- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
| 13-License management commands | 71.81 KB |
display license
Use display license to display detailed license information.
In standalone mode:
display license [ activation-file ]
In IRF mode:
display license [ activation-file ] [ slot slot-number ]
activation-file: Displays license information about activation files. The device supports only license installation through activation files, so this command always displays license information about activation files whether you specify this keyword or not.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices. (In IRF mode.)
The device supports license installation through only activation files in the current software version.
# Display detailed information about all licenses.
<Sysname> display license
cfa0:/license/210235A0W8B1330000412016101010533415964.ak
Feature: pkg_license
Product Description: H3C MSR 36 Voice Software License
Registered at: 2016-10-10 10:21:38
License Type: Permanent
Current State: In use
cfa0:/license/210235A0W8B1330000412016101010420017596.ak
Product Description: H3C MSR 36 Data Software License
Registered at: 2016-10-10 10:14:18
cfa0:/license/210235A0W8B1330000412013073110284693735.ak
Registered at: 2013-07-31 10:29:33
License Type: Trial (days restricted)
Trial Time Left (days): 0
Current State: Expired
Feature |
Feature name. |
Product Description |
License description. |
Registered at |
Time when the license was installed. |
License Type |
License type by validity period: · NA—The system cannot obtain the license type. · Permanent—Purchased license that never expires and is always valid. · Days restricted—Purchased license that is valid for a period of days, for example, 30 days. · Trial (days restricted)—Free trial license that is valid for a period of days. |
Time Left (days) |
Remaining days of the license. This field is available for a purchased license. |
Trial Time Left (days) |
Remaining days of the trial period. This field is available for a trial license. |
Current State |
State of the license: · In use—The license is being used. · Usable—The license is available for use. ¡ If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state. ¡ A date restricted license is in this state if its start date is not reached. · Expired—The license has expired. · Uninstalled—The license has been uninstalled. · Unusable—The license cannot be used. · Invalid—The license is invalid and cannot be used. |
Uninstall Key |
This field is available for licenses that have been uninstalled. When you uninstall an activation file, an Uninstall file that contains an Uninstall key is created. The Uninstall key is required for transferring the license. |
Uninstall Date |
Date when the activation file was uninstalled. |
display license device-id
Use display license device-id to display SN and DID information.
In standalone mode:
In IRF mode:
display license device-id slot slot-number
slot slot-number: Specifies the member ID of an IRF member device. (In IRF mode.)
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
The DID is a string. Enter the string when you register the license with the license center.
# (In standalone mode.) Display the device SN and DID.
<Sysname> display license device-id
SN: 210235A0W8B133000041
Device ID: 4QUF-Hn%W-D+Ss-A$gr-M@A>-t3uB-Qu:v-YafB
# (In IRF mode.) Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 210235A1X5A129000001
Device ID: ZR#9->CKc-4bpd-GrNf-LMap-D@5c-xtF:-:#sA
display license feature
Use display license feature to display brief license information for features.
# (In standalone mode.) Display brief feature license information.
<Sysname> display license feature
Total: 128 Usage: 7
Feature Licensed State
ACG Y Trial
APMGR N -
IPS N -
RemoteTermConn N -
SSLVPN N -
WEB-CACHE N -
pkg_data Y Formal
pkg_security Y Formal
pkg_voice Y Formal
Total |
Total number of licenses that can be installed. |
Usage |
Number of installed licenses. |
Feature |
Feature that must be licensed before being used. |
Licensed |
Licensing state of the feature: · N—Not licensed. · Y—Licensed. |
State |
License type by purchasing state: · Trial—Trial license. If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file. |
license activation-file install
Use license activation-file install to install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file slot slot-number
license-file: Specifies the path of an activation file., a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
(In standalone mode.) License registration requires the device's hardware SN and DID.
In IRF mode:
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the device.
Activation files are device locked rather than MPU locked. A licensed feature can run on the entire system even after an MPU replacement.
# (In standalone mode.) Install activation file 20170810.ak.
[Sysname] license activation-file install flash:/license/20170810.ak
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...Done.
# (In IRF mode.) Install activation file 20170811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20170811.ak slot 1
display license activation-file
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file slot slot-number
license-file: Specifies the file path, a case-sensitive string of 1 to 127 characters.
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# (In standalone mode.) Uninstall activation file flash:/license/20130810.ak.
[Sysname] license activation-file uninstall flash:/license/20130810.ak
Uninstall file: flash:/license/20130810.uak
# (In IRF mode.) Uninstall activation file flash:/license/20130811.ak from the specified slot.
[Sysname] license activation-file uninstall flash:/license/20130811.ak slot 1
Uninstall file: flash:/license/20130811.uak
license compress
Use license compress to compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress slot slot-number
Use this command if the free license storage (see the display license feature command) is not sufficient.
The DID changes each time the license storage is compressed. Before performing a compression, make sure all licenses registered with the old DID have been installed. They cannot be installed after the compression.
This command clears invalid licenses (expired licenses and uninstalled licenses) and Uninstall keys from the license storage area. Back up the Uninstall keys before you compress the license storage.
# (In standalone mode.) Compress the license storage.
[Sysname] license compress
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
# (In IRF mode.) Compress the license storage on the specified slot.
[Sysname] license compress slot 1
