- 14-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-SNMP commands
- 05-RMON commands
- 06-Event MIB commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Sampler commands
- 12-Mirroring commands
- 13-NetStream commands
- 14-IPv6 NetStream commands
- 15-Fast log output commands
- 16-Performance management commands
- 17-Information center commands
- 18-iNQA commands
12-Mirroring commands | 68.34 KB |
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
group-id: Specifies a mirroring group by its ID.
· 1 to 4 for local common mirroring groups.
· 257 to 384 for local FPGA mirroring groups.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet2/0/1 Inbound
Monitor port: GigabitEthernet2/0/2
Mirroring group |
ID of the mirroring group. · 1 to 4 for local common mirroring groups. · 257 to 384 for local FPGA mirroring groups. |
Type |
Type of the mirroring group: Local. |
Status |
Status of the mirroring group: · Active—The mirroring group has taken effect. · Incomplete—The mirroring group configuration is not complete and does not take effect. |
Mirroring port |
Source port. |
Monitor port |
Destination port. |
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
group-id: Specifies a mirroring group ID.
· 257 to 384 for local FPGA mirroring groups. Only FIP260 and FIP380 cards support local FPGA mirroring groups.
In local port mirroring, the source device is directly connected to a data monitoring device. The source device also acts as the destination device and forwards mirrored packets directly to the data monitoring device. Local mirroring groups can be further classified into the following types:
· Local common mirroring group—Uses the software algorithm to mirror packets.
· Local FPGA mirroring group—Uses the FPGA hardware module to mirror packets at a high speed. Through configuring two local FPGA mirroring groups, you can mirror the incoming packets and outgoing packets of one source port to different monitor ports separately.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
# Create local FPGA mirroring group 257.
[Sysname] mirroring-group 257 local
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
A port can act as a source port for only one mirroring group. A source port cannot be used as a monitor port.
For a local FPGA mirroring group, the mirroring source ports and the monitor port must be physical interfaces on the same card.
# Create local mirroring group 1 to monitor the bidirectional traffic of port GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] mirroring-group 1 mirroring-port both
mirroring-group
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 2/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 2/0/1 both
mirroring-group
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
A mirroring group can contain only one monitor port.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
# Create local mirroring group 1 and configure GigabitEthernet 2/0/1 as its monitor port.
[Sysname-GigabitEthernet2/0/1] mirroring-group 1 monitor-port
mirroring-group
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 2/0/1
mirroring-group
Flow mirroring commands
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
Traffic behavior view
You can execute this command multiple times for a traffic behavior to mirror traffic to different interfaces.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 2/0/1 for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface gigabitethernet 2/0/1
