09-Interface Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9153P39 R9001P39)-6W40009-Interface Command Reference
04-Blade interface commands
04-Blade interface commands 52.56 KB
display interface blade
Use display interface blade to display Blade interface information.
display interface [ blade [ interface-number ] ] [ brief ]
context-admin
context-operator
interface-number: Specifies a Blade interface by its number. If you do not specify a Blade interface number, this command displays information about all Blade interfaces.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
If you specify both the interface type and interface number, this command displays information about the specified interface.
# Display information about Blade 1/0/1.
<Sysname> display interface blade 4/0/1
Blade4/0/1
Current state: UP
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0000-0000-0000
Description: Blade4/0/1 Interface
Bandwidth: 40000000kbps
40Gbps-speed mode, full-duplex mode
    Input Dp: 1341 packets, 0 jumboes, 151601 bytes
              0 broadcasts, 0 multicasts, 0 pauses
    DropPkts: 0 CrcDrop, 0 IfStateDrop, 0 InputRawDrop
              0 RateCtrlDrop, 0 RemoteNodeDrop
    Input Cp: 0 packets, 0 jumboes, 0 bytes
    Output: 0 packets, 0 bytes
Current state
State of the interface:
·     DOWN—The interface is administratively up but physically down. There might not be a physical link present or the link has failed.
·     UP—The interface is both administratively and physically up.
Ethernet framing format. PKTFMT_ETHNT_2 indicates that the frames are encapsulated in Ethernet II framing format.
Bandwidth
Expected bandwidth of the interface.
40Gbps-speed mode
The interface is operating at 40 Gbps.
full-duplex mode
The interface is operating in full duplex mode.
The interface is configured with the speed auto command.
The interface is configured with the duplex auto command.
Input Dp: 0 packets, 0 jumboes, 0 bytes
Inbound data packet statistics for the interface:
·     Number of inbound normal packets.
·     Number of inbound jumbo frames.
·     Number of inbound bytes.
·     Number of inbound broadcast packets.
·     Number of inbound multicast packets.
·     Number of inbound pause frames.
A hyphen (-) indicates that the statistical item is not supported.
Dropped packet statistics for the interface:
·     Number of packets dropped due to CRC errors.
·     Number of packets dropped due to interface state check.
·     Number of packets dropped because the interface fails to obtain the function.
·     Number of packets dropped due to rate control.
·     Number of packets dropped because the system fails to obtain the node.
Inbound control statistics for the interface:
Outbound packet statistics for the interface:
·     Number of outbound normal packets.
·     Number of outbound bytes.
·     Number of outbound broadcast packets.
·     Number of outbound multicast packets.
·     Number of outbound pause frames.
# Display brief information about Blade interfaces.
<Sysname> display interface blade brief
Brief information on interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
Blade4/0/1           UP   40G     F(a)   --   --
The brief information of interface(s) under bridge mode:
Brief information about Layer 2 interfaces.
The Speed field displays the (a) flag next to the speed if the speed is automatically negotiated.
The duplex mode of the interface includes:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     T—Trunk.
·     H—Hybrid.
Speed
Speed of the interface in bps.
Duplex
If the duplex mode of an interface is automatically negotiated, the duplex mode attribute of the interface includes the (a) flag. H indicates the half duplex mode. F indicates the full duplex mode.
If an interface is configured to autonegotiate its duplex mode but the autonegotiation has not started, its duplex mode attribute is displayed as A.
·     A—Access.
·     T—Trunk.
·     H—Hybrid.
PVID
Port VLAN ID (PVID) of the interface.
reset counters interface
reset counters interface blade
Use reset counters interface blade to clear the Blade interface statistics.
reset counters interface [ blade [ interface-number ] ]
context-admin
interface-number: Specifies a Blade interface by its number. If you do not specify a Blade interface number, this command clear statistics for all Blade interfaces.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
# Clear the statistics for all Blade interfaces.
<Sysname> reset counters interface blade
