03-DPI Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60003-DPI Command Reference
04-Data filtering commands
04-Data filtering commands 74.40 KB
action
Use action to specify actions for a data filtering rule.
Use undo action to remove the action setting from a data filtering rule.
action { drop | permit } [ logging ]
undo action
The default action of a data filtering rule is drop.
Data filtering rule view
drop: Drops the matching packets.
permit: Permits the matching packets to pass.
logging: Logs the matching packets.
If a packet matches multiple data filtering rules, the device determines the actions as follows:
·     If the matching rules have both the permit and drop actions, the device takes the drop action.
·     If the logging action is specified for any of the matching rules, the device logs the packet.
# Create data filtering policy def.
[Sysname] data-filter policy def
# Specify action permit for data filtering rule r1 in the policy.
[Sysname-data-filter-policy-def] rule r1
[Sysname-data-filter-policy-def-rule-r1] action permit
application
Use application to specify application layer protocols for a data filtering rule.
Use undo application to remove application layer protocols from a data filtering rule.
application { all | type { ftp | http | imap | nfs | pop3 | rtmp | smb | smtp } * }
undo application { all | type { ftp | http | imap | nfs | pop3 | rtmp | smb | smtp } * }
No application layer protocols are specified for a data filtering rule.
all: Specifies all application layer protocols.
type: Specifies specific types of application layer protocols.
ftp: Specifies the FTP protocol.
http: Specifies the HTTP protocol.
imap Specifies the IMAP protocol.
nfs Specifies the NFS protocol. Only NFSv3 is supported.
pop3 Specifies the POP3 protocol.
rtmp Specifies the RTMP protocol.
smb Specifies the SMB protocol. Only SMBv1 and SMBv2 are supported.
smtp: Specifies the SMTP protocol.
Use this command to specify the application layer protocols to which a data filtering rule applies.
# Specify the HTTP protocol for data filtering rule r1 in the policy.
[Sysname-data-filter-policy-def-rule-r1] application type http
data-filter apply policy
Use data-filter apply policy to apply a data filtering policy to a DPI application profile.
Use undo data-filter apply policy to remove the data filtering policy from a DPI application profile.
data-filter apply policy policy-name
No data filtering policy is applied to a DPI application profile.
DPI application profile view
policy-name: Specifies a data filtering policy by its name, a case-insensitive string of 1 to 31 characters.
A data filtering policy takes effect only after it is applied to a DPI application profile.
You can apply only one data filtering policy to a DPI application profile. If you execute this command for a DPI application profile multiple times, the most recent configuration takes effect.
# Apply data filtering policy def to DPI application profile abc.
[Sysname] app-profile abc
[Sysname-app-profile-abc] data-filter apply policy def
app-profile
data-filter policy
data-filter keyword-group
Use data-filter keyword-group to create a keyword group and enter its view, or enter the view of an existing keyword group.
Use undo data-filter keyword-group to delete a keyword group.
data-filter keyword-group keywordgroup-name
undo data-filter keyword-group keywordgroup-name
No keyword groups exist.
keywordgroup-name: Assigns a name to the keyword group, a case-insensitive string of 1 to 31 characters.
A keyword group is a group of keyword match patterns. A packet matches a keyword group if it matches a pattern in the group.
# Create a keyword group named kg1 and enter its view.
[Sysname] data-filter keyword-group kg1
[Sysname-data-filter-keygroup-kg1]
data-filter policy
Use data-filter policy to create a data filtering policy and enter its view, or enter the view of an existing data filtering policy.
Use undo data-filter policy to delete a data filtering policy.
data-filter policy policy-name
undo data-filter policy policy-name
No data filtering policies exist.
policy-name: Assigns a name to the data filtering policy, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
A data filtering policy can contain a maximum of 32 data filtering rules.
# Create data filtering policy def and enter its view.
description (data filtering policy view)
Use description to configure a description for a data filtering policy.
description string
A data filtering policy does not have a description.
Data filtering policy view
string: Specifies a description, a case-sensitive string of 1 to 255 characters.
Use this command to configure descriptions for data filtering policies for easy maintenance.
# Configure the description as The data filter for data filtering policy def.
[Sysname-data-filter-policy-def] description The data filter
description (keyword group view)
Use description to configure a description for a keyword group.
description string
A keyword group does not have a description.
Keyword group view
Use this command to configure descriptions for keyword groups for easy maintenance.
# Configure the description as The data filter keyword group for keyword group kg1.
[Sysname-data-filter-kgroup-kg1] description The data filter keyword group
direction
Use direction to specify the traffic direction for a data filtering rule.
Use undo direction to restore the default.
direction { both | download | upload }
undo direction
A data filtering rule applies to upload traffic.
both: Specifies both the upload and download traffic directions.
download: Specifies the download traffic direction.
upload: Specifies the upload traffic direction.
Use this command to specify the traffic direction to which a data filtering rule applies.
# Specify the download traffic direction for data filtering rule r1 in the policy.
[Sysname-data-filter-policy-def-rule-r1] direction download
keyword-group
Use keyword-group to specify a keyword group for a data filtering rule.
Use undo keyword-group to restore the default.
keyword-group keygroup-name
undo keyword-group
A data filtering rule does not have a keyword group.
keygroup-name: Specifies a keyword group by its name, a case-insensitive string of 1 to 31 characters. The specified keyword group must exist on the device.
A data filtering rule uses the keyword group to filter packets based on the application layer data.
You can specify only one keyword group for a data filtering rule. If you execute this command for a data filtering rule multiple times, the most recent configuration takes effect.
# Specify keyword group kg1 for data filtering rule r1 in the policy.
[Sysname-data-filter-policy-def-rule-r1] keyword-group kg1
pattern
Use pattern to configure a pattern for keyword matching.
Use undo pattern to delete a pattern.
pattern pattern-name { regex | text } pattern-string
undo pattern pattern-name
A keyword group does not contain any keyword match patterns.
Keyword group view
pattern-name: Assigns a name to the match pattern, a case-insensitive string of 1 to 31 characters.
regex pattern-string: Specifies a regular expression, a case-sensitive string of 3 to 245 characters. All printable characters are supported. The regular expression must include a minimum of three consecutive non-wildcard characters.
text pattern-string: Specifies a case-sensitive string of 3 to 245 characters for exact match. All printable characters are supported.
A pattern for keyword matching can be a regular expression or a text string.
A keyword group can contain a maximum of 32 keyword match patterns. A packet matches a keyword group if it matches a pattern in the group.
When you configure a regular expression pattern for keyword matching, follow these restrictions and guidelines:
·     The regular expression pattern can contain a maximum of four branches. For example, 'abc(c|d|e|\x3D)' is valid, and 'abc(c|onreset|onselect|onchange|style\x3D)' is invalid.
·     Nested braces are not allowed. For example, 'ab((abcs*?))' is invalid.
·     A branch cannot be specified after another branch. For example, 'ab(a|b)(c|d)^\\r\\n]+?' is invalid.
·     A minimum of four non-wildcard characters must exist before an asterisk (*) or question mark (?). For example, 'abc*' is invalid and 'abcd*DoS\x2d\d{5}\x20\x2bxi\\r\\nJOIN' is valid.
# In keyword group kg1, configure a keyword match pattern with regular expression (?i)^.*abc.*.
[Sysname-data-filter-kgroup-kg1] pattern 1 regex (?i)^.*abc.*
pre-defined-pattern
Use pre-defined-pattern to enable a predefined pattern in a keyword group.
Use undo pre-defined-pattern to disable a predefined pattern in a keyword group.
pre-defined-pattern name { bank-card-number | credit-card-number | id-card-number | phone-number }
undo pre-defined-pattern name { bank-card-number | credit-card-number | id-card-number | phone-number }
No predefined patterns are enabled in a keyword group.
Keyword group view
name: Specifies a predefined pattern by its name.
bank-card-number: Specifies the bank card number pattern.
credit-card-number: Specifies the credit card number pattern.
id-card-number: Specifies the ID card number pattern.
phone-number: Specifies the phone number pattern.
To match packets that contain phone numbers, bank card numbers, credit card numbers, or ID card numbers in a keyword group, enable the corresponding predefined pattern in the keyword group.
You can execute this command multiple times in a keyword group to enable multiple predefined patterns.
# Enable the phone number predefined pattern in keyword group kg1 to match packets that contain phone numbers.
[Sysname-data-filter-kgroup-kg1] pre-defined-pattern name phone-number
rule
Use rule to create a data filtering rule and enter its view, or enter the view of an existing data filtering rule.
Use undo rule to delete a data filtering rule.
rule rule-name
undo rule rule-name
No data filtering rules exist.
rule-name: Assigns a name to the data filtering rule, a case-insensitive string of 1 to 31 characters.
A data filtering rule contains a set of filtering criteria and the actions for matching packets. The filtering criteria include keyword group, traffic direction, and application layer protocol. The actions include drop, permit, and logging. A packet must match all the filtering criteria for the actions specified for the rule to apply.
# In data filtering policy def, create a data filtering rule named r1 and enter its view.
