05-Network Connectivity Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10005-Network Connectivity Command Reference
13-3G and 4G modem management commands
13-3G and 4G modem management commands 151.32 KB
The following compatibility matrixes show the support of hardware platforms for 3G/4G modem management:
Hardware series
Model
Product code
3G/4G modem management compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes: EWP-WX2508H-PWR-LTE
No:
·     EWP-WX2510H-PWR
·     EWP-WX2510H-F-PWR
·     EWP-WX2540H
·     EWP-WX2540H-F
·     EWP-WX2560H
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40 LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Common management commands
controller cellular
Use controller cellular to enter cellular interface view.
controller cellular cellular-number
cellular-number: Specifies a cellular interface by its number.
# Enter Cellular 1/0/6 interface view.
[Sysname] controller cellular 1/0/6
[Sysname-Cellular 1/0/6]
description
Use description to configure a description for a cellular interface.
The description for a cellular interface is in the interface name Interface format, for example, Cellular 1/0/6 Interface.
Cellular interface view
text: Sets an interface description, a case-sensitive string of 1 to 255 characters.
# Set the description for Cellular 1/0/6 to Cellular-intf.
[Sysname-Cellular1/0/6] description Cellular-intf
display cellular
Use display cellular to display call connection information for a 4G modem.
display cellular [ interface-number ]
cellular [ interface-number ]: Specifies a cellular interface by its number. If you do not specify a cellular interface, this command displays call connection information for all cellular interfaces with 4G modems installed.
The command output might vary by modem manufacturers.
# Display call connection information for a 4G modem (LTE network).
<Sysname> display cellular 1/0/6
Cellular1/0/6:
  Hardware Information:
    Model: U9300C SXNC
    Manufacturer: LONGSUNG
    Modem Firmware Version: 30027
    Hardware Version:-Part=290  version=1
    International Mobile Subscriber Identity (IMSI): None
    International Mobile Equipment Identity (IMEI): 863284043221643
    Modem Status: Online
  Profile Information:
    Profile index: 1
      PDP Type: IPv4
      Header Compression: Off
      Data Compression: Off
      Access Point Name (APN): wonet
    Profile index: 2
      PDP Type: IPv4
      Access Point Name (APN): ctwap
    Profile index: 3
      PDP Type: IPv4
      Access Point Name (APN): WONET
  Network Information:
    Current Service Status: Emergency
    Current Roaming Status: Roaming
    Current Data Bearer Technology: LTE
    Network Selection Mode: Unknown
  Radio Information:
    Technology Preference: LTE only
    Technology Selected: LTE
  LTE related info:
    Current RSSI: 99
  Modem Security Information:
    SIM Status: Not insert
Model
Modem name.
IMEI serial number of the modem.
Modem Status
Status of the modem:
·     Online—The modem is powered on.
·     Offline—The modem is powered off or in lower power mode. The cellular interface is unavailable.
Profile Information
Profile settings for the 4G modem.
Profile index
Index of the profile for modem.
PDP Type
PDP type, displayed only when Profile 1 is Active:
·     IPv4.
·     IPv6.
·     PPP (transparent transmission).
Header Compression
PDP header compression status
·     On.
·     Off.
Data Compression
PDP data compression status:
·     On.
·     Off.
Service status of the modem:
·     Limited—The modem is not in the coverage of the selected network. The cellular interface is not available.
·     Service available—The modem is providing services correctly.
·     Emergency—The modem is providing limited services. The cellular interface is not available.
·     No service—The modem cannot provide services. The cellular interface is not available.
·     Low power—The modem is in low power mode. The cellular interface is not available.
Roaming status:
·     Roaming.
·     Home.
Current data carrier technology:
·     CDMA2000 1X.
·     CDMA2000 HRPD (1xEV-DO).
·     GSM.
·     UMTS.
·     CDMA2000 HRPD (1xEV-DO RevA).
·     EDGE.
·     HSDPA and WCDMA.
·     WCDMA and HSUPA.
·     HSDPA and HSUPA.
·     LTE.
·     CDMA2000 EHRPD.
·     HSDPA+ and WCDMA.
·     HSDPA+ and HSUPA.
·     DC_HSDPA+ and WCDMA.
·     DC_HSDPA+ and HSUPA.
·     HSDPA+ and 64QAM.
·     HSDPA+, 64QAM and HSUPA.
·     TDSCDMA.
·     TDSCDMA and HSDPA.
·     Unknown.
Network selection mode
·     Manual.
·     Automatic.
Mobile Country Code (MCC)
The MCC is displayed if the modem has found the network.
Mobile Network Code (MNC)
The MNC is displayed if the modem is successfully registered with a mobile network.
Location Area Code (LAC)
The LAC is displayed if the modem is successfully registered with a mobile network.
Cell ID
The Cell ID is displayed if the modem is successfully registered with a mobile network.
Radio Information
Radio communication information.
Network connecting preference:
·     AUTO—Connects to a network automatically.
·     GSM only—Connects to a GSM network only.
·     GSM precedence—Connects to a GSM network with preference.
·     WCDMA only—Connects to a WCDMA network only.
·     WCDMA precedence—Connects to a WCDMA network with preference.
·     TD-SCDMA only—Connects to a TD-SCDMA network only.
·     TD-SCDMA precedence—Connects to a TD-SCDMA network with preference.
·     EVDO—Connects to a CDMA-EVDO network only.
·     1x RTT—Connects to a CDMA-1x RTT network only.
·     1xRTT/EVDO HYBRID—Connects to the CDMA-EVDO and CDMA-1x RTT hybrid networks only.
·     LTE only—Connects to an LTE network only.
Technology Selected
Current network:
·     GSM—Has connected to a GSM network.
·     WCDMA—Has connected to a WCDMA network.
·     TD-SCDMA—Has connected to a TD-SCDMA network.
·     EVDO—Has connected to a CDMA-EVDO network.
·     1Xrtt—Has connected to a CDMA-1x RTT network.
·     1xRTT/EVDO HYBRID—Has connected to the CDMA-EVDO and CDMA-1x RTT networks.
·     LTE—Has connected to an LTE network.
LTE related info
Information about the LTE network.
Current RSSI
Current RSSI:
·     An RSSI value in the range of –110 dBm and –51 dBm.
·     Unknown—No signal. The cellular interface is unavailable.
Current RSRQ
Reference Signal Received Quality.
Current RSRP
Reference Signal Receiving Power.
Current SNR
Signal to noise ratio.
Tx Power
Transmitting power.
Information about modem security.
PIN Verification
PIN authentication status:
·     Disabled.
·     Enabled.
·     Unknown.
PIN Status
PIN status:
·     Ready—The SIM card is ready.
·     PIN Requirement—Requires you to execute the pin verify command to enter the PIN for PIN verification.
·     PUK Requirement—Requires you to execute the pin unlock command to unlock the SIM or UIM card.
SIM Status
SIM card status:
·     OK—The SIM card is normal.
·     Network Reject—The SIM card is denied access to the network. The cellular interface is not available.
·     Not Insert—The SIM card is absent. The cellular interface is not available.
·     Not Initialized—The SIM card status cannot be identified.
ICCID
ID of the SIM card, displayed only when the SIM card status is OK.
display controller cellular
Use display controller cellular to display information about cellular interfaces.
display controller [ cellular [ interface-number ] ]
cellular [ interface-number ]: Specifies cellular interfaces or a cellular interface by its number. If you do not specify the cellular keyword, this command displays information about all interfaces. If you specify the cellular keyword but not the interface-number argument, this command displays information about all cellular interfaces.
# Display information about Cellular 1/0/6.
<Sysname> display controller cellular 1/0/6
Cellular1/0/6
Current state: UP
Description: Cellular1/0/6 Interface
Current system time:2020-04-11 22:31:41 Beijing+08:00:00
Last time when physical state changed to up:2020-04-09 17:16:20 Beijing+08:00:00
Last time when physical state changed to down:2020-04-09 17:16:20 Beijing+08:00:00
Modem status: Present
Capability:
 1 Control channel, 1 ETH channel
Control channel traffic statistics:
 TX: 104366 packets
 RX: 104365 packets
Cellular1/0/6
Current state
Status of the interface:
·     DOWN(Administratively)—The interface has been administratively shut down by using the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     UP—The administrative and physical states of the interface are both up.
Description of the interface.
DM port status
DM status:
·     Enabled.
·     Disabled.
Capability:
  1 Control channel, 1 PPP channel
Type and number of channels the cellular interface supports:
·     1 Control channel—Supports one control channel.
·     1 PPP channel—Supports one asynchronous serial subchannel.
·     1 ETH channel—Supports one Ethernet subchannel.
Control channel 0 traffic statistics:
  TX: 0 packets, 0 errors
  RX: 0 packets, 0 errors
Control channel statistics:
·     TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the control channel.
·     RX: 0 packets, 0 errors—Number of packets and number of error packets received through the control channel.
PPP channel 0 traffic statistics
PPP channel statistics:
·     TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the PPP channel.
·     RX: 0 packets, 0 errors—Number of packets and number of error packets received through the PPP channel.
ETH channel 0 traffic statistics
Ethernet channel statistics:
·     TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the Ethernet channel.
·     RX: 0 packets, 0 errors—Number of packets and number of error packets received through the Ethernet channel.
reset counters controller cellular
modem reboot
Use modem reboot to reboot a 4G modem.
modem reboot
CAUTION
CAUTION:
This command will disconnect the established 3G/4G modem connections. Execute this command with caution.
A 4G modem module can automatically detect running errors and reboot. If the 4G modem fails to reboot by itself, you can use this command to reboot it.
# Manually reboot the 4G modem.
[Sysname-Cellular1/0/6] modem reboot
Use reset counters controller cellular to clear statistics on cellular interfaces.
reset counters controller cellular [ interface-number ]
cellular [ interface-number ]: Specifies cellular interfaces or a cellular interface by its number. If you do not specify the interface-number argument, this command clears statistics on all cellular interfaces. If you specify the interface-number argument, this command clears statistics on the specified cellular interface.
To collect traffic statistics on an interface during a period of time, first use the reset counters controller cellular command to clear the existing statistics on the interface.
# Clear statistics on Cellular 1/0/6.
<Sysname> reset counters controller cellular 1/0/6
sendat
Use sendat to issue a configuration directive to a 4G modem.
sendat at-string
at-string: Specifies a configuration directive string, a string of 1 to 300 characters. This argument can be an AT directive (containing +++, A/, or be any string beginning with AT) or a CNS directive. For more information about AT directives, see the sendat command in modem management commands in Network Connectivity Command Reference. Table 3 describes the CNS directive samples.
Table 3 CNS directive description
Directive
CNSn
Controls the CNS heartbeat debugging switch.
·     n = 00000500000000000000—Enables CNS heartbeat debugging.
·     n = 00000800000000000000—Disables CNS heartbeat debugging.
The sendat command does not verify the configuration directive. Each time it issues one configuration directive to the 4G modem, lowercase characters are automatically converted to uppercase characters.
One sendat command issues one configuration directive. To issue multiple configuration directives to a modem, you must repeat the sendat command.
Configuration directives might cause malfunction of a 4G modem. When you issue a configuration directive to the modem, make sure you understand the impact on the 4G modem.
# Issue the ATD169 directive to the 4G modem to call number 169.
[Sysname-Cellular1/0/6] sendat ATD169
# Issue the cns00000500000000000000 directive to the 4G modem to enable CNS heartbeat debugging.
[Sysname-Cellular1/0/6] sendat cns00000500000000000000
shutdown
Use shutdown to shut down a cellular interface.
Use undo shutdown to bring up a cellular interface.
shutdown
The cellular interface is up.
# Shut down Cellular 1/0/6
[Sysname] interface cellular 1/0/6
[Sysname-Cellular1/0/6] shutdown
sim switch-to
Use sim switch-to to specify the primary or secondary SIM card.
sim switch-to card-number
The primary SIM card is used.
card-number: Specifies a SIM card by its slot number. The value is 0 or 1. 0 represents the primary SIM card. 1 represents the secondary SIM card.
CAUTION
CAUTION:
This command might cause traffic interruption. Be aware of the impact of this command before executing it.
On a device that uses dual SIM card, you can execute this command to specify the use of the secondary SIM card when one of the following problems occurs:
·     The 4G link signals of the primary SIM card are weak.
·     The service provider network that the primary SIM card connects to is unavailable.
·     The primary SIM card has failed.
If the issues of the primary SIM card are resolved, you can use this command to specify the use of the primary SIM card.
# Specify the secondary SIM card for the device.
[Sysname-Cellular1/0/6] sim switch-to 1
4G modem-specific management commands
apn-profile
Use apn-profile to create a 4G modem profile.
Use undo apn-profile to remove a 4G modem profile.
apn-profile profile-name
undo apn-profile profile-name
No 4G modem profile exists.
profile-name: Specifies a 4G modem profile name.
A 4G modem profile takes effect only after you apply the profile to a 4G interface. To remove a 4G modem profile, you must first remove the association between the profile and the 4G interface.
# Create 4G modem profile test.
[Sysname] apn-profile test
bandwidth
Use bandwidth to configure the expected bandwidth for an Eth-channel interface.
bandwidth bandwidth-value
undo bandwidth
Eth-channel interface view
# Set the expected bandwidth for Eth-channel 1/0/6:0 to 1000 kbps.
[Sysname] interface eth-channel 1/0/6:0
[Sysname-Eth-channel1/0/6:0] bandwidth 1000
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command before using it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands. Then, use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Eth-channel 1/0/6:0.
[Sysname-Eth-channel1/0/6:0] default
description
Use description to configure the description of an Eth-channel interface.
The description for an Eth-channel interface is in the interface name Interface format, for example, Echannel 1/0/6:0 Interface.
Configure the description of an interface for easy identification and management purposes.
You can use the display interface command to view the description for an interface.
# Configure the description for Eth-channel 1/0/6:0 as Echannel-interface.
[Sysname-Eth-channel1/0/6:0] description Echannel-interface
display interface eth-channel
Use display interface eth-channel to display information about the specified or all Eth-channel interfaces.
display interface [ eth-channel [ channel-id ] ] [ brief [ description | down ] ]
eth-channel [ channel-id ]: Specifies Eth-channel interfaces or an Eth-channel interface by its number. If you do not specify the eth-channel keyword, the command displays information about all interfaces. If you specify the eth-channel keyword but not the channel-id argument, this command displays information about all Eth-channel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Eth-channel 1/0/6:0.
<Sysname> display interface eth-channel 1/0/6:0
Eth-channel1/0/6:0
Current state: DOWN
Line protocol state: DOWN
Description: Eth-channel1/0/6:0 Interface
Bandwidth: 1000 kbps
IP packet frame type: Ethernet II, hardware address: 00a0-d5ff-ff00
IPv6 packet frame type: Ethernet II, hardware address: 00a0-d5ff-ff00
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Last link flapping: 00:00:00
Input:
  0 packets, 0 bytes
  0 broadcasts, 0 multicasts, 0 unicasts, 0 pauses
  0 errors, 0 runts, 0 giants
  0 CRC, 0 overruns
  0 drops, 0 no buffers
Output:
  0 packets, 0 bytes
  0 errors, 0 underruns, 0 collisions
  0 deferred, 0 lost carriers
# Display brief information about Eth-channel 1/0/6:0.
<Sysname> display interface eth-channel 1/0/6:0 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Echannel1/0/6:0      UP   UP(s)    192.168.80.239
# Display information about all Eth-channel interfaces in down state and the causes.
<Sysname> display interface eth-channel brief down
Echannel1/0/6:0      ADM  Administratively
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description for the interface.
Bandwidth
Expected bandwidth of the interface.
Maximum Transmit Unit
MTU of the interface.
Internet protocol processing: disabled
The interface is not assigned an IP address and cannot process IP packets.
Internet Address is 192.168.1.200/24 Primary
IP address of the interface. The primary attribute indicates that the address is the primary IP address..
IP Packet Frame Type
IPv4 packet framing format.
Hardware Address
MAC address of the interface.
IPv6 Packet Frame Type
IPv6 packet framing format.
Packet statistics for urgent queuing in the output queue of the interface:
·     Size—Current number of packets in the queue.
·     Length—Maximum number of packets that can stay in the queue.
·     Discards—Number of dropped packets.
Packet statistics for protocol queuing in the output queue of the interface:
Packet statistics for FIFO queuing in the output queue of the interface:
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when statistics on the logical interface were last cleared by using the reset counters interface command.
If statistics about the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never.
Last 300 seconds input rate
Average input rate during the last 300 seconds:
·     bytes/sec—Average number of received bytes per second.
·     bits/sec—Average number of received bits per second.
·     packets/sec—Average number of received packets per second.
Last 300 seconds output rate
Average output rate over the last 300 seconds:
·     bytes/sec—Average number of sent bytes per second.
·     bits/sec—Average number of sent bits per second.
·     packets/sec—Average number of sent packets per second.
Input: 0 packets, 0 bytes, 0 buffers
Incoming packet statistics:
·     0 packets—Packet number.
·     0 bytes—Packet size in bytes.
·     0 buffers—Number of buffered units.
Output: 0 packets, 0 bytes
Outgoing packet statistics:
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Main IP
Main IP address of the interface.
Cause
Cause for the physical link state of the interface to be DOWN. The value of the field varies by device model.
Administratively represents that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
eth-channel
Use eth-channel to channelize a cellular interface into an Eth-channel interface.
Use undo eth-channel to remove the Eth-channel interface channelized from a cellular interface.
eth-channel channel-number
undo eth-channel channel-number
channel-number: Specifies an Eth-channel interface by its number. The value is 0.
This command names the Eth-channel interface channelized from a cellular interface as eth-channel cellular-number:channel-number.
# Channelize Cellular 1/0/6 into an Eth-channel interface.
[Sysname-Cellular1/0/6] eth-channel 0
Use interface eth-channel to enter Eth-channel interface view.
interface eth-channel interface-number
interface-number: Specifies an Eth-channel interface by its number.
# Enter Eth-channel 1/0/6:0 interface view.
mtu
Use mtu to set the maximum transmission unit (MTU) for an interface.
mtu size
undo mtu
The MTU of an interface is 1500 bytes.
size: Sets the MTU in bytes. The value range for the size argument is 128 to 2000.
# Set the MTU for Eth-channel 1/0/6:0 to 1430 bytes.
[Sysname-Eth-channel1/0/6:0] mtu 1430
Use reset counters interface to clear statistics on the specified or all Eth-channel interfaces.
reset counters interface [ eth-channel [ channel-id ] ]
eth-channel [ channel-id ]: Specifies Eth-channel interfaces or an Eth-channel interface by its number. If you do not the eth-channel keyword, the command clears statistics on all interfaces. If you specify the eth-channel keyword but not the channel-id argument, this command clears statistics on all Eth-channel interfaces. If you specify both the eth-channel keyword and the channel-id argument, this command clears statistics on the specified Eth-channel interface.
Use this command to clear history statistics if you want to collect traffic statistics for a specific period.
# Clear statistics on Eth-channel 1/0/6:0.
<Sysname> reset counters interface eth-channel 1/0/6:0
shutdown
Use shutdown to shut down an Eth-channel interface.
Use undo shutdown to bring up an Eth-channel interface.
shutdown
An Eth-channel interface is up.
# Shut down Eth-channel 1/0/6:0.
[Sysname-Eth-channel1/0/6:0] shutdown
