06-AP Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Points Cloud Mode Command References(E2453 R2453)-6W10006-AP Management Command Reference
01-AP management commands
01-AP management commands 99.18 KB
1 AP management commands
region-code
Use region-code to specify a region code.
region-code code
The region code for APs in China is CN, and the region code for APs in Japan is JP. No region code is specified for APs in any other countries or regions.
Global configuration view
code: Specifies a region code. For more information about region codes, see Table1-1.
Table1-1 Region code information
Country
Code
Country
Code
Andorra
AD
Kenya
KE
United Arab Emirates
AE
Kuwait
KW
Albania
AL
Kazakhstan
KZ
Armenia
AM
Lebanon
LB
Australia
AU
Liechtenstein
LI
Argentina
AR
Sri Lanka
LK
Australia
AT
Lithuania
LT
Azerbaijan
AZ
Luxembourg
LU
Bosnia and Herzegovina
BA
Latvia
LV
Belgium
BE
Libyan
LY
Bulgaria
BG
Morocco
MA
Bahrain
BH
Monaco
MC
Brunei Darussalam
BN
Moldova
MD
Bolivia
BO
Macedonia
MK
Brazil
BR
Macau
MO
Bahamas
BS
Martinique
MQ
Belarus
BY
Malta
MT
Belize
BZ
Korea, Republic of Korea
KR
Canada
CA
Mauritius
MU
Switzerland
CH
Mexico
MX
Cote d'ivoire
CI
Malay Archipelago
MY
Chile
CL
Namibia
NA
China
CN
Nigeria
NG
Colombia
CO
Nicaragua
NI
Costarica
CR
Netherlands
NL
Serbia
RS
Norway
NO
Cyprus
CY
New Zealand
NZ
Czech Republic
CZ
Oman
OM
Germany
DE
Panama
PA
Denmark
DK
Peru
PE
Dominica
DO
Poland
PL
Algeria
DZ
Philippines
PH
Ecuador
EC
Pakistan
PK
Estonia
EE
Puerto Rico
PR
Egypt
EG
Portugal
PT
Spain
ES
Paraguay
PY
Faroe Islands
FO
Qatar
QA
Finland
FI
Romania
RO
France
FR
Russian Federation
RU
Britain
GB
Saudi Arabia
SA
Georgia
GE
Sweden
SE
Gibraltar
GI
Singapore
SG
Greenland
GL
Slovenia
SI
Guadeloupe
GP
Slovak
SK
Greece
GR
San Marino
SM
Guatemala
GT
Salvador
SV
Guam
GU
Syrian
SY
Guyana
GY
Thailand
TH
Honduras
HN
Tunisia
TN
Hong Kong
HK
Turkey
TR
Croatia
HR
Trinidad and Tobago
TT
Hungary
HU
, Province of China
TW
Iceland
IS
Ukraine
UA
India
IN
United States of America
US
Indonesia
ID
Uruguay
UY
Ireland
IE
Uzbekistan
UZ
Israel
IL
The Vatican City State
VA
Iraq
IQ
Venezuela
VE
Italy
IT
Virgin Islands
VI
Jamaica
JM
Vietnam
VN
Jordan
JO
Yemen
YE
Japan
JP
South Africa
ZA
Democratic People's Republic of Korea
KP
Zimbabwe
ZW
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring an AP.
# Specify the global region code.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] region-code US
region-code-lock
region-code-ie
Use region-code-ie to include or exclude region codes in beacon frames and probe responses and specify the installation environment type.
Use undo region-code-ie to restore the default.
region-code-ie { disable | enable { any | indoor | outdoor } }
undo region-code-ie
Beacon frames and probe responses contain region codes and the installation environment type is any.
Service template view
disable: Excludes region codes in beacon frames and probe responses.
enable: Includes region codes in beacon frames and probe responses.
any: Specifies APs that can be installed both indoors and outdoors.
indoor: Specifies APs that can only be installed indoors.
outdoor: Specifies APs that can only be installed outdoors.
If you bind different service templates to radios of an AP, make sure the service templates are specified with the same installation environment type.
# Include region codes in beacon frames and probe responses and specify the type of installation environment as indoor.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] region-code-ie enable indoor
region-code
region-code-lock
Use region-code-lock enable to lock the region code.
Use region-code-lock disable to unlock the region code.
Use undo region-code-lock to restore the default.
region-code-lock { disable | enable }
The region code is not locked.
# Lock the global region code.
[Sysname-wlan-global-configuration] region-code-lock enable
region-code
usb
Use usb enable to enable the USB interface on the AP.
Use undo usb to restore the default.
usb enable
undo usb enable
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware series
Model
Command compatibility
WA6600 series
WA6638
Yes
WA6638i
Yes
WA6636
Yes
WA6630X
No
WA6628
Yes
WA6628X
No
WA6628E-T
No
WA6628XM
No
WA6622
Yes
WA6620
Yes
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
Yes
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
Yes
WA6330-LI
Yes
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
Yes
WA6320H-HI
Yes
WA6320H-LI
Yes
WA6320H-XEPON
No
WAP722 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
Yes
The USB interface is disabled.
This command takes effect only when the input power level of the AP is middle or high.
If the input power level is middle, the MIMO mode can only be 1×1 or 2×2 with the USB interface enabled. With the USB interface disabled, the MIMO mode can reach 4×4.
# Enable the USB interface.
[Sysname] usb enable
wlan connect-ac enable
Use wlan connect-ac enable to enable the AP to connect to the AC.
Use undo wlan connect-ac enable to disable the AP from connecting to the AC.
This feature is enabled. The AP is connected to the AC.
After this feature is disabled, all APs connected to the AC will disconnect from the AC.
# Enable the AP to connect to the AC.
[Sysname] wlan connect-ac enable
Use wlan global-configuration to enter global configuration view.
The configuration priorities for an AP in AP view, AP group view, and global configuration view are in descending order. If no settings are configured in one view, the settings in the view with a lower priority are used. If no settings are configured in any one of the three views, the AP uses the default configuration in the view that has the lowest priority.
# Enter global configuration view.
wlan gps-report enable
Use wlan gps-report enable to enable GPS information reporting.
Use undo wlan gps-report enable to disable GPS information reporting.
Hardware series
Model
WA6600 series
WA6638
No
WA6638i
No
WA6636
No
WA6630X
Yes
WA6628
No
WA6628X
No
WA6628E-T
No
WA6628XM
No
WA6622
No
WA6620
No
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
No
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
No
WA6330-LI
No
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
No
WA6320H-HI
No
WA6320H-LI
No
WA6320H-XEPON
No
WAP722 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
No
GPS information reporting is disabled.
This feature enables an AP installed with GPS antennas to output GPS information at intervals and send the GPS information to the information center. For more information about the destination and output rules in the information center, see System Management Configuration Guide.
# Enable GPS information reporting.
[Sysname] wlan gps-report enable
wlan gps-report interval
Use wlan gps-report interval to set the interval at which the AP reports GPS information.
Use undo wlan gps-report interval to restore the default.
wlan gps-report interval interval
Hardware series
Model
WA6600 series
WA6638
No
WA6638i
No
WA6636
No
WA6630X
Yes
WA6628
No
WA6628X
No
WA6628E-T
No
WA6628XM
No
WA6622
No
WA6620
No
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
No
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
No
WA6330-LI
No
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
No
WA6320H-HI
No
WA6320H-LI
No
WA6320H-XEPON
No
WAP722 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
No
An AP reports GPS information every 5 seconds.
interval: Specifies an interval in the range of 1 to 100 seconds.
This feature takes effect only when GPS information reporting is enabled.
# Set the interval at which the AP reports GPS information to 1 second.
[Sysname] wlan gps-report interval 1
wlan led-mode
Use wlan led-mode to set the LED mode.
Use undo wlan led-mode to restore the default.
wlan led-mode { always-on | awake | normal | quiet }
undo wlan led-mode
The LED mode is normal.
always-on: Specifies the always-on mode. In this mode, all LEDs are steady on.
awake: Specifies the awake mode. In this mode, all the LEDs flash once every minute.
normal: Specifies the normal mode. How LEDs flash in this mode varies by AP model. For more information, see the installation guide for the AP.
quiet: Specifies the quiet mode. In this mode, all the LEDs are off.
# Set the LED mode to awake.
[Sysname] wlan led-mode awake
wlan power-level
Use wlan power-level to set the default input power level of the AP.
Use undo wlan power-level to restore the default.
wlan power-level default { high | low | middle }
undo wlan power-level default
The default input power level of the AP is middle.
high: Specifies the high default input power level.
low: Specifies the low default input power level.
middle: Specifies the middle default input power level.
Configure this command in case the AP cannot obtain its input power level at startup from the uplink switch.
The power level of an AP can be high, middle, or low. An AP automatically learns its input power level from the uplink switch at startup. If the learning operation fails, the AP operates at the input power level specified by this command.
The following table shows the relationship between the AP's power supply mode and input power level:
Power supply mode
Input power level
·     Power adapter.
·     Multiple PoE+ ports.
·     Combination of PoE and PoE+ ports.
High
·     Single PoE+ port
·     Multiple PoE ports
Middle
Single PoE port
Low
An AP's support for MIMO modes and the USB interface varies by power level, as shown in Table1-2.
Table1-2 AP's support for MIMO modes and the USB interface
Input power level
MIMO modes
Whether the USB interface can be enabled
High
1×1, 2×2, 3×3, and 4×4.
Yes.
Middle
Yes when the MIMO mode is 1×1 or 2×2.
Low
1×1.
No.
# Set the default input power level to low for the AP.
[Sysname] wlan power-level default low
wlan virtual-5g-radio enable
Support for this command depends on the AP model.
Use wlan virtual-5g-radio enable to enable 5 GHz radio virtualization.
Use undo wlan virtual-5g-radio enable to restore the default.
Hardware series
Model
WA6600 series
WA6638
No
WA6638i
No
WA6636
No
WA6630X
No
WA6628
No
WA6628X
Yes
WA6628E-T
Yes
WA6628XM
No
WA6622
No
WA6620
No
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
No
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
No
WA6330-LI
No
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
No
WA6320H-HI
No
WA6320H-LI
No
WA6320H-XEPON
No
WAP922 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
No
wlan virtual-5g-radio enable { all | ap-model ap-model }
undo wlan virtual-5g-radio enable { all | ap-model ap-model }
5 GHz radio virtualization is disabled. A 5 GHz radio will not be virtualized into two 5 GHz radios.
5 GHz radio virtualization splits the 5 GHz radio on an AP that has a 2.4 GHz radio and a 5-GHz 8 × 8 mode radio into two 5-GHz 4 × 4 mode radios. With this feature enabled, a dual-radio AP can operate in triple-radio mode.
After you enable 5 GHz radio virtualization or restore the default setting, reboot the AP for the settings to take effect.
The AP starts up with factory default configuration after it switches to triple-radio mode.
# Enable 5 GHz radio virtualization.
[Sysname] wlan virtual-5g-radio enable
Changing the status of this command will reboot the device. Continue? [Y/N]:
