20-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10020-Network Management and Monitoring Command Reference
13-SQA commands
13-SQA commands 65.65 KB
SQA commands
display sqa profile
Use display sqa profile to display configuration information for SQA profiles.
display sqa profile [ profile-name ]
profile-name: Specifies an SQA profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify an SQA profile, this command displays configuration information for all SQA profiles.
# Display configuration information for all SQA profiles.
<Sysname> display sqa profile
SQA profile information:
SQA profile name: ssidcompany1
  SIP: Enabled
SQA profile name: ssidcompany2
  SIP: Enabled
Total SQA profiles: 2
SIP
Status of SIP-based SQA for the SQA profile:
·     Enabled.
·     Disabled.
sip enable
display sqa sip call
Use display sqa sip call to display SIP call information.
display sqa sip call [ [ call-id call-id ] verbose ]
call-id call-id: Specifies a SIP call by its call ID, a case-insensitive string of 1 to 64 characters. If you do not specify a SIP call, this command displays information for all SIP calls.
verbose: Displays detailed information about a SIP call.
If you do not specify any parameters, this command displays brief information about all SIP calls.
# Display brief information about all SIP calls.
<Sysname> display sqa sip call
Caller                 Callee                 Call ID
192.168.111.222:65000  192.168.111.223:5000   asdlkfjakdjfkl
192.121.111.252:65012  192.171.251.223:5000   adfdfdffjakdjfkl
Caller
IP address and port number of the calling party.
Callee
IP address and port number of the called party.
Call ID
ID of a SIP call, which uniquely identifies the call.
# Display detailed information about a SIP call.
<Sysname> display sqa sip call call-id asdlkfjakdjfkl verbose
Call ID: asdlkfjakdjfkl
  Caller information:
    IP: 192.168.111.222    Port: 65000    MAC: 0011-2233-CD55
    Tag: [email protected]
  Callee information:
    IP: 192.168.111.123    Port: 65000    MAC: 0111-2AB3-4456
  Type: Audio     VLAN: 1024              StartTime: 2019-10-12 14:21:36
  MOS(F): 3      MOS(R): 3
  Forward flow (octets): 123564           Forward flow (packets): 456215
  Reverse flow (octets): 25642354         Reverse flow (packets): 2451235
Call ID
ID of the call, which uniquely identifies the call.
IP
IP address of the calling party or called party.
Port
Port number of the calling party or called party.
MAC
MAC address of the calling party or called party.
Tag
Tag of the calling party or called party.
The tag is a URL in the format of x@y, where x represents the username or phone number and y represents the domain name or address of the proxy server.
Media type:
·     Audio.
·     Video.
VLAN
ID of the VLAN to which the SIP call belongs.
This field displays a hyphen (-) if data of the the caller uses a wired client.
StartTime
Time when the SIP call was established.
MOS(F)
Mean Opinion Score (MOS) value for the originating voice traffic (traffic from the calling party to the called party), in the range of 0 to 5.
The higher the value, the better the service.
This field displays a hyphen (-) if the system fails to obtain the value.
MOS(R)
MOS value for the returning voice traffic (traffic from the called party to the calling party), in the range of 0 to 5.
Statistics of the originating voice traffic, in bytes.
Statistics of the originating voice traffic, in packets.
Statistics of the returning voice traffic, in bytes.
Statistics of the returning voice traffic, in packets.
sqa enable
sqa-profile
sqa profile
display sqa sip call-statistics
Use display sqa sip call-statistics to display SIP call statistics.
# Display SIP call statistics.
<Sysname> display sqa sip call-statistics
Total calls      : 21
Successful calls : 15 (Active: 10)
Timeout calls    : -
Abnormal calls   : 3
Total calls
Total number of calls that have been placed.
Successful calls
Total number of calls that have been established successfully.
Active
Total number of ongoing calls.
Timeout calls
Total number of timeout calls.
Abnormal calls
Total number of abnormal calls.
sip enable
sip enable
Use sip enable to enable SIP-based SQA.
Use undo sip enable to disable SIP-based SQA.
sip enable
undo sip enable
SIP-based SQA is disabled.
SQA profile view
With this command configured, the service template bound to an SQA profile can preferentially forward audio and video traffic to provide high-quality audio and video services. It also enables the device to analyze, collect, and save traffic and session information.
SQA does not support analysis of encrypted SIP protocol packets or fragments.
For SIP-based SQA to take effect on a service template bound to a radio, do not enable fast forwarding of AP-to-client data frames for the radio (see WLAN optimization in WLAN Advanced Features Configuration Guide).
# Enable SIP-based SQA for SQA profile ssidcompany.
[Sysname] sqa profile ssidcompany
[Sysname-sqa-profile-ssidcompany] sip enable
sqa profile
sip profile
Use sip profile to create an SQA profile and enter its view, or enter the view of an existing SQA profile.
Use undo sqa profile to delete an SQA profile.
sqa profile profile-name
undo sqa profile profile-name
No SQA profiles exist.
profile-name: Specifies the name of an SQA profile, a case-insensitive string of 1 to 31 characters. The SQA profile name can contain digits, letters, hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create SQA profile ssidcompany and enter its view.
display sqa profile
sqa-profile
sqa-profile
Use sqa-profile to bind an SQA profile to a service template.
Use undo sqa-profile to unbind an SQA profile from a service template.
sqa-profile profile-name
undo sqa-profile
No SQA profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one SQA profile to a service template. To bind a different SQA template to the service template, first unbind the existing SQA profile from the service template.
# Bind SQA profile ssidcompany to service template service.
[Sysname-sqa-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] sqa-profile ssidcompany
sip enable
sqa profile
