18-Internet Access Behavior Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10018-Internet Access Behavior Management Command Reference
01-Bandwidth management commands
01-Bandwidth management commands 123.03 KB
The following compatibility matrixes show the support of hardware platforms for bandwidth management:
Hardware series
Model
Product code
Bandwidth management compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
Yes
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3010H-X-PWR
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-L-PWR
·     WX3024H-L-PWR
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
action
Use action to specify a traffic profile for a traffic rule.
Use undo action to restore the default.
action qos profile profile-name
undo action
No traffic profile is specified for a traffic rule (packets matching a traffic rule are allowed to pass).
Traffic rule view
qos profile profile-name: Specifies a traffic profile by its name. The profile name is a case-insensitive string of 1 to 63 characters.
If a packet matches a traffic rule, the device applies the traffic profile specified for the traffic rule to the packet.
# Create a traffic rule named rule1, and apply traffic profile profile1 to the traffic rule.
[Sysname] traffic-policy
[Sysname-traffic-policy] rule name rule1
[Sysname-traffic-policy-rule-rule1] action qos profile profile1
profile name
rule name
application
Use application to configure application or application group as a match criterion.
Use undo application to delete an application or application group match criterion.
application { app application-name | app-group application-group-name }
undo application { app application-name | app-group application-group-name }
No application or application group is used as a match criterion.
Traffic rule view
app application-name: Specifies an application by its name, a case-insensitive string of 1 to 63 characters.
app-group application-group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters.
You can configure multiple applications or application groups for a traffic rule to match packets.
This command enables the device to manage bandwidth by application type, such as email, P2P, IM, and web browsing.
If you specify a user-defined application that uses DCCP, SCTP, or UDP-Lite as the transport layer protocol, the application is not limited by bandwidth management. For information about user-defined applications, see Security Configuration Guide.
# Configure P2P_General_TCP_Communications as a match criterion for traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] application app P2P_General_TCP_Communications
app-group (Security Command Reference)
nbar application (Security Command Reference)
port-mapping (Security Command Reference)
bandwidth
Use bandwidth to set the total guaranteed bandwidth or maximum bandwidth in a traffic profile.
Use undo bandwidth to delete the total guaranteed bandwidth or maximum bandwidth setting of a traffic profile.
bandwidth { downstream | total | upstream } { guaranteed | maximum } bandwidth-value
undo bandwidth { downstream | total | upstream } { guaranteed | maximum }
The total guaranteed bandwidth and maximum bandwidth are not set in a traffic profile.
Traffic profile view
downstream: Specifies downstream traffic (traffic from a server to a client).
total: Specifies both downstream traffic and upstream traffic.
upstream: Specifies upstream traffic (traffic from a client to a server).
guaranteed: Specifies the guaranteed bandwidth.
maximum: Specifies the maximum bandwidth. The maximum bandwidth must be greater than or equal to the guaranteed bandwidth.
bandwidth-value: Specifies the bandwidth value in the range of 8 to 100000000 kbps.
When you specify traffic profiles for parent and child traffic rules, following these restrictions and guidelines:
·     The maximum bandwidth for the child traffic rule must be smaller than or equal to that for the parent traffic rule.
·     The guaranteed bandwidth for a child traffic rule must be smaller than or equal to that for the parent traffic rule.
·     The traffic profiles cannot be the same for the child and parent traffic rules.
An interface with small default expected bandwidth might experience traffic loss if the following conditions exist:
·     There is a large amount of traffic on the interface.
·     The interface uses the default expected bandwidth.
To avoid traffic loss, implicitly set the expected bandwidth to a large value for such an interface. For example, you can set the expected bandwidth of a tunnel interface to a value greater than 64 kbps (the default) if there is a large amount of traffic on the interface.
# In traffic profile profile1, set both upstream and downstream maximum bandwidth to 10000 kbps, and set both upstream and downstream guaranteed bandwidth to 5000 kbps.
[Sysname-traffic-policy] profile name profile1
[Sysname-traffic-policy-profile-profile1] bandwidth upstream maximum 10000
[Sysname-traffic-policy-profile-profile1] bandwidth downstream maximum 10000
[Sysname-traffic-policy-profile-profile1] bandwidth upstream guaranteed 5000
[Sysname-traffic-policy-profile-profile1] bandwidth downstream guaranteed 5000
bandwidth average enable
Use bandwidth average enable to enable dynamic and even allocation for maximum bandwidth.
Use undo bandwidth average enable to disable dynamic and even allocation for maximum bandwidth.
Dynamic and even allocation for maximum bandwidth is disabled.
This command allows the device to dynamically and evenly allocate the total maximum bandwidth among all online IP addresses.
This command can be enabled only after you set the total maximum bandwidth.
# Enable dynamic and even allocation for maximum bandwidth in traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] bandwidth total maximum 10000
[Sysname-traffic-policy-profile-profile1] bandwidth average enable
bandwidth { downstream | total | upstream } maximum
bandwidth { per-ip | per-user }
Use bandwidth { per-ip | per-user } to set the per-IP or per-user maximum or guaranteed bandwidth for a traffic profile.
Use undo bandwidth { per-ip | per-user } to delete the per-IP or per-user maximum or guaranteed bandwidth setting of a traffic profile.
bandwidth { downstream | total | upstream } { guaranteed | maximum } { per-ip | per-user } bandwidth-value
undo bandwidth { downstream | total | upstream } { guaranteed | maximum } { per-ip | per-user }
The per-IP or per-user maximum bandwidth and guaranteed bandwidth are not set in a traffic profile.
guaranteed: Sets the guaranteed bandwidth.
maximum: Sets the maximum bandwidth.
per-ip: Sets the per-IP bandwidth.
per-user: Sets the per-user bandwidth.
This command allows you to manage bandwidth at finer granularity.
The per-IP or per-user maximum bandwidth cannot be greater than the total maximum bandwidth.
The per-IP or per-user guaranteed bandwidth cannot be greater than the total guaranteed bandwidth.
The per-IP or per-user guaranteed bandwidth cannot be greater than the per-IP or per-user maximum bandwidth.
# In traffic profile profile1, set both upstream and downstream per-IP maximum bandwidth to 10000 kbps.
[Sysname-traffic-policy-profile-profile1] bandwidth upstream maximum per-ip 10000
[Sysname-traffic-policy-profile-profile1] bandwidth downstream maximum per-ip 10000
connection-limit count
Use connection-limit count to set the connection count limit for a traffic profile.
Use undo connection-limit count to delete the connection count limit setting of a traffic profile.
connection-limit count { per-rule | per-ip | per-user } connection-number
undo connection-limit count { per-rule | per-ip | per-user }
No connection count limit is set for a traffic profile.
per-rule: Specifies the total connection count limit (count limit for the traffic rule associated with the traffic profile).
per-ip: Specifies the per-IP connection count limit.
per-user: Specifies the per-user connection count limit.
connection-number: Specifies the maximum number of connections allowed, in the range of 1 to 12000000.
The per-IP or per-user connection count limit cannot be greater than the total connection count limit.
You cannot set both per-IP and per-user connection count limits for one traffic profile.
# In traffic profile profile1, set the total connection count limit to 1000.
[Sysname-traffic-policy-profile-profile1] connection-limit count per-rule 1000
# In traffic profile profile1, set the per-IP connection count limit to 500.
[Sysname-traffic-policy-profile-profile1] connection-limit count per-ip 500
connection-limit rate
Use connection-limit rate to set the connection rate limit for a traffic profile.
Use undo connection-limit rate to delete the connection rate limit setting of a traffic profile.
connection-limit rate { per-rule | per-ip | per-user } connection-rate
undo connection-limit rate { per-rule | per-ip | per-user }
No connection rate limit is set for a traffic profile.
per-rule: Specifies the total connection rate limit (rate limit for the traffic rule associated with the traffic profile).
per-ip: Specifies the per-IP connection rate limit.
per-user: Specifies the per-user connection rate limit.
connection- rate: Specifies the maximum connection rate in the range of 1 to 12000000 connections per second.
The per-IP or per-user connection rate limit cannot be greater than the total connection rate limit.
You cannot set both per-IP and per-user connection rate limits for one traffic profile.
# In traffic profile profile1, set the total connection rate limit to 1000 connections per second.
[Sysname-traffic-policy-profile-profile1] connection-limit rate per-rule 1000
# In traffic profile profile1, set the per-IP connection rate limit to 500 connections per second.
[Sysname-traffic-policy-profile-profile1] connection-limit rate per-user 500
disable
Use disable to disable a traffic rule.
Use undo disable to enable a traffic rule.
disable
undo disable
A traffic rule is enabled.
Traffic rule view
If a traffic rule is not used, use this command to disable it. A disabled traffic rule does not participate in traffic matching. You can copy, rename, and move a disabled traffic rule.
# Disable traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] disable
dscp
Use dscp to configure a DSCP priority as a match criterion.
Use undo dscp to remove all DSCP priority match criteria.
dscp dscp-value
undo dscp
No DSCP priority is used as a match criterion.
Traffic rule view
dscp-value: Specifies a DSCP priority, which can only be a keyword in Table 1.
Table 1 Keyword-value map
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
# Configure DSCP priority af11 as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] dscp af11
profile name
Use profile name to create a traffic profile and enter its view, or enter the view of an existing traffic profile.
Use undo profile name to delete a traffic profile.
profile name profile-name
undo profile name profile-name
No traffic profile exists.
Traffic policy view
profile-name: Specifies a name for the traffic profile, a case-insensitive string of 1 to 63 characters.
A traffic profile defines the bandwidth resources that can be used and takes effect after it is specified for a traffic rule.
# Create a traffic profile named profile1 and enter traffic profile view.
Action
profile reference-mode
Use profile reference-mode to set the reference mode for a traffic profile.
Use undo profile reference-mode to restore the default.
profile reference-mode { per-rule | rule-shared }
The reference mode for a traffic profile is per-rule.
per-rule: Specifies that each traffic rule that uses the traffic profile can reach the bandwidth limits and connection limits specified in the profile.
rule-shared: Specifies that all traffic rules that use the traffic profile share the bandwidth limits and connection limits specified in the profile.
After a traffic profile is specified for a traffic rule, the bandwidth limits and connection limits in the profile take effect. The reference mode for a traffic profile can be per-rule or rule-shared.
# Set the reference mode to rule-shared for traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] profile reference-mode rule-shared
profile rename
Use profile rename to rename a traffic profile.
profile rename old-name new-name
Traffic policy view
old-name: Specifies the old name of the traffic profile, a case-insensitive string of 1 to 63 characters.
new-name: Specifies a new name for the traffic profile, a case-insensitive string of 1 to 63 characters. The new name cannot be an existing traffic profile name.
# Create a traffic profile named profile1, and rename traffic profile profile1 as profile2.
[Sysname-traffic-policy-profile-profile1] quit
[Sysname-traffic-policy] profile rename profile1 profile2
remark dscp
Use remark dscp to mark the DSCP priority for packets of a traffic profile.
Use undo remark dscp to restore the default.
remark dscp dscp-value
undo remark dscp
The DSCP priority for packets of a traffic profile is not marked.
Network devices can classify traffic by using DSCP priorities and provide different treatment for packets with different DSCP priorities.
# Mark DSCP priority af22 for packets of traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] remark dscp af22
profile name
rule copy
Use rule copy to copy a traffic rule.
rule copy rule-name new-rule-name
Traffic policy view
rule-name: Specifies a traffic rule to be copied by its name, a case-insensitive string of 1 to 63 characters.
new-rule-name: Specifies a name for the new traffic rule, a case-insensitive string of 1 to 63 characters. The new name cannot be an existing traffic profile name.
If a traffic rule to be created is similar to an existing traffic rule, create the traffic rule by copying the existing traffic rule and then modify it. The new traffic rule is placed next to the copied traffic rule.
If a traffic rule to be copied has child traffic rules, only the parent traffic rule is copied.
# Create a traffic rule named rule2 by copying traffic rule rule1.
[Sysname-traffic-policy] rule copy rule1 rule2
rule move
Use rule move to move a traffic rule to a new position.
rule move rule-name1 { after | before } rule-name2
Traffic policy view
rule-name1: Specifies a traffic rule to be moved by its name, a case-insensitive string of 1 to 63 characters. The traffic rule can be a parent or child traffic rule.
after: Moves the specified traffic rule to the position after a target traffic rule.
before: Moves the specified traffic rule to the position before a target traffic rule.
rule-name2: Specifies the target traffic rule by its name, a case-insensitive string of 1 to 63 characters.
The device matches traffic with traffic rules in their order of appearance on the device. When a traffic rule is matched, the matching process ends and the device applies the traffic profile specified for the traffic rule to the traffic. If no traffic rule is matched, the device forwards the traffic.
To ensure reasonable, precise bandwidth management, configure traffic rules in ascending order of granularity. If the traffic rules are not in ascending order of granularity, you can use the rule move command to change the position of them.
You can move child traffic rules only within their parent traffic rule.
# Create two traffic rules named rule1 and rule2, and move rule1 to the position after rule2.
[Sysname-traffic-policy-rule-rule1] quit
[Sysname-traffic-policy] rule name rule2
[Sysname-traffic-policy-rule-rule2] quit
[Sysname-traffic-policy] rule move rule1 after rule2
rule name
Use rule name to create a traffic rule and enter its view, or enter the view of an existing traffic rule.
Use undo rule name to delete a traffic rule.
rule name rule-name [ parent parent-rule-name ]
undo rule name rule-name
No traffic rule exists.
Traffic policy view
rule-name: Specifies a name for the traffic rule, a case-insensitive string of 1 to 63 characters.
parent parent-rule-name: Specifies a parent traffic rule by its name, a case-insensitive string of 1 to 63 characters. To successfully create the traffic rule, make sure the parent traffic rule already exists.
You can configure multiple traffic rules in the traffic policy. For a traffic rule, you can configure match criteria to match packets and specify the traffic profile to apply to matching packets. The device matches traffic rules in their order of appearance on the device. When a traffic rule is matched, the matching process ends and the device applies the traffic profile for the traffic rule to the traffic. If no traffic rule is matched, the device forwards the traffic.
For a new traffic rule to inherit the match criteria of an existing traffic rule, specify the existing traffic rule as the parent of the new traffic rule.
A level-4 rule cannot act as a parent rule
You can specify a parent traffic rule only when creating a traffic rule. You cannot add or modify a parent traffic rule for an existing traffic rule.
# Create a traffic rule named rule1 and enter traffic rule view.
rule rename
Use rule rename to rename a traffic rule.
rule rename old-rule-name new-rule-name
Traffic policy view
old-rule-name: Specifies the old name of the traffic rule, a case-insensitive string of 1 to 63 characters.
new-rule-name: Specifies a new name for the traffic rule, a case-insensitive string of 1 to 63 characters. The new name cannot be an existing traffic profile name.
# Create a traffic rule named rule1, and rename traffic rule rule1 as rule2.
[Sysname-traffic-policy] rule rename rule1 rule2
time-range
Use time-range to specify a time range during which a traffic rule is in effect.
Use undo time-range to restore the default.
time-range time-range-name
undo time-range
A traffic rule is in effect at any time.
Traffic rule view
time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 32 characters.
# Specify time range work-time for traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] time-range work-time
time-range
traffic-policy
Use traffic-policy to enter traffic policy view.
traffic-policy
In traffic policy view, you can create and manage traffic rules.
# Enter traffic policy view.
traffic-priority
Use traffic-priority to set the traffic priority for a traffic profile.
Use undo traffic-priority to restore the default.
traffic-priority priority-value
The traffic priority is 1 for a traffic profile.
priority-value: Specifies the priority value in the range of 1 to 7. The larger the priority value, the higher the priority.
When an interface is congested with packets of multiple traffic profiles, packets with higher priority are sent first. Packets with the same priority have the same chance of being forwarded.
# Set the traffic priority to 7 for traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] traffic-priority 7
profile name
user
Use user to configure a username as a match criterion.
Use undo user to delete a username match criterion.
user user-name [ domain domain-name ]
undo user user-name [ domain domain-name ]
No username is used as a match criterion.
Traffic rule view
user-name: Specifies a username, a case-insensitive string of 1 to 55 characters. The username cannot be a, al, or all, and cannot contain the following special characters: backslashes (\), vertical bars (|), slash (/), colon (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@).
domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters. The identity domain name cannot contain the following special characters: backslashes (\), vertical bars (|), slash (/), colon (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@). If you do not specify this option, the system matches the user among users that do not belong to any identity domain. For more information about identity domains, see user identification in Security Configuration Guide.
A username corresponds to changing IP addresses. This command implements per-user bandwidth management and facilitates bandwidth management for mobile Internet users whose IP addresses change.
# Configure username managers as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] user managers
# Configure username user1 in identity domain dpi as a match criterion in traffic rule myrule.
[Sysname-traffic-policy] rule name myrule
[Sysname-traffic-policy-rule-myrule] user user1 domain dpi
local-user (Security Command Reference)
user-identity enable (Security Command Reference)
user-identity static-user (Security Command Reference)
user-group
Use user-group to configure a user group as a match criterion.
Use undo user-group to delete a user group match criterion.
user-group user-group-name [ domain domain-name ]
undo user-group user-group-name [ domain domain-name ]
No user group is used as a match criterion.
Traffic rule view
user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters. The identity domain name cannot contain the following special characters: backslashes (\), vertical bars (|), slash (/), colon (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@). If you do not specify this option, the system matches the user group among user groups that do not belong to any identity domain. For more information about identity domains, see user identification in Security Configuration Guide.
A user group corresponds to changing IP addresses. This command implements per-user-group bandwidth management and facilitates bandwidth management for mobile Internet users whose IP addresses change.
# Configure user group mak as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] user-group mak
# Configure user group usergroup1 in identity domain dpi as a match criterion in traffic rule myrule.
[Sysname-traffic-policy-rule-myrule] user-group usergroup1 domain dpi
user-group (Security Command Reference)
wlan ssid
Use wlan ssid to configure an SSID as a match criterion.
Use undo wlan ssid to delete an SSID match criterion.
wlan ssid ssid-name
undo wlan ssid ssid-name
No SSID is used as a match criterion.
Traffic rule view
ssid-name: Specifies an SSID by its name, a case-sensitive string of 1 to 32 characters.
This command matches the packets of users that use the specified SSID. You can configure this command multiple times to specify multiple SSIDs.
# Configure SSID service as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] wlan ssid service
wlan user-profile
Use wlan user-profile to configure a user profile as a match criterion.
Use undo wlan user-profile to delete a user profile match criterion.
wlan user-profile profile-name
undo wlan user-profile profile-name
No user profile is used as a match criterion.
Traffic rule view
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. The name must begin with a letter and can only contain letters, digits, and underscores (_).
When a user accesses the device, the authentication server first authenticates the user. If the user passes authentication, the authentication server sends to the device the name of the user profile bound to the user account. Then, the device can perform bandwidth management on the user according to the settings of the user profile.
This command takes effect only on wireless users. You can configure this command multiple times to specify multiple user profiles.
# Configure user profile user as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] wlan user-profile user
