02-Dashboard
HomeSupportSecurityH3C SecCenter CSAP-NTAConfigure & DeployConfiguration GuidesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Web-Based Configure Guide-6W60002-Dashboard
04-Threat monitor
04-Threat monitor 25.19 KB
Threat monitor
Introduction
Threat monitor provides the rankings of threats detected in the most recent monitoring interval by different ranking criteria. Both IPS events and anti-virus events are classified as threats.
Threat monitor provides the following widgets:
·     Threat monitor user ranking.
·     Threat monitor application ranking.
·     Attacker ranking.
·     Attacked target ranking.
·     Threat type ranking.
·     Threat name ranking.
·     Threats overview. Support for this widget depends on the device model.
To customize the widgets displayed on the Threat Monitor page, click Select widgets and select the desired widgets from the list.
To enable automatic refresh for a widget:
1.     Click the Set icon  in the top-right corner of the widget.
2.     Select the Auto refresh option.
3.     Enter the refresh interval in the Refresh interval field.
4.     Click OK.
Threat monitor user ranking widget
This widget ranks users by the number of times they are attacked by threats, which helps administrators customize policies to protect vulnerable users.
Threat monitor application ranking widget
This widget ranks applications carrying viruses by the number of times they poses threats to the network, which helps administrators customize security policies to improve security.
Attacker ranking widget
This widget ranks attackers by the number of threat attacks they launched, which helps administrators customize security policies targeted at the attackers to improve security.
Attacked target ranking widget
This widget ranks attacked targets by the number of times they are attacked, which helps administrators customize security policies to protect targets vulnerable to attacks.
Threat type ranking widget
This widget ranks types of threats by threat count, which helps administrators customize security policies to address the most common types of threats to improve security.
Threat name ranking widget
This widget ranks threats by threat count, which helps administrators customize security policies to address the most common threats to improve security.
Security Status
This widget displays the risk factor and security event distribution. To view detailed statistics analysis, click the data in the Security Event Distribution graph.
Top 10 Hosts at Risk
This widget displays compromised host information, including hostname, risk level, and attack events. To view detailed risk analysis for a host, click the hostname.
