02-Security Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60002-Security Command Reference
18-IP-MAC binding commands
18-IP-MAC binding commands 82.54 KB
display ip-mac binding ipv4
Use display ip-mac binding ipv4 to display IPv4-MAC binding entries.
display ip-mac binding ipv4 [ ipv4-address ] [ mac-address mac-address ] [ vlan vlan-id | vpn-instance vpn-instance-name ]
ipv4-address: Specifies an IPv4 address. The IPv4 address cannot be an all 0s, a multicast address, or a loopback address. If you do not specify an IPv4 address, this command displays IPv4-MAC binding entries for all IPv4 addresses.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be all 0s, all Fs (a broadcast MAC address), or a multicast address. If you do not specify a MAC address, this command displays IPv4-MAC binding entries for all MAC addresses.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv4-MAC binding entries for all VLANs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If you do not specify a VPN instance, this command displays IPv4-MAC binding entries for the public network.
# Display IPv4-MAC binding entries.
<Sysname> display ip-mac binding ipv4
Total entries: 1
IP address      MAC address            VPN instance      VLAN ID
1.1.1.1         0000-0000-0001         --                  N/A
Total entries
Total number of IPv4-MAC binding entries.
IP address
IPv4 address in the IPv4-MAC binding entry.
MAC address
MAC address in the IPv4-MAC binding entry.
VPN instance
Name of the VPN instance to which the IPv4-MAC binding entry belongs. If the binding entry belongs to the public network, this field displays hyphens (--).
VLAN ID
VLAN to which the IPv4-MAC binding entry belongs.
ip-mac binding ipv4
display ip-mac binding ipv6
Use display ip-mac binding ipv6 to display IPv6-MAC binding entries.
display ip-mac binding ipv6 [ ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id | vpn-instance vpn-instance-name ]
ipv6-address: Specifies an IPv6 address. The IPv6 address cannot be all 0s, a multicast address, or a loopback address. If you do not specify an IPv6 address, this command displays IPv6-MAC binding entries for all IPv6 addresses.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be all 0s, all Fs (a broadcast MAC address), or a multicast address. If you do not specify a MAC address, this command displays IPv6-MAC binding entries for all MAC addresses.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6-MAC binding entries for all VLANs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If you do not specify a VPN instance, this command displays IPv6-MAC binding entries for the public network.
# Display IPv6-MAC binding entries.
<Sysname> display ip-mac binding ipv6
Total entries: 1
10::10          0000-0000-0001         --                   N/A
Total entries
Total number of IPv6-MAC binding entries.
IP address
IPv6 address in the IPv6-MAC binding entry.
MAC address
MAC address in the IPv6-MAC binding entry.
VPN instance
Name of the VPN instance to which the IPv6-MAC binding entry belongs. If the binding entry belongs to the public network, this field displays hyphens (--).
VLAN ID
VLAN to which the IPv6-MAC binding entry belongs.
ip-mac binding ipv6
display ip-mac binding statistics
Use display ip-mac binding statistics to display statistics about packets dropped by the IP-MAC binding feature.
CSAP-NTA-V200[V1000]:
CSAP-NTA-100[200][300][400][500][600][AK375]:
display ip-mac binding statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics about packets dropped by the IP-MAC binding feature for all member devices. (CSAP-NTA-100[200][300][400][500][600][AK375])
When the deny action is set for packets that do not match any IP-MAC binding entries, this command displays statistics about the following packets:
·     Packets that do not exactly match any IP-MAC binding entries.
·     Packets that do not match any IP-MAC binding entries.
# (CSAP-NTA-V200[V1000])Display statistics about packets dropped by the IP-MAC binding feature.
<Sysname> display ip-mac binding statistics
Statistics about dropped packets:
IPv4 drop statistics:
  IPv4 ip-mac binding dropped packets because partial match ip: 3
  IPv4 ip-mac binding dropped packets because partial match mac: 0
  IPv4 ip-mac binding dropped packets because no match entry: 12
IPv6 drop statistics:
  IPv6 ip-mac binding dropped packets because partial match ip: 0
  IPv6 ip-mac binding dropped packets because partial match mac: 0
  IPv6 ip-mac binding dropped packets because no match entry: 0
# (CSAP-NTA-100[200][300][400][500][600][AK375])Display statistics about packets dropped by the IP-MAC binding feature on the specified slot.
<Sysname> display ip-mac binding statistics slot 1
Slot 1:
Number of IPv4 packets dropped by the IP-MAC binding feature.
Number of IPv4 packets that were dropped because no matching IPv4-MAC binding entries were found for the source MAC address.
Number of IPv4 packets that were dropped because no matching IPv4-MAC binding entry was found for the source IP address.
Number of IPv4 packets that were dropped because no matching IPv4-MAC binding entry was found for the source IP address and source MAC address.
Number of IPv6 packets dropped by the IP-MAC binding feature.
Number of IPv6 packets that were dropped because no matching IPv6-MAC binding entries were found for the source MAC address.
Number of IPv6 packets that were dropped because no matching IPv6-MAC binding entry was found for the source IP address.
Number of IPv6 packets that were dropped because no matching IPv6-MAC binding entry was found for the source IP address and source MAC address.
reset ip-mac binding statistics
display ip-mac binding status
Use display ip-mac binding status to display the status of the IP-MAC binding feature.
This command displays the status of the IP-MAC binding feature and the default action for packets that do not match any IP-MAC binding entries.
# Display the status of the IP-MAC binding feature.
<Sysname> display ip-mac binding status
ip-mac binding: Disabled
ip-mac binding no-match action: Deny
ip-mac binding
Status of the IP-MAC binding feature, Enabled or Disabled.
The default action for packets that do not match any IP-MAC binding entries:
·     Permit—Forwards packets.
·     Deny—Drops packets.
ip-mac binding enable
Use ip-mac binding enable to enable the IP-MAC binding feature.
Use undo ip-mac binding enable to disable the IP-MAC binding feature.
The IP-MAC binding feature is disabled.
The IP-MAC binding feature uses IP-MAC binding entries to match the source IP address and source MAC address in incoming packets:
·     If both the source IP address and source MAC address match the same binding entry, the feature permits the packet.
·     If only the source IP address or source MAC address matches a binding entry, the feature denies the packet.
·     If the source IP address and the source MAC address match no binding entries, the feature processes the packet based on the specified action.
The IP-MAC binding entries are static. Therefore, this feature is applicable to only scenario that all users are statically assigned IP addresses. Using this feature in a network where users' IP addresses are dynamically assigned through DHCP might cause communication failure.
# Enable the IP-MAC binding feature.
[Sysname] ip-mac binding enable
ip-mac binding interface
Use ip-mac binding interface to generate IP-MAC binding entries based on existing ARP and ND entries on an interface.
ip-mac binding interface interface-type interface-number
interface-type interface-number: Specifies an interface by its name and type. The interface must be a Layer 3 Ethernet interface or subinterface, Layer 3 aggregate interface or subinterface, Reth interface or subinterface, or VLAN interface.
Use this command to generate IP-MAC binding entries based on existing ARP entries and ND entries on an interface. If the newly generated IP-MAC binding entries conflict with the existing IP-MAC binding entries, the device retains the existing entries.
To generate IP-MAC binding entries based on ARP entries and ND entries newly added after the command execution, re-execute this command.
To delete IPv4-MAC binding entries generated by using this command, use the undo ip-mac binding ipv4 command. To delete IPv6-MAC binding entries generated by using this command, use the undo ip-mac binding ipv6 command.
IP-MAC binding entries are static. Therefore, the binding entries generated by using this command are not updated when the relevant ARP or ND entries change.
# Generate IP-MAC binding entries based on existing ARP and ND entries on GigabitEthernet 0/0/1.
[Sysname] ip-mac binding interface gigabitethernet 1/0/1
ip-mac binding ipv4
Use ip-mac binding ipv4 to create an IPv4-MAC binding entry.
Use undo ip-mac binding ipv4 to delete IPv4-MAC binding entries.
ip-mac binding ipv4 ipv4-address mac-address mac-address [ vlan vlan-id | vpn-instance vpn-instance-name ]
undo ip-mac binding ipv4 { all | ipv4-address mac-address mac-address [ vlan vlan-id | vpn-instance vpn-instance-name ] }
No IPv4-MAC binding entries are configured.
ipv4-address: Specifies an IPv4 address. The IPv4 address cannot be all 0s, a multicast address, or a loopback address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If you do not specify a VPN instance, the IPv4-MAC binding entry belongs to the public network.
all: Specifies all IPv4-MAC binding entries.
A MAC address can be bound to multiple IPv4 addresses. However, an IPv4 address can be bound to only one MAC address. To bind an IPv4 address in a binding entry to another MAC address, you must delete the existing binding entry, and then create the new binding entry.
IPv4-MAC binding entries created by using this command are globally effective.
The device supports a maximum of 1024 IPv4-MAC binding entries.
# Create an IPv4-MAC binding entry to permit packets with source IPv4 address 192.168.0.1 and source MAC address 0001-0001-0001.
[Sysname] ip-mac binding ipv4 192.168.0.1 mac-address 0001-0001-0001
ip-mac binding ipv6
Use ip-mac binding ipv6 to create an IPv6-MAC binding entry.
Use undo ip-mac binding ipv6 to delete IPv6-MAC binding entries.
ip-mac binding ipv6 ipv6-address mac-address mac-address [ vlan vlan-id | vpn-instance vpn-instance-name ]
undo ip-mac binding ipv6 { all | ipv6-address mac-address mac-address [ vlan vlan-id | vpn-instance vpn-instance-name ] }
No IPv6-MAC binding entries are configured.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be all 0s, all Fs (a broadcast MAC address ), or a multicast address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If you do not specify a VPN instance, the IPv6-MAC binding entry belongs to the public network.
all: Specifies all IPv6-MAC binding entries.
A MAC address can be bound to multiple IPv6 addresses. However, an IPv6 address can be bound to only one MAC address. To bind an IPv6 address in a binding entry to another MAC address, you must delete the existing binding entry and then create the new binding entry.
IPv6-MAC binding entries created by using this command are globally effective.
The device supports a maximum of 1024 IPv6-MAC binding entries.
# Create an IPv6-MAC binding entry to permit packets with source IPv6 address 2012::12:25 and source MAC address 0001-0001-0001.
[Sysname] ip-mac binding ipv6 2012::12:25 mac-address 0001-0001-0001
ip-mac binding no-match action deny
Use ip-mac binding no-match action deny to set the default action to deny for packets that do not match any IP-MAC binding entries.
Use undo ip-mac binding no-match action deny to restore the default.
The default action for packets that do not match any IP-MAC binding entries is permit.
Use this command to permit only packets with both source IP address and source MAC address matching the same binding entry.
# Set the default action to deny for packets that do not match any IP-MAC binding entries.
[Sysname] ip-mac binding no-match action deny
Use reset ip-mac binding statistics to clear statistics about packets dropped by the IP-MAC binding feature.
reset ip-mac binding statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics about packets dropped by the IP-MAC binding feature on all member devices. (CSAP-NTA-100[200][300][400][500][600][AK375])
# (CSAP-NTA-V200[V1000])Clear statistics about packets dropped by the IP-MAC binding feature.
<Sysname> reset ip-mac binding statistics
# (CSAP-NTA-100[200][300][400][500][600][AK375])Clear statistics about packets dropped by the IP-MAC binding feature on the specified slot.
<Sysname> reset ip-mac binding statistics slot 1
