06-WLAN Access Configuration Guide
HomeSupportWirelessvAC1000 Virtual Access ControllerConfigure & DeployConfiguration GuidesH3C vAC1000 Virtual Access Controller Configuration Guides(R5435P03)-6W10006-WLAN Access Configuration Guide
02-802.11v configuration
02-802.11v configuration 94.01 KB
Configuring 802.11v
About 802.11v
802.11v is an amendment standard for wireless network management, which defines numerous enhancements, such as power saving, load balancing, and BSS transition management (BTM). It allows clients to exchange network information and always associate with the optimal AP, which prolongs clients' battery life and improves user experience.
BTM enables clients to roam to the optimal AP if the signal strength of the current AP is low or if a better AP is discovered.
As shown in Figure 1, BTM operates as follows:
1.     The AP or the 802.11v client triggers a BSS transition:
¡     Unsolicited request—If the AP detects that the RSSI of the client is lower than the RSSI threshold, it sends a BTM request to the client.
¡     Solicited request—If the RSSI of the currently associated AP is too low or the client discovered a better AP, the client sends a BTM query to the associated AP. Upon receiving the query, the AP responds with a BTM request.
A BTM request contains information about recommended BSSs.
2.     Upon receiving the BTM request, the client determines whether to disconnect from the current AP and roam to a recommended AP.
3.     If the client determines to perform a roaming, it sends a BTM response to the AP. If the client fails to leave the current BSS before the disassociation timer expires, the AP sends a disassociation request to the client and logs off the client.
Figure 1 BSS transition
Restrictions and guidelines: 802.11v configuration
You can configure radios by using the following methods:
·     Configure radios one by one in radio view.
·     Assign APs to an AP group and configure the radios of the AP group in an AP group's radio view.
·     Configure all radios in global configuration view.
For a radio, the settings made in these views for the same parameter take effect in descending order of radio view, an AP group's radio view, and global configuration view.
Configuring BTM
Enabling BTM
If client anti-sticky is disabled, APs do not examine whether the signal strength of a client is lower than the threshold and do not trigger unsolicited BTM.
Make sure the service template is disabled before you perform this task.
2.     Enter service template view.
wlan service-template service-template-name
3.     Enable BTM.
bss transition-management enable
By default, BTM is disabled.
Specifying the BTM disassociation timeout
If a client fails to leave the current BSS before the disassociation timer expires after sending a BTM response, the associated AP sends a disassociation request to the client and logs off the client.
3.     Specify the BTM disassociation timeout.
bss transition-management forced-disassociation [ timer time ]
By default, the BTM disassociation timeout is not set and APs do not log off clients because of failed BTM disassociation.
Configuring client anti-sticky
This feature enables APs to examine the signal strength of clients at the specified intervals. For an 802.11v client, its associated AP triggers a BSS transition to guide the client to a better BSS if the signal strength of the client is lower than the threshold. For a non-802.11v client, no action is performed.
2.     Enter AP view or an AP group's AP model view.
¡     Enter AP view.
wlan ap ap-name
¡     Execute the following commands in sequence to enter an AP group's AP model view:
wlan ap-group group-name
ap-model ap-model
3.     Enter radio view.
radio radio-id
4.     Configure client anti-sticky.
sacp anti-sticky { disable | enable [ rssi rssi-value ] [ interval interval ] [ forced-logoff ] }
By default:
¡     In radio view, a radio uses the configuration in an AP group's radio view.
¡     In an AP group's radio view, client anti-sticky is enabled.
Display and maintenance commands for 802.11v
Display service template information.
display wlan service-template [ service-template-name ] [ verbose ]
Display client information.
display wlan client [ ap ap-name [ radio radio-id ] | mac-address mac-address | service-template service-template-name | frequency-band { 2.4 | 5 } | vlan vlan-id ] [ verbose ]
For more information about the display wlan service-template and display wlan client commands, see WLAN access commands in WLAN Command Reference.
802.11v configuration examples
Example: Configuring 802.11v
As shown in Figure 2, configure 802.11v for the AP to guide the client to an optimal AP.
Figure 2 Network diagram
# Create service template service.
<AC> system-view
[AC] wlan service-template service
# Set the SSID to service.
[AC-wlan-st-service] ssid service
# Enable BTM.
[AC-wlan-st-service] bss transition-management enable
# Specify the BTM disassociation timeout as 45 seconds.
[AC-wlan-st-service] bss transition-management forced-disassociation 45
# Enable the service template.
[AC-wlan-st-acstname] service-template enable
[AC-wlan-st-acstname] quit
# Create AP ap1, specify the AP model and serial ID, and bind service template service to radio 1 of AP ap1.
[AC] wlan ap ap1 model WA4320i-ACN
[AC-wlan-ap-ap1] serial-id 210235A1BSC123000050
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
# Verify that BTM has been enabled.
[AC] dis wlan service-template service verbose
 Service template name                  : service
 Description                            : Not configured
 SSID                                   : service
 SSID-hide                              : Disabled
 User-isolation                         : Disabled
 Service template status                : Disabled
 Maximum clients per BSS                : Not configured
 Frame format                           : Dot3
 Seamless roam status                   : Disabled
 Seamless roam RSSI threshold           : 50
 Seamless roam RSSI gap                 : 20
 VLAN ID                                : 1
 AKM mode                               : Not configured
 Security IE                            : Not configured
 Cipher suite                           : Not configured
 TKIP countermeasure time               : 0 sec
 PTK lifetime                           : 43200 sec
 PTK rekey                              : Enabled
 GTK rekey                              : Enabled
 GTK rekey method                       : Time-based
 GTK rekey time                         : 86400 sec
 GTK rekey client-offline               : Disabled
 WPA3 status                            : Disabled
 PPSK                                   : Disabled
 PPSK Fail Permit                       : Enabled
 User authentication mode               : Bypass
 Intrusion protection                   : Disabled
 Intrusion protection mode              : Temporary-block
 Temporary block time                   : 180 sec
 Temporary service stop time            : 20 sec
 Fail VLAN ID                           : Not configured
 802.1X handshake                       : Disabled
 802.1X handshake secure                : Disabled
 802.1X domain                          : Not configured
 MAC-auth domain                        : Not configured
 Max 802.1X users per BSS               : 512
 Max MAC-auth users per BSS             : 512
 802.1X re-authenticate                 : Disabled
 Authorization fail mode                : Online
 Accounting fail mode                   : Online
 Authorization                          : Permitted
 Key derivation                         : SHA1
 PMF status                             : Disabled
 Hotspot policy number                  : Not configured
 Forwarding policy status               : Disabled
 Forwarding policy name                 : Not configured
 Forwarder                              : AC
 FT status                              : Disabled
 QoS trust                              : Port
 QoS priority                           : 0
 BTM status                             : Enabled
# Verify that the client has come online.
<AC> display wlan client
Total number of clients: 3
MAC address    Username             AP name               R IP address      VLAN
4581-61ac-885a N/A                  ap1                   1 192.168.66.230  1
# Verify that the client has been logged off 45 seconds after the AP recommends an optimal AP for the client. (Details not shown.)
