- 04-DPI Configuration Guide
- 01-DPI overview
- 02-DPI engine configuration
- 03-IPS configuration
- 04-URL filtering configuration
- 05-Data filtering configuration
- 06-File filtering configuration
- 07-Anti-virus configuration
- 08-Data analysis center configuration
- 09-WAF configuration
- 10-Proxy policy configuration
| 02-DPI engine configuration | 171.20 KB |
Restrictions: Hardware compatibility with the DPI engine
Configure a DPI application profile
Activating policy and rule settings for DPI service modules
Configuring action parameter profiles
Configuring a block source parameter profile
Configuring a capture parameter profile
Configuring a logging parameter profile
Configuring a redirect parameter profile
Configuring an email parameter profile
Enabling inspection suspension upon excessive CPU usage
Configuring DPI engine inspection parameters
Configuring an inspection mode
Configuring stream fixed length inspection
Configuring file fixed length inspection
Configuring MD5 fixed-length file inspection
Configuring MD5 hash-based virus inspection for all files
Setting the maximum data size for file decompression
Configuring advanced features of the DPI engine
Enabling source port-based application identification
Specifying a proxy server for online DPI service signature update
Specifying the cloud query server for DPI services
Enabling support for HA dual-active mode
Display and maintenance commands for DPI engine
About DPI engine
DPI engine is an inspection module shared by DPI service modules. DPI engine uses inspection rules to identify the application layer information, including the application layer protocol and behavior. DPI service modules process packets based on the inspection results.
DPI functions
DPI engine provides the following functions:
· Protocol parsing—Identifies the application layer protocols and analyzes the application layer information. Information analysis includes recognizing, normalizing, and uncompressing application layer fields.
· AC pattern matching—Matches packet payloads by the Aho-Corasick (AC) patterns in inspection rules. AC pattern matching is fast and it is the core function of the DPI engine.
· Option matching—Matches packet payloads by the options in the inspection rules whose AC patterns have been matched. Option matching is slower than AC pattern matching.
DPI engine inspection rules
DPI engine uses inspection rules to match packets. Inspection rules are transformed from the rules or signatures of the DPI service modules. The match criteria in an inspection rule can contain the following types:
· AC pattern—Criteria that identify packet signatures. An AC pattern is a character string that is three or more bytes long.
· Option—Criteria other than AC patterns. For example, an option can be the port number or protocol type.
An inspection rule can contain both AC patterns and options. A packet must match both the AC patterns and options to match the rule.
An inspection rule can also contain only options. A packet matches the rule if it matches the options in the rule.
DPI engine mechanism
As shown in Figure 1, DPI engine works as follows:
1. The DPI engine performs protocol parsing for the packet and searches for applicable inspection rules according to the parsing results.
2. If an applicable inspection rule contains AC patterns, DPI engine performs AC pattern matching first. If an applicable inspection rule does not contain AC patterns, DPI engine directly performs option matching. The packet matches the rule if it matches the options.
3. If the packet matches an AC pattern in an applicable inspection rule, the DPI engine further compares the packet against the options associated with the AC pattern. The packet matches the rule if it matches the both the AC pattern and its associated options. If the packet matches an AC pattern but does not match its associated options, the DPI engine permits the packet to pass.
4. If the packet matches an inspection rule, the DPI engine submits the packet to the corresponding DPI service module for processing. If the packet does not match any rule, the DPI engine permits the packet to pass.
Hardware platform |
Module type |
DPI engine compatibility |
M9006 M9010 M9014 |
Blade IV firewall module |
Yes |
Blade V firewall module |
Yes |
NAT module |
No |
Application delivery engine (ADE) module |
Yes |
Anomaly flow cleaner (AFC) module |
No |
M9010-GM |
Encryption module |
Yes |
M9016-V |
Yes |
M9008-S M9012-S |
Yes |
Yes |
Intrusion prevention service (IPS) module |
Yes |
Video network gateway module |
Yes |
No |
M9008-S-6GW |
IPv6 module |
Yes |
M9008-S-V |
Yes |
M9000-AI-E8 |
Yes |
Yes |
M9000-AI-E16 |
Yes |
DPI engine tasks at a glance
To configure the DPI engine, perform the following tasks:
1. Configure a DPI application profile
2. Activating policy and rule settings for DPI service modules
3. Configuring action parameter profiles
4. (Optional.) Optimizing the DPI engine
5. (Optional.) Enabling inspection suspension upon excessive CPU usage
6. (Optional.) Configuring DPI engine inspection parameters
¡ Configuring an inspection mode
¡ Configuring stream fixed length inspection
¡ Configuring file fixed length inspection
¡ Configuring MD5 fixed-length file inspection
¡ Configuring MD5 hash-based virus inspection for all files
¡ Setting the maximum data size for file decompression
7. (Optional.) Configuring advanced features of the DPI engine
¡ Enabling source port-based application identification
¡ Specifying a proxy server for online DPI service signature update
¡ Specifying the cloud query server for DPI services
¡ Enabling support for HA dual-active mode
8. (Optional.) Disabling the DPI engine
A DPI application profile includes a set of DPI service policies, such as a URL filtering policy. It can be applied to an object policy rule or a security policy rule to specify the DPI service policy for packets that match the rule.
1. Enter system view.
2. Create a DPI application profile and enter its view.
app-profile profile-name
3. Apply DPI service policies to the DPI application profile.
¡ Specify an IPS policy.
ips apply policy policy-name mode { protect | alert }
For more information about this command, see IPS commands in DPI Command Reference.
¡ Specify a URL filtering policy.
url-filter apply policy policy-name
For more information about this command, see URL filtering commands in DPI Command Reference.
¡ Specify a data filtering policy.
data-filter apply policy policyname
For more information about this command, see data filtering commands in DPI Command Reference.
¡ Specify a file filtering policy.
file-filter apply policy policyname
For more information about this command, see file filtering commands in DPI Command Reference.
¡ Specify an anti-virus policy.
anti-virus apply policy policyname mode { alert | protect }
For more information about this command, see anti-virus commands in DPI Command Reference.
¡ Specify a WAF policy.
waf apply policy policy-name mode { protect | alert }
By default, no DPI service policies are applied to a DPI application profile.
By default, when a configuration change to the policies and rules for DPI service modules (such as URL filtering module) occurs, the system detects whether another configuration change occurs at 20-second intervals.
· If no configuration change occurs during an interval, the system performs an activation operation at the end of the next interval.
· If another configuration change occurs during an interval, the system continues to detect configuration changes.
To immediately activate a configuration change, execute the inspect activate command.
This task can cause temporary service outage. As a best practice, perform the task after the configuration of all DPI service policies and rules is complete.
2. Activate policy and rule settings for DPI service modules.
inspect activate
By default, configuration changes to DPI service policies and rules will be automatically activated.
CAUTION: This command causes transient DPI service interruption. DPI-based services might also be interrupted. For example, security policies cannot control access to applications. |
A block source parameter profile defines the block period for the block source action in DPI service modules.
The block source action takes effect only after the blacklist feature is enabled.
With the blacklist feature is enabled, the device drops the matching packet and adds the packet's source IP address to the IP blacklist. Subsequent packets from the source IP address will be dropped directly during the block period.
For more information about the blacklist feature, see attack detection and prevention configuration in the Security Configuration Guide.
2. Create a block source parameter profile and enter its view.
inspect block-source parameter-profile parameter-name
3. Set the block period during which a source IP address is blocked.
block-period period
The default setting is 1800 seconds.
A capture parameter profile defines the following parameters for the capture action in DPI service modules:
· Maximum number of bytes that can be cached.
· Daily export time for cached packets.
· URL to which cached packets are exported.
The device caches captured packets locally and exports the cached packets to the designated URL at the daily export time or when the number of cached bytes reaches the limit. After the export, the device clears the local cache and starts to capture new packets.
2. Create a capture parameter profile and enter its view.
inspect capture parameter-profile parameter-name
3. Set the maximum volume of captured packets that can be cached.
capture-limit kilobytes
By default, the device can cache a maximum of 512 Kilobytes of captured packets.
4. Set the daily export time for cached captured packets.
export repeating-at time
By default, the cached captured packets are exported at 1:00 a.m. every day.
5. Specify the URL to which cached captured packets are exported
export url url-string
By default, no URL is specified for exporting the cached captured packets.
A logging parameter profile defines the log output method and log output language for the logging action in DPI service modules.
After setting the IPS log language to Chinese, only the attack name field of the IPS logs supports displaying in Chinese.
2. Create a logging parameter profile and enter its view.
inspect logging parameter-profile parameter-name
3. Specify the log export method.
log { email | syslog }
By default, logs are exported to the information center.
4. Set the language for IPS log output to Chinese.
log language chinese
By default, IPS logs are output in English.
A redirect parameter profile defines the URL to which packets are redirected for the redirect action in DPI service modules.
2. Create a redirect parameter profile and enter its view.
inspect redirect parameter-profile parameter-name
3. Specify the URL to which packets are redirected.
redirect-url url-string
By default, no URL is specified for packet redirecting.
An email parameter profile defines the following parameters for the email action in DPI service modules:
· Email server.
· Email sender and receiver.
· Username and password for logging in to the email server.
2. Create an email parameter profile and enter its view.
inspect email parameter-profile parameter-name
3. Specify the email server.
email-server addr-string
By default, no email server is specified.
4. Specify the DNS server address.
dns-server ip-address
By default, no DNS server is specified.
5. Specify the email sender address.
sender addr-string
By default, no email sender address is specified.
6. Specify the email receiver address.
receiver addr-string
By default, no email receiver address is specified.
7. (Optional.) Configure email client authentication.
a. Enable email client authentication.
authentication enable
By default, email client authentication is enabled.
b. Specify the username for logging in to the email server.
username name-string
By default, no username is specified for logging in to the email server.
c. Specify the password for logging in to the email server.
By default, no password is specified for logging in to the email server.
d. Enable the secure password transmission feature.
secure-authentication enable
By default, the secure password transmission feature is disabled.
The DPI engine includes a series of optimization features. For example, you can enable the DPI engine to uncompress or decode the compressed or encoded packets to identify the application information of the packets. The optimization features improve inspection and accuracy of the DPI engine, but consume more system resources.
2. Set the maximum number of payload-carrying packets to be inspected per data flow.
inspect packet maximum max-number
By default, the DPI engine can inspect a maximum of 32 payload-carrying packets per data flow.
3. Set the maximum number of options to be cached per TCP or UDP data flow.
inspect cache-option maximum max-number
By default, the DPI engine can cache a maximum of 32 options per TCP or UDP data flow.
4. Configure the TCP segment reassembly feature.
¡ Enable TCP segment reassembly.
inspect tcp-reassemble enable
By default, the TCP segment reassembly feature is disabled.
¡ Set the maximum number of TCP segments that can be cached for reassembly per TCP flow.
inspect tcp-reassemble max-segment max-number
By default, a maximum of 10 TCP segments can be cached for reassembly per TCP flow.
5. (Optional.) Disable a DPI engine optimization feature.
inspect optimization [ chunk | no-acsignature | raw | uncompress | url-normalization ] disable
By default, all DPI engine optimization features are enabled.
You can disable DPI engine optimization features to improve the device performance as needed.
Packet inspection of the DPI engine is a complex and resource-consuming process.
Inspection suspension upon excessive CPU usage works as follows:
· When the device's CPU usage rises to or above the CPU usage threshold, the DPI engine suspends packet inspection to guarantee the device performance.
· When the device's CPU usage drops to or below the CPU usage recovery threshold, the DPI engine resumes packet inspection.
For information about configuring the CPU usage thresholds, see device management in Fundamentals Configuration Guide.
Do not disable inspection suspension upon excessive CPU usage if the device's CPU usage is high.
When the device's CPU usage is low, you can disable this feature to improve inspection accuracy.
When a sudden CPU overload occurs, the DPI engine suspends packet inspection for certain types of traffic to guarantee device performance, even though the CPU usage threshold is not reached.
2. Enable inspection suspension upon excessive CPU usage.
undo inspect cpu-threshold disable
By default, inspection suspension upon excessive CPU usage is enabled.
Select an inspection mode as required:
· Balanced mode—Applicable to most scenarios. This mode makes a tradeoff between the device performance and inspection coverage. The maximum length is 64 Kilobytes for FTP, HTTP, SMB, NFS, and email streams, and the maximum file length for MD5 inspection is 2048 Kilobytes.
· Large coverage mode—Applicable to the scenarios that require large inspection coverage. This mode improves the inspection coverage at the cost of device performance. The maximum length is 128 Kilobytes for FTP, HTTP, SMB, NFS, and email streams, and the maximum file length for MD5 inspection is 5120 Kilobytes.
· High performance mode—Applicable to the scenarios that require high device performance. This mode improves the device performance while ensuring a certain inspection coverage. The maximum length is 32 Kilobytes for FTP, HTTP, SMB, NFS, and email streams, and the maximum file length for MD5 inspection is 32 Kilobytes.
· User-defined mode—Applicable to the scenarios that have specific requirements for inspection coverage and device performance. In this mode, you can execute the inspect stream-fixed-length and inspect md5-fixed-length commands commands to set the maximum stream length for inspection and maximum file length for MD5 value calculation, respectively.
The maximum lengths for stream inspection and MD5 inspection will not change after the user-defined inspection mode is switched, and you can adjust those lengths as required.
2. Configure a DPI engine inspection mode.
inspect coverage { balanced | large-coverage | high-performance | user-defined }
By default, the DPI engine uses the balanced mode.
DPI engine inspects only the fixed-length data after the first packet for each stream. The remaining stream data is not inspected. Reducing the fixed length for stream inspection enhances the inspection efficiency.
This feature can be configured only if the DPI engine inspection mode is user-defined mode.
2. Enable the stream fixed length inspection.
undo inspect stream-fixed-length disable
By default, the stream fixed length inspection is enabled.
3. Set the fixed length for stream inspection.
inspect stream-fixed-length { email | ftp | http | nfs | smb } * length
The default length is 64 Kilobytes for FTP, HTTP, NFS, SMB, and email streams.
The longer the inspection data length, the lower the device throughput, and the higher the packet inspection accuracy.
DPI engine inspects only the fixed-length data of files in each data stream. The remaining data of the file is not inspected. This is because virus signatures are typically embedded in the first half of a file. Narrowing the inspection scope enhances the file inspection efficiency.
Because files are transmitted in a data stream, the fixed length of files must not be longer than that of the data stream.
2. Enable the file fixed length inspection.
inspect file-fixed-length enable
By default, the file fixed length inspection is disabled.
3. Set the fixed length for file inspection.
inspect file-fixed-length { email | ftp | http | nfs | smb } * length-value
By default, the fixed length is 64 Kilobytes for FTP, HTTP, NFS, SMB, and email files.
If a data stream contains multiple files, this feature inspects only the fixed length data of each file.
In the anti-virus services, the device matches the packet signatures, calculates MD5 values of the files, and compares the calculated MD5 values with the MD5 rules in the signature library. If the MD5 value for a file matches an MD5 rule in the signature library, the file is considered to contain viruses. For more information about virus inspection, see "Configuring anti-virus."
The DPI engine inspects the packet signatures and MD5 values at the same time. After the length of a file reaches the fixed stream inspection length, the DPI engine will stop the packet signature inspection. To continue the MD5 inspection for a file, enable MD5 fixed-length file inspection and configure a fixed file length for MD5 inspection longer than the fixed length for stream inspection. Then the DPI engine calculates MD5 value of the fixed-length file.
The increase of the file length for MD5 inspection will reduce the device performance but improve the success rate of the MD5 inspection. The decrease of the file length for MD5 inspection will improve the device performance but reduce the success rate of the MD5 inspection.
2. Enable MD5 fixed-length file inspection.
inspect md5-fixed-length enable
By default, MD5 fixed-length file inspection is enabled.
3. Set the fixed file length for MD5 inspection.
inspect md5-fixed-length { email | ftp | http | nfs | smb } * length
By default, the fixed length of FTP, HTTP, SMB, NFS, and email files for MD5 inspection is 2048 Kilobytes.
This feature enables the DPI engine to generate MD5 hashes for all files and to compare the generated MD5 hashes with the MD5 rules in the signature library. If the MD5 hash generated for a file matches an MD5 rule in the signature library, the file is considered to contain viruses. For more information about virus inspection, see "Configuring anti-virus."
This feature might degrade the processing performance of other services. Enable it only when necessary.
2. Enable MD5 hash-based virus inspection for all files.
inspect md5-verify all-files
By default, the DPI engine performs MD5 hash-based virus inspection only for executable files, office files, and compressed files.
The device can decompress .zip files for file data inspection. Perform this task to set the maximum data size that can be decompressed in a file. The remaining file data will be ignored.
Set an appropriate maximum data size for file decompression. A large data size might make the device get stuck in decompressing large files and the device forwarding performance might be affected. A small data size will affect the accuracy of the file inspection results for DPI services (such as anti-virus and data filtering).
The device can decompress only .zip files and decompress only one layer of file.
2. Set the maximum data size that can be decompressed in a .zip file.
inspect file-uncompr-len max-size
By default, the device can decompress a maximum of 100 MB data in a .zip file.
You can use this feature to identify traffic of applications that use fixed source ports when the following conditions are true:
· The types of traffic transmitted over networks are relatively unvaried and use fixed source ports.
· Destination port-based application identification or signature-based traffic content identification is not supported.
The application identification results produced by this feature might not be accurate. Configure this feature according to your live network as a best practice.
2. Enable source port-based application identification.
inspect source-port-identify enable
By default, source port-based application identification is disabled.
The device must access the company's website for online signature update of DPI services (such as URL filtering). If direct connectivity is not available, the device can access the company's website through the specified proxy server. For more information about online signature update, see "Configuring URL filtering" and "Configuring anti-virus."
If you specify a proxy server by domain name instead of IP address, make sure the device can resolve the domain name into an IP address through DNS. For more information about DNS, see Layer 3—IP Services Configuration Guide.
2. Specify a proxy server for online DPI service signature update
inspect signature auto-update proxy { domain domain-name | ip ip-address } [ port port-number ] [ user user-name password { cipher | simple } string ]
By default, the proxy server used by DPI services for online signature update is not specified.
You can specify the server used for cloud query by DPI services.
Currently, the cloud query server supports URL filtering cloud query and anti-virus MD5 value cloud query.
For successful cloud query, make sure the device can resolve the host name of the cloud query server into an IP address through DNS. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
2. Specify the cloud query server for DPI services.
inspect cloud-server host-name
By default, DPI services use the cloud query server with host name sec.h3c.com.
The feature ensures the device in HA dual-active mode can correctly process DPI services in a network with asymmetric forwarding of flows.
For more information about HA dual-active mode, see high availability group configuration in High Availability Configuration Guide.
This feature takes effect only when the device operates in HA dual-active mode.
This feature might degrade device performance.
This feature takes effect only after you enable transparent service traffic transmission between the remote backup group members (see RBM configuration in High Availability Configuration Guide).
2. Enable support for HA dual-active mode.
inspect dual-active enable
By default, support for HA dual-active mode is disabled.
Packet inspection in the DPI engine is a complex and resource-consuming process. When the CPU usage is too high, you can disable the DPI engine to guarantee the device performance. After you disable the DPI engine, packets will not be processed by DPI.
2. Disable the DPI engine.
inspect bypass
By default, the DPI engine is enabled.
CAUTION: This command causes packets of any protocols not to be processed by DPI. DPI-based services might also be interrupted. For example, security policies cannot control access to applications. |
Task |
Command |
Display the status of the DPI engine. |
display inspect status |
Display information about the MD5 hash-based virus inspection for all files feature. |
display inspect md5-verify configuration |
