H3C SeerEngine-Campus Deployment Guide-E65XX-5W100
HomeSupportAD-NET(SDN)H3C SeerEngine-CampusInstall & UpgradeInstallation GuidesH3C SeerEngine-Campus Deployment Guide-E65XX-5W100
00-Preface
00-Preface 54.74 KB
Preface
This guide describes the procedures for installing, registering, uninstalling, and upgrading SeerEngine-Campus.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C VNF Manager app.
Conventions
This section describes the conventions used in the documentation.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
We appreciate your comments.
