- 16-Security Configuration Guide
- 01-ACL configuration
- 02-Time range configuration
- 03-User profile configuration
- 04-Password control configuration
- 05-Public key management
- 06-PKI configuration
- 07-IPsec configuration
- 08-SSH configuration
- 09-SSL configuration
- 10-Session management
- 11-Connection limit configuration
- 12-Attack detection and prevention configuration
- 13-IP source guard configuration
- 14-ARP attack protection configuration
- 15-ND attack defense configuration
- 16-ASPF configuration
- 17-Protocol packet rate limit configuration
- 18-Crypto engine configuration
- 19-Object group configuration
| 18-Crypto engine configuration | 37.70 KB |
Configuring crypto engines
About crypto engines
Crypto engines provide encryption/decryption services for service modules, for example, the IPsec module. When a service module requires data encryption/decryption, it sends the desired data to a crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Display and maintenance commands for crypto engines
Task |
Command |
Display crypto engine information. |
display crypto-engine |
Display crypto engine statistics. |
display crypto-engine statistics [ engine-id engine-id slot slot-number ] |
Clear crypto engine statistics. |
reset crypto-engine statistics [ engine-id engine-id slot slot-number ] |
