09-Radio Resources Management Configuration Guide
HomeSupportWirelessWX5800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX5800X Series Access Controllers Configuration Guides(E5457)-5W10009-Radio Resources Management Configuration Guide
04-WLAN radio resource measurement configuration
04-WLAN radio resource measurement configuration 105.06 KB
Configuring WLAN radio resource measurement
About WLAN radio resource measurement
WLAN radio resource measurement measures channel qualities and radio performance. It enables client and APs to learn the wireless environment and use wireless resources such as spectrum, power, and bandwidth more effectively.
WLAN radio resource measurement includes 802.11h measurement and 802.11k measurement.
802.11h measurement
802.11h measurement measures channels in the 5 GHz band. Table 1 lists the measurement types it supports.
Table 1 802.11h measurement
Spectrum management measurement
Basic
Measures whether a client has detected any of the following:
·     Packets from other BSSs.
·     OFDM preambles.
·     Radar signals.
·     Unknown signals.
Clear Channel Assessment (CCA)
Percentage of time that the channel was busy during the measurement period.
Receive Power Indication (RPI)
Percentage of time that each RPI was used during the measurement period.
Transmit Power Control (TPC) measurement
Measures the link redundancy and transmission power for clients.
802.11h measurement operates in the following procedure:
1.     An AP sets the Spectrum Mgmt field to 1 in beacons, probe responses, association responses, or reassociation responses to notify the clients that they can send 802.11h measurement requests.
2.     Upon receiving a measurement request from a client, the AP performs the required measurement and sends a report to the client.
The AP can also send measurement requests periodically to clients and collect measurement reports from clients.
802.11k measurement
802.11k measurement measures channels in both the 2.4 GHz and 5 GHz bands. Table 2 lists the measurement types it supports.
Table 2 802.11k measurement
Radio measurement
Beacon
Measures the Received Channel Power Indicator (RCPI) and Received Signal to Noise Indicator (RSNI) of beacons, measurement pilot packets, and probe responses.
Frame
Measures the number of frames transmitted and the average RCPI for these frames.
Station statistics
Measures the received and transmitted fragment counts, received and transmitted multicast frame counts, failed counts, retry counts, ACK failure counts.
Transmit stream
Measures the frame of a specific transmit stream.
Channel load
Measures the channel usage.
Location
Measures the relative locations of a requester and the requested.
Noise histogram
Measures the distribution of noise in different decibel ranges.
Link measurement
Measures RCPI, RSNI, and link redundancy for a requested link.
Neighbor measurement
Measures the channel and BSSID of neighbor APs.
802.11k measurement operates in the following procedure:
3.     An AP sets the Radio Measurement field to 1 in beacons, probe responses, association responses, or reassociation responses to notify the clients that they can send 802.11k measurement requests.
These frames also carry measurement capabilities of the AP to inform clients of measurement types that the AP supports.
The AP periodically sends Measurement Pilot frames to help clients fast discover the AP. Measurement Pilot frames are sent more frequently than beacons and carry less information.
4.     Upon receiving a measurement request from a client, the AP performs the required measurement and sends a report to the client.
Restrictions and guidelines: Radio resource measurement configuration
You can configure APs by using the following methods:
·     Configure APs one by one in AP view.
·     Assign APs to an AP group and configure the AP group in AP group view.
·     Configure all APs in global configuration view.
For an AP, the settings made in these views for the same parameter take effect in descending order of AP view, AP group view, and global configuration view.
WLAN radio resource measurement tasks at a glance
To configure WLAN radio resource measurement, perform the following tasks:
1.     Enabling radio resource management
2.     (Optional.) Setting the measurement duration and interval
3.     (Optional.) Setting the match mode for client radio resource measurement capabilities
2.     Enter AP view or an AP group's AP model view.
¡     Enter AP view.
wlan ap ap-name
¡     Execute the following commands in sequence to enter an AP group's AP model view:
wlan ap-group group-name
ap-model ap-model
3.     Enter radio view.
radio radio-id
4.     Enable a measurement type.
measure { all | link | neighbor | radio | spectrum | tpc } enable
By default:
¡     In radio view, the configuration in an AP group's radio view is used.
¡     In an AP group's radio view, measurement is disabled.
The spectrum and tpc keywords are available only for 5 GHz radios.
5.     Enable radio resource measurement.
resource-measure enable
By default:
¡     In an AP group's radio view, radio resource measurement is disabled.
You must enable radio resource measurement if you enable link, neighbor, or radio measurement.
6.     Enable spectrum management.
spectrum-management enable
By default:
¡     In an AP group's radio view, spectrum management is disabled.
Spectrum or TPC measurement takes effect only after you enable spectrum management.
For more information about this command, see Radio Resources Management Command Reference.
When radio resource measurement is enabled for an AP, the AP sends measurement requests that carry the measurement duration to clients at the specified interval.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Set the measurement duration.
measure-duration time
By default:
¡     In an AP group's radio view, the measurement duration is 500 TUs.
5.     Set the measurement interval.
measure-interval value
By default:
¡     In an AP group's radio view, the measurement interval is 30 seconds.
Set the match mode to allow a client to associate with an AP based on the predefined match criteria. Radio resource measurement capability refers to the radio resource measurement types supported by the AP and client. The device supports the following match modes for client radio resource measurement capabilities:
·     All—A client is allowed to associate with an AP only when all of its radio resource measurement capabilities match the AP's radio resource measurement capabilities.
·     None—Client radio resource measurement capabilities are not checked.
·     Partial—A client is allowed to associate with an AP as long as one of its radio resource measurement capabilities matches any of the AP's radio resource measurement capabilities.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Set the match mode for client radio resource measurement capabilities.
rm-capability mode { all | none | partial }
By default:
¡     In an AP group's radio view, an AP does not check the radio resource measurement capabilities of a client.
Display and maintenance commands for WLAN radio resource measurement
Display client measurement reports.
display wlan measure-report ap ap-name radio radio-id [ client mac-address mac-address ]
Radio resource measurement configuration examples
Example: Configuring radio resource measurement
As shown in Figure 1, configure radio resource measurement to meet the following requirements:
·     The client can come online only when all its radio resource measurement capabilities match the AP's.
·     The client can perform all types of measurements.
Figure 1 Network diagram
# Create service template 1.
<AC> system-view
[AC] wlan service-template 1
# Set the SSID to resource-measure, and enable the service template.
[AC-wlan-st-1] ssid resource-measure
[AC-wlan-st-1] quit
# Create manual AP ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Enter radio view of radio 1.
[AC-wlan-ap-ap1] radio 1
# Enable spectrum management.
[AC-wlan-ap-ap1-radio-1] spectrum-management enable
# Enable radio resource measurement.
[AC-wlan-ap-ap1-radio-1] resource-measure enable
# Enable all measurement features.
[AC-wlan-ap-ap1-radio-1] measure all enable
# Set the match mode for client radio resource measurement capabilities to All.
[AC-wlan-ap-ap1-radio-1] rm-capability mode all
# Bind the service template to radio 1, and enable the radio.
[AC-wlan-ap-ap1-radio-1] service-template 1
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
# Verify that the client has come online.
[AC] display wlan client
Total number of clients: 1
MAC address    Username             AP name               R IP address      VLAN
00ee-bd44-557f N/A                  ap1                   1 1.1.1.1         1
# Display measurement reports from the client.
[AC] display wlan measure-report ap ap1 radio 1
Client MAC address                              : 00ee-bd44-557f
Link measurement:
  Link margin                                   : 2 dBm
  RCPI                                          : -85 dBm
  RSNI                                          : 53 dBm
Noise histogram:
  Antenna ID                                    : 3
  ANPI                                          : -56 dBm
  IPI0 to IPI10 density                         : 5 12 16 13 8 5 5 15 17 1 3
Spectrum measurement:
  Transmit power                                : 20 dBm
  BSS                                           : Detected
  OFDM preamble                                 : Detected
  Radar                                         : Detected
  Unidentified signal                           : Undetected
  CCA busy fraction                             : 60
  RPI0 to RPI7 density                          : 3 7 11 19 15 23 15 7
Frame report entry:
  BSSID                                         : a072-2351-e253
  PHY type                                      : fhss
  Average RCPI                                  : -10 dBm
  Last RSNI                                     : 2 dBm
  Last RCPI                                     : -20 dBm
  Frames                                        : 1
Dot11BSSAverageAccessDelay group:
  Average access delay                          : 32 ms
  BestEffort average access delay               : 1 ms
  Background average access delay               : 1 ms
  Video average access delay                    : 1 ms
  Voice average access delay                    : 1 ms
  Clients                                       : 32
  Channel utilization rate                      : 11
Transmit stream:
  Traffic ID                                    : 0
  Sent MSDUs                                    : 60
  Discarded MSDUs                               : 5
  Failed MSDUs                                  : 3
  MSDUs resent multiple times                   : 3
  Lost QoS CF-Polls                             : 2
  Average queue delay                           : 2 ms
  Average transmit delay                        : 1 ms
  Bin0 range                                    : 0 to 10 ms
  Bin0 to Bin5                                  : 5 10 10 5 10 10
