- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-IP forwarding basics commands
- 07-Fast forwarding commands
- 08-Multi-CPU packet distribution commands
- 09-Adjacency table commands
- 10-IRDP commands
- 11-IP performance optimization commands
- 12-UDP helper commands
- 13-IPv6 basics commands
- 14-DHCPv6 commands
- 15-IPv6 fast forwarding commands
- 16-Tunneling commands
- 17-GRE commands
- 18-ADVPN commands
- 19-WAAS commands
- 20-AFT commands
- 21-Lighttpd service commands
- 22-Web caching commands
| 08-Multi-CPU packet distribution commands | 38.25 KB |
The following compatibility matrix shows the support of hardware platforms for multi-CPU packet distribution:
Hardware |
Multi-CPU packet distribution compatibility |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR2600-6-X1, MSR2600-10-X1 |
No |
MSR 2630 |
No |
MSR3600-28, MSR3600-51 |
No |
No |
No |
MSR3610-I-DP, MSR3610-IE-DP |
Yes |
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow | per-packet }
The device uses the flow-based policy.
per-flow: Specifies the flow-based forwarding. The device forwards packets of the same flow to the same CPU. This policy takes the first-in first-out rule.
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
