03-Monitor
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Comware 7 Web configuration guide(R9153P38 R9724P38 R9001P38 E9153P38)-6W40103-Monitor
24-TopN file filtering trends
24-TopN file filtering trends 12.49 KB
Introduction
The File Type Trend page allows you to generate a trend report for the types of files transferred over a specific time range. You can use the information to customize file filtering profiles to reduce the information leakage and virus infection risks on the company network.
