06-AP Management Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Points Cloud Mode Configuration Guides(E2453 R2453)-6W10006-AP Management Configuration Guide
01-AP management configuration
01-AP management configuration 77.22 KB
1 Managing the AP
Enabling the AP to connect to an AC
After this feature is enabled, the AP will discover ACs and select an optimal AC to connect to it. If this feature is disabled, the APs that have connected to the AC will go offline.
2.     Enable the AP to connect to an AC.
wlan connect-ac enable
By default, this feature is enabled. The AP is connected to an AC.
Configuring the default input power level
The power level of the AP can be high, middle, or low. The AP automatically obtains its input power level from the uplink switch at startup. If the AP fails to obtain its input power level, the AP operates at the configured default input power level.
An AP can be powered through a power adapter or through its PoE or PoE+ ports. The following table shows the relationship between the AP's power supply mode and input power level:
Power supply mode
Input power level
·     Power adapter.
·     Multiple PoE+ ports.
·     Combination of PoE and PoE+ ports.
High
·     Single PoE+ port
·     Multiple PoE ports
Middle
Single PoE port
Low
An AP's support for MIMO modes and the USB interface varies by power level, as shown in Table1-1.
Table1-1 AP's support for MIMO modes and the USB interface
Input power level
Supported MIMO modes
Whether USB interfaces can be enabled
High
1×1, 2×2, 3×3, and 4×4.
Yes.
Middle
Yes when the MIMO mode is 1×1 or 2×2.
Low
1×1.
No.
When you configure the default input power level for the AP, make sure the setting matches its power mode. An excessively low input power level prevents the AP from operating correctly. An excessively high input power level causes overload of the AP in case of power shortage.
2.     Configure the default input power level.
Wlan power-level default { high | low | middle }
By default, the default input power level is middle.
Enabling or disabling the USB interface
After you enable the USB interface for the AP, the USB interface becomes active only when the input power level of the AP is middle or high.
If the input power level is middle, the MIMO mode can only be 1×1 or 2×2 with the USB interface enabled. With the USB interface disabled, the MIMO mode can reach 4×4.
For information about MIMO modes, see radio management in Radio Resources Configuration Guide.
The following compatibility matrix shows the support of hardware platforms for this feature:
Hardware series
Model
Feature compatibility
WA6600 series
WA6638
Yes
WA6638i
Yes
WA6636
Yes
WA6630X
No
WA6628
Yes
WA6628X
No
WA6628E-T
No
WA6628XM
No
WA6622
Yes
WA6620
Yes
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
Yes
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
Yes
WA6330-LI
Yes
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
Yes
WA6320H-HI
Yes
WA6320H-LI
Yes
WA6320H-XEPON
No
WAP922 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
Yes
2.     Enable the USB interface.
usb enable
By default, the USB interface is disabled on the AP.
Setting a LED lighting mode
You can configure LEDs on the AP to flash in the following modes:
·     quiet—All LEDs are off.
·     awake—All LEDs flash once every minute.
·     always-on—All LEDs are steady on.
·     normal—This mode can identify the running status of an AP.
2.     Set a LED lighting mode.
wlan led-mode { always-on | awake | normal | quiet }
By default, the LED lighting mode is normal.
Specifying a region code
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring the AP.
To prevent regulation violation caused by region code modification, lock the region code.
2.     Enter global configuration view.
wlan global-configuration
3.     Specify a region code.
region-code code
By default, the region code for APs in China is CN, and the region code for APs in Japan is JP. No region code is specified for APs in any other countries or regions.
4.     (Optional.) Lock the region code.
region-code-lock enable
By default, the region code is not locked.
Enabling GPS information reporting
This feature enables an AP installed with GPS antennas to output GPS information at intervals and send the GPS information to the information center. For more information about the destination and output rules in the information center, see System Management Configuration Guide.
Hardware series
Model
WA6600 series
WA6638
No
WA6638i
No
WA6636
No
WA6630X
Yes
WA6628
No
WA6628X
No
WA6628E-T
No
WA6628XM
No
WA6622
No
WA6620
No
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
No
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
No
WA6330-LI
No
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
No
WA6320H-HI
No
WA6320H-LI
No
WA6320H-XEPON
No
WAP922 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
No
2.     Enable GPS information reporting.
wlan gps-report enable
By default, GPS information reporting is disabled.
3.     Set the interval at which a fat AP reports GPS information.
wlan gps-report interval interval
By default, the interval is 5 seconds.
Enabling 5 GHz radio virtualization
Support for this feature depends on the AP model.
5 GHz radio virtualization splits the 5 GHz radio on an AP that has a 2.4 GHz radio and a 5-GHz 8 × 8 mode radio into two 5-GHz 4 × 4 mode radios. With this feature enabled, a dual-radio AP can operate in triple-radio mode.
Hardware series
Model
WA6600 series
WA6638
No
WA6638i
No
WA6636
No
WA6630X
No
WA6628
No
WA6628X
Yes
WA6628E-T
Yes
WA6628XM
No
WA6622
No
WA6620
No
WA6620X
No
WA6620X-LI
No
WA6620XE-LI
No
WA6500 series
WA6528i
No
WA6300 series
WA6338
No
WA6338-HI
No
WA6338-LI
No
WA6330
No
WA6330-LI
No
WA6322
No
WA6322H
No
WA6322H-HI
No
WA6322H-LI
No
WA6320
No
WA6320-C
No
WA6320-D
No
WA6320-HI
No
WA6320-SI
No
WA6320S-C
No
WA6320S-E
No
WA6320H
No
WA6320H-HI
No
WA6320H-LI
No
WA6320H-XEPON
No
WAP922 series
WAP922
No
WAP922E
No
WAP922H
No
WAP922X
No
WAP923 series
WAP923
No
After you enable 5 GHz radio virtualization or restore the default setting, reboot the AP for the settings to take effect.
The AP starts up with factory default configuration after it switches to triple-radio mode.
2.     Enable 5 GHz radio virtualization.
wlan virtual-5g-radio enable
By default, 5 GHz radio virtualization is disabled. A 5 GHz radio will not be virtualized into two 5 GHz radios.
