01-Fundamentals Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60001-Fundamentals Command Reference
04-License management commands
04-License management commands 100.64 KB
display license
Use display license to display detailed license information.
CSAP-NTA-V200[V1000]:
display license [ activation-file ]
CSAP-NTA-100[200][300][400][500][600][AK375]:
display license [ activation-file ] [ slot slot-number ]
activation-file: Displays license information about activation files.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices. (CSAP-NTA-100[200][300][400][500][600][AK375])
If you do not specify any parameters, this command displays detailed information about all licenses.
# Display detailed information about all licenses.
<Sysname> display license
flash:/license/SecurityTemporary.ak
Feature: IPRPT
Product Description: H3C SecCenter CSAP-NTA-V1 Signature Update License,1 Year
License SN: 213130A50P0214000006
Registered at: 2021-02-03 08:19:50
License Type: Trial (days restricted)
Trial Time Left (days): 102
Current State: In use
Feature
Feature name.
Product Description
License description.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Days restricted—Purchased license that is valid for a period of days, for example, 30 days.
·     Trial (days restricted)—Free trial license that is valid for a period of days.
Time Left (days)
Remaining days of the license. This field is available for a formal license.
Remaining days of the trial period. This field is available for a trial license.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use.
¡     If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
¡     A date restricted license is in this state if its start date is not reached.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
display license device-id slot slot-number
slot slot-number: Specifies the member ID of an IRF member device. (CSAP-NTA-100[200][300][400][500][600][AK375])
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# (CSAP-NTA-V200[V1000])Display the device SN and DID.
<Sysname> display license device-id
SN: 210231S12500XSUPSUPC
Device ID: XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
# (CSAP-NTA-100[200][300][400][500][600][AK375])Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 210235A1FXH164000026
Device ID: flash:/license/210235A1FXH164000026.did
display license feature
Use display license feature to display brief license information for features.
# (CSAP-NTA-V200[V1000])Display brief feature license information.
<Sysname> display license feature
Total: 50 Usage: 7
Feature       Licensed     State
OPT           Y            Formal
OSPF          N            -
MPLS          Y            Trial
# (CSAP-NTA-100[200][300][400][500][600][AK375])Display brief feature license information.
Slot 1:
Total: 32  Usage: 0
ACG                             N               -
AV                              N               -
IPS                             N               -
SLB                             N               -
SSLVPN                          N               -
UFLT                            N               -
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Formal—Purchased license.
·     Trial—Trial license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file.
license activation-file install
Use license activation-file install to install an activation file.
license activation-file install license-file
license activation-file install license-file slot slot-number
license-file: Specifies the path of an activation file, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
(CSAP-NTA-V200[V1000])License registration requires the device's hardware SN and DID.
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the device.
Activation files are device locked. A licensed feature can run on the IRF member device where its activation file is installed even after the member device is moved from one IRF fabric to another IRF fabric.
# (CSAP-NTA-V200[V1000])Install activation file 20170810.ak.
[Sysname] license activation-file install flash:/license/20170810.ak
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...Done.
# (CSAP-NTA-V200[V1000])Install activation file package 20170101.tar.
[Sysname] license activation-file install flash:/license/20170101.tar
Decompress......Done.
Begain to install test01.ak …Done.
Begain to install test02.ak …Done.
Begain to install test03.ak …Done.
Total Num:3
Success Num:3
Failed Num:0
# (CSAP-NTA-100[200][300][400][500][600][AK375])Install activation file 20170811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20170811.ak slot 1
display license
license activation-file uninstall
license compress
Use license compress to compress the license storage.
license compress
license compress slot slot-number
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# (CSAP-NTA-V200[V1000])Compress the license storage.
[Sysname] license compress
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
# (CSAP-NTA-100[200][300][400][500][600][AK375])Compress the license storage on the specified slot.
[Sysname] license compress slot 1
snmp-agent trap enable license
Use snmp-agent trap enable license to enable SNMP notifications for licensing.
Use undo snmp-agent trap enable license to disable SNMP notifications for licensing.
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware
Command compatibility
CSAP-NTA-100, CSAP-NTA-200, CSAP-NTA-AK375
No
CSAP-NTA-300, CSAP-NTA-400, CSAP-NTA-500, CSAP-NTA-600
No
CSAP-NTA-V200, CSAP-NTA-V1000
Yes
SNMP notifications for licensing are enabled.
After you enable SNMP notifications for licensing, the device automatically generates notifications for the following events:
·     The activation file being used by the device is lost.
·     The device disconnects from the license server or reconnects to the license server successfully after it disconnects from the license server.
·     The license obtained from the license server is about to expire or has expired.
For license event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for licensing.
[Sysname] snmp-agent trap enable license
display snmp-agent trap-list (Network Management and Monitoring Command Reference)
license client enable
License client commands
The following compatibility matrix shows the support of hardware platforms for license client:
Hardware
License client compatibility
No
No
Yes
display license client
Use display license client to display the license client configuration and the obtained license information on the license client.
# Display the license client configuration and the obtained license information on the license client.
<Sysname> display license client
Username: user
Ciphertext password: ******
License server's IPv4 address: 192.168.3.124, port: 5001
License client: Enabled
License Name: STANDARD_256CPU_PERMANENT
License Description: vNTA1000
Get Time: 2022-03-21 13:35:14
Username
Username for accessing the license server.
This field displays Not configured if no username is specified.
Ciphertext password
Password in encrypted form for accessing the license server.
This field displays Not configured if no password is specified.
IPv4 address of the license server.
This field displays Not configured if no IPv4 address of the license server is specified.
Port
Port number of the license server.
This field displays Not configured if no port number of the license server is specified.
License client
Status of the license client:
·     Enabled.
·     Disabled.
License name
Name of the license.
License description
Description of the license.
Current State
Current status of the license:
·     In use—The license is in use.
·     Unusable—The license is not in use.
·     Reserved (client is disconnected from license server, but license is still available for n days)—The device is disconnected from the license server for more than 32 hours (excluding 32 hours), and the value n represents the number of validity days of the license.
·     Expired (will be reclaimed in n days)—The license has expired and will be reclaimed in n days.
Get Time
Time when the license was obtained from the license server.
license client username
Use license client username to specify the username and password on the license client for logging in to the license server.
Use undo license client username to delete the username and password settings.
license client username username password { cipher | simple } password
No username or password is specified on the license client.
username: Specify the username, a case-sensitive string of 1 to 31 characters.
cipher: Specify a password in encrypted form.
simple: Specifies a password in plaintext form.
password: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 33 to 73 characters.
You can specify only one username and one password on the license client for login to the license server.
If you execute the command multiple times before enabling the license client, the most recent configuration takes effect.
To modify the username and password settings on an enabled license client, disable the license client first.
# Specify test and 123456 as the username and password on the license client.
[Sysname] license client username test password simple 123456
Use license client enable to enable the license client.
Use undo license client enable to disable the license client.
License client is disabled, and it cannot get licenses from the license server.
Specify the IP address, username, and password of the license server before enabling the license client. Otherwise, the configuration fails.
After you enable the license client, the device automatically initiates a connection to the license server. The license server verifies the license client identity through the username and password. If they are consistent with those specified on the license server, the license client passes authentication. Then the client can apply for licenses from the license server and use the licensed features.
# Enable the license client.
[Sysname] license client enable
license client install feature
Use license client install feature to apply for feature licenses from the license server and install them.
Use undo license client install feature to uninstall feature licenses and release them.
license client install feature dpi-1year
undo license client install feature dpi-1year
The license client does not apply for feature licenses from the license server automatically.
dpi-1year: Specifies a license for using the IPS, anti-virus, application recognition, URL filtering signature library update, WAF signature library update, and threat intelligence features for 1 year.
After a license is uninstalled and released, the license server withdraws the license. The withdrawn license can be used on other virtual devices within the validity period.
# Apply for the dpi-1year license and install it.
[Sysname] license client install feature dpi-1year
license client install standard
Use license client install standard to apply for a standard license from the license server and install it.
Use undo license client install standard to uninstall the standard license and release it.
license client install standard 256vcpu-permanent
The license client does not apply for a standard license from the license server automatically.
256vcpu-permanent: Specifies a 256-vCPU license for using 256 vCPUs permanently.
Each virtual device comes with a trail license that allows 256 vCPUs free for 180 days. The trial period starts when the virtual device is created. To ensure service continuity, execute this command to apply for a formal license from the license server and install it before the trail period expires.
Choose a proper formal license to match the virtual device requirement. The number of licensed vCPUs must be equal to or greater than the vCPU upper limit supported by the virtual device. The upper limit is defined when the virtual device is created. For example, for a virtual device supporting a maximum of 5 vCPUs, an 8-vCPU license will be appropriate.
Each virtual device supports only one standard license. If you apply for a new standard license on the device where a standard license has been installed, the license client will first uninstall the existing license and release it, and then apply for the new license.
Before applying for a standard license, make sure the license client and license server are reachable to each other, and the requested license exists on the license server.
# Apply for standard license 256vcpu-permanent from the license server and install it.
[Sysname] license client install standard 256vcpu-permanent
license server
Use license server to specify the IP address and port number of the license server.
Use undo license server to delete the license server settings on the license client.
license server { ipv4 ipv4-address | ipv6 ipv6-address } port port-number [ vpn-instance vpn-instance-name ]
undo license server { ipv4 ipv4-address | ipv6 ipv6-address } port port-number [ vpn-instance vpn-instance-name ]
No IP address or port number of the license server is specified.
ipv4-address: Specifies the IPv4 address of the license server.
ipv6-address: Specifies the IPv6 address of the license server.
port-number: Specifies the port number of the license server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies a VPN instance to which the license server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the license server is on the public network, do not specify this option.
You can specify a maximum of four license servers on the license client. Each license server is uniquely identified by the combination of an IP address, a port number, and a VPN instance.
When the upper limit is reached, you cannot specify new license servers unless you delete existing license server settings.
If you apply for a new standard license on a device with a standard license installed, the license client will first uninstall the existing license and release it, and then apply for the new license.
As a best practice, make sure only one license server is reachable.
To modify the license server settings on an enabled license client, disable the license client first.
# Specify 192.168.100.1 and 5001 as the IPv4 address and port number of the license server, respectively.
[Sysname] license server ipv4 192.168.100.1 port 5001
# Specify 3001::1 and 5555 as the IPv6 address and port number of the license server, respectively.
[Sysname] license server ipv6 3001::1 port 5555
