- 02-System Management Command Reference
- 01-Basic device management commands
- 02-Device hardening commands
- 03-Hardware resource management commands
- 04-EAA commands
- 05-Process monitoring and maintenance commands
- 06-Fast log output commands
- 07-Flow log commands
- 08-Information center commands
- 09-GOLD commands
| 03-Hardware resource management commands | 167.08 KB |
display cpu-usage configuration
card-mode
Use card-mode to set the operating mode for an interface card.
card-mode slot slot-number subslot subslot-number mode-name
The default varies by device model.
slot slot-number: Specifies a card by its slot number.
subslot subslot-number: Specifies a subcard by its subslot number.
mode-name: Specifies an operating mode. Available operating modes depend on the interface card type. The following shows all operating mode values:
· oc-12-pos: Specifies the oc-12-pos mode. All interfaces on the interface card act as 622 Mbps POS interfaces.
· oc-3-pos: Specifies the oc-3-pos mode. All interfaces on the interface card act as 155 Mbps POS interfaces.
For the new operating mode to take effect, you must perform one of the following tasks to activate the new operating mode:
· Hot swap the interface card if the interface card supports hot swapping.
· Restart the device.
For more information about interface types, see Interface Configuration Guide.
# Set the operating mode to oc-3-pos for an interface card.
[Sysname] card-mode slot 1 subslot 1 oc-3-pos
Please reboot or hot-swap the card or subcard (if supported) to make the configuration take effect.
display alarm
Use display alarm to display device hardware alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards.
# Display device hardware alarm information.
<Sysname> display alarm
Slot CPU Level Info
0 0 ERROR faulty
Slot |
Slot that generated the alarm. If the alarm was generated by the chassis frame, this field displays a hyphen (-). |
CPU |
ID of the CPU where the alarm occurred. |
Level |
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order. |
Info |
Detailed alarm information: · faulty—The slot is starting up or faulty. · Fan n is absent—The specified fan is absent. · Power n is absent—The specified power supply is absent. · Power n is faulty—The specified power supply is faulty. · The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold. · The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold. |
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [data-plane ] [ summary ] [ slot slot-number ]
data-plane: Displays CPU usage statistics for the data plane. Support for this keyword depends on the device model.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards.
cpu cpu-number: Specifies a CPU by its number.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 0 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# Display the current CPU usage statistics in table form.
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
0 0 17% 29% 28%
x% in last 5 seconds Last 5 sec |
Average CPU usage during the most recent 5-second interval. |
y% in last 1 minute Last 1 min |
Average CPU usage during the most recent 1-minute interval. |
z% in last 5 minutes Last 5 min |
Average CPU usage during the most recent 5-minute interval. |
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 80%.
CPU usage monitor is enabled. |
CPU usage tracking is enabled. |
Current monitor interval is 60 seconds. |
Sampling interval for CPU usage tracking is 60 seconds. |
Current monitor threshold is 80%. |
The CPU usage alarm threshold is 80% |
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Command Reference.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage tracking is enabled, the system regularly samples CPU usage and saves the samples to a buffer. This command displays the most recent 60 samples in a coordinate system as follows:
· The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
· The horizontal axis represents the time.
· Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 0 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
· Process name. The name SYSTEM represents the entire system.
· CPU that is holding the process: CPU 0 in slot 1.
· Historical CPU usage statistics for the entire system during the last 60 minutes.
¡ 12 minutes ago—Approximately 5%.
¡ 13 minutes ago—Approximately 10%.
¡ 14 minutes ago—Approximately 15%.
¡ 15 minutes ago—Approximately 10%.
¡ 16 and 17 minutes ago—Approximately 5%.
¡ 18 minutes ago—Approximately 10%.
¡ 19 minutes ago—Approximately 5%.
¡ Other time—2% or lower.
display device
Use display device to display device hardware information.
display device [ flash | harddisk | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Displays flash memory information.
harddisk: Displays hard disk information.
usb: Displays USB interface information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the cf-card, flash, harddisk, sd-card, and usb keywords, this command displays hardware information about cards.
# Display device hardware information.
<Sysname> display device
Slot No. Board type Status Primary SubSlots
0 RT-SR6602-I Normal Master 0
1 RT-FIP-30 Normal N/A 2
2 RT-RISER-FHFL-X16 Normal N/A 1
Board Type |
Hardware type. |
Status |
Card status: · Standby—The card is the standby MPU. · Master—The card is the active MPU. · Absent—The slot is not installed with a card. · Fault—The card is faulty and cannot start up. · Normal—The card is an interface card and is operating correctly. · Offline-OLO—The card is a switching fabric module and is isolated. |
display device manuinfo
Use display device manuinfo to display hardware electronic label information for the device.
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays hardware electronic label information of all cards.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display hardware electronic label information for the device.
<Sysname> display device manuinfo
display device manuinfo fan
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
display device manuinfo power
Use display device manuinfo power to display electronic label information for a power supply.
display device manuinfo power power-id
power-id: Specifies a power supply by its ID.
# Display electronic label information for a power supply.
<Sysname> display device manuinfo power 1
display environment
Use display environment to display temperature information.
This command displays information about all temperature sensors on the device if you do not specify a card.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature LowerLimit WarningLimit AlarmLimit ShutdownLimit
0 Outflow 1 37 0 64 68 N/A
0 Hotspot 1 60 0 93 95 N/A
0 Hotspot 2 45 0 80 100 N/A
0 Hotspot 3 42 0 88 110 N/A
1 Outflow 1 52 0 66 68 N/A
1 Hotspot 1 63 0 80 100 N/A
Table 5 Command output
System Temperature information (degree centigrade) |
Temperature information (°C). |
sensor |
Temperature sensor: · hotspot—Hotspot sensor. · inflow—Air inlet sensor. · outflow—Air outlet sensor. |
Slot |
Sensor position. For a sensor on the chassis or fan tray, this field displays Vent. |
Temperature |
Current temperature. |
Lower |
Lower temperature limit. If the device does not support this field, this field displays NA. |
Warning |
Warning temperature threshold. If the device does not support this field, this field displays NA. |
Alarm |
Alarming temperature threshold. If the device does not support this field, this field displays NA. |
Shutdown |
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA. |
display fan
Use display fan to display fan tray operating status information.
display fan [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# Display the operating states of all fan trays.
<Sysname> dis fan
Fan No. State Speed
1 Normal 35
2 Normal 35
3 Normal 50
Table 6 Command output
Fan No. |
Fan tray ID. |
State |
Fan tray status: · Absent—No fan tray is present in the slot. · Fault—The fan tray is faulty. · Normal—The fan tray is operating correctly. |
Speed |
Percentage of the current fan speed over the highest fan speed. |
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 16335164 4145632 12189532 0 8596 2472508 77.5%
-/+ Buffers/Cache: 1664528 14670636
Swap: 0 0 0
Container memory statistics are measured in KB:
Slot 0:
Total Used Free UsageRatio
Mem: 16335164 2357588 12189532 14.4%
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
0 0 16335164 4144720 12190444 8596 2472508 77.5%
Slot CPU Total Used Free UsageRatio
0 0 16335164 2358048 12190444 14.4%
Table 7 Command output
Memory statistics are measured in KB: |
Memory usage information on the physical device, in KB. |
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. The memory space is virtually divided into two parts. Part 1 is solely used for kernel code, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. If this field is not supported, two hyphens (--) are displayed. |
Buffers |
Physical memory used for buffers. If this field is not supported, two hyphens (--) are displayed. |
Cached Caches |
Physical memory used for caches. If this field is not supported, two hyphens (--) are displayed. |
FreeRatio |
Free memory ratio. |
-/+ Buffers/Cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Memory space for swapping. |
LowMem |
Low-memory usage information. |
HighMem |
High-memory usage information. |
Container memory statistics are measured in KB |
Container memory usage information, including: · Total—Total size of the physical memory space that can be allocated in the Comware container, in KB. · Used—Used physical memory in the Comware container, in KB. · Free—Free physical memory in the Comware container, in KB. · UsageRatio—Free physical memory usage in the Comware container. |
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
Minor: 256M
Severe: 192M
Critical: 128M
Normal: 320M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Enter minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
[Back to minor low-memory state]
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
display power-supply
Use display power-supply to display power supply management information.
display power-supply [ verbose ]
verbose: Displays detailed power supply management information. If you do not specify this keyword, this command displays the brief information.
# Display power supply management information.
<Sysname> display power-supply
PWR No. State
1 Normal
2 Absent
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 8 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 8 Common transceiver alarm components
APD |
Avalanche photo diode |
PCS |
Physical coding sublayer |
PHY XS |
PHY extended sublayer |
PMA/PMD |
Physical medium attachment/physical medium dependent |
power |
Optical power |
REFCLK |
Reference clock |
RX |
Receive |
TEC |
Thermoelectric cooler |
Temp |
Temperature |
TX |
Transmit |
WIS |
WAN interface sublayer |
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 0/0/6.
<Sysname> display transceiver alarm interface ten-gigabitethernet 0/0/6
Ten-GigabitEthernet0/0/6 transceiver current alarm information:
RX loss of signal
RX power low
Table 9 Command output
transceiver current alarm information |
Alarms present on the transceiver module. |
RX loss of signal |
Received signals are lost. |
RX power low |
Received power is low. |
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 0/0/6.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 0/0/6
Ten-GigabitEthernet0/0/6 transceiver diagnostic information:
Temp(°C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(°C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Table 10 Command output
transceiver diagnostic information |
Digital diagnosis information for the transceiver module in the interface. |
Wave.er(nm) |
Wavelength offset in nm, accurate to 0.001 nm. This field is supported only on the HPE X130 10G SFP+ LC LH80 Tunable Transceiver (JL250A) and SFP-XG-LH80-Tunable transceiver modules. |
Freq.er(GHz) |
Frequency offset in GHz, accurate to 0.1 GHz. This field is supported only on the HPE X130 10G SFP+ LC LH80 Tunable Transceiver (JL250A) and SFP-XG-LH80-Tunable transceiver modules. |
[Module] |
Parameters of the transceiver module. |
Temp.(°C) |
Temperature in °C, accurate to 1°C. |
Voltage(V) |
Voltage in V, accurate to 0.01 V. |
TEC Current(%) |
TEC current in percentage, accurate to 0.01%. |
Laser Temp(°C) |
Laser temperature in °C, accurate to 0.01°C. |
[Channel] |
Channel number. A channel is also referred to as a lane. |
Bias(mA) |
Bias current in mA, accurate to 0.01 mA. |
RX power(dBm) |
Receive power in dBm, accurate to 0.01 dBm. |
TX power(dBm) |
Transmit power in dBm, accurate to 0.01 dBm. |
display transceiver interface
Use display transceiver interface to display the key parameters of a transceiver module.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 0/0/6.
<Sysname> display transceiver interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver information:
Transceiver Type :10G_BASE_SR_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 80(OM2),20(OM1),300(OM3)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
Ordering Name :SFP-XG-SX-MM850-D
Table 11 Command output
Transceiver Type |
Model of the transceiver module. |
Connector Type |
Connector type of the transceiver module: · Optical connectors, including SC connector developed by NTT, and 1.25mm/RJ45 LC connector developed by Lucent. · Other connectors, including RJ-45 and CX4. |
Wavelength(nm) |
For the transceiver module, this field displays central wavelength of the laser sent, in nm. If the transceiver module such as 10GBASE-LX4, supports multiple wavelengths, each wavelength value is separated by a comma. For the electrical transceiver, this field displays N/A. |
Transfer Distance(xx) |
Transfer distance. For a single-mode transceiver module, the distance is measured in km. For other transceiver modules, the distance is measured in m. If the transceiver module supports multiple transfer media, the transfer distances are separated by commas. The corresponding transfer medium is enclosed in the brackets following the transfer distance value. The following are the transfer media: · 9um—9/125 um single-mode optical fiber. · 50um—50/125 um multi-mode optical fiber. · 62.5um—62.5/125 um multi-mode optical fiber. · TP—Twisted pair. · CX4—CX4 cable. |
Max power(W) |
Maximum power of the transceiver module. |
Digital Diagnostic Monitoring |
Support for digital diagnostic monitoring: · Yes. · No. |
Vendor Name |
Vendor name or vendor name specified for the transceiver module. |
Ordering Name |
Ordering name of the transceiver module. |
display transceiver itu-channel
Use display transceiver itu-channel to display ITU channel information for transceiver modules.
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays ITU channel information for the transceiver modules on all interfaces.
supported channel: Specifies ITU channels supported on the interface. If this keyword is not specified, the command displays the ITU channel that is in use on the interface.
This command is supported only on the HPE X130 10G SFP+ LC LH80 Tunable Transceiver (JL250A) module and SFP-XG-LH80-Tunable Transceiver module.
# Display ITU channel information for the transceiver module in Ten-GigabitEthernet0/0/6.
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 0/0/6
Interface Channel WaveLength(nm) Frequency(THz)
ten-gigabitethernet 0/0/6 1 1566.72 191.35
# Display ITU channels supported by the transceiver module in Ten-GigabitEthernet0/0/6.
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 0/0/6 supported-channel
ITU channel settings supported on Ten-GigabitEthernet0/0/6 :
1 1566.72 191.35
2 1566.31 191.40
3 1565.90 191.45
4 1565.50 191.50
5 1565.09 191.55
6 1564.68 191.60
7 1564.27 191.65
8 1563.86 191.70
Omitted…
Table 12 Command output
WaveLength(nm) |
Wavelength of the channel in nm, accurate to 0.01 nm. This field displays a hyphen (-) in the following situations: · No transceiver module is installed on the interface. · The transceiver module does not support specifying an ITU channel number. · The command failed to obtain the ITU channel information. · The device does not support the ITU channel number stored on the transceiver module. |
Frequency(THz) |
Frequency of the channel in THz, accurate to 0.01 THz. This field displays a hyphen (-) in the following situations: · No transceiver module is installed on the interface. · The transceiver module does not support specifying an ITU channel number. · The command failed to obtain the ITU channel information. · The device does not support the ITU channel number stored on the transceiver module. |
itu-channel
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 0/0/6.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 0/0/6
Ten-GigabitEthernet0/0/6 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2019-09-01
Vendor Name : H3C
Table 13 Command output
Manu. Serial Number |
Serial number generated during debugging and testing. |
Manufacturing Date |
Debugging and testing date. The date takes the value of the system clock of the computer when debugging and testing is performed. |
Vendor Name |
The value is H3C. |
itu-channel
Use itu-channel to set the ITU channel number for a transceiver module.
Use undo itu-channel to restore the default.
itu-channel channel-number
undo itu-channel
The ITU channel number is 1.
Ethernet interface view
channel-number: Specifies the ITU channel number.
The ITU channel number is saved in a register on the transceiver module. It is not saved to the configuration file.
# Set the ITU channel number to 2 for the transceiver module in Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 512 MB.
Severe alarm threshold: 448 MB.
Critical alarm threshold: 384 MB.
Normal state threshold: 576 MB.
Early-warning threshold: 640 MB.
Sufficient-memory threshold: 704 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
(On devices that do not support low memory.) You can use the display memory command to display memory usage information.
(On devices that support low memory.) The system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information.
(On devices with slots that support low memory.) For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
Use monitor cpu-usage enable to enable CPU usage tracking.
Use undo monitor cpu-usage enable to disable CPU usage tracking.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage tracking for the active MPU.
After you enable CPU usage tracking, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage tracking.
[Sysname] monitor cpu-usage enable
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
CPU usage alarm thresholds depend on the device model.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU.
CAUTION: If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected. |
The device samples CPU usage and CPU core usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage alarm threshold to 90%.
[Sysname] monitor cpu-usage threshold 90
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. To disable port status detection, set this argument to 0.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
