02-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10002-Fundamentals Command Reference
07-Software upgrade commands
07-Software upgrade commands 86.89 KB
The WX1800H series, WX2500H series, MAK series, and WX3000H series access controllers do not support parameters or commands that are available only in IRF mode.
As a best practice, store the startup images in the factory default file system. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
boot-loader file
Use boot-loader file to specify startup image files.
In standalone mode:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { backup | main }
boot-loader file ipe-filename { backup | main }
In IRF mode:
boot-loader file boot filename system filename [ feature filename&<1-30> ] { all | slot slot-number } { backup | main }
boot-loader file ipe-filename { all | slot slot-number } { backup | main }
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
ipe-filename: Specifies an .ipe image package file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all hardware components to which the specified images apply.
slot slot-number: Specifies the IRF member ID of a member device. (In IRF mode.)
backup: Specifies the files as backup startup image files. Backup images are used only when main images are not available.
main: Specifies the files as main startup image files. The device always first attempts to start up with main startup files.
The boot-loader file command overwrites the entire startup image list. To add new startup feature images, specify all feature image files in the old startup image list, including feature image files. The new startup image list will contain only the feature image files that are specified in the command.
To load the specified startup software images, you must reboot the system.
If the upgrade images are not found in the file system on the slot specified to upgrade, the system automatically copies the images to that file system. The destination directory is the root directory of the file system. If the destination root directory already contains a startup image with the same name as an upgrade image, you must choose whether to overwrite the image.
# (In standalone mode.) Specify flash:/all.ipe as the main startup image file.
<Sysname> boot-loader file flash:/all.ipe main
Verifying the file flash:/all.ipe on the device.............Done.
H3C WX2560H images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to the device.
File flash:/boot.bin already exists on the device.
File flash:/system.bin already exists on the device.
Overwrite the existing files? [Y/N]:Y
Decompressing file boot.bin to flash:/boot.bin........................Done.
Decompressing file system.bin to flash:/system.bin...............................Done.
Verifying the file flash:/boot.bin on the device...Done.
Verifying the file flash:/system.bin on the device.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on the device..
# (In standalone mode.) Specify flash:/boot.bin and flash:/system.bin as the main startup boot and system image files.
<Sysname> boot-loader file boot flash:/boot.bin system flash:/system.bin main
# (In IRF mode.) Specify flash:/all.ipe as the main startup image file for slot 1.
<Sysname> boot-loader file flash:/all.ipe slot 1 main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C WX5560H images in IPE:
  boot.bin
  system.bin
Add images to slot 1.
File flash:/boot.bin already exists on slot 1.
File flash:/system.bin already exists on slot 1.
Verifying the file flash:/boot.bin on slot 1...Done.
Verifying the file flash:/system.bin on slot 1.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# (In IRF mode.) Specify flash:/all.ipe as the main startup image file for all IRF member devices.
<Sysname> boot-loader file slot1#flash:/all.ipe all main
Verifying the file flash:/all.ipe on slot 1......................................Done.
  Boot.bin
  System.bin
This command will set the main startup software images. Continue? [Y/N]:y
File flash:/Boot.bin already exists on slot 1.
File flash:/System.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:y
Decompressing file Boot.bin to flash:/Boot.bin........................Done.
Decompressing file System.bin to flash:/System.bin........................Done.
File flash:/Boot.bin already exists on slot 2.
Do you want to overwrite the file?
 Y: Overwrite the file.
 N: Not overwrite the file.
 A: From now on, overwrite or not overwrite without prompt.
Please make a choice. [Y/N/A]:a
What type of overwrite operation do you want to perform?
 Y: Overwrite without prompt.
 N: Not overwrite or display prompt.
 Q: Return to the previous step.
Please make a choice. [Y/N/Q]:y
An existing file will be overwritten without prompt if it has the same name as any upgrade file.
Loading......................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 2.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 3.
Decompression completed.
Do you want to delete flash:/all.ipe now? [Y/N]:n
display boot-loader
boot-loader update
Use boot-loader update to synchronize startup images.
boot-loader update { all | slot slot-number }
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware series
Model
Product code
Command compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
all: Synchronizes startup images from the master to all subordinate devices.
slot slot-number: Specifies the IRF member ID of a subordinate device.
You can use this command to synchronize startup images after adding new member devices.
The startup images synchronized to the subordinate device are set as main startup images, regardless of whether the source startup images are main or backup.
·     If the master device has started up with main startup images, its main startup images are synchronized to the subordinate device, regardless of whether any main startup image has been respecified on the master device.
·     If the master device has started up with backup startup images, its backup startup images are synchronized to the subordinate device, regardless of whether any backup startup image has been respecified on the master device.
Startup image synchronization fails if any software image being synchronized is not available or is corrupted.
# Synchronize startup images from the active MPU to the standby MPU in slot 2.
<Sysname> boot-loader update slot 2
This command will update all the standby MPU. Please do not reboot any MPU during the upgrade. Continue? [Y/N]:y
Updating. Please wait...
Verifying the file cfa0:/boot.bin on slot 2...Done
Verifying the file cfa0:/system.bin on slot 2....Done.
Successfully updated the startup software images of all the standby MPU.
display boot-loader
bootrom backup
Use bootrom backup to back up the BootWare image in the Normal area to the Backup area on a BootWare.
In standalone mode:
bootrom backup [ all | part ]
In IRF mode:
bootrom backup slot slot-number-list [ all | part ]
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies an IRF member device by its member ID or a range of IRF member devices in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
all: Backs up the entire BootWare image, including the basic segment and the extended segment. If you do not specify the all or part keyword, this command backs up the entire BootWare image.
part: Backs up the extended BootWare image section.
A BootWare is divided into a Normal area and a Backup area. The BootWare image is stored in the Normal area and backed up to the Backup area. At startup, the system reads the BootWare image automatically from the Normal area. If the image is inaccessible, the system reads the BootWare image from the Backup area.
If the BootWare image in the Normal area is corrupted or requires a version rollback, use the bootrom restore command to copy the BootWare image in the Backup area to the Normal area.
# Back up the entire BootWare image from the Normal area to the Backup area.
<Sysname> bootrom backup slot 1
Now backing up the Boot ROM, please wait...
......Done.
bootrom restore
bootrom read
Use bootrom read to back up the BootWare image in the Normal area of a BootWare to the default file system.
In standalone mode:
bootrom read [ all | part ]
In IRF mode:
bootrom read slot slot-number-list [ all | part ]
For each BootWare image you are backing up, this command creates two files (basicbtm.bin and extendbtm.bin) in the flash memory for the basic segment and the extended segment. If the BootWare image in the Normal area of a BootWare is corrupted or requires a version rollback, use the bootrom update command to read the two backup files from the flash memory to the BootWare.
# Back up the BootWare image from the Normal area of BootWare to the flash memory.
<Sysname> bootrom read slot 1
  Now reading the Boot ROM, please wait...
.........Done.
bootrom update
bootrom restore
Use bootrom restore to replace the BootWare image in the Normal area with the BootWare image in the Backup area for image restoration or version rollback.
In standalone mode:
bootrom restore [ all | part ]
In IRF mode:
bootrom restore slot slot-number-list [ all | part ]
all: Restores the entire BootWare image, including the basic segment and the extended segment. If you do not specify the all or part keyword, this command restores the entire BootWare image.
part: Restores the extended BootWare image section.
# (In standalone mode.) Restore the entire BootWare image.
<Sysname> bootrom restore all
  This command will restore the Boot ROM file, Continue? [Y/N]:y
  Now restoring the Boot ROM, please wait...
......Done.
# (In IRF mode.) Restore the entire BootWare image.
<Sysname> bootrom restore slot 1
  This command will restore the Boot ROM file on the specified board(s), Continue? [Y/N]:y
......Done.
bootrom backup
bootrom update
Use bootrom update to load the BootWare image from a file system to the Normal BootWare area.
In standalone mode:
bootrom update file file [ all | part ]
In IRF mode:
bootrom update file file slot slot-number-list [ all | part ]
file file: Specifies the file that contains the BootWare image. The file argument represents the file name, a string of 1 to 63 characters.
all: Loads the entire BootWare image, including the basic segment and the extended segment. If you do not specify the all or part keyword, this command restores the entire BootWare image.
part: Loads the extended BootWare image section.
BootWare images are contained in the .bin Comware boot image file. You can specify a Comware boot image file in this command to upgrade the BootWares in the system before you upgrade the Comware images. If you do not upgrade BootWares before upgrading Comware images, the system automatically upgrades BootWares as necessary when loading Comware images.
The new BootWare images take effect after you reboot the device.
# (In standalone mode.) Use the file a.bin in the root directory of the flash memory to upgrade the BootWare image.
<Sysname> bootrom update file flash:/a.bin
   This command will update the Boot ROM file, Continue? [Y/N]:y
   Now updating the Boot ROM, please wait................Done.
# (In IRF mode.) Use the file a.bin in the root directory of the flash memory to upgrade the BootWare image.
<Sysname> bootrom update file flash:/a.bin slot 1
   This command will update the Boot ROM file on the specified board(s), Continue? [Y/N]:y
boot-loader file
display boot-loader
Use display boot-loader to display current software images and startup software images.
In standalone mode:
display boot-loader
In IRF mode:
display boot-loader [ slot slot-number ]
slot slot-number: Specifies the member ID of an IRF member device. If you do not specify a member device, this command displays the software images on each IRF member device.
# (In standalone mode.) Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on the device:
Current software images:
  Image                                                 Version
  flash:/boot.bin                                     Release 0053
  flash:/system.bin                                   Release 0053
Main startup software images:
  Image                                                 Version
  flash:/boot.bin                                     Releae 0054
  flash:/system.bin                                   Releae 0054
Backup startup software images:
  Image                                                 Version
  flash:/boot.bin                                     --
  flash:/system.bin                                   --
# (In IRF mode.) Display the current software images and startup software images.
Software images on slot 1:
  Image                                                 Version
  Image                                                 Version
  flash:/boot.bin                                     Release 0054
  flash:/system.bin                                   Release 0054
  Image                                                 Version
  flash:/boot.bin                                      --
Comware images that have been loaded.
Image name.
Version
Image version.
If an image is corrupted or deleted, this field displays two hyphens (--).
Primary Comware images for the next startup.
If the primary Comware images are not specified, this field displays None.
Backup Comware images for the next startup.
If the backup Comware images are not specified, this field displays None.
boot-loader file
