11-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath IPS Comware 7 Command References (R8560 R8660)-6W60011-Layer 3—IP Routing Command Reference
10-Routing policy commands
10-Routing policy commands 161.07 KB
Common routing policy commands
apply cost
Use apply cost to set a cost for routes.
Use undo apply cost to restore the default.
undo apply cost
No cost is set for routes.
Routing policy node view
context-admin
+: Increases a cost value.
-: Decreases a cost value.
cost-value: Specifies a cost in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to set a cost of 120 for OSPF external routes.
[Sysname-route-policy-policy1-10] if-match route-type external-type1or2
[Sysname-route-policy-policy1-10] apply cost 120
apply cost-type
Use apply cost-type to set a cost type for routes.
Use undo apply cost-type to restore the default.
apply cost-type { type-1 | type-2 }
No cost type is set for routes.
context-admin
type-1: Sets the cost type to OSPF Type-1 external route.
type-2: Sets the cost type to OSPF Type-2 external route.
# Configure node 10 in permit mode for routing policy policy1 to set the cost type for routes that have a tag of 8 to OSPF Type-1 external routes.
[Sysname-route-policy-policy1-10] if-match tag 8
[Sysname-route-policy-policy1-10] apply cost-type type-1
apply ip-precedence
Use apply ip-precedence to set an IP precedence for matching routes.
Use undo apply ip-precedence to restore the default.
No IP precedence is set.
context-admin
value: Specifies an IP precedence in the range of 0 to 7.
clear: Clears the IP precedence of matching routes.
# Configure node 10 in permit mode for routing policy policy1 to set an IP precedence of 3 for routes matching prefix list 100.
[Sysname] ip prefix-list 100 permit 192.168.10.1 24
[Sysname-route-policy-policy1-10] if-match ip address prefix-list 100
[Sysname-route-policy-policy1-10] apply ip-precedence 3
apply preference
Use apply preference to set a preference for a routing protocol.
Use undo apply preference to restore the default.
apply preference preference
No preference is set for a routing protocol.
context-admin
preference: Specifies a preference in the range of 1 to 255.
If you have set preferences for routing protocols by using the preference command, the apply preference command sets a new preference for the matching routing protocol. Unmatched routing protocols still use the preferences set by using the preference command.
# Configure node 10 in permit mode for routing policy policy1 to set the preference for OSPF external routes to 90.
[Sysname-route-policy-policy1-10] apply preference 90
apply prefix-priority
Use apply prefix-priority to set a prefix priority for routes.
Use undo apply prefix-priority to restore the default.
No prefix priority is set, which means the prefix priority is low.
context-admin
critical: Sets the critical prefix priority for routes.
high: Sets the high prefix priority for routes.
medium: Sets the medium prefix priority for routes.
# Configure node 10 in permit mode for routing policy policy1 to set prefix priority critical for routes matching prefix list abc.
[Sysname-route-policy-policy1-10] if-match ip address prefix-list abc
[Sysname-route-policy-policy1-10] apply prefix-priority critical
apply tag
Use apply tag to set a tag for IGP routes.
Use undo apply tag to restore the default.
apply tag tag-value
undo apply tag
No routing tag is set for IGP routes.
context-admin
tag-value: Specifies the tag value in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to set a tag of 100 for IGP routes.
[Sysname-route-policy-policy1-10] apply tag 100
continue
Use continue to specify the next node to be matched.
Use undo continue to restore the default.
continue [ node-number ]
undo continue
No next node is specified.
context-admin
node-number: Specifies the routing policy node number in the range of 0 to 65535.
The specified next node must have a larger number than the current node.
Example
# Specify the next node 20 for node 10 of the routing policy policy1.
[Sysname-route-policy-policy1-10] continue 20
description
Use description to configure a description for a routing policy node.
No description is configured for a routing policy node.
context-admin
text: Specifies a description for the routing policy node, a case-sensitive string of 1 to 80 characters.
# Configure node 10 in permit mode for routing policy policy1 and configure aa as the description for the node.
[Sysname-route-policy-policy1-10] description aa
display ip rd-list
Use display ip rd-list to display route distinguisher (RD) list information.
context-admin
context-operator
rd-list-number: Displays information about an RD list. The rd-list-number argument represents the number of the RD list, in the range of 1 to 65535. If you do not specify an RD list, this command displays information about all RD lists.
# Display information about all RD lists.
<Sysname> display ip rd-list
Route Distinguisher List Number 1
        index: 1          Permit 1.1.1.1:1 2.2.2.2:* 100:1 200:*
Route Distinguisher List Number 2
        index: 2          Deny   1:1 2:2
RD list number.
index
Index of the RD list item.
Permit
Match mode:
·     Permit.
·     Deny.
ip rd-list
display route tag-list
Use display route tag-list to display tag list information.
display route tag-list [ tag-list-number ]
context-admin
context-operator
tag-list-number: Specifies a tag list by its number in the range of 1 to 65535. If you do not specify this argument, the command displays information about all tag lists.
# Display information about tag list 1.
<Sysname> display route tag-list 1
Tag list 1
        Index: 1          Mode: Permit  Tag value: 1 2 3
        Index: 2          Mode: Permit  Tag value: 6 7 8
Tag list
Tag list number.
Index
Index of an item.
Mode
Match mode:
·     Permit.
·     Deny.
Tag value
Tag value.
route tag-list
display route-policy
Use display route-policy to display routing policy information.
context-admin
context-operator
name route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all routing policies.
# Display information about routing policy policy1.
<Sysname> display route-policy name policy1
Route-policy: policy1
  Permit : 1
          Description: policy1
          if-match cost 10
          continue: next node 11
          apply preference 10
Route-policy
Routing policy name.
permit
Match mode:
·     Permit.
·     Deny.
Routing policy description.
if-match
Match criterion.
continue
Specify the next node to be matched.
apply
Action.
if-match cost
Use if-match cost to match routes that have the specified cost.
Use undo if-match cost to restore the default.
if-match cost cost-value
undo if-match cost
No cost match criterion is configured.
context-admin
# Configure node 10 in permit mode for routing policy policy1 to permit routes with a cost of 8.
[Sysname-route-policy-policy1-10] if-match cost 8
if-match interface
Use if-match interface to match routes that have the specified output interfaces.
Use undo if-match interface to remove the specified output interface match criterion.
No output interface match criterion is configured.
context-admin
&<1-16>: Indicates that you can specify a maximum of 16 interfaces.
# Configure node 10 in permit mode for routing policy policy1 to permit routes with the output interface GigabitEthernet 1/0/1.
[Sysname-route-policy-policy1-10] if-match interface gigabitethernet 1/0/1
if-match rd-list
Use if-match rd-list to match routes whose RD matches the specified RD list.
Use undo if-match rd-list to remove the specified RD list match criterion.
No RD list match criterion is configured.
context-admin
rd-list-number: Specifies an RD list by its number in the range of 1 to 65535.
# Configure node 10 in permit mode for routing policy rp1 to match routes whose RD matches RD list 1.
[Sysname] ip rd-list 1 permit 1:1
[Sysname] route-policy rp1 permit node 10
[Sysname-route-policy-rp1-10] if-match rd-list 1
ip rd-list
if-match route-type
Use if-match route-type to set a route-type match criterion.
Use undo if-match route-type to remove the specified route-type match criterion.
if-match route-type { external-type1 | external-type1or2 | external-type2 | internal | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
undo if-match route-type [ external-type1 | external-type1or2 | external-type2 | internal | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 ] *
No route-type match criterion is set.
context-admin
external-type1: Matches OSPF Type 1 external routes.
external-type1or2: Matches OSPF Type 1 and Type 2 external routes.
external-type2: Matches OSPF Type 2 external routes.
internal: Matches OSPF internal routes (including OSPF intra-area and inter-area routes).
nssa-external-type1: Matches OSPF NSSA Type 1 external routes.
nssa-external-type1or2: Matches OSPF NSSA Type 1 and 2 external routes.
nssa-external-type2: Matches OSPF NSSA Type 2 external routes.
# Configure node 10 in permit mode for routing policy policy1 to match OSPF internal routes.
[Sysname-route-policy-policy1-10] if-match route-type internal
if-match tag
Use if-match tag to match IGP routes that have the specified tag.
Use undo if-match tag to restore the default.
if-match tag tag-value
undo if-match tag
No tag match criterion is configured.
context-admin
tag-value: Specifies a tag in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to match IGP routes that have a tag of 8.
if-match tag-list
Use if-match tag-list to match IGP routes whose tag matches the specified tag list.
Use undo if-match tag-list to restore the default.
if-match tag-list tag-list-number
No tag list match criterion is configured.
context-admin
# Configure node 10 in permit mode for routing policy policy1 to match IGP routes whose tag matches tag list 100.
[Sysname-route-policy-policy1-10] if-match tag-list 100
route tag-list
ip rd-list
Use ip rd-list configure an RD list.
Use undo ip rd-list to remove an RD list.
undo ip rd-list rd-list-number [ index index-number ] [ { deny | permit } route-distinguisher&<1-10> ]
No RD lists exist.
context-admin
index index-number: Specifies an index number for an RD list item, in the range of 1 to 4294967295. An item with a smaller index number is matched first. If you do not specify this option, the index number starts from 10 and increases by 10 for each of the consecutive RD list items.
deny: Specifies the deny mode. If a route matches the item, the route is denied without being compared with the next item. If a route does not match the item, the route is compared with the next item.
permit: Specifies the permit mode. If a route matches the item, it passes the RD list. If a route does not match the item, the route is compared with the next item.
route-distinguisher&<1-10>: Specifies a list of up to 10 RD list items. Each item is a string of 3 to 21 characters.
An RD has the following forms:
·     16-bit AS number:32-bit self-defined number. For example, 101:3.
·     16-bit AS number:wildcard character. For example, 101:*.
·     32-bit IP address:16-bit self-defined number. For example, 192.168.122.15:1.
·     32-bit IP address:wildcard character. For example, 192.168.122.15:*.
·     32-bit AS number:16-bit self-defined number. For example, 65536:1. The minimum AS number is 65536.
·     32-bit AS number:wildcard character. For example, 65536:*. The minimum AS number is 65536.
An RD list matches the RDs of BGP routes. An RD list is identified by an RD list number and can contain multiple items that specify RD ranges. The relationship between the items is logical OR. A route matches the RD list if it matches one item in the list. A route does not match the RD list if it does not match any items in the list.
To filter routes by RD, use the ip rd-list command together with the if-match rd-list command. If you specify a nonexistent RD list for the if-match rd-list command, all routes pass the RD match criterion.
# Configure RD list 1 to permit routes with RD 100: 1.
[Sysname] ip rd-list 1 permit 100:1
display ip rd-list
if-match rd-list
route tag-list
Use route tag-list to configure a tag list.
Use undo route tag-list to delete a tag list or a tag list entry.
route tag-list tag-list-number [ index index-number ] { deny | permit } tag-value&<1-32>
undo route tag-list tag-list-number [ index index-number [ { deny | permit } tag-value&<1-32> ] ]
No tag lists exist.
context-admin
index index-number: Specifies an index for the tag list entry, in the range of 1 to 4294967295. A tag list entry with a smaller index number is matched first. If you do not specify this option, the index number starts from 1 and increases by 1 for each of the consecutive tag list entries.
deny: Specifies the match mode for the tag list as deny.
permit: Specifies the match mode for the tag list as permit.
tag-value: Specifies a tag value in the range of 0 to 4294967295. &<1-32> indicates that the argument before it can be entered up to 32 times.
If you execute this command multiple times for a tag list entry, all tag values take effect. A tag list entry can contain up to 32 tag values.
# Configure tag list 1 and create tag list entry 10 to permit IGP routes with tag value 100 to pass.
[Sysname] route tag-list 1 index 10 permit 100
if-match tag-list
route-policy
Use route-policy to create a routing policy and a node and enter routing policy node view, or enter the view of an existing routing policy node.
Use undo route-policy to remove a routing policy or a node of it.
No routing policies exist.
context-admin
route-policy-name: Specifies a routing policy name, a case-sensitive string of 1 to 63 characters.
deny: Specifies the deny match mode for the routing policy node. If a route matches all the if-match clauses of the node, it is denied without being compared with the next node. If a route does not match any if-match clauses of the node, the route is compared with the next node.
permit: Specifies the permit match mode for the routing policy node. If a route matches all the if-match clauses of the node, it is handled by the apply clauses of the node. If a route does not match any if-match clauses of the node, the route is compared with the next node.
node node-number: Specifies a node number in the range of 0 to 65535. A node with a smaller number is matched first.
Use a routing policy to filter routing information. A routing policy can contain several nodes and each node contains a set of if-match and apply clauses. The if-match clauses define the match criteria of the node and the apply clauses define the actions to be taken on packets matching the criteria. The relation between the if-match clauses of different types is logical AND and the relation between the if-match clauses of the same type is logical OR. if-match clauses of all types must be met. The relation between nodes is logical OR. A packet passing a node passes the routing policy. If a packet does not pass any nodes, the packet does not pass the routing policy.
# Create node 10 in permit mode for routing policy policy1 and enter routing policy node view.
IPv4 routing policy commands
apply fast-reroute
Use apply fast-reroute to set a backup link for fast route (FRR).
Use undo apply fast-reroute to restore the default.
No backup link for FRR is configured.
context-admin
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the specified interface is a non-P2P interface, you must also specify a backup next hop. Non-P2P interfaces include NBMA and broadcast interfaces.
backup-nexthop ip-address: Specifies a backup next hop.
This command sets a backup link in the routing policy for FRR.
Using the routing policy, a routing protocol can designate a backup link for specific routes to implement FRR. When the primary link fails, FRR immediately directs packets to the backup link to minimize interruption time.
# Configure node 10 of routing policy policy1 to set the backup output interface GigabitEthernet 1/0/1 and backup next hop 193.1.1.8 for the route destined for 100.1.1.0/24.
[Sysname-route-policy-policy1-10] apply fast-reroute backup-interface gigabitethernet 1/0/1 backup-nexthop 193.1.1.8
apply ip-address next-hop
Use apply ip-address next-hop to set a next hop for IPv4 routes.
Use undo apply ip-address next-hop to restore the default.
No next hop is set for IPv4 routes.
context-admin
ip-address: Specifies the next hop IP address.
public: Specifies the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you use this command to set a next hop for redistributed routes, the configuration does not take effect.
If you do not specify the public keyword and the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
# Configure node 10 in permit mode for routing policy policy1 to set next hop 193.1.1.8 for routes matching prefix list 100.
[Sysname-route-policy-policy1-10] apply ip-address next-hop 193.1.1.8
display ip prefix-list
Use display ip prefix-list to display IPv4 prefix list statistics.
context-admin
context-operator
name prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all IPv4 prefix lists.
# Display the statistics for IPv4 prefix list abc.
<Sysname> display ip prefix-list name abc
Prefix-list: abc
 Permitted 0
 Denied 0
         index: 10        Deny   6.6.6.0/24              ge  26  le  28
Prefix-list
Name of the IPv4 prefix list.
Permitted
Number of routes matching the criterion.
Denied
Number of routes not matching the criterion.
index
Index of an item.
deny
Match mode of the item:
·     Permit.
·     Deny.
6.6.6.0/24
IP address and mask.
ge
Greater-equal, the lower mask length limit.
le
Less-equal, the upper mask length limit.
ip prefix-list
reset ip prefix-list
if-match ip
Use if-match ip to match IPv4 routes whose destination, next hop, or source address matches an ACL or IPv4 prefix list.
Use undo if-match ip to remove the specified ACL or IPv4 prefix list match criterion.
if-match ip { address | next-hop } { acl { ipv4-acl-number | name ipv4-acl-name } | prefix-list prefix-list-name }
undo if-match ip { address | next-hop } [ acl | prefix-list ]
No ACL or IPv4 prefix list match criterion is configured.
context-admin
address: Matches the destination address of IPv4 routes.
next-hop: Matches the next hop of IPv4 routes.
acl ipv4-acl-number: Specifies an ACL by its number. The value range for the ipv4-acl-number argument is 2000 to 3999 for the address keyword, and 2000 to 2999 for the next-hop keyword.
acl name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with a letter and cannot be all.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
Follow these restrictions and guidelines to use an IPv4 advanced ACL rule to configure an ACL match criterion:
·     To match the destination address of IPv4 routes, execute the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to create the rule.
·     To match the destination address mask of IPv4 routes, execute the rule [ rule-id ] { deny | permit } ip destination dest-addr dest-wildcard command to create the rule. Make sure the wildcard mask specified by the dest-wildcard argument is consecutive. If the wildcard mask is nonconsecutive, the rule is not applicable to the if-match ip command.
# Configure node 10 of routing policy policy1 to match IPv4 routes whose next hop matches IP prefix list p1.
[Sysname-route-policy-policy1-10] if-match ip next-hop prefix-list p1
ip prefix-list
Use ip prefix-list to configure an IPv4 prefix list or an item for the list.
Use undo ip prefix-list to remove an IPv4 prefix list or an item of it.
undo ip prefix-list prefix-list-name [ index index-number ]
No IPv4 prefix lists exist.
context-admin
prefix-list-name: Specifies an IPv4 prefix list name, a case-sensitive string of 1 to 63 characters.
index index-number: Specifies an index number for an IPv4 prefix list item, in the range of 1 to 65535. An item with a smaller index number is matched first. If you do not specify this option, the index number starts from 10 and increases by 10 for each of the consecutive prefix list items.
permit: Specifies the permit mode. If a route matches the item, it passes the IPv4 prefix list. If a route does not match the item, the route is compared with the next item.
ip-address mask-length: Specifies an IPv4 prefix and mask length. The value range for the mask-length argument is 0 to 32.
greater-equal min-mask-length, less-equal max-mask-length: Specifies a prefix length range. The greater-equal keyword means "greater than or equal to" and the less-equal keyword means "less than or equal to." The prefix length range relation is mask-length <= min-mask-length <= max-mask-length <= 32.
·     If only the min-mask-length argument is specified, the prefix length range is [ min-mask-length, 32 ].
·     If only the max-mask-length argument is specified, the prefix length range is [ mask-length, max-mask-length ].
·     If both the min-mask-length and max-mask-length arguments are specified, the prefix length range is [ min-mask-length, max-mask-length ].
An IPv4 prefix list is used to filter IPv4 addresses. It can contain multiple items, each of which specifies a range of IPv4 prefixes. The relation between the items is logical OR. If an item is passed, the IPv4 prefix list is passed. If no item is passed, the IP prefix list cannot be passed.
If both the ip-address and mask-length arguments are specified as 0.0.0.0 0, only the default route will be matched.
To match all routes, use 0.0.0.0 0 less-equal 32.
# Configure IP prefix list p1 to permit routes destined for network 10.0.0.0/8 and with mask length 17 or 18.
[Sysname] ip prefix-list p1 permit 10.0.0.0 8 greater-equal 17 less-equal 18
Use reset ip prefix-list to clear IPv4 prefix list statistics.
context-admin
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all IPv4 prefix lists.
# Clear the statistics for IPv4 prefix list abc.
<Sysname> reset ip prefix-list abc
ip prefix-list
IPv6 routing policy commands
apply ipv6 fast-reroute
Use apply ipv6 fast-reroute to set a backup link for fast route (FRR).
Use undo apply ipv6 fast-reroute to restore the default.
context-admin
backup-nexthop ipv6-address: Specifies an IPv6 backup next hop.
# Configure node 10 of routing policy policy1 to set the backup next hop 1::1/64 for the route destined for 100::1/64.
[Sysname] ipv6 prefix-list abc index 10 permit 100::1 64
[Sysname-route-policy-policy1-10] if-match ipv6 address prefix-list abc
[Sysname-route-policy-policy1-10] apply ipv6 fast-reroute backup-nexthop 1::1
apply ipv6 next-hop
Use apply ipv6 next-hop to set a next hop for IPv6 routes.
Use undo apply ipv6 next-hop to restore the default.
No next hop is set for IPv6 routes.
context-admin
ipv6-address: Specifies the next hop IPv6 address.
# Configure node 10 in permit mode for routing policy policy1 to set next hop 3ffe:506::1 for IPv6 routes matching prefix list 100.
[Sysname] ipv6 prefix-list 100 permit 2::2 64
[Sysname-route-policy-policy1-10] if-match ipv6 address prefix-list 100
[Sysname-route-policy-policy1-10] apply ipv6 next-hop 3ffe:506::1
display ipv6 prefix-list
Use display ipv6 prefix-list to display IPv6 prefix list statistics.
context-admin
context-operator
name prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all IPv6 prefix lists.
# Display the statistics for all IPv6 prefix lists.
<Sysname> display ipv6 prefix-list
Prefix-list6: 666
 Permitted 0
 Denied 0
         index: 10        Permit 6::/64                  ge  66  le  88
Table 5 Command output
Prefix-list6
Name of the IPv6 prefix list.
Permitted
Denied
index
Index number of an item.
permit
·     Permit.
·     Deny.
6::/64
IPv6 address and prefix length for matching.
ge
Greater-equal, the lower prefix length limit.
le
Less-equal, the upper prefix length limit.
ipv6 prefix-list
reset ipv6 prefix-list
if-match ipv6
Use if-match ipv6 to match IPv6 routes whose destination, next hop, or source address matches an ACL or IPv6 prefix list.
Use undo if-match ipv6 to remove the specified ACL or IPv6 prefix list match criterion.
if-match ipv6 { address | next-hop } { acl { ipv6-acl-number | name ipv6-acl-name } | prefix-list prefix-list-name
undo if-match ipv6 { address | next-hop } [ acl | prefix-list ]
No ACL or IPv6 prefix list match criterion is configured.
context-admin
address: Matches the destination address of IPv6 routes.
next-hop: Matches the next hop of IPv6 routes.
acl ipv6-acl-number: Specifies an IPv6 ACL by its number. The value range for the ipv6-acl-number argument is 2000 to 3999 for the address keyword, and 2000 to 2999 for the next-hop and route-source keywords.
acl name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with a letter and cannot be all.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
Follow these restrictions and guidelines to use an IPv6 advanced ACL rule to configure an ACL match criterion:
·     To match the destination address of IPv6 routes, execute the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to create the rule.
·     To match the destination address prefix of IPv6 routes, execute the rule [ rule-id ] { deny | permit } ip destination dest-addr dest-wildcard command to create the rule. Make sure the address prefix specified by the dest-wildcard argument is consecutive. If the address prefix is nonconsecutive, the rule is not applicable to the if-match ipv6 command.
# Configure node 10 of routing policy policy1 to permit routes whose next hop matches IPv6 prefix list p1.
[Sysname-route-policy-policy1-10] if-match ipv6 next-hop prefix-list p1
ipv6 prefix-list
Use ipv6 prefix-list to configure an IPv6 prefix list or an item for it.
Use undo ipv6 prefix-list to remove an IPv6 prefix list or an item.
ipv6 prefix-list prefix-list-name [ index index-number ] { deny | permit } ipv6-address { prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ] | inverse inverse-prefix-length }
undo ipv6 prefix-list prefix-list-name [ index index-number ]
No IPv6 prefix lists exist.
context-admin
prefix-list-name: Specifies an IPv6 prefix list name, a case-sensitive string of 1 to 63 characters.
index index-number: Specifies an index number for an IPv6 prefix list item, in the range of 1 to 65535. An item with a smaller index number is matched first. If you do not specify this option, the index number starts from 10 and increases by 10 for each of the consecutive IPv6 prefix list items.
permit: Specifies the permit mode. If a route matches the item, it passes the IPv6 prefix list. If a route does not match the item, the route is compared with the next item.
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the IPv6 prefix length. The value range for the prefix-length argument is 0 to 128.
The prefix length range relation is mask-length <= min-mask-length <= max-mask-length <= 128.
·     If only the min-prefix-length argument is specified, the prefix length range is [ min-prefix-length, 128 ].
·     If only the max-prefix-length argument is specified, the prefix length range is [ prefix-length, max-prefix-length ].
·     If both the min-prefix-length and max-prefix-length arguments are specified, the prefix length range is [ min-prefix-length, max-prefix-length ].
inverse inverse-prefix-length: Matches IPv6 addresses from the least significant bit to the specified length. The value range for the inverse-prefix-length argument is 1 to 128.
An IPv6 prefix list is used to filter IPv6 addresses. An IPv6 prefix list can have multiple items, and each of them specifies a range of IPv6 prefixes. The relation between the items is logical OR. A route passing an item passes the IPv6 prefix list. A route passing no item does not pass the IPv6 prefix list.
If the ipv6-address prefix-length argument is specified as :: 0, only the default route matches.
To match all routes, configure :: 0 less-equal 128.
# Permit IPv6 addresses with a mask length between 32 bits and 64 bits.
[Sysname] ipv6 prefix-list abc permit :: 0 greater-equal 32 less-equal 64
# Deny IPv6 addresses with a prefix 3FFE:D00::/32 and a prefix length greater than or equal to 32 bits.
[Sysname] ipv6 prefix-list abc deny 3FFE:D00:: 32 less-equal 128
Use reset ipv6 prefix-list to clear IPv6 prefix list statistics.
context-admin
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all IPv6 prefix lists.
# Clear the statistics for IPv6 prefix list abc.
<Sysname> reset ipv6 prefix-list abc
ipv6 prefix-list
