HomeSupportConfigure & DeployConfiguration GuidesH3C Access Points Anchor AC Mode Configuration Guides(E2453 R2453)-6W10001-Fundamentals Configuration Guide
03-Login management configuration
03-Login management configuration 312.47 KB
1 Login overview·· 1-1
2 Using the console port for the first device access· 2-2
3 Configuring CLI login· 3-3
About CLI login· 3-3
User lines· 3-3
Login authentication modes· 3-3
User roles· 3-4
Restrictions and guidelines: CLI login configuration· 3-4
Configuring console login· 3-4
About console, AUX, and USB login· 3-4
Restrictions and guidelines· 3-5
Console login configuration tasks at a glance· 3-5
Configuring console login authentication· 3-5
Configuring common console login settings· 3-6
Configuring Telnet login· 3-8
About Telnet login· 3-8
Restrictions and guidelines· 3-8
Configuring the device as a Telnet server 3-8
Using the device to log in to a Telnet server 3-11
Configuring SSH login· 3-12
About SSH login· 3-12
Configuring the device as an SSH server 3-12
Using the device to log in to an SSH server 3-13
Display and maintenance commands for CLI login· 3-14
4 Configuring Web login· 4-15
About Web login· 4-15
Restrictions and guidelines: Web login configuration· 4-15
Web login configuration tasks at a glance· 4-15
Prerequisites for Web login· 4-15
Configuring HTTP login· 4-15
Configuring HTTPS login· 4-16
Configuring a Web login local user 4-16
Managing Web connections· 4-17
Enabling Web operation logging· 4-17
Display and maintenance commands for Web login· 4-17
Web login configuration examples· 4-18
Example: Configuring HTTP login· 4-18
5 Accessing the device through SNMP·· 5-19
6 Configuring RESTful access· 6-20
About RESTful access· 6-20
Configuring RESTful access over HTTP· 6-20
Configuring RESTful access over HTTPS· 6-20
7 Controlling user access to the device· 7-22
About login user access control 7-22
Controlling Telnet and SSH logins· 7-22
Controlling Telnet logins· 7-22
Controlling SSH logins· 7-22
Example: Controlling Telnet login· 7-23
Controlling Web logins· 7-24
Configuring source IP-based Web login control 7-24
Example: Controlling Web login· 7-24
Controlling SNMP access· 7-25
About SNMP access control 7-25
Example: Controlling SNMP access· 7-25
Configuring command authorization· 7-26
About command authorization· 7-26
Restrictions and guidelines· 7-26
Procedure· 7-27
Example: Configuring command authorization· 7-27
Configuring command accounting· 7-29
About command accounting· 7-29
Restrictions and guidelines· 7-29
Procedure· 7-30
Example: Configuring command accounting· 7-30
1 Login overview
The device supports the following types of login methods:
·     CLI loginAt the CLI, you can enter text commands to configure and manage the device.
To log in to the CLI, you can use one of the following methods:
¡     Connect to the console port.
¡     Use Telnet.
¡     Use SSH.
·     Web loginThrough the Web interface, you can configure and manage the device visually.
·     SNMP accessYou can run SNMP on an NMS to access the device MIB, and perform Get and Set operations to configure and manage the device.
·     RESTful accessYou can use RESTful API operations to configure and manage the device.
The first time you access the device, you can only log in to the CLI through the console port unless the device is automatically configured at startup. After login, you can change console login parameters or configure other access methods.
Console login is the fundamental login method.
To log in through the console port, prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
1.     Turn off the PC.
The serial ports on PCs do not support hot swapping. Before connecting a cable to or disconnecting a cable from a serial port on a PC, you must turn off the PC.
2.     Find the console cable shipped with the device and connect the DB-9 female connector of the console cable to the serial port of the PC.
3.     Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure2-1 Connecting a terminal to the console port
4.     Turn on the PC.
5.     On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
¡     Bits per second—9600 bps.
¡     Flow control—None.
¡     Parity—None.
¡     Stop bits—1.
¡     Data bits—8.
6.     Power on the device and press Enter as prompted.
The user view prompt appears. You can enter commands to configure or manage the device. To get help, enter a question mark (?).
About CLI login
The device uses user lines (also called user interfaces) to manage CLI sessions and monitor user behavior. For a user line, you can configure access control settings, including the login authentication method and user roles.
User lines
User line types
The device supports the following types of user lines, and different user lines require different login methods:
·     Console line: Console port.
·     Virtual type terminal (VTY) line: Telnet or SSH.
User line numbering
A user line has an absolute number and a relative number.
An absolute number uniquely identifies a user line among all user lines. The user lines are numbered starting from 0 and incrementing by 1, in the sequence of console and VTY lines. You can use the display line command without any parameters to view supported user lines and their absolute numbers.
A relative number uniquely identifies a user line among all user lines of the same type. The number format is user line type + number. All types of user lines are numbered starting from 0 and incrementing by 1. For example, the first VTY line is VTY 0.
User line assignment
The device assigns user lines to CLI login users depending on their login methods. When a user logs in, the device checks the idle user lines for the login method, and assigns the lowest numbered user line to the user. For example, if VTY 0 and VTY 3 are idle when a user Telnets to the device, the device assigns VTY 0 to the user.
Each user line can be assigned only to one user at a time. If no user line is available, a CLI login attempt will be rejected.
You can configure login authentication to prevent illegal access to the device CLI.
The device supports the following login authentication modes:
·     None—Disables authentication. This mode allows access without authentication and is insecure.
·     Password—Requires password authentication. A user must provide the correct password at login.
·     Scheme—Uses the AAA module to provide local or remote login authentication. A user must provide the correct username and password at login.
Different login authentication modes require different user line configurations, as shown in Table3-1.
Table3-1 Configuration required for different login authentication modes
Authentication mode
Configuration tasks
None
Set the authentication mode to none.
Password
1.     Set the authentication mode to password.
2.     Set a password.
Scheme
1.     Set the authentication mode to scheme.
2.     Configure login authentication methods in ISP domain view. For more information, see Security Configuration Guide.
User roles
A user is assigned user roles at login. The user roles control the commands available for the user. For more information about user roles, see "Configuring RBAC."
The device assigns user roles based on the login authentication mode and user type.
·     In none or password authentication mode, the device assigns the user roles specified for the user line.
·     In scheme authentication mode, the device uses the following rules to assign user roles:
¡     For an SSH login user who uses publickey or password-publickey authentication, the device assigns the user roles specified for the local device management user with the same name.
¡     For other users, the device assigns user roles according to the user role configuration of the AAA module. If the AAA server does not assign any user roles and the default user role feature is disabled, a remote AAA authentication user cannot log in.
For commands that are available in both user line view and user line class view, the following rules apply:
·     A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
·     A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
·     A setting in user line class view takes effect only on users who log in after the setting is made. It does not affect users who are already online when the setting is made.
You can connect a terminal to the console port of the device to log in and manage the device, as shown in Figure3-1. For information about the login procedure, see "Using the console port for the first device access."
Figure3-1 Logging in through the console port
By default, console login is enabled and does not require authentication. The default user role is network-admin for a console user. To improve device security, configure password or scheme authentication for console login immediately after you log in to the device for the first time.
A console login configuration change takes effect only for users who log in after the change is made. It does not affect users who are already online when the change is made.
To configure console login, perform the following tasks:
1.     Configuring console login authentication
¡     Disabling authentication for console login
¡     Configuring password authentication for console login
¡     Configuring scheme authentication for console login
2.     (Optional.) Configuring common console login settings
2.     Enter Console line view or class view.
¡     Enter console line view.
line console first-number [ last-number ]
¡     Enter console line class view.
line class console
3.     Disable authentication.
authentication-mode none
By default, authentication is disabled for console login.
4.     Assign a user role.
user-role role-name
By default, a console user is assigned the network-admin user role.
¡     Enter console class view.
line class console
3.     Enable password authentication.
authentication-mode password
4.     Set a password.
set authentication password { hash | simple } string
By default, no password is set.
5.     Assign a user role.
user-role role-name
line class console
3.     Enable scheme authentication.
authentication-mode scheme
4.     Configure user authentication parameters in ISP domain view.
To use local authentication, configure a local user and set the relevant attributes. To use remote authentication, configure a RADIUS or HWTACACS scheme. For more information, see AAA in User Access and Authentication Configuration Guide.
Some common console login settings take effect immediately and can interrupt the current session. Use a login method different from console login to log in to the device before you change console login settings.
After you change console login settings, adjust the settings on the configuration terminal accordingly for a successful login.
line class console
3.     Configure terminal attributes.
¡     Enable the terminal service.
shell
Be default, the terminal service is enabled on all user lines.
The undo shell command is not available in console line view.
¡     Specify the terminal display type.
By default, the terminal display type is ANSI.
The device supports ANSI and VT100 terminal display types. As a best practice, specify VT100 type on both the device and the configuration terminal. You can also specify the ANSI type for both sides, but a display problem might occur if a command line has more than 80 characters.
¡     Set the maximum number of lines of command output to send to the terminal at a time.
screen-length screen-length
By default, the device sends a maximum of 24 lines to the terminal at a time.
To disable pausing between screens of output, set the value to 0.
¡     Set the size for the command history buffer.
history-command max-size value
By default, the buffer size is 10. The buffer for a user line can save a maximum of 10 history commands.
¡     Set the CLI connection idle-timeout timer.
By default, the CLI connection idle-timeout timer is 10 minutes.
If no interaction occurs between the device and the user within the idle-timeout interval, the system automatically terminates the user connection on the user line.
If you set the timeout timer to 0, the connection will not be aged out.
4.     Specify the command to be automatically executed for login users on the lines.
auto-execute command command
By default, no command is specified for auto execution.
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
This command is not available in console line view or console line class view.
5.     Configure shortcut keys.
¡     Specify the terminal session activation key.
activation-key character
By default, pressing Enter starts the terminal session.
¡     Specify the escape key.
escape-key { key-string | default }
By default, pressing Ctrl+C terminates a command.
¡     Set the user line locking key.
lock-key key-string
By default, no user line locking key is set.
About Telnet login
The device can act as a Telnet server to allow Telnet login, or as a Telnet client to Telnet to other devices.
A Telnet login configuration change takes effect only on users who log in after the change is made. It does not affect users who are already online when the change is made.
Telnet server configuration tasks at a glance
To configure the device as a Telnet server, perform the following tasks:
1.     Enabling the Telnet server
2.     Configuring Telnet login authentication
¡     Disabling authentication for Telnet login
¡     Configuring password authentication for Telnet login
¡     Configuring scheme authentication for Telnet login
3.     (Optional.) Configuring common Telnet server settings
4.     (Optional.) Configuring common VTY line settings
2.     Enable the Telnet server.
telnet server enable
By default, the Telnet server is disabled.
2.     Enter VTY line view or class view.
¡     Enter VTY line view.
line vty first-number [ last-number ]
¡     Enter VTY line class view.
line class vty
By default, password authentication is enabled for Telnet login.
In VTY line view, this command is associated with the protocol inbound command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
4.     (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user is assigned the network-operator user role.
line class vty
4.     Set a password.
set authentication password { hash | simple } password
5.     (Optional.) Assign a user role.
user-role role-name
line class vty
2.     Set the DSCP value for outgoing Telnet packets.
IPv4:
telnet server dscp dscp-value
IPv6:
By default, the DSCP value is 48.
3.     Specify the Telnet service port number.
IPv4:
IPv6:
By default, the Telnet service port number is 23.
4.     Set the maximum number of concurrent Telnet users.
aaa session-limit telnet max-sessions
By default, the maximum number of concurrent Telnet users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online Telnet users, no additional users can Telnet in until the number drops below the new limit.
For more information about this command, see User Access and Authentication Command Reference.
line class vty
3.     Configure VTY terminal attributes.
shell
By default, the terminal service is enabled on all user lines.
4.     Specify the supported protocols.
By default, Telnet and SSH are supported.
A protocol change takes effect only on users who log in after the setting is made. It does not affect users who are already online when the setting is made.
In VTY line view, this command is associated with the authentication-mode command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
5.     Specify the command to be automatically executed for login users on the user lines.
IMPORTANT
IMPORTANT:
Before you execute this command and save the configuration, make sure you can access the CLI to modify the configuration through other VTY lines.
For a VTY line, you can specify a command that is to be automatically executed when a user logs in. After executing the specified command, the system automatically disconnects the Telnet session.
6.     Configure shortcut keys.
¡     Specify the shortcut key for terminating a task.
escape-key { character | default }
The default setting is Ctrl+C.
lock-key key-string
You can use the device as a Telnet client to log in to a Telnet server.
Figure3-2 Telnetting from the device to a Telnet server
Assign an IP address to the device and obtain the IP address of the Telnet server. If the device resides on a different subnet than the Telnet server, make sure the device and the Telnet server can reach each other.
2.     (Optional.) Specify the source IPv4 address or source interface for outgoing Telnet packets.
By default, no source IPv4 address or source interface is specified. The device uses the primary IPv4 address of the output interface as the source address for outgoing Telnet packets.
3.     Exit to user view.
4.     Use the device to log in to a Telnet server.
IPv4:
telnet remote-host [ service-port ] [ source { interface interface-type interface-number | ip ip-address } ] [ dscp dscp-value ] [ escape character ]
IPv6:
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ] [ dscp dscp-value ] [ escape character ]
About SSH login
SSH offers a secure remote login method. By providing encryption and strong authentication, it protects devices against attacks such as IP spoofing and plaintext password interception. For more information, see Security Configuration Guide.
The device can act as an SSH server to allow Telnet login, or as an SSH client to log in to an SSH server.
This section provides the SSH server configuration procedure used when the SSH client authentication method is password. For more information about SSH and publickey authentication configuration, see Security Configuration Guide.
2.     Create local key pairs.
public-key local create { dsa | ecdsa secp256r1 | rsa }
3.     Enable the SSH server.
ssh server enable
By default, the SSH server is disabled.
4.     (Optional.) Create an SSH user and specify the authentication mode.
ssh user username service-type stelnet authentication-type password
5.     Enter VTY line view or class view.
line class vty
6.     Enable scheme authentication.
By default, password authentication is enabled for VTY lines.
7.     (Optional.) Specify the protocols for the user lines to support.
8.     (Optional.) Set the maximum number of concurrent SSH users.
By default, the maximum number of concurrent SSH users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online SSH users, no additional SSH users can log in until the number drops below the new limit.
9.     (Optional.) Configure common settings for VTY lines:
a.     Return to system view.
b.     Configure common settings for VTY lines.
See "Configuring common VTY line settings."
You can use the device as an SSH client to log in to an SSH server.
Figure3-3 Logging in to an SSH server from the device
Assign an IP address to the device and obtain the IP address of the SSH server. If the device resides on a different subnet than the SSH server, make sure the device and the SSH server can reach each other.
To use the device to log in to an SSH server, execute one of the following commands in user view:
IPv4:
ssh2 server
IPv6:
ssh2 ipv6 server
To work with the SSH server, you might need to specify a set of parameters. For more information, see Security Configuration Guide.
Remarks
Display user line information.
display line [ num1 | { console | vty } num2 ] [ summary ]
N/A
Display the packet source setting for the Telnet client.
display telnet client
N/A
Display online CLI users.
display users [ all ]
N/A
Release a user line.
free line { num1 | { console | vty } num2 }
Multiple users can log in to the device to simultaneously configure the device. When necessary, you can execute this command to release some connections.
You cannot use this command to release the connection you are using.
This command is available in user view.
Lock the current user line and set the password for unlocking the line.
lock
By default, the system does not lock any user lines.
Lock the current user line and enable unlocking authentication.
lock reauthentication
By default, the system does not lock any user lines or initiate reauthentication.
To unlock the locked user line, you must press Enter and provide the login password to pass reauthentication.
This command is available in any view.
Send messages to user lines.
send { all | num1 | { console | vty } num2 }
About Web login
The device provides a built-in Web server that supports HTTP 1.0, HTTP 1.1, and HTTPS. You can use a Web browser to log in to and configure the device.
HTTPS uses SSL to ensure the integrity and security of data exchanged between the client and the server, and is more secure than HTTP. You can define a certificate-based access control policy to allow only legal clients to access the Web interface.
To improve device security, the system automatically enables the HTTPS service when you enable the HTTP service. When the HTTP service is enabled, you cannot disable the HTTPS service.
To configure Web login, perform the following tasks:
1.     Configuring Web login
¡     Configuring HTTP login
¡     Configuring HTTPS login
2.     Configuring a Web login local user
3.     Managing Web connections
4.     Enabling Web operation logging
Before logging in to the Web interface of device, log in to the device by using any other method and assign an IP address to the device. Make sure the configuration terminal and the device can communicate over the IP network.
1.     (Optional.) Specify a fixed verification code for Web login.
web captcha verification-code
By default, no fixed verification code is specified. A Web user must enter the verification code displayed on the login page at login.
Execute this command in user view.
2.     Enter system view.
3.     Enable the HTTP service.
ip http enable
By default, the HTTP service is disabled.
4.     (Optional.) Specify the HTTP service port number.
ip http port port-number
The default HTTP service port number is 80.
5.     (Optional.) Specify the HTTP methods to be added to the reply to an OPTIONS request.
By default, no HTTP methods are specified.
In HTTPS login mode, the device uses a self-signed certificate (a certificate that is generated and signed by the device itself). To use the HTTPS login mode, you must enable HTTPS service on the device.
By default, no fixed verification code is configured. A Web user must enter the verification code displayed on the login page at login.
3.     Enable the HTTPS service.
ip https enable
By default, the HTTPS service is disabled.
4.      (Optional.) Specify the HTTPS service port number.
ip https port port-number
The default HTTPS service port number is 443.
5.     (Optional.) Set the HTTPS login authentication mode.
By default, manual authentication mode is used for HTTPS login.
2.     Create a local user and enter local user view.
3.     (Optional.) Configure a password for the local user.
By default, no password is configured for a local user. The local user can pass authentication after entering the correct username and passing attribute checks.
4.     Configure user attributes.
¡     Assign a user role to the local user.
The default user role is network-operator for a Web user.
¡     Specify the service type for the local user.
service-type { http | https }
By default, no service type is specified for a local user.
Setting the Web connection idle-timeout timer
2.     Set the Web connection idle-timeout timer.
web idle-timeout minutes
By default, the Web connection idle-timeout timer is 10 minutes.
Specifying the maximum number of online HTTP or HTTPS users
2.     Specify the maximum number of online HTTP or HTTPS users.
aaa session-limit { http | https } max-sessions
By default, the device supports a maximum number of 32 online HTTP users and 32 online HTTPS users.
Changing this setting does not affect users who are currently online. If the new setting is less than the number of online HTTP or HTTPS users, no additional HTTP or HTTPS users can log in until the number drops below the new limit. For more information about this command, see User Access and Authentication Command Reference.
Logging off Web users
To log off Web users, execute the following command in user view:
2.     Enable Web operation logging.
webui log enable
By default, Web operation logging is disabled.
Execute display commands in any view and the free web users command in user view.
Display HTTP service configuration and status information.
display ip http
Display HTTPS service configuration and status information.
display ip https
Display Web interface navigation tree information.
display web menu [ chinese ]
Display online Web users.
display web users
Log off online Web users.
As shown in Figure4-1, the host and the AC can communicate over the IP network.
Configure the AC to allow the host to log in by using HTTP.
Figure4-1 Network diagram
# Create VLAN-interface 100 and assign IP address 192.168.100.99/24 to the interface. (Details not shown.)
# Create a local user named admin. Set the password to admin, the service type to HTTP, and the user role to network-admin.
<AC> system-view
[AC] local-user admin
[AC-luser-manage-admin] service-type http
[AC-luser-manage-admin] authorization-attribute user-role network-admin
[AC-luser-manage-admin] password simple admin
[AC-luser-manage-admin] quit
# Enable HTTP.
[AC] ip http enable
1.     On the host, run a Web browser and enter the IP address of the device in the address bar.
The Web login page appears.
2.     Enter the username and password. Click Login.
After you pass authentication, the homepage appears and you can configure the AC.
You can run SNMP on an NMS to access the device MIB and perform Get and Set operations to configure and manage the device.
Figure5-1 SNMP access diagram
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
·     Send RESTful requests to the device to pass authentication.
·     Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
2.     Enable RESTful access over HTTP.
restful http enable
By default, RESTful access over HTTP is disabled.
3.     Create a local user and enter local user view.
4.     Configure a password for the local user.
5.     (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful access user.
6.     Specify the HTTP service for the local user.
service-type http
2.     Enable RESTful access over HTTPS.
restful https enable
By default, RESTful access over HTTPS is disabled.
6.     Specify the HTTPS service for the local user.
service-type https
You can use ACLs to prevent unauthorized access. To control user access, specify an existing ACL that has rules so only users permitted by the ACL can access the device.
·     If no ACL is applied, all users can access the device.
·     If the ACL for Web user access control does not exist or does not have rules, all Web users can access the device.
·     If the ACL for Telnet, SSH, or SNMP access control does not exist or does not have rules, no Telnet, SSH, or SNMP users can access the device.
For more information about ACLs, see Security Configuration Guide.
To monitor and control user behavior, configure command authorization and accounting.
2.     Apply an ACL to control Telnet logins.
IPv4:
telnet server acl [ mac ] acl-number
IPv6:
telnet server ipv6 acl { ipv6 | mac } acl-number
By default, no ACL is used to control Telnet logins.
3.     (Optional.) Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
telnet server acl-deny-log enable
By default, logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
2.     Apply an ACL to control SSH logins.
IPv4:
IPv6:
By default, no ACL is used to control SSH logins.
3.     (Optional.) Enable logging for SSH login attempts that are denied by the SSH login control ACL.
By default, logging is disabled for SSH login attempts that are denied by the SSH login control ACL.
For more information about ssh commands, see SSH in Security Command Reference.
As shown in Figure7-1, the AC is a Telnet server.
Configure the AC to permit only Telnet packets sourced from Host B.
Figure7-1 Network diagram
# Configure an ACL to permit packets sourced from Host B.
<AC> system-view
[AC] acl basic 2000 match-order config
[AC-acl-ipv4-basic-2000] rule 1 permit source 10.110.100.52 0
[AC-acl-ipv4-basic-2000] quit
# Enable the Telnet server and apply the ACL to filter Telnet logins.
[AC] telnet server enable
[AC] telnet server acl 2000
# Log in to Telnet server 10.110.110.66 from Host B.
C:> telnet 10.110.110.66
Trying 10.110.110.66 ...
Press CTRL+K to abort
Connected to 10.110.110.66 ...
* Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.*
<AC>
The output shows that you can log in to the Telnet server from Host B.
# Log in to Telnet server 10.110.110.66 from Host A.
C:\> telnet 10.110.110.66
Failed to connect to the remote host!
The output shows that you cannot log in to the Telnet server from Host A.
2.     Apply a basic ACL to control Web logins.
¡     Control HTTP logins.
ip http acl [ advanced | mac ] { acl-number | name acl-name }
¡     Control HTTPS logins.
ip https acl [ advanced | mac ] {acl-number | name acl-name }
By default, no ACL is applied to control Web logins.
As shown in Figure7-2, the AC is an HTTP server.
Configure the AC to provide HTTP service only to Host B.
Figure7-2 Network diagram
# Create an ACL and configure rule 1 to permit packets sourced from Host B.
<AC> system-view
[AC] acl basic 2030 match-order config
[AC-acl-ipv4-basic-2030] rule 1 permit source 10.110.100.52 0
[AC-acl-ipv4-basic-2030] quit
# Enable the HTTP service and apply the ACL to the HTTP service so only a Web user on Host B can access the AC.
[AC] ip http enable
[AC] ip http acl 2030
# Verify that you can log in to HTTP server 10.110.110.66 from Host B.
1.     On Host B, launch a Web browser and enter http://10.110.110.66 in the address bar.
# Verify that you cannot log in to HTTP server 10.110.110.66 from Host A.
1.     On Host A, launch a Web browser and enter http://10.110.110.66 in the address bar.
You cannot pass authentication.
For information about SNMP access control, see SNMP in Network Management and Monitoring Configuration Guide.
As shown in Figure7-3, the AC is running SNMP.
Configure the AC to allow Host A and Host B to access the AC through SNMP.
Figure7-3 Network diagram
# Create an ACL to permit packets sourced from Host A and Host B.
<AC> system-view
[AC-acl-ipv4-basic-2000] rule 2 permit source 10.110.100.46 0
# Enable the SNMP agent, configure SNMP user usera, and associate the ACL with the SNMP community and the SNMP group.
[AC] snmp-agent
[AC] snmp-agent community read aaa acl 2000
[AC] snmp-agent group v2c groupa acl 2000
[AC] snmp-agent usm-user v2c usera groupa acl 2000
# Access the AC from the NMS at 10.110.100.52 or 10.110.100.46. You can access the AC. (Details not shown.)
# Access the AC from any other NMS. You cannot access the AC. (Details not shown.)
By default, commands available for a user depend only on the user's user roles. When the authentication mode is scheme, you can configure the command authorization feature to further control access to commands. After you enable command authorization, a user can use only commands that are permitted by both the AAA scheme and user roles.
The command authorization method can be different from the user login authorization method.
For the command authorization feature to take effect, you must configure a command authorization method in ISP domain view. For more information, see AAA in User Access and Authentication Configuration Guide.
2.     Enter user line view or user line class view.
¡     Enter user line view.
line { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
¡     Enter user line class view.
line class { console | vty }
A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class. A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
By default, authentication is disabled for console login and password authentication is enabled for VTY login.
4.     Enable command authorization.
By default, command authorization is disabled, and the commands available for a user only depend on the user role.
If the command authorization command is executed in user line class view, command authorization is enabled on all user lines in the class. You cannot execute the undo command authorization command in the view of a user line in the class.
As shown in Figure7-4, a user needs to log in to the AC to manage the AC from Host A.
Configure the AC to perform the following operations:
·     Allow Host A to Telnet in after authentication.
·     Use the HWTACACS server to control the commands that the user can execute.
·     Use local authorization if the HWTACACS server is not available.
Figure7-4 Network diagram
# Assign IP addresses to relevant interfaces. Make sure the AC and the HWTACACS server can reach each other, and the AC and Host A can reach each other. (Details not shown.)
# Enable the Telnet server.
<AC> system-view
# Enable scheme authentication for user lines VTY 0 through VTY 4.
[AC] line vty 0 4
[AC-line-vty0-4] authentication-mode scheme
# Enable command authorization for the user lines.
[AC-line-vty0-4] command authorization
[AC-line-vty0-4] quit
# Create HWTACACS scheme tac.
[AC] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication and authorization.
[AC-hwtacacs-tac] primary authentication 192.168.2.20 49
[AC-hwtacacs-tac] primary authorization 192.168.2.20 49
# Set the shared keys to expert.
[AC-hwtacacs-tac] key authentication simple expert
[AC-hwtacacs-tac] key authorization simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[AC-hwtacacs-tac] user-name-format without-domain
[AC-hwtacacs-tac] quit
# Configure the system-defined domain (system).
[AC] domain system
# Use scheme tac for login user authentication and command authorization. Use local authentication and local authorization as the backup method.
[AC-isp-system] authentication login hwtacacs-scheme tac local
[AC-isp-system] authorization command hwtacacs-scheme tac local
[AC-isp-system] quit
# Create local user monitor. Set the simple password to 123, the service type to Telnet, and the default user role to level-1.
[AC] local-user monitor
[AC-luser-manage-monitor] password simple 123
[AC-luser-manage-monitor] service-type telnet
[AC-luser-manage-monitor] authorization-attribute user-role level-1
# Telnet to AC 10.110.100.77 from Host A. After login, execute the ip http enable command. Because you are not authorized to execute the command, the system displays Permission denied.
C:\> telnet 10.110.100.77
Trying 10.110.100.77 ...
Connected to 10.110.100.77 ...
login: monitor
Password:
<AC> system-view
[AC] ip http enable
Permission denied.
[AC]
# Execute the interface command. Because you are authorized to execute the command, you enter the interface view.
[AC-GigabitEthernet1/0/1]
Command accounting uses the HWTACACS server to record all executed commands to monitor user behavior on the device.
If command accounting is enabled but command authorization is not, every executed command is recorded. If both command accounting and command authorization are enabled, only authorized commands that are executed are recorded.
The command accounting method can be the same as or different from the command authorization method and user login authorization method.
For the command accounting feature to take effect, you must configure a command accounting method in ISP domain view. For more information, see AAA in User Access and Authentication Configuration Guide.
By default, authentication is disabled for console login, and password authentication is enabled for VTY login.
4.     Enable command accounting.
command accounting
By default, command accounting is disabled. The accounting server does not record the commands executed by users.
If the command accounting command is executed in user line class view, command accounting is enabled on all user lines in the class. You cannot execute the undo command accounting command in the view of a user line in the class.
As shown in Figure7-5, users need to log in to the AC to manage the AC.
Configure the AC to send commands executed by users to the HWTACACS server to monitor and control user operations on the AC.
Figure7-5 Network diagram
<AC> system-view
# Enable command accounting for user line console 0.
[AC] line console 0
[AC-line-console0] command accounting
[AC-line-console0] quit
# Enable command accounting for user lines VTY 0 through VTY 4.
[AC] line vty 0 4
[AC-line-vty0-4] command accounting
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for accounting.
[AC-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared key to expert.
[AC-hwtacacs-tac] key accounting simple expert
# Configure the system-defined domain (system) to use the HWTACACS scheme for command accounting.
[AC] domain system
[AC-isp-system] accounting command hwtacacs-scheme tac
Use each host as a Telnet or SSH client to log in to the AC respectively, and perform VLAN and interface configuration. The accounting server processes accounting packets from the hosts as defined by the accounting settings.
