10-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath IPS Comware 7 Configuration Guides (R8560 R8660)-6W60010-Layer 3—IP Services Configuration Guide
10-IP performance optimization configuration
10-IP performance optimization configuration 129.28 KB
Optimizing IP performance
IP performance optimization tasks at a glance
All IP performance optimization tasks are optional.
1.     Configuring features for IP packets
¡     Enabling an interface to receive and forward directed broadcasts destined for the directly connected network
¡     Setting the interface MTU for IPv4 packets
¡     Enabling IPv4 local fragment reassembly
This feature is applicable in IRF networks.
¡     Enabling IPv4 virtual fragment reassembly
¡     Enabling fragment centralizaton for IPv4 VFR
¡     Disabling IPv4 VFR
¡     Enabling fragment centralizaton for IPv6 VFR
¡     Disabling IPv6 VFR
2.     Configuring features for ICMP messages
¡     Enabling sending ICMP error messages
¡     Configuring rate limit for ICMP error messages
¡     Specifying the source address for ICMP packets
3.     Configuring features for TCP packets
¡     Setting TCP MSS for an interface
¡     Configuring TCP path MTU discovery
¡     Enabling SYN Cookie
¡     Setting the TCP buffer size
¡     Setting TCP timers
¡     Enabling carrying the TCP timestamp option in outgoing TCP packets
About forwarding broadcasts destined for the directly connected network
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
2.     Enter interface view.
3.     Enable the interface to receive and forward directed broadcasts destined for the directly connected network.
ip forward-broadcast
By default, an interface can receive directed broadcasts destined for the directly connected network, but it cannot forward these broadcasts.
The interface MTU for IPv4 packets defines the largest size of an IPv4 packet that an interface can transmit without fragmentation. When a packet exceeds the MTU of the sending interface, the device processes the packet in one of the following ways:
·     If the packet disallows fragmentation, the device discards it.
·     If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set the MTU based on the network environment to avoid fragmentation.
3.     Set the interface MTU for IPv4 packets.
ip mtu mtu-size
By default, the interface MTU is not set.
Use this feature on a device to improve fragment reassembly efficiency. This feature enables the LPU to reassemble the IPv4 fragments of a packet if all the fragments arrive at it. If this feature is disabled, all IPv4 fragments are delivered to the active MPU for reassembly. The feature applies only to fragments destined for the same LPU.
Use this feature on a multichassis IRF fabric to improve fragment reassembly efficiency. This feature enables a subordinate to reassemble the IPv4 fragments of a packet if all the fragments arrive at it. If this feature is disabled, all IPv4 fragments are delivered to the master device for reassembly. The feature applies only to fragments destined for the same subordinate.
2.     Enable IPv4 local fragment reassembly.
ip reassemble local enable
By default, IPv4 local fragment reassembly is disabled.
To prevent each service module from processing packet fragments that do not arrive in order, you can enable the virtual fragment reassembly (VFR) feature. This feature virtually reassembles the fragments of a datagram through fragment check, sequencing, and caching, ensuring fragments arrive at each service module in order.
VFR can detect and prevent the following types of attacks:
·     Tiny fragment attack—The first fragment size is too small to hold the Layer 4 (such as TCP and UDP) header field, which is forced into the second fragment. VFR discards all tiny fragments.
·     Overlapping fragment attack—Two consecutive incoming fragments are identical or overlap with each other. If an overlapping fragment is detected, VFR discards all fragments within a fragment chain.
·     Fragment flooding attack—The maximum number of concurrent preassemblies or the number of fragments per datagram exceeds the upper limits. VFR discards subsequent fragments if the upper limit is reached.
The enabling status of VFR can be managed at CLI or the enabling status of a service module that can call VFR. VRF is enabled in either of the following conditions:
·     A service module that can call it is enabled.
·     The ip virtual-reassembly enable command is executed.
If fragment reassembly is required, but a service module cannot call it, execute this command at CLI.
2.     Enable IPv4 virtual fragment reassembly.
By default, IPv4 virtual fragment reassembly is disabled.
On an HA network, if an HA device enabled with IPv4 VFR does not receive all fragments of a datagram, it cannot reassemble the datagram and will discard the received fragments. To resolve this issue, you can enable this feature. Devices that do not receive the first fragment of a datagram forward the received fragments of this datagram to the device that receives the first fragment for VFR.
This feature is applicable to devices enabled with IPv4 VFR on a HA network.
For more information about HA network, see high availability configuration in High Availability Configuration Guide.
2.     Enable fragment centralizaton for IPv4 VFR.
ip virtual-reassembly centralize
By default, fragment centralizaton is disabled for IPv4 VFR.
Disabling IPv4 VFR
IPv4 VFR checks, sequences, and caches fragments upon fragment receiving to ensure that fragments to assemble are in the correct order. By default, IPv4 VFR is enabled.
On an HA network, if an HA device does not receive all fragments of a datagram, it cannot reassemble the datagram and will discard the received fragments. For the devices to permit the received fragments to pass, you can disable IPv4 VFR.
With IPv4 VFR disabled, ASPF and connection limit do not take effect on the received IPv4 fragments and the fragments will be forwarded directly.
Use this feature according to the demands of VFR.
2.     Disable IPv4 VFR.
ip virtual-reassembly suppress
On an HA network, if an HA device enabled with IPv6 VFR does not receive all fragments of a datagram, it cannot reassemble the datagram and will discard all the received fragments. To resolve this issue, you can enable this feature. Devices that do not receive the first fragment of a datagram forward the received fragments of this datagram to the device that receives the first fragment for VFR.
This feature is applicable to devices enabled with IPv6 VFR on a HA network.
2.     Enable fragment centralizaton for IPv6 VFR.
ipv6 virtual-reassembly centralize
By default, fragment centralizaton is disabled for IPv6 VFR.
Disabling IPv6 VFR
IPv6 VFR checks, sequences, and caches fragments upon fragment receiving to ensure that fragments to assemble are in the correct order. By default, IPv6 VFR is enabled.
On an HA network, if an HA device does not receive all fragments of a datagram, it cannot reassemble the datagram and will discard the received fragments. For the devices to permit the received fragments to pass, you can disable IPv6 VFR.
With IPv6 VFR disabled, ASPF and connection limit do not take effect on the received IPv6 fragments and the fragments will be forwarded directly.
2.     Disable IPv6 VFR.
ipv6 virtual-reassembly suppress
Configuring the DF bit for IP packets
This task configures the Don't Fragment (DF) bit for the IP packets to be forwarded:
·     set—Sets the DF bit in the IP packets to 1 to prevent the devices on the path from fragmenting the IP packets. If the path MTU is less than the size of the IP packets and DF bit is set, communication interruption occurs. The devices on the path will drop the IP packets and reply ICMP error messages to the IP packet sender.
·     clear—Sets the DF bit in the IP packets to 0. The devices can fragment the IP packets before forwarding them.
This feature does not apply to IP packets generated by the local device.
2.     Configure the DF bit for IP packets.
ip df-bit { clear | set }
By default, the DF bit value of IP packets is retained as it is.
About sending ICMP error messages
ICMP messages are used by network layer and transport layer protocols to communicate updates and errors with other devices, facilitating network management.
Sending excessive ICMP messages increases network traffic. The device performance degrades if it receives a lot of malicious ICMP messages that cause it to respond with ICMP error messages. To prevent such problems, the sending of ICMP error messages is disabled by default. You can enable sending ICMP error messages of different types as needed.
ICMP error messages include redirect messages, time exceeded messages, and destination unreachable messages.
Enabling sending ICMP redirect messages
A host that has only one default route sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop when the following conditons are met:
·     The receiving and sending interfaces are the same.
·     The packet source IP address and the IP address of the packet receiving interface are on the same segment.
·     There is no source route option in the received packet.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing table.
2.     Enable sending ICMP redirect messages.
ip redirects enable
By default, the sending of ICMP redirect messages is disabled.
Enabling sending ICMP time exceeded messages
A device sends ICMP time exceeded messages by following these rules:
·     The device sends the source an ICMP TTL exceeded in transit message when the following conditions are met:
¡     The received packet is not destined for the device.
¡     The TTL field of the packet is 1.
·     When the device receives the first fragment of an IP datagram destined for it, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
If the ICMP time exceeded message sending is disabled, the device does not send ICMP TTL exceeded in transit messages. However, it can still send ICMP fragment reassembly time exceeded messages.
2.     Enable sending ICMP time exceeded messages.
ip ttl-expires enable
By default, the sending of ICMP time exceeded messages is disabled.
Enable sending ICMP destination unreachable messages
A device sends ICMP destination unreachable messages by following these rules:
·     The device sends the source an ICMP network unreachable message when the following conditions are met:
¡     The packet does not match any route.
¡     No default route exists in the routing table.
·     The device sends the source an ICMP protocol unreachable message when the following conditions are met:
¡     The packet is destined for the device.
¡     The transport layer protocol of the packet is not supported by the device.
·     The device sends the source an ICMP port unreachable message when the following conditions are met:
¡     The UDP packet is destined for the device.
¡     The packet's port number does not match the corresponding process.
·     The device sends the source an ICMP source route failed message when the following conditions are met:
¡     The source uses Strict Source Routing to send packets.
¡     The intermediate device finds that the next hop specified by the source is not directly connected.
·     The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
¡     The MTU of the sending interface is smaller than the packet.
¡     The packet has DF set.
2.     Enable sending ICMP destination unreachable messages.
ip unreachables enable
By default, the sending of ICMP destination unreachable messages is disabled.
To avoid sending excessive ICMP error messages within a short period that might cause network congestion, you can limit the rate at which ICMP error messages are sent. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
2.     Set the interval for tokens to arrive in the bucket and the bucket size for ICMP error messages.
By default, a token is placed in the bucket at intervals of 100 milliseconds and the bucket allows a maximum of 10 tokens.
To disable the ICMP rate limit, set the interval to 0 milliseconds.
Specifying the source IP address for outgoing ping echo requests and ICMP error messages helps users to locate the sending device easily. As a best practice, specify the IP address of the loopback interface as the source IP address.
If you specify an IP address in the ping command, ping echo requests use the specified address as the source IP address rather than the IP address specified by the ip icmp source command.
2.     Specify the source address for outgoing ICMP packets.
By default, no source address is specified for outgoing ICMP packets. The default source IP addresses for different types of ICMP packets vary as follows:
¡     For an ICMP error message, the source IP address is the IP address of the receiving interface of the packet that triggers the ICMP error message. ICMP error messages include Time Exceeded, Port Unreachable, and Parameter Problem messages.
¡     For an ICMP echo request, the source IP address is the IP address of the sending interface.
¡     For an ICMP echo reply, the source IP address is the destination IP address of the ICMP echo request specific to this reply.
The maximum segment size (MSS) option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, it fragments the segment according to the receiver's MSS.
·     If you set the TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
·     This configuration takes effect only for TCP connections established after the configuration rather than the TCP connections that already exist.
·     This configuration is effective only for IP packets.
3.     Set the TCP MSS for the interface.
tcp mss value
By default, the TCP MSS is not set.
TCP path MTU discovery (in RFC 1191) discovers the path MTU between the source and destination ends of a TCP connection. The device uses the path MTU to calculate the MSS to avoid IP fragmentation. The path MTU uses an aging mechanism to ensure that the source device can increase the path MTU when the minimum link MTU on the path increases.
TCP path MTU discovery works as follows:
1.     A TCP source device sends a packet with the Don't Fragment (DF) bit set.
2.     A router discards the packet that exceeds the MTU of the outgoing interface and returns an ICMP error message. The error message contains the MTU of the outgoing interface.
3.     Upon receiving the ICMP message, the TCP source device calculates the current path MTU of the TCP connection.
4.     The TCP source device sends subsequent TCP segments that are smaller than the MSS (MSS = path MTU – IP header length – TCP header length).
If the TCP source device still receives ICMP error messages when the MSS is smaller than 32 bytes, the TCP source device will fragment packets.
An ICMP error message received from a router that does not support RFC 1191 has the MTU of the outgoing interface set to 0. Upon receiving the ICMP message, the TCP source device selects the path MTU smaller than the current path MTU from the MTU table as described in RFC 1191. Based on the selected path MTU, the TCP source device calculates the TCP MSS. The MTU table contains MTUs of 68, 296, 508, 1006, 1280, 1492, 2002, 4352, 8166, 17914, 32000, and 65535 bytes. Because the minimum TCP MSS specified by the system is 32 bytes, the actual minimum MTU is 72 bytes.
The aging mechanism of the path MTU is as follows:
·     When the TCP source device receives an ICMP error message, it reduces the path MTU and starts an aging timer for the path MTU.
·     After the aging timer expires, the source device uses a larger MSS in the MTU table, as described in RFC 1191.
·     If no ICMP error message is received within two minutes, the source device increases the MSS again until the MSS negotiated during TCP three-way handshake is reached.
Make sure all devices on a TCP connection are enabled to send ICMP error messages by using the ip unreachables enable command.
2.     Enable TCP path MTU discovery.
By default, TCP path MTU discovery is disabled.
Enabling SYN Cookie
A TCP connection is established through a three-way handshake. An attacker can exploit this mechanism to mount SYN Flood attacks. The attacker sends a large number of SYN packets, but does not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and can no longer handle normal services.
SYN Cookie can protect the server from SYN Flood attacks. When the server receives a SYN packet, it responds with a SYN ACK packet without establishing a TCP semi-connection. The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the client.
2.     Enable SYN Cookie.
tcp syn-cookie enable
By default, SYN Cookie is disabled.
2.     Set the size of TCP receive/send buffer.
tcp window window-size
The default buffer size is 63 KB.
Setting TCP timers
You can set the following TCP timers:
·     SYN wait timer—TCP starts the SYN wait timer after sending a SYN packet. Within the SYN wait timer if no response is received or the upper limit on TCP connection tries is reached, TCP fails to establish the connection.
·     FIN wait timer—TCP starts the FIN wait timer when TCP changes the connection state to FIN_WAIT_2. If no FIN packet is received within the timer interval, TCP terminates the connection. If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer, and tears down the connection when the timer expires.
2.     Set the TCP SYN wait timer.
By default, the TCP SYN wait timer is 75 seconds.
3.     Set the TCP FIN wait timer.
By default, the TCP FIN wait timer is 675 seconds.
The TCP timestamp option in TCP packets is used to calculate the RTT between two communicating devices. In some networks, it is required to prevent the intermediate devices from obtaining the TCP timestamps in packets passing through. Then you can disable carrying the TCP timestamp option in outgoing packets on a device at either end.
2.     Enable carrying the TCP timestamp option in outgoing TCP packets.
tcp timestamps enable
By default, the device adds the TCP timestamp option in outgoing TCP packets.
Display and maintenance commands for IP performance optimization
Display ICMP statistics.
Display IP packet statistics.
Display brief information about RawIP connections.
Display detailed information about RawIP connections.
display rawip verbose [ slot slot-number [ pcb pcb-index ] ]
Display brief information about TCP connections.
Display TCP traffic statistics.
Display detailed information about TCP connections.
Display brief information about UDP connections.
 Display UDP traffic statistics.
Display detailed information about UDP connections.
Clear IP packet statistics.
Clear TCP traffic statistics.
reset tcp statistics
Clear UDP traffic statistics.
reset udp statistics
