01-Fundamentals Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6728-6W10001-Fundamentals Command Reference
13-License management commands
13-License management commands 68.98 KB
display license
Use display license to display detailed license information.
In standalone mode:
display license [ activation-file ]
In IRF mode:
display license [ activation-file ] [ chassis chassis-number ]
activation-file: Displays license information about activation files.
chassis chassis-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices. (In IRF mode.)
# (In standalone mode.) Display detailed information about all licenses.
<Sysname> display license
cfa0:/license/210231A1UXA1290000012017082516403519153.ak
Feature: pkg_license
Product Description: H3C MSR 56 Data Software License
Registered at: 2014-06-01 02:25:56
License Type: Permanent
Current State: Uninstalled
Uninstall Key: Zb8t-M/Je-piVX-:NtX-evEk-JYnF-TibR-3D>$
Uninstall Date: 2014-09-13 19:11:03
cfa0:/license/5660_voice.ak
Product Description: H3C MSR 56 Voice Software License
Registered at: 2013-04-18 09:10:17
Current State: In use
cfa0:/license/5660_security.ak
Product Description: H3C MSR 56 Security Software License
Registered at: 2013-04-18 09:09:44
Feature
Feature name.
Product Description
License description
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Days restricted—Purchased license that is valid for a period of days, for example, 30 days.
·     Trial (days restricted)—Free trial license that is valid for a period of days.
Time Left (days)
Remaining days of the license. This field is available for a purchased license.
Trial Time Left (days)
Remaining days of the trial period. This field is available for a trial license.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use.
¡     If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
¡     A date restricted license is in this state if its start date is not reached.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
In standalone mode:
In IRF mode:
display license device-id chassis chassis-number
chassis chassis-number: Specifies the member ID of an IRF member device. (In IRF mode.)
Each device has a unique SN and DID. When you register a license for a device, you must provide its SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# (In standalone mode.) Display the device SN and DID.
<Sysname> display license device-id
SN: 210231S12500XSUPSUPC
Device ID:QCZ#-sg$W-4ASi-xam%-9Dqs-Ftvq-:2sU-FjN3
display license feature
Use display license feature to display brief license information for features.
# (In standalone mode.) Display brief feature license information.
<Sysname> display license feature
Total: 128  Usage: 4
Feature                         Licensed        State
ACG                             N               -
IPS                             N               -
POSA                            N               -
RemoteTermConn                  N               -
SSLVPN                          N               -
WEB-CACHE                       N               -
pkg_data                        N               -
pkg_security                    Y               Formal
pkg_voice                       Y               Formal
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Formal—Purchased license.
·     Trial—Trial license.
·     Pre-licensed—Preinstalled license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file.
license activation-file install
Use license activation-file install to install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file chassis chassis-number
license-file: Specifies the path of an activation file package., a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
(In standalone mode.) License registration requires the device's hardware SN and DID.
In IRF mode:
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the IRF member device.
A licensed feature can run on the IRF member device where its activation file is installed even after the IRF member device joins another IRF fabric.
# (In standalone mode.) Install activation file 20130810.ak.
[Sysname] license activation-file install flash:/license/20130810.ak
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...Done.
display license
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file chassis chassis-number
license-file: Specifies the file path, a case-sensitive string of 1 to 127 characters.
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# (In standalone mode.) Uninstall activation file flash:/license/20130810.ak.
[Sysname] license activation-file uninstall flash:/license/20130810.ak
Uninstall file: flash:/license/20130810.uak
display license
license compress
Use license compress to compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress chassis chassis-number
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# (In standalone mode.) Compress the license storage.
[Sysname] license compress
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files.Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
