- 06-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-AFT commands
- 07-Fast forwarding commands
- 08-Multi-CPU packet distribution commands
- 09-Adjacency table commands
- 10-IPv6 fast forwarding commands
- 11-Tunneling commands
- 12-GRE commands
- 13-IPv6 basics commands
- 14-IP performance optimization commands
- 15-IP forwarding basics commands
- 16-WAAS commands
| 07-Fast forwarding commands | 63.94 KB |
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
ip fast-forwarding load-sharing
reset ip fast-forwarding cache
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
context-admin
context-operator
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
Aging time: 30s
Use display ip fast-forwarding cache to display fast forwarding entries.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays all fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for all member devices.
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If Output_If Flg
7.0.0.13 68 8.0.0.1 67 17 GE1/0/3 GE1/0/1 5
SIP |
Source IP address. |
SPort |
Source port number. |
DIP |
Destination IP address. |
DPort |
Destination port number. |
Pro |
Protocol number. |
Input_If |
Input interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the input interface does not exist, this field displays a hyphen (-). |
Output_If |
Output interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the output interface does not exist, this field displays a hyphen (-). |
Flg |
Internal tag, marking internal operation information, such as fragmentation. |
Use display ip fast-forwarding fragcache to display fast forwarding entries for fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
context-admin
context-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for fragmented packets on all member devices.
# Display fast forwarding entries about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If ID Relay_flag
7.0.0.13 68 8.0.0.1 67 17 GE1/0/3 2 1
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
Input_If |
ID |
Fragment ID. |
Relay_flag |
Fragment pass-through flag: · 0—Not pass through. · 1—Pass through. |
Use ip fast-forwarding aging-time to configure the aging time for fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time is 30 seconds.
context-admin
aging-time: Specifies the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for fast forwarding entries.
[Sysname] ip fast-forwarding aging-time 20
ip fast-forwarding dscp
Use ip fast-forwarding dscp to enable DSCP-based fast forwarding for GRE and VXLAN packets.
Use undo ip fast-forwarding dscp to restore the default.
DSCP-based fast forwarding for GRE and VXLAN packets is disabled.
context-admin
This command is applicable to GRE packets (with IP as the passenger protocol) and VXLAN packets that are processed by software.
This feature uses the DSCP value in the outer header instead of the source port number among the identification criteria to identify GRE and VXLAN traffic flows.
This command is mutually exclusive with NAT and load balancing.
# Enable DSCP-based GRE and VXLAN packet fast forwarding.
[Sysname] ip fast-forwarding dscp
Use ip fast-forwarding load-sharing to enable fast forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast forwarding load sharing.
Fast forwarding load sharing is enabled.
context-admin
Fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
ip fast-forwarding vxlan-port
Use ip fast-forwarding vxlan-port to specify the destination UDP port number for identifying VXLAN packets.
Use undo ip fast-forwarding vxlan-port to restore the default.
ip fast-forwarding vxlan-port port-number
The destination UDP port number is 4789.
Predefined use roles
context-admin
port-number: Specifies a UDP port number in the range of 1 to 65535.
This feature is applicable to only the UDP packets that are processed by software.
In a VXLAN network, configure this command on intermediate devices to identify VXLAN packets.
# Specify the destination UDP port number to 4900 for identifying VXLAN packets.
[Sysname] ip fast-forwarding vxlan-port 4900
Use reset ip fast-forwarding cache to clear the fast forwarding table.
reset ip fast-forwarding cache [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears the fast forwarding table for all member devices.
# Clear the fast forwarding table.
<Sysname> reset ip fast-forwarding cache
