10-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath IPS Comware 7 Command References (R8560 R8660)-6W60010-Layer 3—IP Services Command Reference
11-Multi-CPU packet distribution commands
11-Multi-CPU packet distribution commands 41.46 KB
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow [ three-tuple | mode { source-ip | destination-ip | source-port | destination-port } ] | per-packet }
The device uses the flow-based policy that identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
context-admin
per-flow: Specifies the flow-based forwarding. The device forwards packets of the same flow to the same CPU. The device identifies a data flow by source IP address, destination IP address, source port number, destination port number, and protocol number. The CPU processes flow packets by following the first-in first-out rule.
three-tuple: Identifies a data flow by the three-tuple (source IP address, destination IP address, and protocol number). If you do not specify this keyword, the device identifies a data flow by the five-tuple.
The following compatibility matrix shows the support of hardware platforms for the three-tuple keyword:
Series
Models
Parameter compatibility
T5000 series
T5010, T5020
No
T5030, T5060, T5080, T5000-C, T5000-S
Yes
T10X0 series
T1020, T1030, T1050, T1060, T1080
No
T1000-AK series
T1000-AK340, T1000-AK345, T1000-AK350, T1000-AK355, T1000-AK365
No
T1000-AI series
T1000-AI-25, T1000-AI-35, T1000-AI-50, T1000-AI-55, T1000-AI-60, T1000-AI-65, T1000-AI-70, T1000-AI-80, T1000-AI-90
No
IPS modules
IM-IPSX-IV, LSQM1IPSDSC0, LSWM1IPSD0
Yes
mode: Specifies a flow-based forwarding mode.
source-ip: Identifies a flow by source IP address.
destination-ip: Identifies a flow by destination IP address.
source-port: Identifies a flow by source port.
destination-port: Identifies a flow by destination port.
The following compatibility matrix shows the support of hardware platforms for the mode keyword:
Series
Models
T5000 series
T5010, T5020
No
Yes
T10X0 series
No
T1000-AK series
No
T1000-AI series
No
IPS modules
Yes
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
If you do not specify any keyword for flow identification, the device identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
