- 06-Network
- 01-Scanner
- 02-VRF
- 03-Interface
- 04-Interface pairs
- 05-Interface collaboration
- 06-Security zones
- 07-VLAN
- 08-MAC
- 09-DNS
- 10-ARP
- 11-ND
- 12-Forwarding advanced settings
- 13-ALG
- 14-GRE
- 15-IPsec
- 16-ADVPN
- 17-L2TP
- 18-SSL VPN
- 19-Routing table
- 20-Static routing
- 21-Policy-based routing
- 22-OSPF
- 23-BGP
- 24-IS-IS
- 25-RIP
- 26-IPv4 multicast routing
- 27-IPv6 multicast routing
- 28-PIM
- 29-IGMP
- 30-MLD
- 31-DHCP
- 32-HTTP
- 33-SSH
- 34-NTP
- 35-FTP
- 36-Telnet
- 37-MAC authentication
- 38-MAC address whitelist
- 39-MAC access silent MAC info
- 40-MAC access advanced settings
- 41-IP authentication
- 42-IPv4 whitelist
- 43-IPv6 whitelist
| 34-NTP | 14.18 KB |
NTP
Introduction
Network Time Protocol (NTP) is used to synchronize system clocks among distributed time servers and clients on a network.
NTP uses stratums 1 to 15 to define clock accuracy. A lower stratum value represents higher accuracy.
If devices on a network cannot synchronize to an authoritative time source, you can perform the following tasks to achieve NTP synchronization on the network:
1. Select a device that has a relatively accurate clock on the network.
2. Configure the local clock of the device as its reference source.
3. Configure the device as a time server to synchronize other devices on the network.
You can configure a local clock as the reference source from the Web interface.
Before configuring a local clock as the reference source, adjust the time on the local clock to ensure that it is accurate.
