05-Network Connectivity Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5456)-6W10005-Network Connectivity Configuration Guide
27-IP forwarding basics configuration
27-IP forwarding basics configuration 54.59 KB
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Display and maintenance commands for FIB table············································································ 1
Configuring load sharing··················································································· 3
About load sharing·························································································································· 3
Restrictions: Hardware compatibility with loading sharing··································································· 3
Configuring load sharing mode········································································································ 4
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see IP routing basics configuration in Network Connectivity Configuration Guide.
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 4 FIB entry count: 4
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
10.2.0.0/16        10.2.1.1        U        GE1/0/1                  Null
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·     Destination—Destination IP address.
·     Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·     Nexthop—IP address of the next hop.
·     Flag—Route flag.
·     OutInterface—Output interface.
·     Token—MPLS Label Switched Path index number.
·     Label—Inner label.
Display FIB entries.
display fib  [ ip-address [ mask | mask-length ] ]
About load sharing
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
Hardware series
Model
Product code
Loading sharing compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-X
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. You can configure the device to identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, and IP protocol number.
In the per-packet load sharing mode, the device forwards packets over equal-cost routes.
2.     Configure load sharing.
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } global
By default, the device performs per-flow load sharing.
