08-WLAN Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5456)-6W10008-WLAN Security Command Reference
04-WLAN DRS commands
04-WLAN DRS commands 53.86 KB
WLAN DRS commands
The following compatibility matrixes show the support of hardware platforms for WLAN DRS:
Hardware series
Model
Product code
WLAN DRS compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
Yes
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3010H-X-PWR
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-L-PWR
·     WX3024H-L-PWR
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
wlan drs enable
Use wlan drs enable to enable DRS.
Use undo wlan drs enable to disable DRS.
wlan drs [ ipv6 ] enable
undo wlan drs [ ipv6 ] enable
DRS is disabled.
ipv6: Enables DRS for IPv6 packets. If you do not specify this keyword, the command enables DRS for IPv4 packets.
With this feature enabled, DPI report statistics (DRS) classifies user application and URL session information detected by DPI, and stores the statistics in file drs.db in the bash directory of the local SQL database. You can view the statistics on the local database by using SQL database statements or from the Web interface.
# Enable DRS for IPv4 packets.
[Sysname] wlan drs enable
# Enable DRS for IPv6 packets.
[Sysname] wlan drs ipv6 enable
wlan drs report-oasis
Use wlan drs report-oasis to set the DRS information reporting interval and the number of entries to be reported every time.
Use undo wlan drs report-oasis to restore the default.
wlan drs report-oasis { app | url } [ interval interval | number number ] *
undo wlan drs report-oasis { app | url }
The AC reports 10 DRS entries to the cloud platform server every 1000 milliseconds.
app: Specifies user application information.
url: Specifies URL session information.
interval interval: Specifies the reporting interval in the range of 100 to 10000 milliseconds.
number number: Specifies the number of entries to be reported every time, in the range of 1 to 60.
# Set the DRS information reporting interval to 100 seconds, and the number of entries to be reported every time to 20.
[Sysname] wlan drs report-oasis app interval 100 number 20
wlan drs report-oasis enable
Use wlan drs report-oasis enable to enable DRS information reporting to the cloud platform server.
Use undo wlan drs report-oasis enable to disable DRS information reporting to the cloud platform.
DRS information reporting to the cloud platform is enabled.
This feature enables the AC to send a specific number of DRS entries to the cloud platform at the specified interval.
# Enable DRS information reporting to the cloud platform.
[Sysname] wlan drs report-oasis enable
wlan drs wired-statistics enable
Use wlan drs wired-statistics enable to enable DRS for wired clients.
Use undo wlan drs wired-statistics enable to disable DRS for wired clients.
DRS for wired clients is disabled.
This feature enables the AC to send a specific number of DRS entries for wired clients to the cloud platform at the specified interval.
# Enable DRS for wired clients.
[Sysname] wlan drs wired-statistics enable
