08-WLAN Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10008-WLAN Security Command Reference
05-PMM commands
05-PMM commands 54.40 KB
PMM commands
The following compatibility matrixes show the support of hardware platforms for PMM:
Hardware series
Model
Product code
PMM compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes:
·     WX2510H
·     WX2510H-F
No:
·     WX2508H-PWR-LTE
·     WX2540H
·     WX2540H-F
·     WX2560H
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
PMM compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
pmm audit-format
Use pmm audit-format to specify the audit packet format.
Use undo pmm audit-format to restore the default.
pmm audit-format { exands | jc | rzx }
The audit packet format is not specified.
exands: Specifies the exands format.
jc: Specifies the jc format, a format required by ACOrange.
rzx: Specifies the rzx format, a format required by SURFILTER.
# Specify the audit packet format as rzx.
[sysname] pmm audit-format rzx
pmm enable
pmm http server
pmm sftp server
pmm source-interface
pmm enable
Use pmm enable to enable packet monitor management (PMM).
Use undo pmm enable to disable PMM.
pmm enable
undo pmm enable
PMM is disabled.
After you enable PMM, the AP starts obtaining packets from clients and sends the packets to the server in the format required by the server.
# Enable PMM for VLAN-interface 100.
[Sysname] pmm enable
pmm audit-format
pmm http server
Use pmm http server to specify the IP address of the exands server.
Use undo pmm http server to restore the default.
pmm http server ipv4 ip-address
The IP address of the exands server is not specified.
ipv4 ip-address: Specifies the IPv4 address of the exands server in dotted decimal notation.
# Specify the IP address of the exands server as 59.40.79.91.
[Sysname] pmm http server ipv4 59.40.79.91
pmm audit-format
Use pmm source-interface to specify the source interface for sending captured packets to a server.
Use undo pmm source-interface to restore the default.
pmm source-interface interface-type interface-number
The source interface for sending captured packets to a server is not specified.
AP view
interface-type interface-number: Specifies the interface type and number.
# Specify VLAN-interface 1 as the source interface for sending captured packets to a server.
[Sysname] pmm source-interface vlan-interface 1
pmm audit-format
pmm enable
pmm sftp server
