17-Security Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)-R9112-6W10017-Security Command Reference
07-Packet filter commands
07-Packet filter commands 85.25 KB
If you do not specify a VPN instance, whether an ACL rule applies to VPN packets varies by device model.
display packet-filter
Use display packet-filter to display ACL application information for packet filtering.
display packet-filter interface [ interface-type interface-number ] [ inbound | outbound ] [ slot slot-number [ cpu cpu-number ] ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays ACL application information for packet filtering on all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide. If you specify an Ethernet interface, you do not need to specify the slot slot-number option.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ACL application information for packet filtering for the active MPU.
If neither the inbound keyword nor the outbound keyword is specified, this command displays ACL application information for packet filtering in both directions.
# Display ACL application information for inbound packet filtering on interface Ten-GigabitEthernet 0/0/6.
<Sysname> display packet-filter interface ten-gigabitethernet 0/0/6 inbound
Interface: Ten-GigabitEthernet0/0/6
 Inbound policy:
  IPv4 ACL 2001
  IPv6 ACL 2002 (Failed)
  MAC ACL 4003
Interface to which the ACL applies.
Inbound policy
ACL used for filtering incoming traffic.
Outbound policy
ACL used for filtering outgoing traffic.
IPv4 ACL 2001
IPv4 basic ACL 2001 has been successfully applied.
The device has failed to apply IPv6 basic ACL 2002.
IPv4 default action
Packet filter default action for packets that do not match any IPv4 ACLs:
·     Deny—The default action deny has been successfully applied for packet filtering.
·     Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions.
·     Permit—The default action permit has been successfully applied for packet filtering.
IPv6 default action
Packet filter default action for packets that do not match any IPv6 ACLs:
MAC default action
Packet filter default action for packets that do not match any Layer 2 ACLs:
display packet-filter statistics
Use display packet-filter statistics to display packet filtering statistics.
display packet-filter statistics interface interface-type interface-number { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ] [ brief ]
default: Displays the default action statistics for packet filtering.
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2 ACL type.
acl-number: Specifies an ACL by its number. The following are available value ranges:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
·     4000 to 4999 for Layer 2 ACLs.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
brief: Displays brief statistics.
If you do not specify any parameters, this command displays packet filtering statistics for all ACLs.
To specify the IPv4 ACL type, do not specify the ipv6 keyword.
# Display packet filtering statistics for all ACLs on incoming packets of Ten-GigabitEthernet 0/0/6.
<Sysname> display packet-filter statistics interface ten-gigabitethernet 0/0/6 inbound
 Inbound policy:
  IPv4 ACL 2001
   From 2019-06-04 10:25:21 to 2019-06-04 10:35:57
   rule 0 permit source 2.2.2.2 0 (2 packets)
   rule 5 permit source 1.1.1.1 0 (Failed)
   rule 10 permit vpn-instance test (No resource)
   Totally 2 packets permitted, 0 packets denied
   Totally 100% permitted, 0% denied
  IPv6 ACL 2000
  MAC ACL 4000
   rule 0 permit
  IPv4 default action: Deny
   Totally 7 packets
  IPv6 default action: Deny
   From 2019-06-04 10:25:41 to 2019-06-04 10:35:57
   Totally 0 packets
  MAC default action: Deny
   From 2019-06-04 10:25:34 to 2019-06-04 10:35:57
   Totally 0 packets
Inbound policy
Outbound policy
IPv4 ACL 2001
IPv4 ACL 2002 (Failed)
The device has failed to apply IPv4 basic ACL 2002.
Start time and end time of the statistics.
2 packets
Two packets matched the rule.
This field is not displayed when no packets matched the rule.
No resource
Resources are not enough for counting matches for the rule. In packet filtering statistics, this field is displayed for a rule when resources are not sufficient for rule match counting.
The device has failed to apply rule 5.
Number of packets permitted and denied by the ACL.
Ratios of permitted and denied packets to all packets.
IPv4 default action
IPv6 default action
MAC default action
Totally 7 packets
The default action has been executed on seven packets.
reset packet-filter statistics
display packet-filter statistics sum
Use display packet-filter statistics sum to display accumulated packet filtering statistics for an ACL.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac ] { acl-number | name acl-name } [ brief ]
# Display accumulated packet filtering statistics for IPv4 basic ACL 2001 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2001
Sum:
 Inbound policy:
  IPv4 ACL 2001
# Display brief accumulated packet filtering statistics for IPv4 basic ACL 2000 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2000 brief
Sum:
 Inbound policy:
  IPv4 ACL 2000
Sum
Accumulated packet filtering statistics.
Inbound policy
Accumulated packet filtering statistics in the inbound direction.
Outbound policy
Accumulated packet filtering statistics in the outbound direction.
IPv4 ACL 2001
Accumulated packet filtering statistics of IPv4 basic ACL 2001.
2 packets
display packet-filter verbose
Use display packet-filter verbose to display ACL application details for packet filtering.
display packet-filter verbose interface interface-type interface-number { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ] [ slot slot-number [ cpu cpu-number ] ]
interface interface-type interface-number: Specifies an interface by its type and number. The slot slot-number option is not available for an Ethernet interface.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ACL application details for packet filtering for the active MPU.
If acl-number, name acl-name, ipv6, or mac is not specified, this command displays application details of all ACLs for packet filtering.
# Display application details of all ACLs for inbound packet filtering on Ten-GigabitEthernet 0/0/6.
<Sysname> display packet-filter verbose interface ten-gigabitethernet 0/0/6 inbound
 Inbound policy:
  IPv4 ACL 2001
   rule 0 permit
   rule 10 permit vpn-instance test (Failed)
  IPv6 ACL 2000
   rule 0 permit
  MAC ACL 4000
Inbound policy
Outbound policy
IPv4 ACL 2001
IPv4 default action
IPv6 default action
MAC default action
packet-filter
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound }
undo packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound }
No ACL is applied to an interface to filter packets.
Interface view
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
To the same direction of an interface, you can apply a maximum of 32 ACLs.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] packet-filter 2001 inbound
packet-filter default deny
Use packet-filter default deny to set the packet filtering default action to deny. The packet filter denies packets that do not match any ACL rule.
Use undo packet-filter default deny to restore the default.
The packet filtering default action is permit. The packet filter permits packets that do not match any ACL rule.
The packet filter applies the default action to all ACL applications for packet filtering. The default action appears in the display command output for packet filtering.
# Set the packet filter default action to deny.
[Sysname] packet-filter default deny
Use reset packet-filter statistics to clear the packet filtering statistics.
reset packet-filter statistics interface [ interface-type interface-number ] { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet filtering statistics for all interfaces.
default: Clears the default action statistics for packet filtering.
If default, acl-number, name acl-name, ipv6, or macis not specified, this command clears the packet filtering statistics for all ACLs.
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering on Ten-GigabitEthernet 0/0/6.
<Sysname> reset packet-filter statistics interface ten-gigabitethernet 0/0/6 inbound 2001
