| 01-Hardware Information and Specifications | 536.34 KB |
1 Product models and technical specifications
Product models
The S6880 switch series includes the following models:
Product code |
Product model |
LS-6880-48Y8C |
S6880-48Y8C |
LS-6880-48X8C |
S6880-48X8C |
Technical specifications
Table1-1 Technical specifications
Item |
S6880-48Y8C |
S6880-48X8C |
Dimensions (H × W × D) |
44.0 × 440 × 400 mm (1.73 × 17.32 × 15.75 in) |
Weight |
≤ 9 kg (19.84 lb) |
Console port |
1 × serial console port |
Management Ethernet port |
1 |
USB port |
1 |
SFP+ port |
N/A |
48 |
SFP28 port |
48 |
N/A |
QSFP28 port |
8 |
8 |
Fan tray slot |
4 |
Power supply slot |
2 |
Input voltage |
PSR450-12A/PSR450-12A1: · AC input ¡ Rated voltage range: 100 to 240 VAC @ 50/60 Hz ¡ Max voltage range: 90 to 290 VAC @ 47 to 63 Hz · HVDC input ¡ Rated voltage range: 240 VDC ¡ Max voltage range: 180 to 320 VDC PSR450-12AHD: · AC input ¡ Rated voltage range: 100 to 240 VAC @ 50/60 Hz ¡ Max voltage range: 90 to 290 VAC @ 47 to 63 Hz · HVDC input ¡ Rated voltage range e: 240 to 380 VDC ¡ Max voltage range: 180 to 400 VDC PSR450-12D: · Rated voltage range: –48 to –60 VDC · Max voltage range: –36 to –72 VDC |
Power consumption (static) |
· Single AC input: 67.72 W · Dual AC inputs: 77.86 W · Single DC input: 68.39 W · Dual DC inputs: 75.09 W |
Power consumption (fully configured) |
· Single AC input: 285.4 W · Dual AC inputs: 283.5 W · Single DC input: 294.5 W · Dual DC inputs: 298 W |
· Single AC input: 280.4 W · Dual AC inputs: 278.5 W · Single DC input: 289.5 W · Dual DC inputs: 293 W |
Chassis leakage current compliance |
· UL62368-1 · EN62368-1 · IEC62368-1 · UL60950-1 · EN60950-1 · IEC60950-1 · GB4943.1 |
Melting current of power supply fuse |
· PSR450-12A/PSR450-12A1/PSR450-12AHD: 10 A @ 250 V · PSR450-12D: 20 A @ 125 V |
Operating temperature |
–5°C to +45°C (23°F to 113°F) |
Relative humidity |
5% RH to 95% RH, noncondensing |
Fire resistance compliance |
2 Chassis views
S6880-48Y8C
Figure2-1 Front panel
(1) SFP28 port |
(2) SFP28 port LED |
(3) QSFP28 port |
(4) QSFP28 port LED |
(5) System status LED (SYS) |
(1) Management Ethernet port LED (ACT) |
(2) Management Ethernet port LED (LINK) |
(3) Serial console port |
(4) Removable fan tray 1 |
(5) Removable fan tray 2 |
(6) Removable fan tray 3 |
(7) Removable fan tray 4 |
(8) Removable power supply 1 (PWR1) |
(9) Removable power supply 2 (PWR2) |
(10) USB port |
(11) Reset button |
(12) SSD slot (reserved for future use) |
(13) Management Ethernet port (MGMT) |
(14) Grounding screw |
The S6880-48Y8C switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-2, two PSR450-12A1 power supplies are installed in the power supply slots.
The S6880-48Y8C switch came with the four fan tray slots empty. You must install four fan trays of the same model for the switch. In Figure2-2, four FAN-40B-1-A fan trays are installed in the fan tray slots.
The S6880-48Y8C switch provides a reset button on the rear panel for you to reset the switch.
To use both the console port and USB port on the S6880-48Y8C switch, use a small-sized USB drive or a USB extension cable.
S6880-48X8C
Figure2-3 Front panel
(1) SFP+ port |
(2) SFP+ port LED |
(3) QSFP28 port |
(10) USB port |
(11) Reset button |
The S6880-48X8C switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-4, two PSR450-12A1 power supplies are installed in the power supply slots.
The S6880-48X8C switch came with the four fan tray slots empty. You must install four fan trays of the same model for the switch. In Figure2-4, four FAN-40B-1-A fan trays are installed in the fan tray slots.
The S6880-48X8C switch provides a reset button on the rear panel for you to reset the switch.
To use both the console port and USB port on the S6880-48X8C switch, use a small-sized USB drive or a USB extension cable.
3 FRUs
The switch uses modular design. Table3-1 describes the FRUs available for the switch.
Table3-1 FRUs available for the switch
FRUs |
· S6880-48Y8C/S6880-48X8C |
Power supplies |
PSR450-12A |
Yes |
PSR450-12A1 |
Yes |
PSR450-12AHD |
Yes |
PSR450-12D |
Yes |
Fan trays |
FAN-40B-1-A |
Yes |
FAN-40F-1-A |
Yes |
Power supplies
CAUTION: When the switch has power supplies in 1+1 redundancy, you can replace a power supply without powering off the switch. Before replacing a power supply, make sure it is powered off. |
The switch uses removable power supplies. You can install one power supply, or two power supplies in 1+1 redundancy for the switch.
You can install two power supplies of different models on the same switch.
Table3-2 Power supply specifications
Power supply model |
Item |
Specifications |
PSR450-12A PSR450-12A1 |
AC input |
Rated input voltage |
100 to 240 VAC @ 50 or 60 Hz |
Max input voltage |
90 to 290 VAC @ 47 to 63 Hz |
Max output power |
450 W |
HVDC input |
240 VDC |
Max input voltage |
180 to 320 VDC |
Max output power |
450 W |
PSR450-12AHD |
AC input |
Max input voltage |
Max output power |
450 W |
HVDC input |
240 to 380 VDC |
Max input voltage |
180 to 400 VDC |
Max output power |
450 W |
PSR450-12D |
DC input |
–48 to –60 VDC |
Max input voltage |
–36 to –72 VDC |
Max output power |
450 W |
Fan trays
CAUTION: For adequate heat dissipation, you must install fan trays of the same model for the switch. |
Table3-3 Fan tray specifications
Fan tray model |
Item |
Specifications |
· FAN-40B-1-A (from the port side to the power supply side) · FAN-40F-1-A (from the power supply side to the port side) |
40 × 40.6 × 117 mm (1.57 × 1.60 × 4.61 in) |
Fan speed |
21000 R.P.M |
Max airflow |
26 CFM (0.74 m3/min) |
Input voltage |
12 V |
Maximum power consumption |
27.72 W |
Documentation reference |
H3C FAN-40F-1-A & FAN-40B-1-A Fan Trays User Guide |
4 Ports and LEDs
As a best practice, use H3C transceiver modules and cables for the switch. H3C transceiver modules and cables are subject to change over time. For the most up-to-date list of H3C transceiver modules and cables, contact H3C Support or marketing staff. For information about the specifications and views of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Ports
Console port
Table4-1 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
Compliant standard |
EIA/TIA-232 |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Services |
· Provides connection to an ASCII terminal. · Provides connection to a serial port of a local terminal (for example a PC) running a terminal emulation program. |
Compatible devices |
All device models |
Table4-2 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port transmission rate |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X autosensing |
Transmission medium |
Category 5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i, 802.3u, and 802.3ab |
Functions and services |
Connects to a computer or remote network management work station for upgrading and managing applications and Boot ROM |
All device models |
USB port
The USB port supplies power as per USB 2.0 specifications. Use only USB 2.0-compliant USB devices for the USB port. The port might not identity USB devices that are not compliant with USB 2.0.
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
Table4-3 USB port specifications
Item |
Specification |
Interface type |
USB 2.0 |
OHC |
Uploads and downloads data at a rate up to 480 Mbps |
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files |
All device models |
SFP+ port
Table4-4 SFP+ port specifications
Item |
Specification |
Interface type |
SFP+ port |
Compatible transceiver modules and cables |
· SFP transceiver modules and cables in Table4-5. · 10-GE SFP+ transceiver modules and cables in Table4-6, Table4-7, and Table4-8. |
S6880-48Y8C |
Table4-5 GE SFP transceiver modules and cables available for the SFP+ ports
GE SFP transceiver module and cable |
Central wavelength (nm) |
Connector |
Cable/Fiber type and diameter (µm) |
Modal bandwidth (MHz × km) |
SFP copper transceiver module |
SFP-GE-T SFP-GE-T-D |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP fiber transceiver module |
SFP-GE-SX-MM850-A SFP-GE-SX-MM850-D |
850 |
LC |
Multi-mode, 50/125 |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
Multi-mode, 62.5/125 |
200 |
275 m (902.23 ft) |
160 |
200 m (656.17 ft) |
SFP-GE-LX-SM1310-A SFP-GE-LX-SM1310-D |
1310 |
LC |
Single-mode, 9/125 |
N/A |
10 km (6.21 miles) |
500 or 400 |
500 |
SFP-GE-LH40-SM1310 SFP-GE-LH40-SM1310-D |
1310 |
LC |
N/A |
40 km (24.86 miles) |
SFP-GE-LH40-SM1550 |
1550 |
LC |
N/A |
SFP-GE-LH80-SM1550 SFP-GE-LH80-SM1550-D |
1550 |
LC |
N/A |
80 km (49.71 miles) |
SFP-GE-LH100-SM1550 |
1550 |
LC |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
· TX: 1310 · RX: 1490 |
LC |
N/A |
SFP-GE-LX-SM1490-BIDI |
· TX: 1490 · RX: 1310 |
LC |
N/A |
SFP-GE-LH40-SM1310-BIDI |
· TX: 1310 · RX: 1550 |
LC |
N/A |
SFP-GE-LH40-SM1550-BIDI |
· TX: 1550 · RX: 1310 |
LC |
N/A |
SFP-GE-LH70-SM1490-BIDI |
· TX: 1490 · RX: 1550 |
LC |
N/A |
70 km (43.50 miles) |
SFP-GE-LH70-SM1550-BIDI |
· TX: 1550 · RX: 1490 |
LC |
N/A |
SFP copper cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP copper cable |
N/A |
1.5 m (4.92 ft) |
Table4-6 10-GE SFP+ transceiver modules available for the SFP+ ports
10-GE SFP+ module |
Central
wavelength |
Connector |
Fiber
diameter |
Multimode
fiber modal bandwidth |
SFP-XG-SX-MM850-D |
850 |
LC |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310-D |
1310 |
LC |
N/A |
SFP-XG-LX-SM1270-BIDI |
1270 |
LC |
N/A |
SFP-XG-LX-SM1330-BIDI |
1330 |
LC |
N/A |
SFP-XG-LH40-SM1270-BIDI |
1270 |
LC |
N/A |
SFP-XG-LH40-SM1550 |
1550 |
LC |
N/A |
SFP-XG-LH40-SM1330-BIDI |
1330 |
LC |
N/A |
SFP-XG-LH80-SM1550-BIDI |
1550 |
LC |
N/A |
SFP-XG-LH80-SM1490-BIDI |
1490 |
LC |
N/A |
SFP-XG-LH80-SM1550 |
1550 |
LC |
N/A |
IMPORTANT: · BIDI transceiver modules transmit and receive different central wavelengths for bidirectional transmission of optical signals on a single fiber. · BIDI transceiver modules must be used in matched pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table4-7 SFP+ copper cables available for the SFP+ ports
Cable description |
Cable length |
LSWM1STK |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
Table4-8 SFP+ AOC cables available for the SFP+ ports
Cable description |
Cable length |
SFP-XG-D-AOC-7M |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
SFP28 ports
Table4-9 SFP28 port specifications
Item |
Specification |
Interface type |
SFP28 port |
· SFP28 transceiver modules and cables in Table4-10, Table4-11, and Table4-12 · 10-GE SFP+ transceiver modules and cables in Table4-6, Table4-7, and Table4-8. |
S6880-48Y8C |
Table4-10 SFP28 transceiver modules available for the SFP28 ports
SFP28 transceiver module |
Connector |
Modal bandwidth (MHz*km) |
Maximum transmission distance |
SFP-25G-SR-MM850 |
850 |
LC |
Multimode, 50/125 |
2000 |
· FEC negotiation disabled: 30 m (98.43 ft) · FEC negotiation enabled: 70 (229.66 ft) |
4700 |
· FEC negotiation disabled: 40 m (131.23 ft) · FEC negotiation enabled: 100 m (328.08 ft) |
SFP-25G-LR-SM1310 |
1310 |
LC |
Single mode, 9/125 |
N/A |
NOTE: For more information about FEC negotiation, see Ethernet interfaces in H3C S6880 Switch Series Layer 2–LAN Switching Configuration Guide. |
Table4-11 25G SFP28 copper cables available for the SFP28 ports
25G SFP28 copper cable |
SFP-25G-D-CAB-1M |
1 m (3.28 ft) |
SFP-25G-D-CAB-3M |
3 m (9.84 ft) |
SFP-25G-D-CAB-5M |
5 m (16.40 ft) |
Table4-12 25G SFP28 fiber cables available for the SFP28 ports
25G SFP28 fiber cable |
SFP-25G-D-AOC-3M |
3 m (9.84 ft) |
SFP-25G-D-AOC-5M |
5 m (16.40 ft) |
SFP-25G-D-AOC-7M |
7 m (22.97 ft) |
SFP-25G-D-AOC-10M |
10 m (32.81 ft) |
SFP-25G-D-AOC-20M |
20 m (65.62 ft) |
QSFP28 ports
Table4-13 QSFP28 port specifications
Item |
Specification |
Interface type |
QSFP28 port |
· QSFP+ transceiver modules and cables in Table4-14, Table4-15, Table4-16, and Table4-17. · QSFP28 transceiver modules and cables in Table4-18, Table4-19, Table4-20, and Table4-21 |
All device models |
Restrictions and guidelines |
You can use a QSFP-100G-SR4-MM850 transceiver module to connect one 100G QSFP28 port to four 25G SFP28 ports. The QSFP28 transceiver module and SFP28 transceiver modules to be connected must be the same in specifications, including central wavelength and fiber type. |
Table4-14 QSFP+ transceiver modules available for the QSFP28 ports
QSFP+ transceiver module |
Connector |
QSFP-40G-SR4-MM850 |
850 |
MPO (PC-polished, 12-core) |
Multimode, 50/125 |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.13 ft) |
QSFP-40G-CSR4-MM850 |
850 |
Multimode, 50/125 |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.34 ft) |
QSFP-40G-BIDI-SR-MM850 |
850 |
LC |
Multimode, 50/125 |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.13 ft) |
QSFP-40G-BIDI-WDM850 |
Four lanes: · 850 · 880 · 910 · 940 |
LC |
Multimode, 50/125 |
2000 |
240 m (787.40 ft) |
QSFP-40G-LR4-WDM1300 |
Four lanes: · 1271 · 1291 · 1311 · 1331 |
LC |
N/A |
QSFP-40G-LR4L-WDM1300 |
LC |
N/A |
2 km (1.24 miles) |
QSFP-40G-ER4-WDM1300 |
LC |
N/A |
Table4-15 QSFP+ copper cables available for the QSFP+ ports
QSFP+ copper cable |
LSWM1QSTK0 |
1 m (3.28 ft) |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
Table4-16 QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable |
Cable length |
QSFP-40G-D-AOC-3M |
3 m (9.84 ft) |
QSFP-40G-D-AOC-7M |
7 m (22.97 ft) |
QSFP-40G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-40G-D-AOC-20M |
20 m (65.62 ft) |
Table4-17 QSFP+ to SFP+ copper cables available for the QSFP+ ports
QSFP+ to SFP+ copper cable |
LSWM1QSTK3 |
1 m (3.28 ft) |
LSWM1QSTK4 |
3 m (9.84 ft) |
LSWM1QSTK5 |
5 m (16.40 ft) |
Table4-18 QSFP28 transceiver modules available for the QSFP28 ports
QSFP28 transceiver module or cable |
Connector |
QSFP-100G-SR4-MM850 |
850 |
MPO (PC polished, 12-fiber) |
Multimode, 50/125 |
2000 |
70 m (229.66 ft) |
4700 |
100 m (328.08 ft) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 1295 · 1300 · 1304 · 1309 |
LC |
N/A |
QSFP-100G-LR4L-WDM1300 |
Four lanes: · 1264.5 to 1277.5 · 1284.5 to 1297.5 · 1304.5 to 1317.5 · 1324.5 to 1337.5 |
LC |
N/A |
2 km (1.24 miles) |
QSFP-100G-ER4L-WDM1300 |
Four lanes: · 1295.56 · 1300.05 · 1304.58 · 1309.14 |
LC |
N/A |
Table4-19 QSFP28 copper cables available for the QSFP28 ports
QSFP28 copper cable |
Cable length |
QSFP-100G-D-CAB-1M |
1 m (3.28 ft) |
QSFP-100G-D-CAB-3M |
3 m (9.84 ft) |
QSFP-100G-D-CAB-5M |
5 m (16.40 ft) |
Table4-20 QSFP28 fiber cables available for the QSFP28 ports
QSFP28 fiber cable |
Cable length |
QSFP-100G-D-AOC-7M |
7 m (22.97 ft) |
QSFP-100G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-100G-D-AOC-20M |
20 m (65.62 ft) |
Table4-21 QSFP28 to SFP28 copper cables available for the QSFP28 ports
QSFP28 to SFP28 copper cable |
Cable length |
QSFP-100G-4SFP-25G-CAB-1M |
1 m (3.28 ft) |
QSFP-100G-4SFP-25G-CAB-3M |
3 m (9.84 ft) |
QSFP-100G-4SFP-25G-CAB-5M |
5 m (16.40 ft) |
NOTE: MPO connectors include physical contact (PC) connectors with a flat-polished face and angle-polished contact (APC) connectors with an angle-polished face (8°). |
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-22 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch is operating correctly. |
Flashing green |
The switch is performing power-on self-test (POST). |
Steady red |
The system has failed to pass POST or has problems such as fan failure. |
Off |
The switch is powered off or has failed to start up. |
QSFP28 port LEDs
Table4-23 QSFP28 port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 100 Gbps. |
Flashing green |
The port is sending or receiving data at 100 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 10 Gbps, 25 Gbps, or 40 Gbps. |
Flashing yellow |
The port is sending or receiving data at 10 Gbps, 25 Gbps, or 40 Gbps. |
Off |
No transceiver module or cable has been installed or no link is present on the port. |
SFP28 port LEDs
Table4-24 SFP28 port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 25 Gbps. |
Flashing green |
The port is sending or receiving data at 25 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed. The port has a link and is operating at 10 Gbps. |
Flashing yellow |
The port is sending or receiving data at 10 Gbps. |
Off |
SFP+ port LED
Table4-25 SFP+ port LED description
SFP+ port LED status |
Steady green |
A link is present on the port and the port is operating at 10 Gbps. |
Flashing green |
Steady yellow |
A link is present on the port and the port is operating at 1 Gbps. |
Flashing yellow |
The port is sending or receiving data at 1 Gbps. |
Off |
No link is present on the port. |
Management Ethernet port LEDs
The switch provides two status LEDs LINK and ACT for the copper management Ethernet port.
Table4-26 Copper management Ethernet port LED description
LED mark |
Status |
LINK |
Off |
No link is present on the port |
Steady green |
The port is operating at 10/100/1000 Mbps. |
ACT |
Off |
The port is not receiving or sending data. |
Flashing yellow |
The port is sending or receiving data. |
Fan tray alarm LEDs
The FAN-40B-1-A and FAN-40F-1-A fan trays each provide an alarm LED. For more information about the LED, see the user guide for the fan tray.
Power supply alarm LEDs
The PSR450-12A, PSR450-12A1, PSR450-12AHD, and PSR450-12D power supplies each provide an alarm LED. For more information about the LED, see the user manual for the power supply.
5 Cooling system
CAUTION: The chassis and power supplies use separate air aisles. Make sure the two aisles are not blocked when the switch is operating. |
The switch uses a highly efficient front-rear air aisle cooling system to provide adequate heat dissipation and ensure system stability. Consider the site ventilation design when you plan the installation site for the switch.
Table5-1 Cooling system for the switch
Available fan trays |
Airflow direction |
FAN-40F-1-A |
From the power supply side to the port side |
FAN-40B-1-A |
From the port side to the power supply side |
Figure5-1 Airflow from the power supply side to the port side (with FAN-40F-1-A fan trays)
Figure5-2 Airflow from the port side to the power supply side (with FAN-40B-1-A fan trays)
