21-Internet of Things Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10021-Internet of Things Command Reference
02-LoRaWAN commands
02-LoRaWAN commands 104.48 KB
LoRaWAN commands
The following compatibility matrix shows the support of hardware platforms for LoRaWAN:
Hardware series
Model
Product code
LoRaWAN compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
channel-group
Use channel-group to specify a working channel group.
undo channel-group to restore the default.
channel-group group-number
undo channel-group
No working channel group is specified.
LoRa radio view
group-number: Specifies a working channel group number. The value range for this argument is 1 to 12.
This command enables a LoRa radio interface to select a working channel group that has less interference to communicate with LoRa end nodes.
Table 1 shows the center frequencies of different working channel groups.
Table 1 Center frequencies of working channel groups (unit: MHz, channel bandwidth: 125 KHz)
Working channel group
Channel 1
Channel 2
Channel 3
Channel 4
Channel 5
Channel 6
Channel 7
Channel 8
1
470.3
470.5
470.7
470.9
471.1
471.3
471.5
471.7
2
471.9
472.1
472.3
472.5
472.7
472.9
473.1
473.3
3
473.5
473.7
473.9
474.1
474.3
474.5
474.7
474.9
4
475.1
475.3
475.5
475.7
475.9
476.1
476.3
476.5
5
476.7
476.9
477.1
477.3
477.5
477.7
477.9
478.1
6
478.3
478.5
478.7
478.9
479.1
479.3
479.5
479.7
7
479.9
480.1
480.3
480.5
480.7
480.9
481.1
481.3
8
481.5
481.7
481.9
482.1
482.3
482.5
482.7
482.9
9
483.1
483.3
483.5
483.7
483.9
484.1
484.3
484.5
10
484.7
484.9
485.1
485.3
485.5
485.7
485.9
486.1
11
486.3
486.5
486.7
486.9
487.1
487.3
487.5
487.7
12
487.9
488.1
488.3
488.5
488.7
488.9
489.1
489.3
# Specify working channel group 11 for LoRa radio 1.
[Sysname] wlan ap ap1 model WA5320X-L
[Sysname-wlan-ap-ap1] lora-radio 1
[Sysname-wlan-ap-ap1-LoRa-Radio-1] channel-group 11
display iot lora ap
Use display iot lora ap to display LoRa information about an AP.
display iot lora ap ap-name
ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
This command displays LoRa information about an AP only when the AP supports the LoRa module.
# Display LoRa information about an AP.
<Sysname> display iot lora ap ap1
Server domain                   : N/A
Domain IP                       : N/A
Server IP                       : 10.99.43.107
Destination port                : 1680
Destination push port           : 1690
Keepalive interval              : 15 seconds
Statistics report interval      : 90 seconds
Encryption                      : Enabled
Encrypted destination port      : 1702
CRC forwarding-policy           : CRC correct
GWMP version                    : 2
Radio 1:
 Channel group                  : 11
 Tx power                       : 20 dBm
Aging time                     : 60 minutes
 End node info learning         : Disabled
Server domain
Domain name of the LoRa server.
Domain IP
IP address resolved from the domain name of the LoRa server.
Server IP
IP address of the LoRa server.
Destination port
Port number of the LoRa server.
Push port number of the LoRa server.
Keepalive interval
Interval (in seconds) at which the LoRa gateway sends keepalive packets to the LoRa server.
Interval (in seconds) at which the LoRa gateway sends statistics information to the LoRa server.
Encryption
Link encryption state: Enabled or Disabled.
Port number that the LoRa server uses to establish the encrypted link.
CRC-based packet forwarding policy:
·     CRC all—Forwards all packets.
·     CRC correct, No CRC—Forwards packets that have passed CRC and packets without CRC.
·     CRC correct, CRC error—Forwards packets that have passed or failed CRC.
·     CRC correct—Forwards packets that have passed CRC.
GWMP version
GWMP version number.
Radio
LoRa radio number.
Channel group
Working channel group of the LoRa radio. This field is available only when the 470 MHz frequency band is used. This field displays N/A if no working channel group is specified.
Tx power
Transmit power of the LoRa radio.
Aging time
Aging time of end node entries in minutes.
End node entry learning state: Enabled or Disabled.
display iot lora join-info
Use display iot lora join-info to display join request information about end nodes learnt by the LoRa gateway.
# Display join request information about end nodes learnt by the LoRa gateway.
<Sysname> display iot lora join-info
Total join nodes: 2
DevEUI            Last time       Interface         Aged After
38AD8EFFFE618ACD  11-12 15:11     LoRa-Radion1/0/1  00:26:23
38AD8EFFFE618AE2  11-12 15:08     LoRa-Radion1/0/1  00:24:57
Total join nodes
Total number of end node join requests.
DevEUI
End node identifier.
Last time
Time when the gateway received the most recent join request from an end node.
LoRa radio interface that received the end node join request.
Aged after
Remaining aging time for the end node join request, in the format of hh:mm:ss.
node-info aging
node-info learning enable
reset iot lora join-info
display iot lora node-info ap
Use display iot lora node-info ap to display LoRa end node entries learnt by an AP after the end nodes join the network.
display iot lora node-info ap ap-name
This command displays the LoRa end node entries learnt by an AP only when the AP supports the LoRa module.
# Display LoRa end node entries learnt by an AP after the end nodes join the network.
<Sysname> display iot lora node-info ap ap1
Total end nodes: 2
Node IP           FPort   ADR       FCnt      LRID         Aged after
0.0.0.38          3       Disabled  7680      1            00:59:34
0.0.141.35        3       Disabled  44294     1            00:19:10
Total end nodes
Total number of end node entries after the end nodes join the network.
Node IP
IP address of the end node.
FPort
Port number in the frame sent by the end node.
ADR
ADR state in the frame sent by the end node: Enabled or Disabled.
FCnt
ID of the frame sent by the end node.
LRID
LoRa radio that received the end node frame.
Aged after
Remaining aging time for the end node entry after an end node joins the network, in the format of hh:mm:ss.
node-info aging
reset iot lora node-info ap
iot lora encrypt
Use iot lora encrypt to enable link encryption.
Use undo iot lora encrypt to disable link encryption.
iot lora encrypt [ port port-number ]
Link encryption is disabled. Packets between the LoRa gateway and the LoRa server are transmitted unencrypted through the port number specified by the iot lora server-address or iot lora server-domain command.
AP view
port-number: Specifies the port number of the LoRa server, in the range of 1025 to 65535. The default port number is 1702.
Use this command to enable packets between the LoRa gateway and the LoRa server to be transmitted encrypted through the specified port number.
Modification of LoRa server settings will clear the encryption configuration on the LoRa gateway. To have packets transmitted encrypted, re-enable link encryption for the LoRa gateway.
# Enable link encryption and specify the port number of the LoRa server as 5000.
[Sysname-wlan-ap-ap1] iot lora encrypt port 5000
display iot lora ap
iot lora forwarding-policy
Use iot lora forwarding-policy to specify a CRC-based packet forwarding policy.
Use undo iot lora forwarding-policy to restore the default.
iot lora forwarding-policy { all | crc-error | no-crc }
Only packets that have passed CRC are forwarded.
AP view
all: Forwards all packets.
crc-error: Forwards packets that have passed or failed CRC.
no-crc: Forwards packets that have passed CRC and packets without CRC.
# Configure the LoRa gateway to forward packets that have passed or failed CRC.
[Sysname-wlan-ap-ap1] iot lora forwarding-policy crc-error
display iot lora ap
iot lora gwmp-version
Use iot lora gwmp-version to specify the GWMP version.
Use undo iot lora gwmp-version to restore the default.
iot lora gwmp-version version
GWMP version 2 is used.
AP view
version: Specifies the GWMP version. The value can be 1 or 2.
The LoRa gateway sends Tx ACK packets to the LoRa server only when GWMP version 2 is used.
# Configure the LoRa gateway to use GWMP version 1.
[Sysname-wlan-ap-ap1] iot lora gwmp-version 1
display iot lora ap
iot lora keepalive interval
Use iot lora keepalive interval to set the interval at which the LoRa gateway sends keepalive packets to the LoRa server.
Use undo iot lora keepalive interval to restore the default.
iot lora keepalive interval interval
The LoRa gateway sends keepalive packets to the LoRa server at intervals of 10 seconds.
AP view
interval: Specifies the interval at which the LoRa gateway sends keepalive packets to the LoRa server. The value range for this argument is 5 to 100 seconds.
The LoRa gateway sends keepalive packets to the LoRa server at the specified intervals. If the LoRa gateway fails to receive a response from the LoRa server within three intervals, it tears down the link to the LoRa server.
As a best practice, set the interval for sending keepalive packets shorter than the interval for NAT session timeout to avoid packet loss in a NAT-enabled network.
# Configure the LoRa gateway to send keepalive packets to the LoRa server at intervals of 15 seconds.
[Sysname-wlan-ap-ap1] iot lora keepalive interval 15
display iot lora ap
Use iot lora server-address to specify the IP address and port number of the LoRa server.
Use undo iot lora server-address to restore the default.
iot lora server-address ip ipv4-address port port-number [ push-port push-port-number ]
The IP address and port number of the LoRa server are not specified.
AP view
ip ipv4-address: Specifies the IPv4 address of the LoRa server.
port port-number: Specifies the port number of the LoRa server, in the range of 1025 to 65535.
push-port push-port-number: Specifies the push port number of the LoRa server, in the range of 1025 to 65535. The default push port number is the port number specified by the port port-number option.
The LoRa gateway can communicate with a LoRa server only after you specify the LoRa server on the LoRa gateway.
If you do not specify a push port number, the pull port number is also used as the push port number.
For an H3C LoRa server, the push port number cannot be the same as the pull port number.
The domain name configuration takes precedence over the IP address configuration. If you specify the IP address and then the domain name, the IP address is cleared and the Lora gateway will use the domain name to reestablish a link with the Lora server.
# Specify the IPv4 address and port number of the LoRa server as 192.168.1.1 and 1680, respectively.
[Sysname-wlan-ap-ap1] iot lora server-address ip 192.168.1.1 port 1680
display iot lora ap
Use iot lora server-domain to specify the domain name and port number of the LoRa server.
Use undo iot lora server-domain to restore the default.
iot lora server-domain domain-name ip port port-number [ push-port push-port-number ]
The domain name and port number of the LoRa server are not specified.
AP view
domain-name: Specifies the domain name of the LoRa server, a case-sensitive string of 1 to 253 characters.
ip: Resolves the domain name to an IPv4 address.
The LoRa gateway can communicate with the LoRa server only after you specify the LoRa server on the LoRa gateway.
The domain name configuration takes precedence over the IP address configuration. If you specify the IP address and then the domain name of the LoRa server, the IP address is cleared and the Lora gateway will use the domain name to reestablish a link with the Lora server.
# Specify the domain name and port number of the LoRa server as server.com and 1680, respectively.
[Sysname-wlan-ap-ap1] iot lora server-domain server.com ip port 1680
display iot lora ap
iot lora statistics-report interval
Use iot lora statistics-report interval to set the interval at which the LoRa gateway sends statistics information to the LoRa server.
Use undo iot lora statistics-report interval to restore the default.
iot lora statistics-report interval interval
The LoRa gateway sends statistics information to the LoRa server at intervals of 30 seconds.
AP view
interval: Specifies the interval at which the LoRa gateway sends statistics information to the LoRa server. The value range for this argument is 20 to 600 seconds.
# Configure the LoRa gateway to send statistics information to the LoRa server at intervals of 45 seconds.
[Sysname-wlan-ap-ap1] iot lora statistics-report interval 45
display iot lora ap
lora-radio
Use lora-radio to enter LoRa radio view.
lora-radio lora-radio-id
AP view
lora-radio-id: Specifies the LoRa radio number.
# Enter LoRa radio view.
[Sysname-wlan-ap-ap1-loRa-Radio-1]
node-info aging
Use node-info aging to set the aging time for end node entries.
Use undo node-info aging to restore the default.
node-info aging aging-time
The aging time for end node entries is 60 minutes.
LoRa radio view
aging-time: Specifies the aging time for end node entries, in the range of 10 to 1440 minutes.
After learning the information about an end node, the device generates an entry or refreshes the existing entry for the end node.
Perform this task to set the aging time for end node entries. If an end node entry is not refreshed within the aging time, it will be deleted.
Set an appropriate aging time based on the actual network conditions. A short aging time results in frequent entry generation and removal. A long aging time consumes massive device resources.
# Specify the aging time as 20 minutes for end node entries.
[Sysname-wlan-ap-ap1-LoRa-Radio-1] node-info timer aging 20
Use node-info learning enable to enable end node entry learning.
Use undo node-info learning enable to restore the default.
End node entry learning is disabled.
LoRa radio view
This command enables the device to learn end node entries in real time.
When the number of end node entries that the device learns reached the limit, the device stops learning end node entries.
# Enable end node entry learning.
[Sysname-wlan-ap-ap1-LoRa-Radio-1] node-info learning enable
node-info aging
Use reset iot lora join-info to clear join request information about end nodes learnt by the LoRa gateway.
# Clear join request information about end nodes learnt by the LoRa gateway.
<Sysname> reset iot lora join-info
node-info aging
Use reset iot lora node-info ap to clear end node entries learnt by an AP after the end nodes join the network.
reset iot lora node-info ap ap-name
# Clear end node entries learnt by AP ap1 after the end nodes join the network.
<Sysname> reset iot lora node-info ap ap1
node-info aging
tx-power
Use tx-power to set a transmit power.
Use undo tx-power to restore the default.
tx-power { power-value | max }
undo tx-power
The transmit power of a LoRa radio is 17 dBm.
LoRa radio view
power-value: Specifies a transmit power in dBm. The value of this argument can be -6, -3, 0, 3, 6, 10, 11, 12, 13, 14, or 17.
max: Specifies the maximum transmit power.
Configure this command to manually specify a transmit power.
# Set the transmit power of LoRa radio lora-radio 1 to 10 dBm.
[Sysname-wlan-ap-ap1-LoRa-Radio-1] tx-power 10
display iot lora ap
