17-User Access and Authentication Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9119-6W10017-User Access and Authentication Command Reference
08-User profile commands
08-User profile commands 56.68 KB
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
display user-profile [ session-group ] [ name profile-name ] [ slot slot-number ]
session-group: Specifies a session group profile.
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, underscores (_), minus signs (–), and dots (.). The name can start with an English letter or digit, and cannot contain only digits. The name must be unique globally. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays user profile configuration and online user information on all cards.
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
  User-Profile: aaa
    Direction: Inbound
      Committed Access Rate:
        CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
      Policy: p1
      Packet-filter ipv6 2222
    Direction: Outbound
      Policy: p2
      Packet-filter 2222
    Connection-limit amount: 1000
    Connection-limit rate: 100
      Authentication-free rule:
      acl 3000
      acl name flow1
      acl ipv6 3000
      acl ipv6 name flow2
    User user_1:
      Authentication type: 802.1X
      Network attributes:
        Interface    : GigabitEthernet0/0/1
        MAC address  : 0000-1111-2222
      Failed action list:
        Direction: Inbound
         Policy: p1
    User user_2:
      Authentication type: Portal
      Network attributes:
        Interface    : GigabitEthernet0/0/3
        IP address   : 172.16.187.16
        VPN          : N/A
        Service VLAN : 100
# Display configuration and online user information for all session group profiles.
<Sysname> display user-profile session-group
  Session-Group-Profile: aaa
    Direction: Outbound
      QMProfile: a
    User user_1:
      Network attributes:
      Failed action list:
        Direction Outbound
         QMProfile: a
    User user_2:
      Network attributes:
        VPN          : N/A
        Service VLAN : 100
  Session-Group-Profile: bbb
    Direction: Outbound
        CIR 512 (kbps), CBS 1024 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
      QMProfile: a
    User user_4:
      Network attributes:
        Interface    : GigabitEthernet0/0/2
        IP address   : 172.16.187.166
        VPN          : N/A
        Service VLAN : 100
User-Profile
User profile name.
Inbound
Policy applied to incoming traffic.
Outbound
Policy applied to outgoing traffic.
Session group profile name.
CIR
Committed information rate, in kbps.
CBS
Committed burst size, in bytes.
EBS
Excess burst size, in bytes.
PIR
Peak information rate, in kbps.
Maximum number of user connections set by the connection limits.
Maximum connection establishment rate set by the connection limits.
User profile free rule.
Policy
Policy name.
Packet-filter
Packet filter that uses an IPv4 ACL.
Packet-filter ipv6
Packet filter that uses an IPv6 ACL.
QMProfile
Queue scheduling profile.
User user_1
Username of a user account with which a user profile or session group profile is associated.
Authentication type
·     802.1X—802.1X authentication.
·     Portal—Portal authentication.
·     PPP—PPP authentication.
·     MACA—MAC authentication.
·     WLAS.
Network attributes
Online user information.
Failed action list
Actions that failed to be applied to the user.
qos session-group identify
Use qos session-group identify to identify a session group on an interface.
Use undo qos session-group identify to restore the default.
qos session-group identify { customer-vlan | service-vlan | customer-service-vlan | subscriber-id }
No session group is identified on the interface.
Interface view
customer-vlan: Identifies a session group by CVLAN. A CVLAN is used by a customer on the private network.
service-vlan: Identifies a session group by SVLAN. An SVLAN is used by a service provider to transmit VLAN tagged traffic for customers.
customer-service-vlan: Identifies a session group by CVLAN and SVLAN.
subscriber-id: Identifies a session group by subscriber ID.
To configure a session group profile, you must first use the command.
# Configure GigabitEthernet 0/0/1 to identify a session group by an SVLAN.
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] qos session-group identify service-vlan
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name [ type session-group ]
undo user-profile profile-name
No user profiles exist.
type session-group: Specifies a session group profile.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
# Create session group profile a123 and enter the view of a123.
[Sysname] user-profile a123 type session-group
[Sysname-session-group-profile-a123]
