03-Monitor
HomeSupportSecurityH3C SecCenter CSAP-NTAConfigure & DeployConfiguration GuidesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Web-Based Configure Guide-6W60003-Monitor
29-Asset security
29-Asset security 23.49 KB
Asset security
This help contains the following topics:
·     Introduction
·     Restrictions and guidelines
·     Configure asset security
·     Appendix
Introduction
The device analyses health status of downstream hosts and supports displaying the number of compromised hosts and security event distribution in graphs and tables. You can view a summary on the security status of downstream hosts, and a detailed security analysis report for a single host. Thus, you can take prevention actions based asset security information.
·     The detailed security analysis report for a single host displays only the statistics over the past half year.
·     The device generates detailed security analysis reports only for the hosts at the Controlled risk level or higher.
1.     Click the Monitor tab.
2.     In the navigation pane, select Asset Security.
The page displays security summary of hosts on the Hosts at risk tab. For information about risk levels, see "Appendix."
3.     To view the detailed security analysis report for a single host, click the host name in the table.
Appendix
Table 1 Risk level description
Risk level
Vulnerable
A vulnerability exists on a host.
Attacked
Malicious attacks are present and not blocked. For example, a host might be attacked by DDoS attacks, SQL injection attacks, worm attacks, Web shells, or has received ransomware or bots.
Controlled
Communication exists between an infected host and a C&C server.
Spread
An infected host has sent threats to other hosts.
Damaged
A file on an infected host has been leaked, or an infected host has been attacked by ransomware or has been forced to run mining software.
