- 16-Security Configuration Guide
- 01-ACL configuration
- 02-APR configuration
- 03-ARP attack protection configuration
- 04-ASPF configuration
- 05-IP source guard configuration
- 06-IPsec configuration
- 07-ND attack defense configuration
- 08-Password control configuration
- 09-PKI configuration
- 10-SSH configuration
- 11-SSL configuration
- 12-User profile configuration
- 13-Public key management
- 14-Attack detection and prevention configuration
- 15-Session management
- 16-Crypto engine configuration
- 17-Connection limit configuration
- 18-Time range configuration
| 05-IP source guard configuration | 112.63 KB |
Configuring the processing method for packets from unknown source IPv4 addresses
Display and maintenance commands for IPSG
Configuring IP source guard
About IPSG
IP source guard (IPSG) prevents spoofing attacks by using WLAN snooping entries to filter packets received by an AP. It drops packets that do not match the entries.
WLAN snooping is enabled by default on the AP. A WLAN snooping entry is an IP-MAC binding.
· In an IPv4 network, WLAN snooping reads the clients' IP-MAC bindings from the ARP messages or DHCP packets that pass through the AP. IPSG uses only the WLAN snooping entries obtained through DHCP packets.
· In an IPv6 network, WLAN snooping reads the clients' IP-MAC bindings from packets that pass through the AP. The packets are RA messages, NS messages, NA messages, and DHCP packets. IPSG uses all WLAN snooping entries for packet filtering.
For information about DHCP, DHCPv6, and ND, see Network Connectivity Configuration Guide.
As shown in Figure 1, the AP has a WLAN snooping entry for the client that has obtained an IP address from the DHCP server. IPSG forwards packets only from the legal client.
Configuring the IPSG feature
IPSG enabled for a service template filters only packets from the clients in the BSSs created based on the service template. It does not affect clients in other BSSs.
1. Enter system view.
2. Enter service template view.
wlan service-template service-template-number
3. Enable the IPSG feature.
IPv4:
ip verify source
IPv6:
ipv6 verify source
By default, the IPSG feature is disabled.
After you enable the IPSG feature on the AC, the IPv4 addresses learned from DHCP packets by APs are identified as known source IPv4 addresses. The following IPv4 addresses are unknown source IPv4 addresses:
· IPv4 addresses learned from ARP packets that are intercepted by APs.
· IPv4 addresses that have not been learned by APs.
You can configure APs to perform one of the following process methods for incoming packets from unknown source IPv4 addresses:
· Drop the packets only.
· Drop the packets and send deauthentication frames to the sources.
3. Configure the processing method for packets from unknown source IPv4 addresses received by APs.
ip verify unknown-ip { deauthenticate | drop }
By default, APs drop packets from unknown source IPv4 addressess.
Task |
Command |
Display IPv4SG bindings. |
display ip source binding [ wlan-snooping ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] |
Display IPv6SG bindings. |
display ipv6 source binding [ wlan-snooping ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] |
IPSG configuration examples
Example: Configuring IPSG
As shown in Figure 2, the clients access the WLAN through SSID service. Client 1 and Client 2 obtain IP addresses through the DHCP server (the switch).
Enable IPSG for the service template on the AC to make the AP filter incoming packets. The AP forwards the packets only from Client 1 and Client 2.
# Create service template 1.
<AC> system-view
[AC] wlan service-template 1
# Set the SSID to service for the service template, and enable the service template.
[AC-wlan-st-1] ssid service
# Enable the IPSG feature for IPv4.
[AC-wlan-st-1] ip verify source
[AC-wlan-st-1] quit
# Create the AP ap1 with the mode WA4620i-CAN, and set its serial ID to 210235A29G007C000020.
[AC] wlan ap ap1 model WA4620i-ACN
[AC-wlan-ap-ap1] serial-id 210235A29G007C000020
# Enter radio view of radio 2 and bind service template 1 to radio 2.
[AC-wlan-ap-ap1] radio 2
[AC-wlan-ap-ap1-radio-2] service-template 1
[AC-wlan-ap-ap1-radio-2] quit
[AC-wlan-ap-ap1] quit
# Use Client 1 and Client 2 to obtain their IP addresses through DHCP, and manually assign Client 3 the IP address of Client 1. (Details not shown.)
# Verify that packets from Client 1 and Client 2 are allowed to pass. (Details not shown.)
# Verify that packets from client 3 are dropped. (Details not shown.)
