed link-speed ]
undo wan-metrics
No WAN link status parameters are set.
link-down: Sets the link status for the WAN to down.
link-test: Sets the link status for the WAN to testing.
link-up: Sets the link status for the WAN to up.
asymmetric: Specifies the asymmetric link.
downlink-speed downlink-speed: Specifies the downlink speed in the range of 1 to 4194304 Kbps.
uplink-speed uplink-speed: Specifies the uplink speed in the range of 1 to 4194304 Kbps.
symmetric: Specifies the symmetric link.
link-speed link-speed: Specifies the symmetric link speed in the range of 1 to 4194304 Kbps.
# Set the link status to up and the symmetric link rate to 67 Kbps for the WAN.
[Sysname-wlan-hs-1] wan-metrics link-up symmetric link-speed 67
wlan hotspot-policy
Use wlan hotspot-policy to create a Hotspot 2.0 policy and enter its view, or enter the view of an existing Hotspot 2.0 policy.
Use undo wlan hotspot-policy to delete a Hotspot 2.0 policy.
wlan hotspot-policy policy-number
undo wlan hotspot-policy policy-number
No Hotspot 2.0 policies exist.
You cannot delete a Hotspot 2.0 policy that has been bound to a service template.
# Create Hotspot 2.0 policy 1 and enter its view.
[Sysname-wlan-hs-1]
wlan hotspot osu-icon unload
Use wlan hotspot osu-icon unload to unload all OSU server icon files.
This command only unloads OSU server icon files, and does not delete icon files.
# Unload all OSU server icon files.
[Sysname] wlan hotspot osu-icon unload
icon-file
Use wlan hotspot osu-icon upload to load all the specified OSU server icon files.
Use this command to load all icon files specified for an OSU server to validate the changes when icon file changes occur.
# Load all the specified OSU server icon files.
[Sysname] wlan hotspot osu-icon upload
icon-file
wlan osu-provider
Use wlan osu-provider to create an OSU server and enter its view, or enter the view of an existing OSU server.
Use undo wlan osu-provider to delete the specified OSU server.
wlan osu-provider osu-provider-number
undo wlan osu-provider osu-provider-number
No OSU server exists.
You cannot delete an OSU server that has been bound to a Hotspot 2.0 policy.
# Create OSU server 1 and enter its view.
