H3C Servers BIOS User Guide for AMD EPYC Series Rome & Milan Processors-6W100
HomeSupportServerH3C Uniserver R4950 G5Configure & DeployUser ManualsH3C Servers BIOS User Guide for AMD EPYC Series Rome & Milan Processors-6W100
01-Text
01-Text 8.30 MB
About the BIOS·· 1
Introduction· 1
Applicable products· 1
Using this document 1
Common BIOS tasks· 1
Entering the BIOS setup utility· 1
Displaying processor information· 4
Displaying memory information· 5
Displaying onboard drive information· 7
Displaying HDM network information· 8
Setting HDM network information· 9
Configuring BIOS passwords· 10
About this task· 10
Restrictions and guidelines· 11
Setting a BIOS password· 12
Deleting a BIOS password· 13
Setting the system date and time· 16
Setting the BIOS boot mode· 17
Setting the server boot order 17
Configuring RAID·· 19
Restoring BIOS default settings· 19
BIOS menus· 21
Main menu· 21
Advanced menu· 22
AMD CBS submenu· 24
AMD PBS submenu· 54
Trusted Computing submenu· 57
PSP Firmware Versions submenu· 60
ACPI Settings submenu· 61
Serial Port Console Redirection submenu· 62
CPU Configuration submenu· 68
PCI Subsystem Settings submenu· 70
USB Configuration submenu· 74
CSM Configuration submenu· 76
NVMe Configuration submenu· 77
SATA Configuration submenu· 78
Network Configuration submenu· 79
Miscellaneous Configuration submenu· 81
iSCSI Configuration submenu (for Rome processors only) 82
Driver Health submenu· 90
Chipset menu· 91
North Bridge submenu· 92
Server menu· 94
View FRU information submenu· 97
Firmware Information submenu· 98
HDM Network Configuration submenu· 99
HDM User Settings submenu· 104
Security menu· 105
Boot menu· 111
Exit menu· 117
Acronyms and abbreviations· 120
About the BIOS
Introduction
The Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1, the BIOS interacts between the server hardware and the operating system (OS).
Figure 1 Layered architecture of a server system
Applicable products
This document is applicable to the H3C UniServer R4950 G5 server and R5500 G5 AMD server.
Using this document
The information in this document is subject to change over time. You can access the H3C website to obtain the most recent version of the BIOS.
The information in this document might differ from your product if it contains custom configuration options or features.
The figures used in this document are for illustration only and might differ from your product.
Common BIOS tasks
This section provides procedures for the following common BIOS tasks:
·     Entering the BIOS setup utility
·     Displaying processor information
·     Displaying memory information
·     Displaying onboard drive information
·     Displaying HDM network information
·     Setting HDM network information
·     Configuring BIOS passwords
·     Setting the system date and time
·     Setting the BIOS boot mode
·     Setting the server boot order
·     Configuring RAID
·     Restoring BIOS default settings
1.     Connect a keyboard, a mouse, and a monitor to the server or enable the remote console from the HDM Web interface.
For information about enabling the remote console, see H3C Servers HDM User Guide.
2.     Start or restart the server.
3.     Press Del or Esc when the BIOS startup screen opens, as shown in Figure 2.
Figure 2 BIOS setup screen
Table 1 BIOS shortcut keys
Key
Esc/Del
Enter the BIOS setup screen.
F7
Enter the Boot menu.
F10
Enter the iFIST GUI. For more information, see H3C Servers iFIST User Guide.
F12
Enter PXE boot.
4.     (Optional.) If you have set a BIOS administrator password and a user password, select the role before entering BIOS setup, and then enter the BIOS password. Figure 3 and Figure 4 use user Admin as an example.
By default, no BIOS passwords are set. For information about BIOS password setup, see "Configuring BIOS passwords."
If you enter an incorrect password for three consecutive times, the server will restart automatically.
If you forget the password, use the system maintenance switch in the server to clear BIOS password settings. For more information about the system maintenance switch, see the user guide for the server.
Figure 3 Selecting a role to enter setup
Figure 4 Entering the BIOS password
5.     On the BIOS setup utility screen that opens, follow the instructions at the lower-right side of the screen to configure BIOS settings, as shown in Figure 5.
Table 2 shows detailed information about the operation keys.
Figure 5 BIOS setup utility screen
Table 2 Operation keys
Key
Arrows
Select a screen or item.
Enter
Select an item to edit its value or access a submenu.
Change the field value of the selected item.
ESC
Exit the BIOS setup utility or return to the previous screen.
F1
Display the general help window.
F2
Load previous values in the BIOS.
F3
Load default values in the BIOS.
F4
Save the current configuration and exit the BIOS.
<K>
Scroll up the help area at the upper-right side of the screen.
<M>
Scroll down the help area at the upper-right side of the screen.
1.     Enter the BIOS setup utility. For more information, see "Entering the BIOS setup utility."
2.     Select Advanced > CPU Configuration, and press Enter.
The CPU Configuration submenu opens, as shown in Figure 6.
Figure 6 CPU Configuration submenu screen
3.     Select a processor node to view detailed information about the processor, as shown in Figure 7. This section selects Node 1 Information as an example.
For more information about the CPU Configuration submenu, see "CPU Configuration submenu."
Figure 7 Viewing node1 information
2.     Select Advanced > North Bridge, and press Enter.
The North Bridge Configuration submenu opens, as shown in Figure 9.
Figure 8 North Bridge Configuration submenu
3.     Select a socket to view DIMM information for the corresponding processor, including DIMM presence status, capacity, and frequency, and then press Enter, as shown in Figure 9.
This section selects Socket 1 Information as an example.
For more information about the North Bridge Configuration and Socket N Information submenus, see "North Bridge submenu."
Figure 9 Socket 1 Information submenu
2.     Select Advanced > SATA Configuration, and press Enter.
The SATA Configuration submenu that opens displays drive information, as shown in Figure 10.
Figure 10 PCH SATA Configuration submenu
2.     Select Server > HDM Network Configuration, and press Enter.
The HDM Network Configuration submenu that opens displays HDM network configuration information, as shown in Figure 11.
Figure 11 HDM Network Configuration screen
Perform this task to configure the IP address, subnet mask, and router IP address of HDM network ports and the method of obtaining the network information.
The submenus are the same for both HDM dedicated and shared network ports. This example uses the HDM dedicated network port.
Do not disconnect the AC power within 15 seconds after you modify and save HDM IPv4 and IPv6 address settings. Otherwise, the IP address setting might fail.
To avoid network storms, make sure the IP address of the HDM shared network port is on a network segment different than the HDM dedicated network port.
To avoid device disconnection, make sure HDM network configurations are correct.
As shown in Figure 11, in the HDM Network Configuration submenu, both IPv4 configuration and IPv6 configuration are supported. Take IPv4 network configuration as an example.
3.     Select IPv4 Network Configuration.
4.     Select Configuration Address source for the HDM dedicated network port, and press Enter.
5.     In the dialog box that opens, select the method for obtaining HDM network information. Options are:
¡     UnspecifiedRetains current configuration.
¡     StaticUses manually specified configuration.
¡     DynamicHdmDhcpUses network information obtained through DHCP.
Figure 12 Configuration Address Source dialog box
6.     Press Enter. If you select Static as the method for obtaining HDM network information, edit the following items and press Enter every time you finish editing:
¡     Station IP address—Enter a static IP address. This item is required. If you do not enter a static IP address, the default HDM IP address will be 0.0.0.0.
¡     Subnet mask—Enter a subnet mask for the static IP address. This item is required.
¡     Router IP address—Enter a gateway IP address.
7.     Press F4 and then press Enter to save the configuration.
The server will restart automatically.
BIOS passwords include a boot password as well as an administrator password and a user password for BIOS Setup. By default, no passwords are set.
·     A boot password is required each time the server starts up.
·     An administrator password or a user password is required each time you enter the BIOS Setup screen.
If only the administrator password is set, you can enter this password to obtain administrator privileges. The system prompts for the password when you use shortcut keys to enter the BIOS setup utility, iFIST, boot menu, or PXE boot interface.
If only the user password is set, you can enter this password to obtain user privileges. Table 3 shows the menu items that are accessible in the BIOS with the user privileges.
Table 3 BIOS menu items accessible with the user password
Level-1 menu
Submenu items
Server
IPv4/IPv6 Network Configuration > Refresh
Security
User Password
Exit
Save Changes and Exit
Discard Changes and Exit
Save Changes and Reset
Discard Changes and Reset
Save Changes
Discard Changes
When you change a BIOS password, make sure the new password is different from the most recent three passwords.
The BIOS passwords must meet the following requirements:
·     A case-sensitive string of 8 to 20 characters. Valid characters are letters, digits, spaces, and special characters in Table 4.
·     Contain a minimum of two character types from uppercase letters, lowercase letters, and digits.
·     Contain a minimum of one space or special character.
Table 4 Special characters
Character name
Symbol
Character name
Symbol
Back quote
Tilde
Exclamation point
At sign
Pound sign
Dollar sign
Percent sign
Caret
Ampersand sign
Asterisk
Left parenthesis
Right parenthesis
Underscore
_
Plus sign
Minus sign
Equal sign
Left bracket
Right bracket
Back slash
Left brace
Right brace
Vertical bar
Semi-colon
Apostrophe
Colon
Quotation marks
Comma
Dot
Forward slash
Left angle bracket
Right angle bracket
Question mark
The procedure is the same for setting the administrator password and the user password. As a best practice, set the administrator password if you set the user password. This section uses the administrator password as an example.
To set the administrator password:
2.     Select Security > Administrator Password, and press Enter
3.     In the Create New Password dialog box that opens, enter an administrator password, and press Enter, as shown in Figure 13.
Figure 13 Creating an administrator password
4.     In the Confirm New Password dialog box that opens, enter the password again, and press Enter.
Figure 14 Confirming the administrator password
5.     Press F4 and then press Enter to save the configuration.
The server will continue operating. The new password is required at the next server boot.
The procedure is the same for deleting the administrator password and the user password. This section uses the administrator password as an example.
To delete the administrator password:
2.     Select Security > Administrator Password, and press Enter, as shown in Figure 15.
Figure 15 Selecting the administrator password
3.     In the Enter Current Password dialog box that opens, enter the current administrator password, and press Enter.
Figure 16 Entering the current administrator password
3.     Press Enter when the Create New Password dialog box opens as shown in Figure 17.
Figure 17 Deleting the administrator password
4.     In the WARNING dialog box that opens, select Yes, and press Enter.
Figure 18 Confirming the deletion
5.     Press F4 and then press Enter to save the configuration and exit the BIOS setup utility.
2.     Select the Main menu.
Figure 19 Main menu
3.     Set the system date:
a.     Select System Date.
The system date is in the format of mm/dd/yyyy.
a.     Press Enter or Tab to switch between the month, day, and year fields and then use the following methods to modify the value:
-     Press + to increase the value by 1.
-     Press to decrease the value by 1.
-     Press numeric keys to enter a new value.
4.     Set the system time:
a.     Select System Time.
The system time uses the 24-hour time system and is in the format of hh:mm:ss.
a.     Press Enter or Tab to switch between the hour, minute, and second fields and then use the following methods to modify the value:
The server supports two BIOS boot modes: legacy mode and UEFI mode.
By default, the boot mode is UEFI. For operating systems that support only the legacy mode, change the boot mode to legacy.
32-bit operating systems do not support the UEFI mode and you must install such operating systems in Legacy mode.
An operating system can run only in the BIOS boot mode under which the system was installed. For example, operating systems installed in legacy mode cannot start up in UEFI mode, and operating systems installed in UEFI mode cannot start up in legacy mode.
1.     Enter the BIOS setup screen. For more information, see "Entering the BIOS setup utility."
2.     Select Boot > Boot mode select, and press Enter.
3.     In the Boot mode select dialog box that opens, select LEGACY or UEFI, and press Enter.
Figure 20 Setting the BIOS boot mode
4.     Press F4 and then press Enter to save the configuration.
Perform this task to change the server boot order.
The default boot order is hard disk > network > CD/DVD > other device as shown in the Fixed Boot Order Priorities list in Figure 21.
If the server has more than one boot devices of the same type, the Fixed Boot Order Priorities list displays only the first boot device. To change the first boot device, enter the corresponding priorities submenu of the boot device, and then set the first boot option. For example, to change the first boot option for hard disks, enter the UEFI Hard Disk Drive BBS Priorities submenu as shown in Figure 100, and then set the first boot option.
2.     As shown in Figure 21, select the Boot menu.
Figure 21 Boot menu
Table 5 Server boot options
Item
Example
Hard Disk
Disk (including virtual drives), SD cards, and USB-HDD.
Network
Network.
CD/DVD
CD-ROM and DVD-ROM (including virtual ones), USB-CD, and USB-DVD.
Other Device
The options include but are not limited to:
·     Boot option for entering the Shell command line interface. This option is available only when EFI Shell Boot is set to Enabled.
·     Other unidentified boot devices.
Disabled
The boot option is disabled.
3.     As shown in Figure 22, select the option to be modified from the Fixed Boot Order Priorities area, and press Enter.
4.     In the dialog box that opens, select a new boot device type, and press Enter.
Figure 22 Changing a boot option submenu screen
Configuring RAID
For information about to configure RAID through the BIOS, see the storage controller user guide for the server.
Perform this task to restore the BIOS to its default settings if unknown modifications to the BIOS cause system problems.
2.     Press F3 in the BIOS, or select Exit > Restore Defaults and press Enter as shown in Figure 23.
3.     Press F4 and Enter to save the settings. The configuration will take effect after the server reboots.
Figure 23 Restoring the default from the Exit submenu screen
BIOS menus
Main menu
As shown in Figure 24, the Main menu contains information about the BIOS, memory, system language, and system time and date. For more information about the menu items, see Table 6.
Figure 24 Main menu screen
Table 6 Items on the Main menu screen
Item
BIOS Information
Project Name
Displays the project name.
N/A
Product Name
Displays the product name.
N/A
BIOS Version
Displays the BIOS version.
N/A
System Uuid
Displays the universally unique identifier (UUID) of the system.
N/A
Serial Number
Displays the serial number of the server, a string of 2 to 20 characters. Only uppercase letters and digits are allowed.
N/A
Asset Tag
Specify the asset tag of the server, a case-sensitive string of 2 to 32 characters.
N/A
Build Date and Time
Displays the compiling date and time of the BIOS build.
N/A
Memory Information
Total Memory
Displays the total memory capacity of the system in GB.
N/A
System Language
Displays the language used in the system.
The BIOS supports English and simplified Chinese.
To switch between the languages, press Enter.
English
System Date
Displays the system date. You can change the system date as needed.
The system date is in the format of mm/dd/yyyy. To move between the month, day, and year fields, press Enter or Tab. To change the value for the selected field, use the following method:
·     Press + to increase the value by 1.
·     Press - to decrease the value by 1.
·     Press a numeric key to set the value.
N/A
System Time
Displays the system time. You can change the system time as needed.
The system time is in the format of hh:mm:ss in 24-hour format. To move between the hour, minute, and second fields, press Enter or Tab. To change the value for the selected field, use the following method:
N/A
Advanced menu
As shown in Figure 25, the Advanced menu contains advanced system features and functionalities, which are described in Table 7.
Figure 25 Advanced menu screen
Table 7 Items on the Advanced menu screen
Item
AMD CBS
Submenu for configuring processor-related settings.
AMD PBS
Submenu for configuring AMD PBS settings.
Trusted Computing
Submenu for configuring trusted computing.
Submenu for viewing firmware version of Platform Security Processor (PSP).
ACPI Settings
Submenu for configuring advanced configuration and power interface (ACPI) settings.
Submenu for configuring serial console port redirection.
CPU Configuration
Submenu for configuring processors.
Submenu for configuring the PCI subsystem.
USB Configuration
Submenu for configuring USB.
CSM Configuration
Submenu for configuring the compatibility support module (CSM).
NVMe Configuration
Submenu for configuring NVMe.
SATA Configuration
Submenu for configuring SATA settings.
Submenu for configuring network stacks.
Other configuration.
iSCSI Configuration
Submenu for configuring iSCSI settings. This menu is displayed only for Rome processors.
AMD CBS submenu
Figure 26 shows the AMD CBS menu screen, on which you can configure processor-related settings as described in Table 8.
Figure 26 AMD CBS submenu screen
Table 8 Items on the AMD CBS submenu screen
Item
CPU Common Options
Submenu for configuring common processor settings, as shown in Figure 27.
The submenu items are described in Table 9.
DF Common Options
Submenu for configuring common Data Fabric (DF) settings, as shown in Figure 34.
The submenu items are described in Table 16.
UMC Common Options
Submenu for configuring common Unified Memory Controllers (UMC) settings, as shown in Figure 38.
The submenu items are described in Table 20.
NBIO Common Options
Submenu for configuring common Northbridge IO (NBIO) settings, as shown in Figure 45.
The submenu items are described in Table 27.
FCH Common Options
Submenu for configuring common Server/Fusion Controller Hub (FCH) settings, as shown in Figure 48.
The submenu items are described in Table 30.
CPU Common Options submenu
Figure 27 shows the CPU Common Options submenu screen, on which you can configure features such as hyper-threading and threading control for processors.
Figure 27 CPU Common Options submenu screen
Table 9 Items on the CPU Common Options submenu screen
Item
Performance
Submenu for CPU performance configuration, as shown in Figure 28.
The submenu items are described in Table 10.
N/A
Prefetcher settings
Submenu for configuring CPU prefetcher options, as shown in Figure 33.
The submenu items are described in Table 15.
N/A
Platform First Error Handling
Select whether to enable platform first error handling.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Enabled
Core Performance Boost
Select whether to enable core performance boost.
Options:
·     Enabled.
·     Disabled.
Enabled
Global C-state Control
Select whether to enable CPUs to operate in C-state power saving mode.
This feature enables processors to automatically adjust its power state, voltage, frequency, and power consumption according to the actual situation.
Options:
·     Auto.
·     EnabledAllows a processor to enter low-consumption state to save power. However, this can increase memory latency and frequency jitter.
·     Disabled.
Disabled
Power Supply Idle Control
Select the option to control power supply in idle state.
Options:
·     Auto.
·     Low Current IdleProvides low current in idle state.
·     Typical Current IdleProvides typical current in idle state.
Auto
Local APIC Mode
Select a local Advanced Programmable Interrupt Controller (APIC) mode.
Options:
·     AutoAutomatically sets the mode to xAPIC. If the total number of processor cores exceeds 256, the mode automatically changes to x2APIC.
·     xAPICSelects the xAPIC mode.
·     x2APICSelects the x2APIC mode. This mode helps OSs run more efficiently on high core count configurations and optimizes interrupt distribution in a virtualized environment.
Auto
ACPI_CST C1 Declaration
Select whether to make the C1 state available for OSs.
Options:
·     Auto.
·     EnabledMakes the C1 state available for OSs.
·     DisabledMakes the C1 state unavailable for OSs.
Auto
MCA error thresh enable
Select whether to enable MCA error thresholding.
Options:
·     AutoEnables MCA error thresholding by default.
·     FalseDisables MCA error thresholding.
·     TrueEnables MCA error thresholding.
Auto
The default is True for Rome processors.
MCA error thresh count
This item is available only when MCA error thresh enable is set to True.
Set the MCA error threshold in hexadecimal notation.
0xff5
The default is 0x5f for Rome processors.
SMEE
Select whether to enable AMD encryption, including Secure Memory Encryption (SME) and Secure Encrypted Virtualization (SEV).
Options:
·     Enabled.
·     Disabled.
This item is displayed only for Milan processors.
Enabled
Performance submenu
Figure 28 shows Performance submenu screen. The submenu items are described in Table 10.
Figure 28 Performance submenu screen
Table 10 Items on the Performance submenu screen
Item
OC Mode
Select the overclock settings.
Options:
·     Normal OperationUses common settings.
·     CustomizedUses custom settings.
Normal Operation
Custom Core Pstates
Submenu for configuring custom core P-states options, as shown in Figure 30.
The submenu items are described in Table 12.
N/A
CCD/Core/Thread Enablement
Submenu for configuring CCD/core/thread enablement options, as shown in Figure 32.
The submenu items are described in Table 14.
N/A
SMT Control
Select whether to enable Symmetric Multi-Threading (SMT) control.
Options:
·     Enabled.
·     Disabled.
Enabled
The warning screen as shown in Figure 29 opens before you access the Custom Core Pstates submenu. The submenu items are described in Table 11.
Figure 29 Warning screen for access to Custom Core Pstates submenu
Table 11 Items on the warning screen for access to the Custom Core Pstates submenu
Item
Accept
Acknowledge the warning message and access the Custom Core Pstates submenu.
N/A
Figure 30 shows Custom Core Pstates submenu screen. The submenu items are described in Table 12.
Core P-states indicate the operating performance states that feature the combination of core frequencies and voltages. Processors support a maximum of three core P-states available for OSs, including Pstate0 (basic frequency), Pstate1 (medium frequency), and Pstate 2 (minimum frequency).
Figure 30 Custom Core Pstates submenu screen
Table 12 Items on the Custom Core Pstates submenu screen
Item
Custom Pstate0
Select whether to enable customizing Pstate0 settings.
Options:
·     CustomAllows you to customize Pstate0 settings.
·     Auto.
Auto
Frequency (MHz)
This item is available only when Custom Pstate0 is set to Custom.
Displays the core frequency for Pstate0.
N/A
Voltage (uV)
This item is available only when Custom Pstate0 is set to Custom. This item is not displayed for Milan processors.
Displays the voltage for Pstate0.
N/A
Pstate0 FID
Set the Pstate0 frequency ID (FID). Current operating frequency = 200MHz × FID/DID.
N/A
Pstate0 DID
Set the Pstate0 divisor ID (DID).
N/A
Pstate0 VID
Set the Pstate0 voltage ID (DID).
N/A
Custom Pstate1
Select whether to enable customizing Pstate1 settings. This item is not displayed for Milan processors.
Options:
·     DisabledDisables configuring Pstate1 settings.
·     CustomAllows you to customize Pstate1 settings.
·     Auto.
Auto
Frequency (MHz)
Displays the core frequency for Pstate1.
N/A
Voltage (uV)
This item is available only when Custom Pstate1 is set to Custom.
Displays the voltage for Pstate1.
N/A
Pstate1 FID
Set the Pstate1 FID. Current operating frequency = 200MHz × FID/DID.
N/A
Pstate1 DID
Set the Pstate1 DID.
N/A
Pstate1 VID
N/A
Custom Pstate2
Select whether to enable customizing Pstate2 settings. This item is not displayed for Milan processors.
Options:
·     DisabledDisables configuring Pstate2 settings.
·     CustomAllows you to customize Pstate2 settings.
·     Auto.
Auto
Frequency (MHz)
Displays the core frequency for Pstate2.
N/A
Voltage (uV)
This item is available only when Custom Pstate2 is set to Custom.
Displays the voltage for Pstate2.
N/A
Pstate2 FID
Set the Pstate2 FID. Current operating frequency = 200MHz × FID/DID.
N/A
Pstate2 DID
Set the Pstate2 DID.
N/A
Pstate2 VID
N/A
The warning screen as shown in Figure 31 opens before you access the CCD/Core/Thread Enablement submenu. The submenu items are described in Table 13.
Figure 31 Warning screen for access to CCD/Core/Thread Enablement submenu
Table 13 Items on the warning screen for access to CCD/Core/Thread Enablement submenu
Item
Accept
Acknowledge the warning message and access the CCD/Core/Thread Enablement submenu.
N/A
Figure 32 shows CCD/Core/Thread Enablement submenu screen. The submenu items are described in Table 14.
Figure 32 CCD/Core/Thread Enablement submenu screen
Table 14 Items on the CCD/Core/Thread Enablement submenu screen
Item
SMT Control
Select whether to enable simultaneous multithreading (SMT) control.
Options:
·     Enabled.
·     Disabled.
S3 sleeping state is not supported when STM control is disabled.
Enabled
Prefetcher Settings submenu
Figure 33 shows Prefetcher Settings submenu screen. The submenu items are described in Table 15.
Figure 33 Prefetcher Settings submenu screen
Table 15 Items on the Prefetcher Settings submenu screen
Item
L1 Stream HW Prefetcher
Select whether to enable the level-1 stream hardware prefetcher.
Options:
·     AutoThe level-1 stream hardware prefetcher is typically enabled by default.
·     Disabled.
·     Enabled.
Auto
L2 Stream HW Prefetcher
Select whether to enable the level-2 stream hardware prefetcher.
Options:
·     AutoThe level-2 stream hardware prefetcher is typically enabled by default.
·     Disabled.
·     Enabled.
Auto
DF Common Options submenu
Figure 34 shows the DF Common Options submenu screen, on which you can configure features such as DRAM scrub time, memory interleaving, and link speed.
Figure 34 DF Common Options submenu screen
Table 16 Items on the DF Common Options submenu screen
Item
Scrubber
Submenu for DRAM scrubbing configuration, as shown in Figure 35.
The submenu items are described in Table 17.
N/A
Memory Addressing
Submenu for memory addressing configuration, as shown in Figure 36.
The submenu items are described in Table 18.
N/A
Link
Submenu for link speed configuration, as shown in Figure 37.
The submenu items are described in Table 19.
N/A
Scrubber submenu
Figure 35 shows Scrubber submenu screen. The submenu items are described in Table 17.
Figure 35 Scrubber submenu screen
Table 17 Items on the Scrubber submenu screen
Item
DRAM scrub time
Set the memory scrub duration.
Options:
·     Disabled.
·     1 hour.
·     4 hours.
·     8 hours.
·     16 hours.
·     24 hours.
·     48 hours.
·     AutoThis option is recommended. The scrub duration is 24 hours by default.
Auto
Poison scrubber control
Select whether to enable poison scrubber control. This feature marks uncorrectable errors in DRAM to avoid delay errors in subsequent accesses.
Options:
·     AutoThis feature is automatically enabled by default.
·     Enabled.
·     Disabled.
Auto
Memory Addressing submenu
Figure 36 shows Memory Addressing submenu screen. The submenu items are described in Table 18.
Figure 36 Memory Addressing submenu screen
Table 18 Items on the Memory Addressing submenu screen
Item
NUMA nodes per socket
Specify the number of desired NUMA nodes per socket (NPS).
Options:
·     NPS0.
·     NPS1.
·     NPS2.
·     NPS4.
·     AutoThe default is set to NPS1 automatically.
Auto
Memory interleaving
Select whether to enable memory interleaving.
Options:
·     Auto.
·     Disabled. If this feature is disabled, the configuration of the NUMA nodes per socket parameter does not take effect.
Auto
Link submenu
Figure 37 shows Link submenu screen. The submenu items are described in Table 19.
Figure 37 Link submenu screen
Table 19 Items on the Link submenu screen
Item
4-link xGMI max speed
Specify the maximum speed of 4-link xGMI.
Options:
·     13Gbps.
·     16Gbps.
·     18Gbps.
·     Auto.
Auto
3-link xGMI max speed
Specify the maximum speed of 3-link xGMI.
Options:
·     10Gbps.
·     13Gbps.
·     16Gbps.
·     18Gbps.
·     Auto.
Auto
UMC Common Options submenu
Figure 38 shows the UMC Common Options submenu screen, on which you can view and configure memory mapping settings.
Figure 38 UMC Common Options submenu screen
Table 20 Items on the UMC Common Options submenu screen
Item
DDR4 Common Options
Submenu for setting common DDR4 options, as shown in Figure 39.
The submenu items are described in Table 21.
N/A
DRAM Memory Mapping
Submenu for configuring DRAM memory mapping settings, as shown in Figure 44.
The submenu items are described in Table 26.
N/A
DDR4 Common Options submenu
Figure 39 shows DDR4 Common Options submenu screen. The submenu items are described in Table 21.
Figure 39 DDR4 Common Options submenu screen
Table 21 Items on the DDR4 Common Options submenu screen
Item
DRAM Timing Configuration
Submenu for configuring DRAM timing settings, as shown in Figure 41.
The submenu items are described in Table 23.
N/A
Common RAS
Submenu for setting common RAS options, as shown in Figure 42.
The submenu items are described in Table 24.
N/A
The warning screen as shown in Figure 40 opens before you access the DRAM Timing Configuration submenu. The submenu items are described in Table 22.
Figure 40 Warning screen for access to DRAM Timing Configuration submenu
Table 22 Items on the warning screen for access to DRAM Timing Configuration submenu
Item
Accept
Acknowledge the warning message and access the DRAM Timing Configuration submenu.
N/A
Figure 41 shows DRAM Timing Configuration submenu screen. The submenu items are described in Table 23.
Figure 41 DRAM Timing Configuration submenu
Table 23 Items on the DRAM Timing Configuration submenu screen
Item
Overclock
Select whether to enable memory overclock.
Options:
·     Enabled.
·     AutoThe system might enable memory overclock within the specified range.
Auto
Memory Clock Speed
This item is available only when Overclock is set to Enabled.
Set the memory clock speed.
By default, the memory clock speed is automatically adjusted depending on DIMM installation method. If you install 1 DIMM per channel (1DPC), the speed is automatically set to 2666MT/s. If you install 2DPC in one channel, the speed is automatically set to 2400 MT/s.
To use other a memory clock speed than the default one, set the speed as needed.
Options:
·     AutoThis option is not available when you install 2DPC in one channel.
·     2133 MT/s.
·     2400 MT/s.
·     2666 MT/s.
·     2933 MT/s.
Auto
Figure 42 shows Common RAS submenu screen. The submenu items are described in Table 24.
Figure 42 Common RAS submenu screen
Table 24 Items on the Common RAS submenu screen
Item
Data Poisoning
Select whether to enable data poisoning.
Options:
·     EnabledAllows the system to continue operating even when uncorrectable errors are detected. This option takes effect only when the OS also supports data poisoning.
·     Disabled.
·     Auto.
Auto
DRAM Post Package Repair
Select whether to enable DRAM post package repair.
Options:
·     Enabled.
·     Disabled.
Disabled
RCD Parity
Select whether to enable RCD parity.
Options:
·     Enabled.
·     Disabled.
·     Auto.
The system can perform parity check on RDIMMs only when all installed RDIMMs support parity check.
Auto
DRAM Address Command Parity Retry
Select whether to enable DRAM address command parity retry.
Options:
·     Enabled.
·     Disabled.
·     Auto.
Auto
Max Parity Error Replay
Set the maximum number of parity error retries in hexadecimal notation.
This item is configurable only when DRAM Address Command Parity Retry is set to Enabled.
8
Write CRC Enable
Select whether to enable the write CRC feature.
Options:
·     EnabledEnables the system to examine the memory and correct memory data bus errors during memory writing.
·     Disabled.
·     Auto.
Auto
DRAM Write CRC Enable and Retry Limit
Select whether to enable DRAM write CRC and retry limit.
Options:
·     Enabled.
·     Disabled.
·     Auto.
Auto
Max Write CRC Error Replay
Set the maximum number of write CRC error retries in hexadecimal notation.
This item is configurable only when DRAM Write CRC Enable and Retry Limit is set to Enabled.
8
Disable Memory Error Injection
Select whether to disable memory error injection.
Options:
·     FalseDoes not disable memory error injection.
·     TrueDisables memory error injection.
True
ECC Configuration
Submenu for ECC configuration, as shown in Figure 43.
Figure 43 shows ECC Configuration submenu screen. The submenu items are described in Table 25.
Figure 43 ECC Configuration submenu screen
Table 25 Items on the ECC Configuration submenu screen
Item
DRAM ECC Symbol Size
Set the DRAM ECC symbol size.
Options:
·     ×4.
·     ×8.
·     ×16.
·     Auto.
Auto
DRAM UECC Retry
Select whether to enable DRAM uncorrectable ECC error (UECC) retry.
Options:
·     Enabled.
·     Disabled.
·     Auto.
Auto
DRAM Memory Mapping submenu
Figure 44 shows DRAM Memory Mapping submenu screen. The submenu items are described in Table 26.
Figure 44 DRAM Memory Mapping submenu screen
Table 26 Items on the DRAM Memory Mapping submenu screen
Item
Chipselect Interleaving
Select whether to enable interleaving memory blocks across the DRAM chip selects.
Auto
NBIO Common Options submenu
Figure 45 shows the NBIO Common Options submenu screen, on which you can configure NBIO settings, including RAS settings and AER settings.
Figure 45 NBIO Common Options submenu screen
Table 27 Items on the NBIO Common Options submenu screen
Item
IOMMU
Select whether to enable I/O memory management unit (IOMMU).
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
ACS Enable
Select whether to enable access control services (ACS).
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
SMU Common Options
Submenu for setting common SMU options, as shown in Figure 46.
The submenu items are described in Table 28.
N/A
NBIO RAS Common Options
Submenu for setting common NBIO RAS options, as shown in Figure 47.
The submenu items are described in Table 29.
N/A
Enable AER Cap
Select whether to enable the advanced error reporting capability.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
SMU Common Options submenu
Figure 46 shows the SMU Common Options submenu screen. The submenu items are described in Table 28.
Figure 46 SMU Common Options submenu screen
Table 28 Items on the SMU Common Options submenu screen
Item
Determinism Control
Select whether to enable determinism control.
Options:
·     AutoUses the fused determinism.
·     ManualCustomizes the determinism.
Manual
Determinism Slider
This item is available only when Determinism Control is set to Manual.
Set the determinism settings.
Options:
·     AutoUses the default performance determinism settings.
·     PowerIndicates the energy saving first mode.
·     PerformanceIndicates the performance first mode.
Performance
EfficiencyModeEn
Select whether to enable the high performance mode.
Options:
·     Enabled.
·     Disabled.
Disabled
xGMI Link Width Control
Select whether to enable xGMI link width control.
Options:
·     AutoSets xGMI link width control automatically.
·     Manual—Customizes xGMI link width control.
Auto
xGMI Force Link Width
This item is available only when xGMI Link Width Control is set to Manual.
Set the xGMI force link width.
Options:
·     0.
·     1.
·     2.
2
xGMI Force Link Width Control
Select whether to enable xGMI force link width control.
Options:
·     UnforceSets xGMI link width control automatically.
·     ForceCustomizes xGMI link width control.
Unforce
xGMI Max Link Width
This item is available only when xGMI Max Link Width Control is set to Manual.
Set the xGMI max link width.
Options:
·     0.
·     1.
1
Select whether to enable xGMI max link width control.
Options:
·     AutoSets xGMI max link width control automatically.
·     Manual—Customizes xGMI max link width control.
Auto
APBDIS
Configure Algorithm Performance Boost Disable (APBDIS).
Options:
·     AutoThe system uses the non-mission mode automatically.
·     0Uses the non-mission mode.
·     1Uses the mission mode.
Auto
DF Cstates
Select whether to enable DF C-states.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Disabled
Fixed SOC Pstate
This item is available only when APBDIS is set to 1.
Set the fixed SOC P-state value.
Options:
·     Auto.
·     P0.
·     P1.
·     P2.
·     P3.
P0
The default is Auto for Milan processors.
CPPC
Select whether to enable collaborative processor performance control (CPPC).
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
NBIO RAS Common Options submenu
Figure 47 shows the NBIO RAS Common Options submenu screen. The submenu items are described in Table 29.
Figure 47 NBIO RAS Common Options submenu screen
Table 29 Items on the NBIO RAS Common Options submenu screen
Item
NBIO RAS Control
Set NBIO RAS control.
Options:
·     DisabledDisables NBIO RAS.
·     MCAEnables MCA.
·     LegacyUses the traditional NBIO RAS method.
·     AutoAllows processors to manage NBIO RAS control.
Auto
PCIe Aer Reporting Mechanism
Select the method of reporting AER errors from PCIe.
Options:
·     Firmware FirstHandles errors through generation of a system management interrupt (SMI).
·     OS FirstHandles errors through generation of a system control interrupt (SCI).
·     MCA—Reports errors through MCA. This item is not displayed for Milan processors.
·     AutoUses the default method adopted by processors.
Auto
Edpc Control
Select whether to enable enhanced downstream port containment (eDPC) control on the PCIe root ports that connect to external PCIe devices.
Options:
·     Disabled.
·     Enabled.
·     Auto.
Disabled
NBIO Poison Consumption
Select whether to enable NBIO poison consumption.
Options:
·     Disabled.
·     Enabled.
·     Auto.
Auto
FCH Common Options submenu
Figure 48 shows the FCH Common Options submenu screen. The submenu items are described in Table 30.
Figure 48 FCH Common Options submenu screen
Table 30 Items on the FCH Common Options submenu screen
Item
SATA Configuration Options
Submenu for configuring SATA settings, as shown in Figure 49.
The submenu items are described in Table 31.
N/A
USB Configuration Options
Submenu for configuring USB settings, as shown in Figure 50.
The submenu items are described in Table 32.
N/A
SATA Configuration Options submenu
Figure 49 shows the SATA Configuration Options submenu screen. The submenu items are described in Table 31.
Figure 49 SATA Configuration Options screen
Table 31 Items on the SATA Configuration Options submenu screen
Item
SATA Enable
Select whether to enable OnChip SATA controller.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
USB Configuration Options submenu
Figure 50 shows the USB Configuration Options submenu screen. The submenu items are described in Table 32.
Figure 50 USB Configuration Options screen
Table 32 Items on the SATA Configuration Options submenu screen
Item
XHCI Controller0 enable
Select whether to enable XHCI controller 0.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
XHCI Controller1 enable
Select whether to enable XHCI controller 1.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
MCM USB enable
Submenu for configuring MCM USB enablement settings, as shown in Figure 51.
The submenu items are described in Table 33.
N/A
Figure 51 MCM USB enable submenu screen
Table 33 Items on the MCM USB enable submenu screen
Item
XHCI2 enable (Socket2)
Select whether to enable XHCI controller 2.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
XHCI3 enable (Socket2)
Select whether to enable XHCI controller 3.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
AMD PBS submenu
Figure 52 shows the AMD PBS menu screen, on which you can configure AMD PBS settings, as described in Table 34.
Figure 52 AMD PBS submenu screen
Table 34 Items on the AMD PBS submenu screen
Item
RAS
Submenu for configuring RAS settings, as shown in Figure 53.
The submenu items are described in Table 35.
N/A
SPI Locking
Select whether to enable SPI locking for protecting the ROM part.
Options:
·     Disabled.
·     Enabled.
Disabled
SRIS mode debug
Select whether to enable the SRIS debugging mode.
Options:
·     Disabled.
·     Enabled.
·     Auto.
Auto
Skip interval
This item is available only when SRIS mode debug is set to Enabled.
Set the skip intervals for SKP generation.
Options:
·     1506;144;6050;640.
·     1538;154;6068;656.
·     1358;128;6032;624.
·     1180;112;5996;608.
1506;144;6050;640
LOWER_SKP_OS_GEN_SUPPORT
Specify the lowest PCIe version that supports the generation of SKP ordered sets.
Options:
·     Disabled.
·     Gen1: PCIe 1.0.
·     Gen2: PCIe 2.0.
·     Gen3: PCIe 3.0.
·     Gen4: PCIe 4.0.
Disabled
LOWER_SKP_OS_RCV_SUPPORT
Specify the lowest PCIe version that supports the receiving of SKP ordered sets.
Options:
·     Disabled.
·     Gen1: PCIe 1.0.
·     Gen2: PCIe 2.0.
·     Gen3: PCIe 3.0.
·     Gen4: PCIe 4.0.
Disabled
SRIS Autodetect
Select whether to enable SRIS auto detection.
Options:
·     Disabled.
·     Enabled.
·     Auto.
Auto
SKP Interval Selection Mode
This item is available only when SRIS Autodetect is set to Enabled.
Specify the SKP interval selection mode.
Options:
·     SKP ordered set Interval Lock Mode.
·     Dynamic SKP ordered set Interval Mode.
·     Far End Nominal Empty Mode.
Autodetect Factor
Specify the auto detection factor.
Options:
·     1x.
·     0.95x.
·     0.9x.
·     0.85x.
1x
RAS submenu
Figure 53 shows the RAS submenu screen. The submenu items are described in Table 35.
Figure 53 RAS submenu screen
Table 35 Items on the RAS submenu screen
Item
RAS Periodic SMI Control
Select whether to enable RAS periodic SMI for reporting polling errors.
Options:
·     Enabled.
·     Disabled.
Enabled
DDR4 DRAM Hard Post Package Repair
Select whether to enable DDR4 DRAM hardware post package repair, which allows a spare DRAM line to replace a faulty DRAM line.
Options:
·     Enabled.
·     Disabled.
Disabled
The server might contain a trusted platform module (TPM) or a trusted cryptography module (TCM).
The Trusted Computing submenu screen varies by security module type installed on the server.
Trusted Computing submenu (TCM module installed)
Figure 54 shows the Trusted Computing submenu screen when a TCM module is installed and you can configure TCM module settings on the screen. The submenu items are described in Table 36.
Figure 54 Trusted Computing submenu screen (TCM module installed)
Table 36 Items on the Trusted Computing submenu screen when a TCM module is installed
Item
Configuration
Security Device Support
Select Enabled or Disabled to enable or disable BIOS support for security devices.
Enabled
TCM State
Select Enabled or Disabled to enable or disable TCM.
The server will restart to have the change take effect.
Enabled
Pending Operation
Select the TCM operation to be performed during the next boot process. The server will restart to have the change take effect.
Options:
·     NoneDisables this feature.
·     TCM ClearClears the TCM.
None
Current Status Information
TCM Enabled Status
Displays whether TCM is enabled or disabled.
N/A
TCM Active Status
Displays whether TCM is activated or deactivated.
N/A
TCM Owner Status
Displays the TCM ownership state. Options are Owned and Unowned.
N/A
Trusted Computing submenu (TPM module installed)
Figure 55 shows the Trusted Computing submenu screen when a TPM module is installed and you can configure TPM module settings on the screen. The submenu items are described in Table 37.
Figure 55 Trusted Computing submenu screen (TPM module installed)
Table 37 Items on the Trusted Computing submenu screen when a TPM module is installed
Item
Firmware Version
Displays the firmware version.
N/A
Vendor
Displays the name of the vendor.
N/A
Enabled
Active PCR banks
Displays the active platform configuration register (PCR) banks.
N/A
Available PCR Banks
Displays the available PCR banks.
N/A
SHA-1 PCR Bank
Select Enabled or Disabled to enable or disable the SHA-1 PCR bank.
Enabled
SHA256 PCR Bank
Select Enabled or Disabled to enable or disable the SHA256 PCR bank.
Enabled
SM3_256 PCR Bank
Select Enabled or Disabled to enable or disable the SM3_256 PCR bank.
Enabled
TPM State
Select Enabled or Disabled to enable or disable TPM.
Enabled
Pending Operation
Select the TPM operation to be performed during the next boot process. The server will reboot to have the change take effect.
Options:
·     TPM Clear—Clears the TPM.
None
Platform Hierarchy
This item is inaccessible.
Select Enabled or Disabled to enable or disable platform hierarchy.
Enabled
Storage Hierarchy
Select Enabled or Disabled to enable or disable storage hierarchy.
Enabled
Endorsement Hierarchy
Select Enabled or Disabled to enable or disable endorsement hierarchy.
Enabled
TPM 2.0 UEFI Spec Version
Select the supported Trusted Computing Group (TCG) specification version.
Options:
·     TCG_1_2—Supports Windows 8 and Windows 10.
·     TCG_2—Supports TCG 2 protocols, TCG 2 event formats, and Windows 10 or higher.
TCG_2
Physical Presence Spec Version
Select the Physical Presence Interface (PPI) specification version to be reported to the OS.
Options:
·     1.2.
·     1.3Some HCK tests might not support this version.
1.3
TPM 2.0 InterfaceType
Displays the TPM 2.0 interface type. This item is inaccessible.
N/A
PH Randomization
Select Enabled or Disabled to enable or disable platform hierarchy randomization.
This feature is used only for tests at the development phase.
Disabled
Figure 56 shows the PSP Firmware Versions submenu screen, which displays basic PSP firmware version information as described in Table 38.
Figure 56 PSP Firmware Versions submenu screen
Table 38 Items on the PSP Firmware Versions submenu screen
Item
PSP Directory Level 1 (Fixed)
Displays information about the current PSP directory level 1.
PSP Recovery BL Ver
Displays the PSP recovery bootloader version.
SMU FW Version
Displays the SMU firmware version.
ABL Version
Displays the ABL firmware version.
PSP Directory Level 2 Updateable)
Displays information about the PSP directory level 2 that can be updated.
PSP BootLoader Version
Displays the PSP bootloader version.
SMU FW Version
ABL Version
Figure 57 shows the ACPI Settings submenu screen. The submenu items are described in Table 39.
Figure 57 ACPI Settings submenu screen
Table 39 Items on the ACPI Settings submenu screen
Item
Enable ACPI Auto Configuration
Select Enabled or Disabled to enable or disable ACPI auto configuration.
Disabled
Lock Legacy Resources
Select Enabled or Disabled to enable or disable lock of legacy resources.
Disabled
Serial port console redirection enables you to send all text-based output to one of the onboard serial ports by using a physical or virtual serial port.
Figure 58 shows the Serial Port Console Redirection submenu screen, on which you can configure console redirection settings as described in Table 40.
Figure 58 Serial Port Console Redirection submenu screen
Table 40 Items on the Serial Port Console Redirection submenu screen
Item
COM0
Serial port COM0.
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on COM0.
Enabled
Console Redirection Settings
Open the Console Redirection Settings submenu for COM0, as shown in Figure 87.
The Console Redirection Settings submenu is accessible only when Console Redirection is enabled on COM0.
N/A
Legacy Console Redirection Settings
Open the Legacy Console Redirection Settings submenu, as shown in Figure 60.
N/A
Serial Port for Out-of-Band Management/Windows Emergency Management Services (EMS)
Serial port for out-of-band management or Windows Emergency Management Services (EMS).
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on the EMS port.
Disabled
Open the Console Redirection Settings submenu for the EMS port, as shown in Figure 61.
The Console Redirection Settings submenu is accessible only when Console Redirection is enabled for the EMS port.
N/A
Console Redirection Settings submenu (COM0)
Figure 59 shows a Console Redirection Settings submenu screen for serial port COM0, on which you can configure data change mode between the local and the remote terminals. The submenu items are described in Table 41.
Figure 59 Console Redirection Settings submenu screen (COM0)
Table 41 Items on the Console Redirection Settings submenu screen (COM0)
Item
Terminal Type
Select the type of the terminal used for console redirection.
Options:
·     VT100—Uses a supported VT100 video terminal with the ASCII character set.
·     VT100+—Uses a supported VT100-plus video terminal and its character set. VT100+ supports colors and function keys.
·     VT-UTF8Uses a video terminal with the UTF-8 character set.
·     ANSIUses the ANSI character set, which is an extended ASCII character set.
VT100+
Bits Per Second
Set the baud rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     38400.
·     57600.
·     115200.
This baud rate setting must match the setting on the remote terminal.
As a best practice, set a low speed on a long or noisy serial line.
115200
Data Bits
Set the number of bits used to represent one character of data.
Options:
·     7.
·     8.
8
Parity
Set the parity bit to be sent with the data bits for transmission error detection.
Options:
·     NoneDisables the parity check.
·     Even—Sets the parity bit so that the number of ones in the data set is an even number.
·     Odd—Sets the parity bit so that the number of ones in the data set is an odd number.
·     MarkAlways sets the parity bit to 1. If the parity bit is 0, an error has occurred.
·     Space—Always sets the parity bit to 0. If the parity bit is 1, an error has occurred.
None
Stop Bits
Set the number of stop bits used to indicate the end of a serial data packet.
Options:
·     1.
·     2.
Two stop bits might be required for communications with a slow device.
1
Flow Control
Select a flow control method to prevent data loss from buffer overflow.
Options:
·     NoneNo flow control is used.
·     Hardware RTS/CTSFlow control that uses the ready to send/clear to send (RTS/CTS) signal. When you select this option, make sure it is supported on the serial port.
If you enable hardware RTS/CTS on a serial port that does not support hardware flow control (such as a port that uses a USB-to-serial cable), or on a serial port with no cable connected, the following issues might occur:
·     Failure to load the option ROM of embedded and external PCIe modules.
·     Screen blackout.
·     Cursor flickering.
None
VT-UTF8 Combo Key Support
Select Enabled or Disabled to enable or disable VT-UTF8 combination key support for ANSI/VT100 terminals.
Enabled
Recorder Mode
Select Enabled or Disabled to enable or disable the recorder mode, which is used to capture terminal text data.
Disabled
Resolution 100×31
Select Enabled or Disabled to enable or disable enhanced terminal resolution (100 × 31).
Enabled
Putty KeyPad
Select a mode to change the action of the function keys and keypad in PuTTY.
Options:
·     VT100.
·     LINUX.
·     XTERMR6.
·     SCO.
·     ESCN.
·     VT400.
VT100
Figure 60 shows a Legacy Console Redirection Settings submenu screen. The submenu items are described in Table 42.
Figure 60 Legacy Console Redirection Settings submenu screen
Table 42 Items on the Legacy Console Redirection Settings submenu screen
Item
Redirection COM Port
Displays the redirection COM port.
Options:
·     COM0Serial port 0.
COM0
Legacy OS Redirection Resolution
Sets the resolution, the number of rows and columns, supported in console redirection on the legacy OS.
Options:
·     80×24Supports 80 rows and 24 columns.
·     80×25Supports 80 rows and 25 columns.
80×24
Redirection After POST
Selects whether to enable console redirection after POST.
Options:
·     Always Enable—Always enables this feature. With this feature enabled, legacy OS redirection remains enabled in a legacy OS.
·     BootLoaderEnables boot loader. With this feature disabled, the system disables legacy OS redirection before entering a legacy OS.
Always Enable
Console Redirection Settings submenu (EMS port)
Figure 61 shows a Console Redirection Settings submenu screen for the EMS port. The submenu items are described in Table 43.
Figure 61 Console Redirection Settings submenu screen (EMS port)
Table 43 Items on the Console Redirection Settings submenu screen (EMS port)
Item
Out-of-Band Mgmt Port
Indicate the EMS port.
This port allows Microsoft Windows EMS to remotely access the Window OS to collect fault information.
N/A
Terminal Type EMS
Options:
VT100+
Bits per second EMS
Set the data transfer rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     57600.
·     115200.
This data transfer rate setting must match the setting on the remote terminal.
115200
Flow Control EMS
Options:
·     Software Xon/Xoff—Flow control that uses the XON (transmit ON) and XOFF (transmit OFF) control characters. When the data transfer rate exceeds 1200 bits per second, the receiver sends an XOFF to have the sender stop transmission. The sender will resume the transmission only when it receives an XON from the receiver.
None
Data Bits
Displays the number of bits used to represent one character of data.
8
Parity
Options:
·     NoneNo parity bit is sent.
·     Mark—Always sets the parity bit to 1. If the parity bit is 0, an error has occurred.
None
Stop Bits
Displays the number of stop bits used to indicate the end of a serial data packet.
1
Figure 62 shows the CPU Configuration submenu screen, on which you can view and configure processor parameters.
The submenu items are described in Table 44.
Figure 62 CPU Configuration submenu screen
Table 44 Items on the CPU Configuration submenu screen
Item
SVM Mode
Select Enabled or Disabled to enable or disable processor virtualization mode.
This mode allows the Virtual Machine Monitor (VMM) to use additional hardware performance provided by processors.
Enabled
Node N Information
Displays information about node N.
N/A
Node N Information submenu
Figure 63 shows the Node N Information submenu screen. The submenu items are described in Table 45.
Figure 63 Node N Information submenu screen
Table 45 Items on the Node N Information submenu screen
Item
AMD EPYC 7702 64-Core Processor
Processor vendor, model, and number of cores.
64 Cores 128 Threads
Number of cores and number of threads.
Running @ 2022 MHz 1500 mV
Available PCR banks.
Processor Family
Processor family.
Processor Model
Processor operating mode.
Microcode Patch Level
Microcode patch level.
L1 Instruction Cache
Level-1 instruction cache size and number of ways.
L1 Data Cache
Level-1 data cache size and number of ways.
L2 Cache
Level-2 cache size and number of ways.
L3 Cache per Socket
Level-3 cache size and number of ways.
Figure 64 shows the PCI Subsystem Settings submenu screen, on which you can configure the PCI subsystem.
The submenu items are described in Table 46.
Figure 64 PCI Subsystem Settings submenu screen
Table 46 Items on the PCI Subsystem Settings menu screen
Item
PCI Bus Driver Version
Displays the PCI bus driver version.
N/A
PCI Devices Common Settings
Above 4G Decoding
Select Enabled or Disabled to enable or disable decoding of 64-bit PCIe modules in a 4 GB or greater address space.
Disabling this option can cause an M60 or K80 GPU to get stuck in the EarlyPOST 100% phase, preventing you from accessing the BIOS setup menu or the OS.
Enabled
SR-IOV Support
Select Enabled or Disabled to enable or disable support for PCIe single-root I/O virtualization (SR-IOV). SR-IOV virtualizes one physical PCIe module into multiple virtual PCIe modules, each of which can be bound to a virtual machine, thus allowing multiple accesses to the physical PCIe module.
With SR-IOV support enabled, the BIOS allocates I/O resources if a PCIe module supports SR-IOV. With SR-IOV support disabled, the OS allocates I/O resources if a PCIe module supports SR-IOV.
Enabled
BME DMA Mitigation
Select Enabled or Disabled to enable or disable DMA access to PCIe channels.
Options:
·     EnabledIn this state, DMA channel attacks cannot be blocked and PCIe device performance is not affected.
·     DisabledIn this state, DMA channel attacks can be blocked, but PCIe device performance will degrade.
Disabled
PCI Express Settings
PCIe device settings.
N/A
PCI Express GEN 2 Settings
PCIe GEN2 device settings.
N/A
PCI Hot-Plug Settings
PCIe hot swapping settings.
N/A
PCI Express Settings submenu
Figure 65 shows the PCI Express Settings submenu screen. The submenu items are described in Table 47.
Figure 65 PCI Express Settings submenu screen
Table 47 Items on the PCI Express Settings submenu screen
Item
ASPM Support
Select whether to enable PCIe Active State Power Management (ASPM).
Options:
·     AutoAllows the BIOS to configure ASPM automatically.
·     Force L0sForces all links to enter L0s state.
·     Disabled—Disables ASPM.
Enabling ASPM might cause PCIe device connection errors.
Disabled
PCI Express GEN 2 Settings submenu
Figure 66 shows the PCI Express GEN 2 Settings submenu screen. The submenu items are described in Table 48.
Figure 66 PCI Express GEN 2 Settings submenu screen
Table 48 Items on the PCI Express GEN 2 Settings submenu screen
Item
Target Link Speed
Set the target link speed.
Options:
·     Auto.
·     Force to 2.5 GT/s.
·     Force to 5.0 GT/s.
·     Force to 8.0 GT/s.
·     Force to 16.0 GT/s.
·     Force to 32.0 GT/s. This option is displayed only for Milan processors.
Auto
Clock Power Management
Select Enabled or Disabled to enable or disable clock power management.
With this feature enabled, the system uses CLKREQ# signals to manage the power of link clocks.
Disabled
PCI Hot-Plug Settings submenu
Figure 67 shows the PCI Hot-Plug Settings submenu screen. The submenu items are described in Table 49.
Figure 67 PCI Hot-Plug Settings submenu screen
Table 49 Items on the PCI Hot-Plug Settings submenu screen
Item
BIOS Hot-Plug Support
Select Enabled or Disabled to enable or disable PCI hot swapping.
If the OS does not support PCIe hot swapping, you can enable this feature to hot swap PCIe devices.
Enabled
Figure 68 shows the USB Configuration submenu screen, on which you can view information about USB devices and configure USB devices.
The submenu items are described in Table 50.
Figure 68 USB Configuration submenu screen
Table 50 Items on the USB Configuration submenu screen
Item
USB Module Version
Displays the USB module version.
N/A
USB Controllers
Displays USB controller information.
XHCI represents XHCI controllers that support USB 3.0.
N/A
USB Devices
Displays USB devices.
Options:
·     Drives—Number of connected USB drives, including physical drives and virtual drives.
·     Keyboard—Number of connected keyboards.
·     Mouse—Number of connected mouses.
·     Hub—Number of connected USB hubs.
N/A
Legacy USB Support
Select whether to enable legacy USB support.
Options:
·     Enabled—Enables legacy USB support.
·     Disabled—Disables legacy USB support. USB devices are available only for EFI application programs.
·     Auto—Enables legacy USB support only when a USB device is connected to the server.
Enabled
XHCI Hand-off
Select whether to enable the XHCI hand-off feature. This feature specifies the owner of the control over USB 3.0 ports.
Options:
·     Enabled—Hands off the control over USB 3.0 ports to the OS after the OS loads.
·     Disabled—BIOS controls USB 3.0 ports.
Enabled
USB Mass Storage Driver Support
Select Enabled or Disabled to enable or disable the support for USB mass storage drivers.
Enabled
Mass Storage Devices
Specify the type of mass storage devices. Drivers without media will be simulated based on the driver type.
Options:
·     AutoDisplays the device type based on the media format.
·     Floppy.
·     Forced FDD.
·     Hard Disk.
·     CD-ROM.
Auto
Figure 69 shows the CSM Configuration submenu screen, on which you can configure features described in Table 51.
Figure 69 CSM Configuration submenu screen
Table 51 Items on the CSM Configuration submenu screen
Item
CSM Support
Select Enabled or Disabled to enable or disable support for UEFI-incapable operating systems.
You must enable CSM support in legacy boot mode.
Enabled
CSM16 Module Version
Displays the version of the CSM 16 module.
N/A
Option ROM execution
OptionRom execution settings.
N/A
Network
Select the option ROM load method for network adapters.
This option is available when the option ROM policy is in custom mode.
Options:
·     Do not launch—Does not load option ROM.
·     UEFI—Loads the option ROM for network adapters in UEFI boot mode.
·     Legacy—Loads the option ROM for network adapters in legacy boot mode.
UEFI
Storage
Select the option ROM load method for storage devices.
Options:
·     UEFI—Loads the option ROM for storage devices in UEFI boot mode.
·     Legacy—Loads the option ROM for storage devices in legacy boot mode.
UEFI
Video
Select the option ROM load method for video devices.
Options:
·     UEFI—Loads the option ROM for video cards in UEFI boot mode.
·     Legacy—Loads the option ROM for video cards in legacy boot mode.
UEFI
Other PCI Devices
Select the option ROM load method for other PCI devices such as input devices.
Options:
·     UEFI—Loads the option ROM for other PCI devices in UEFI boot mode.
·     Legacy—Loads the option ROM for other PCI devices in legacy boot mode.
UEFI
NVMe Configuration submenu
Figure 70 shows the NVMe Configuration submenu screen. The submenu items are described in Table 52.
Figure 70 NVMe Configuration submenu screen
Table 52 Items on the NVMe Configuration submenu screen
Item
Slot 61: INTEL SSDPE2KX010T7
NVMe device configuration submenu.
Figure 71 shows the SATA Configuration submenu screen, on which you can view information about connected SATA devices.
The submenu items are described in Table 53.
Figure 71 SATA Configuration submenu screen
Table 53 Items on the SATA Configuration submenu screen
Item
SATA Controller
Displays the Segment ID, Bus ID, Device ID, and Function ID of a SATA controller.
Port x
Displays the name of the device connected to a SATA port. This field displays Not Present if no device is connected.
Figure 72 shows the Network Configuration submenu screen, on which you can configure PXE functions for network ports.
The submenu items are described in Table 54.
Figure 72 Network Configuration submenu screen
Table 54 Items on the Network Configuration submenu screen
Item
IPv4 PXE Support
Select Enabled or Disabled to enable or disable OS loading over an IPv4 network.
If Disabled is selected, the IPv4 PXE boot option will not be created.
Enabled
IPv6 PXE Support
Select Enabled or Disabled to enable or disable OS loading over an IPv6 network.
If Disabled is selected, the IPv6 PXE boot option will not be created.
Disabled
PXE boot wait time
Set the wait time for using the ESC key to abort the PXE boot:
Value range: 0 to 5, in seconds.
0
Media Detect Count
Set the maximum number of media presence detections.
Value range: 1 to 50.
1
PXE Retry Count
Set the maximum number of PXE retries.
Value range: 0 to 50.
A value of 0 indicates that the number of PXE retries is not limited.
1
PCIE NIC Configuration
PCIe NIC configuration menu.
N/A
PCIE NIC Configuration submenu
Figure 73 shows the PCIE NIC Configuration submenu screen, on which you can configure the PCIe network adapter.
The submenu items are described in Table 55.
Figure 73 PCIE NIC Configuration submenu screen
Table 55 Items on the PCIE NIC Configuration submenu screen
Item
PCIE NIC PXE
Select Enabled or Disabled to enable or disable PCIe NIC PXE.
Enabled
NICx: Slot x
Displays the relations between the NIC ID and the slot ID. The PXE settings of each port on the NIC are listed below.
N/A
NICm Portn PXE
Select Enabled or Disabled to enable or disable PXE on a specific NIC port. If this NIC port does not exist, this setting does not take effect.
Enabled
Miscellaneous Configuration submenu
Figure 74 shows the Miscellaneous Configuration submenu screen. The submenu items are described in Table 56.
Figure 74 Miscellaneous Configuration submenu screen
Table 56 Items on the Miscellaneous Configuration submenu screen
Item
Debug Mode
Select Enabled or Disabled to enable or disable the server to output log messages through the BIOS serial port.
Disabled
iSCSI Configuration submenu (for Rome processors only)
Figure 75 shows the iSCSI Configuration submenu screen. The submenu items are described in Table 57.
This submenu is available only when an iSCSI-capable device is connected.
Figure 75 iSCSI Configuration submenu screen
Table 57 Items on the iSCSI Configuration submenu screen
Item
Attempt Priority
Set an attempt priority.
Host iSCSI Configuration
Configure host iSCSI settings.
Attempt Priority submenu
Figure 76 shows the Attempt Priority submenu screen. The submenu items are described in Table 58.
Figure 76 Attempt Priority submenu screen
Table 58 Items on the Attempt Priority submenu screen
Item
Attempt Priority
Set the priorities of the host, Redfish, and Rsd iSCSI attempts.
Commit Changes and Exit
Commit the changes and exit.
Host iSCSI Configuration submenu
Figure 77 shows the Host iSCSI Configuration submenu screen. The submenu items are described in Table 59.
Figure 77 Host iSCSI Configuration submenu screen
Table 59 Items on the Host iSCSI Configuration submenu screen
Item
iSCSI Initiator Name
Set the name of the iSCSI initiator, a string of 4 to 223 characters.
The name must be in the IQN format of iqn.YYYY-MM.Domain name:Device name.
·     YYYY—Year.
·     MM—Month.
·     Domain name—Domain names in the reversed order (with the last domain comes first).
·     Device name.
For example, iqn.2003-02.com.emu:test123.
Add an Attempt
Add an iSCSI attempt.
Delete Attempts
Delete an iSCSI attempt.
Change Attempt Order
Change the order of iSCSI attempts.
Add an Attempt submenu
Figure 78 shows the Add an Attempt submenu screen. The submenu items are described in Table 60.
Figure 78 Add an Attempt submenu screen
Table 60 Items on the Add an Attempt submenu screen
Items
MAC 38:97:D6:D2:54:51
MAC address of an iSCSI NIC port. The submenu items are the same for each port.
Figure 79 shows the submenu for configuring an attempt. The submenu items are described in Table 61.
Figure 79 MAC 38:97:D6:D2:54:51 submenu screen
Table 61 Items on the MAC 38:97:D6:D2:54:51 submenu screen
Item
iSCSI Attempt Name
Set the name of the iSCSI attempt. The name is a string of 1 to 12 characters.
N/A
iSCSI Mode
Set the iSCSI mode.
Options:
·     Disabled—Disables iSCSI.
·     Enabled—Enables iSCSI.
·     Enabled for MPIO—Enables MPIO iSCSI.
Disabled
Internet Protocol
Select the Internet protocol.
Options:
·     IPv4—Enables IPv4.
·     IPv6—Enables IPv6.
·     Autoconfigure—Configures the Internet protocol automatically. IPv4 takes precedence over IPv6.
IPv4
Connection Retry Count
Set the maximum number of connection retries.
Value range: 0 to 16.
A value of 0 indicates no connection retries.
0
Connection Establishing Timeout
Set the connection timeout time, in milliseconds.
1000 ms
OUT-format ISID
Displays the ID of the iSCSI initiator.
N/A
Configure ISID
Configure the ID of the iSCSI initiator.
The last six digits of the MAC address of the network adapter port.
Enable DHCP
Select Enabled or Disabled to enable or disable DHCP.
Disabled
Initiator IP Address
Set the IP address of the iSCSI initiator.
N/A
Initiator Subnet Mask
Set the subnet mask of the iSCSI initiator.
N/A
Gateway
Set the gateway IP address.
N/A
Target Name
Set the name of the iSCSI target.
N/A
Target Address
Set the address of the iSCSI target.
N/A
Target Port
Set the port number of the iSCSI target.
3260
Boot LUN
Set the LUN of the iSCSI target, in hexadecimal notation.
N/A
Authentication Type
Select the authentication type.
Options:
·     None.
·     CHAP.
None
CHAP Type
Select the CHAP authentication type.
Options:
·     Mutual—Two-way CHAP authentication.
·     One way—One-way CHAP authentication.
Mutual
CHAP Name
Set the name for CHAP authentication.
N/A
CHAP Secret
Set the password for CHAP authentication.
N/A
CHAP Status
Displays the status of CHAP authentication.
N/A
Reverse CHAP Name
Set the name for reverse CHAP authentication.
N/A
Reverse CHAP Secret
Set the password for reverse CHAP authentication.
N/A
Reverse CHAP Status
Displays the status of reverse CHAP authentication.
N/A
Save Changes
Save the changes.
N/A
Back to Previous Page
Return to the previous submenu.
N/A
Delete Attempts submenu
Figure 80 shows the Delete Attempts submenu screen. The submenu items are described in Table 62.
Figure 80 Delete Attempts submenu screen
Table 62 Items on the Delete Attempts submenu screen
Items
Attempt x
Select whether to delete an attempt.
Options:
·     Enabled—Deletes the attempt.
·     DisabledDoes not delete the attempt.
Disabled
Commit the changes the return to the previous submenu.
N/A
Discard Changes and Exit
Discard the changes the return to the previous submenu.
N/A
Change Attempt Order submenu
Figure 81 shows the Change Attempt Order submenu screen. The submenu items are described in Table 63.
Figure 81 Change Attempt Order submenu screen
Table 63 Items on the Change Attempt Order submenu screen
Item
Change the order of existing attempts.
Select an attempt and press the + or key to change its order.
Driver Health submenu
Figure 82 shows the Driver Health submenu screen, on which you can view the health status of installed drivers and controllers and repair failed drivers or controllers as instructed.
The submenu items are described in Table 64.
Figure 82 Driver Health submenu screen
Table 64 Items on the Driver Health submenu screen
Items
Controller 8f069598 Child 0
Displays the health state of a driver or a controller.
Options:
·     Healthy.
·     Failed.
If the state is Failed, press Enter and follow the instructions to repair the driver or controller. The repair method varies by driver or controller.
Chipset menu
Figure 83 shows the Chipset menu. From the menu, you can access the north bridge configuration submenu.
The menu items are described in Table 65.
Figure 83 Chipset menu screen
Table 65 Items on Chipset menu screen
Item
North Bridge
North bridge configuration submenu.
North Bridge submenu
Figure 84 shows a North Bridge submenu screen, on which you can view the total memory capacity and memory presence status.
The submenu items are described in Table 66.
Figure 84 North Bridge submenu screen
Table 66 Items on the North Bridge submenu screen
Item
Memory Information
Memory information.
Total Memory
Total memory size, in GB.
Socket N Information
Memory information submenu for processor N.
Socket N Information submenu
Figure 85 shows the Socket N Information submenu screen. The submenu items are described in Table 67.
Figure 85 Socket N Information submenu screen
Table 67 Items on the Socket N Information submenu screen
Item
Memory information for processor N.
Processor1 Ch1 DIMM A0:Size 32768 MB,Speed 2666 MT/s
Displays information about the DIMM in slot A0 of channel 1 of processor 1. In this example, the memory size is 32768 MB and the memory frequency is 2666 MT/s.
Server menu
Figure 86 shows the Server menu. From the menu, you can configure the FRB-2 timer, watchdog, HDM network, and HDM user settings, and view firmware information.
The menu items are described in Table 68.
Figure 86 Server menu screen
Table 68 Items on the Server menu screen
Item
FRB-2 Timer
Select Enabled or Disabled to enable or disable the FRB-2 timer.
Enabled
FRB-2 Timer Timeout
This item is configurable only when FRB-2 Timer is set to Enabled.
Set the timeout time for the FRB-2 timer.
Options:
·     3 Minutes.
·     4 Minutes.
·     5 Minutes.
·     6 Minutes.
·     10 Minutes.
·     15 Minutes.
·     20 Minutes.
15 Minutes
FRB-2 Timer Policy
Select the action to take when the FRB-2 timer expires.
Options:
·     Do Nothing—No action is taken.
·     Reset—Reboots the system.
·     Power Down—Removes power from the system.
·     Power Cycle—Power cycles the system.
Power Cycle
OS Watchdog Timer
Select Enabled or Disabled to enable or disable the OS watchdog timer.
The OS watchdog timer starts when the OS begins to run and restarts the operating system if the system gets stuck. This helps restore the system in case of system crush.
Disabled
OS Wtd Timer Timeout
This item is configurable only when OS Watchdog Timer is set to Enabled.
Set the timeout time for the OS watchdog timer.
For Milan processors, the value range is 5 to 30 minutes.
For Rome processors, options are as follows:
·     5 Minutes.
·     10 Minutes.
·     15 Minutes.
·     20 Minutes.
10 Minutes
OS Wtd Timer Policy
Select the action to take when the OS watchdog timer expires.
Options:
Reset
AC Restore Settings
Select the state to which the system is restored when the system AC power is restored.
Options:
·     Always Remain Off—The system always returns to the power-off state.
·     Restore Last Power State—The system returns to the power state when AC power was lost.
·     Always Power On—The system always returns to the power-on state.
Load HDM Default
To restore the default settings for HDM, select this item, and then press Enter. It takes about one minute to restore the default HDM settings. After the restoration finishes, the server restarts automatically.
CAUTION CAUTION:
Do not configure HDM-related items before the server restarts.
N/A
View FRU Information
Access the submenu for viewing FRU information.
N/A
Firmware Information
Access the submenu for viewing firmware information.
N/A
HDM Network Configuration
Access the HDM network configuration submenu.
N/A
HDM User Settings
Access the HDM user configuration submenu.
N/A
HDM Warm Reset
Perform an HDM warm restart.
N/A
View FRU information submenu
Figure 87 shows the View FRU information submenu screen. The submenu items are described in Table 69.
Figure 87 View FRU information submenu screen
Table 69 Items on the View FRU information submenu screen
Item
System Manufacturer
System manufacturer.
System Product Name
System product name.
System Version
System version.
System Serial Number
System serial number.
Board Manufacturer
System board manufacturer.
Board Product Name
System board product name.
Board Version
System board version. This item is displayed only for Rome processors.
Board Part Number
System board part number. This item is displayed only for Milan processors.
Board Serial Number
System board serial number.
Chassis Manufacturer
Chassis manufacturer.
Chassis Version
Chassis version. This item is displayed only for Rome processors.
Chassis Part Number
Chassis part number. This item is displayed only for Milan processors.
Chassis Serial Number
Chassis serial number.
Chassis Part Number
System Uuid
System universally unique identifier (UUID).
Firmware Information submenu
Figure 88 shows the Firmware Information submenu screen. The submenu items are described in Table 70.
Figure 88 Firmware Information submenu screen
Table 70 Items on the Firmware Information submenu screen
Item
BIOS Information
BIOS Vendor
BIOS vendor.
Core Version
Core version.
Compliancy
Standard with which the BIOS is compliant.
Project Name
Project name.
BIOS Version
BIOS version.
Build Date and Time
Build date and time for the BIOS.
HDM Information
HDM Self Test Status
HDM self-test status.
HDM Device ID
HDM device ID.
HDM Device Revision
HDM device revision.
HDM Firmware Revision
HDM firmware revision.
IPMI Version
IPMI version.
HDM Network Configuration submenu
Figure 89 shows the HDM Network Configuration submenu screen. The submenu items are described in Table 71.
Figure 89 HDM Network Configuration submenu screen
Table 71 Items on the HDM Network Configuration submenu screen
Item
Sharelink Network
Access the submenu for configuring the HDM shared network port.
IPv4 Network Configuration
Access the submenu for configuring IPv4 network settings.
IPv6 Network Configuration
Access the submenu for configuring IPv6 network settings.
Sharelink Network submenu
Figure 90 shows the Sharelink Network submenu screen.
Figure 90 Sharelink Network submenu screen
IPv4 Network Configuration submenu
Figure 91 shows the IPv4 Network Configuration submenu screen. The submenu items are described in Table 72.
IMPORTANT
IMPORTANT:
The submenu items are the same for the HDM shared network port and the HDM dedicated network port. Make sure the shared network port and the dedicated network port use IP addresses from different subnets.
Figure 91 IPv4 Network Configuration submenu screen
Table 72 Items on the IPv4 Network Configuration submenu screen
Item
Refresh
Refresh HDM network configuration.
Press Enter to refresh the configuration before making any changes.
N/A
HDM Net Mode
Displays the HDM network mode dynamically.
Options:
·     Normal Mode—In this mode, the HDM can be accessed through the HDM shared network port or the HDM dedicated network port.
·     Active/standby Mode—In this mode, the HDM dedicated port is used as the first choice to access the HDM.
·     Bonding Mode—In this mode, the HDM shared network port and the HDM dedicated network port are used as one logical network port.
N/A
Dedicated VLAN Setting
Select Enabled or Disabled to enable or disable VLAN on the HDM dedicated network port.
Disabled
Dedicated VLAN id
This item is available only when Dedicated VLAN Setting is set to Enabled.
Configures the VLAN ID, in the range of 2 to 4094.
2
Dedicated VLAN priority
Specify the priority of a VLAN for the dedicated network port, in the range of 0 to 7. The larger the number, the higher the priority.
When traffic congestion occurs, frames with the highest priority will be sent first.
0
Shared VLAN Settings
Select Enabled or Disabled to enable or disable VLAN on the HDM shared network port.
Disabled
Shared VLAN id
This item is available only when Shared VLAN Setting is set to Enabled.
2
Shared VLAN priority
Specify the priority of a VLAN for the shared network port, in the range of 0 to 7. The larger the number, the higher the priority.
0
HDM Dedicated/Shared Network Port
Configuration Address source
Configure the HDM network status parameters.
Options:
·     Unspecified—Retains the current configuration.
·     StaticUses manually specified configuration.
·     DynamicHdmDhcpUses network information obtained through DHCP.
Unspecified
Current Configuration Address source
Displays the current address source.
N/A
Station IP Address
This item is available only when Configuration Address source is set to Static.
The configured HDM static IPv4 address takes effect only after both the Station IP Address and Subnet Mask are configured.
Specify the station IP address for the port.
N/A
Subnet Mask
This item must be specified if you set the HDM static IPv4 address.
Specify the subnet mask.
0.0.0.0
Station MAC Address
MAC address of the port.
N/A
Router IP Address
Specify the gateway IP address.
N/A
Router MAC Address
Displays the gateway MAC address.
N/A
IPv6 Network Configuration submenu
Figure 92 shows the IPv6 Network Configuration submenu screen. The submenu items are described in Table 73.
IMPORTANT
IMPORTANT:
Figure 92 IPv6 Network Configuration submenu screen
Table 73 Items on the IPv6 Network Configuration submenu screen
Item
Refresh
N/A
HDM Net Mode
Options:
N/A
Options:
Unspecified
N/A
Station IPv6 address
The configured HDM static IPv6 address takes effect only after both the Station IP Address and Subnet Mask are configured.
Specify the station IPv6 address for the port.
N/A
Prefix Length
This item must be specified if you set the HDM static IPv6 address.
Specify the prefix length, in the range of 0 to 127. 0 indicates that no prefix length is specified.
0
IPv6 Router IP Address
The IPv6 gateway IPv6 address and the port IPv6 address must be in the same subnet.
Specify the IPv6 gateway IP address.
N/A
IPv6 address status
Displays the status of the IPv6 address.
N/A
IPv6 DHCP Algorithm
Displays the IPv6 DHCP algorithm.
N/A
HDM User Settings submenu
Figure 93 shows the HDM User Settings submenu screen. The submenu items are described in Table 74.
Figure 93 HDM User Settings submenu screen
Table 74 Items on the HDM User Settings submenu screen
Item
User ID
Displays the current HDM user ID.
User Name
Press Enter to modify the HDM username.
A username is a case-sensitive string of 1 to 16 characters and supports only letters, digits, and underscores (_).
The name of the login user cannot be modified.
User Password
Set the HDM user password.
The password must follow these HDM password complexity check rules:
·     When password complexity check is enabled:
¡     The password must be a case-sensitive string of 8 to 20 characters and can contain only letters, digits, spaces, and special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
¡     It must contain at least two kinds of characters: uppercase letters, lowercase letters, or digits.
¡     It must contain at least one space or special character.
¡     It cannot be the same as the username or the reverse order of the username.
·     When password complexity check is disabled, the password must be a case-sensitive string of 2 to 20 characters and can contain only letters, digits, spaces, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
By default, password complexity check is enabled.
For more information about how to enable or disable password complexity check, see HDM online help.
Load HDM User Configuration Default
Restore the default HDM user configuration. If the default HDM user is online, this feature is not available.
Security menu
Figure 94 shows the Security menu, on which you can configure security features such as setting the BIOS administrator and user passwords.
The menu items are described in Table 75.
Figure 94 Security menu screen
Table 75 Items on the Security menu screen
Item
Password Description
Displays the password description.
Administrator Password
Set the administrator password. For more information about restrictions for setting the administrator password, see "Restrictions and guidelines."
User Password
Set the user password. As a best practice, set the administrator password if you set the user password.
For more information about restrictions for setting the user password, see "Restrictions and guidelines."
Power On Password
Set the power-on password. For more information about restrictions for setting the power-on password, see "Restrictions and guidelines."
HDD Security Configuration
Displays hard disk drives that support security configuration, for example, P2:TS256GMTS800.
To configure security settings for a hard disk drive, select the disk drive and press Enter.
Secure Boot Menu
This item is available only in UEFI boot mode.
Access the submenu for configuring secure boot.
Figure 95 shows the HDD Security Configuration submenu screen. The submenu items are described in Table 76.
Figure 95 HDD Security Configuration submenu screen
Table 76 Items on the HDD Security Configuration submenu screen
Item
Security Supported
Displays whether the hard disk drive supports security configuration.
Security Enabled
Displays whether HDD security is enabled.
Security Locked
Displays whether the hard disk drive is locked.
Security Frozen
Displays the security frozen status. You cannot format a drive in frozen state.
HDD User Pwd Status
Displays whether an HDD user password is set.
Set User Password
Set an HDD user password, 1 to 32 characters in length.
If an HDD user password is set or removed, the setting on the BIOS will not affect the password.
If this item is inaccessible or hidden, you can power cycle the server for this item to become accessible.
Figure 96 shows the Secure Boot submenu screen. The submenu items are described in Table 77.
Secure boot is available only in UEFI mode. With this feature enabled, key authentication is required when you load any operating system or hardware driver program. This prevents intrusion of malware. The servers come with a secure boot key and you can import keys as needed. Secure boot does not require any hardware (for example, Trusted Platform Module).
Figure 96 Secure Boot submenu screen
Table 77 Items on the Secure Boot menu screen
Item
System Mode
Displays the system mode.
N/A
Secure Boot
Select Enabled or Disabled to enable or disable secure boot. With secure boot enabled, key authentication is required to load any operating system or hardware driver, and the secure boot feature is in active state.
Disabled
Secure Boot Mode
Select a secure boot mode.
Options:
·     StandardUses the preset secure boot key and certificate. In this mode, you can select whether to install factory default secure boot keys, as shown in Figure 97.
·     CustomIn this mode, you can change the image execution policy and manage secure boot keys.
Custom
Restore Factory Keys
Restore the factory default secure boot keys.
N/A
Reset To Setup Mode
Reset the system mode to setup mode.
N/A
Key Management
Access the submenu for key management.
N/A
Figure 97 Installing factory default secure boot keys
Figure 98 shows the Key Management submenu. The submenu items are described in Table 78.
Figure 98 Key Management submenu screen
Table 78 Items on the Key Management submenu screen
Item
Vendor Keys
Displays whether the vendor keys have been modified.
Options:
·     ValidThe vendor keys are valid.
·     ModifiedThe vendor keys have been modified or deleted.
N/A
Factory Key Provision
Select Enabled or Disabled to enable or disable provisioning the factory default keys. If this item is set to Enabled, you must install the factory default secure boot keys.
Disabled
Restore factory default keys.
This operation forces the system to enter user mode and installs factory default secure boot keys.
N/A
Reset To Setup Mode
N/A
Export Secure Boot Variables
Export all secure boot variables.
N/A
Enroll Efi Image
Enroll the EFI image.
This operation enables secure boot for the image and enrolls a SHA256 hash of the PE image in the authorized signature database (DB).
N/A
Device Guard Ready
Indicates the server is ready for device guard.
N/A
Remove ‘UEFI CA’ from DB
Remove UEFI CA from DB.
N/A
Restore DB defaults
Restore all DB variables to factory defaults.
N/A
Platform Key(PK)
Managing the platform key.
Option is Update.
N/A
Key Exchange Keys
Manage key exchange keys.
Options:
·     Update.
·     Append.
N/A
Authorized Signatures
Configure authorized signatures.
Options:
·     Update.
·     Append.
N/A
Forbidden Signatures
Access the submenu for managing forbidden signatures.
Options:
·     Update.
·     Append.
N/A
Authorized TimeStamps
Manage authorized timestamps.
Options:
·     Update.
·     Append.
N/A
OsRecovery Signatures
Configure operating system recovery signatures.
Options:
·     Update.
·     Append.
N/A
Boot menu
Figure 99 shows the Boot menu, on which you can configure boot settings such as the boot mode and boot order.
The menu items are described in Table 79.
Figure 99 Boot menu screen
Table 79 Items on the Boot menu screen
Item
Bootup NumLock State
Select On or Off to turn on or turn off the NumLock key on the numeric keypad of the keyboard at system boot.
On
Quiet Boot
Select On or Off to enable or disable quiet boot mode.
Options:
·     DisabledEnables the boot screen to display POST information during boot process.
·     Enabled—Enables the boot screen to display the product logo instead of POST information during boot process.
Disabled
Hide Logo
Select Enabled or Disabled to display or hide the logo on the boot screen.
Disabled
Early VGA Mode
Displays the early VGA mode.
Options:
·     Detail—Displays detail information, including logo, version, HDM IP address, progress, and alarm information.
·     SimpleDisplays simple information, including logo, version, and HDM IP address.
·     LogoOnly—Display the logo only.
Detail
iFIST Boot
Select Enabled or Disabled to enable or disable iFIST boot.
Enabled
USB Boot
Select Enabled or Disabled to enable or disable USB boot.
Enabled
EFI Shell Boot
This item is unavailable when Boot Mode Select is set to LEGACY.
Select Enabled or Disabled to enable or disable shell boot.
Disabled
Boot Mode Select
Select the boot mode.
Options:
·     LEGACY.
·     UEFI.
CAUTION CAUTION:
If the operating system is not installed in the target boot mode, switching the boot mode might cause operating system startup failure.
UEFI
Fixed Boot Order Priorities
Displays the prioritized list of bootable devices from which the system can boot.
In legacy mode, a drive is displayed in the list only if it has the highest boot priority (BBS priority) among all the drives of the same type. To display a drive in this list, enter the BBS priorities submenu for the drive type, and then set this drive as the first boot option.
N/A
Boot Option #1
Set the first boot option.
To disable the first boot option, select Disabled for this item.
N/A
Boot Option #2
Set the second boot option.
To disable the second boot option, select Disabled for this item.
N/A
Boot Option #3
Set the third boot option.
To disable the third boot option, select Disabled for this item.
N/A
Boot Option #4
Set the fourth boot option.
To disable the fourth boot option, select Disabled for this item.
N/A
UEFI Hard Disk Drive BBS Priorities
This item is available only in UEFI boot mode when a hard disk drive is connected.
Access the submenu for configuring the boot priorities of hard disk drive, USB-HDD, and SD card, as shown in Figure 100.
The submenu items are described in Table 80.
N/A
This item is available only in legacy boot mode when a hard disk drive is connected.
Access the submenu for configuring the boot priorities of hard disk drive, USB-HDD, and SD card.
N/A
UEFI CDROM/DVD Drive BBS Priorities
This item is available only in UEFI boot mode when a CD- or DVD-ROM drive is connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives, as shown in Figure 101.
The submenu items are described in Table 81.
N/A
This item is available only in legacy boot mode when a CD- or DVD-ROM drive is connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives.
N/A
UEFI Network Drive BBS Priorities
This item is available only in UEFI boot mode when a network drive is connected.
Access the submenu for configuring the boot priorities of available network drives, as shown in Figure 102.
The submenu items are described in Table 82.
N/A
This item is available only in legacy boot mode when a network drive is connected.
Access the submenu for configuring the boot priorities of available network drives.
N/A
UEFI Other Drive BBS Priorities
This item is available only when other devices available for system boot are connected.
Access the submenu for configuring the boot priorities of other devices, as shown in Figure 103. The submenu items are described in Table 83.
The options include but are not limited to:
·     Embedded UEFI shell. This option is available only when EFI Shell Boot is set to Enabled.
·     Other unidentified boot devices.
N/A
Figure 100 UEFI Hard Disk Drive BBS Priorities submenu screen
Table 80 Items on the UEFI Hard Disk Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a hard disk as the first boot option. To disable this boot option, select Disabled.
Boot Option #2
Select a hard disk as the second boot option. To disable this boot option, select Disabled.
Boot Option #3
Select a hard disk as the third boot option. To disable this boot option, select Disabled.
Boot Option #4
Select a hard disk as the fourth boot option. To disable this boot option, select Disabled.
The number of available options varies by server configuration.
Figure 101 UEFI CDROM/DVD Drive BBS Priorities submenu screen
Table 81 Items on the UEFI CDROM/DVD Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a CD- or DVD-ROM drive as the first boot option. To disable this boot option, select Disabled.
Figure 102 UEFI Network Drive BBS Priorities submenu screen
Table 82 Items on the UEFI Network Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a PXE boot device as the first boot option. To disable this boot option, select Disabled.
Boot Option #2
Select a PXE boot device as the second boot option. To disable this boot option, select Disabled.
Figure 103 UEFI Other Drive BBS Priorities submenu screen
Table 83 Items on the UEFI Other Drive BBS Priorities submenu screen
Item
Boot Option #1
Select the other type of boot devices as the first boot option. To disable this boot option, select Disabled.
Exit menu
Figure 104 shows the Exit menu, on which you can modify BIOS parameter settings and exit the BIOS.
The menu items are described in Table 84.
Figure 104 Exit menu screen
Table 84 Items on the Exit menu screen
Item
Save Options
Save Changes and Exit
Exit with changes saved.
Exit without saving changes.
Save Changes and Reset
Restart the server with changes saved. (Recommended)
Discard Changes and Reset
Restart the server without saving changes.
Save Changes
Save changes without exiting the BIOS.
Discard Changes
Discard changes without exiting the BIOS.
Default Options
Restore Defaults
Restore the factory-default settings.
Boot Override
Select a boot device option and press Enter to boot from that device.
This setting is a one-time setting that takes effect only at the next boot. Subsequent boots will use the boot order configured on the Boot menu screen.
If unsaved BIOS Setup changes exist, selecting a boot device option triggers the system to open the Save&Reset dialog box. You can select Yes to save the changes and restart the device as configured in the Boot menu, or select No to close the dialog box. If No is selected, you can then discard the changes and re-select a device option from the Boot Override field to restart the system from that device immediately.
For information about discarding current changes, see Figure 104 or press F2.
Acronyms and abbreviations
Term
Definition
A
ACPI
Advanced Configuration and Power Interface
AHCI
Advanced Host Controller Interface
ARI
Alternative Routing-ID
ASPM
B
BIOS
Basic Input Output System
C
CCX
Core Complex
CSM
Compatibility Support Module
CRC
Cyclic Redundancy Check
D
DF
Data Fabric
DMA
Direct Memory Access
DRAM
Dynamic Random Access Memory
E
ECC
Error Checking and Correcting
EFI
Extensible Firmware Interface
EMS
F
FCH
Server Controller Hub (SCH), also called FCH
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDM
Hardware Device Management
I
IIO
Integrated I/O Module
L
LTR
Latency Tolerance Reporting
M
MAC
Media Access Control
MBIST
Memory built-in self-test
MMIO
Memory mapping I/O
N
NBIO
NorthBridge IO
NIC
Network Interface Controller
NMI
Non Maskable Interrupt
NTB
Non-Transparent Bridging
NUMA
Non Uniform Memory Access
O
ODT
On-Die Termination
OS
Operating System
P
PCI
Peripheral Component Interface
PCIe
Peripheral Component Interconnect Express
PECI
Platform Environment Control Interface
PK
Platform Key
POR
Plan Of Record
POST
Power On Self Test
PSP
Platform Security Processor
PWM
Pulse Width Modulation
PXE
Preboot Execute Environment
R
RAID
Redundant Arrays of Independent Disks
RAS
Reliability, Availability, Serviceability
ROM
Read-Only Memory
RTS/CTS
Request To Send/Clear To Send
S
SAS
Serial Attached SCSI
SATA
Serial Advanced Technology Attachment
SCSI
Small Computer System Interface
SEL
System Event Log
SEV
Secure Encrypted Virtualization
SLIT
System Locality Information Table
SMI
System Management Interrupt
SMM
System Management Mode
SMT
Simultaneous multithreading.
SMU
System Management Unit
SRAT
ACPI Static Resource Affinity Table
SR-IOV
Single-Root I/O Virtualization
SMBIOS
System Management BIOS
SVM
Secure virtual machine
T
TPM
TCM
Trusted Computing Platform
TDP
Thermal Design Power
TLP
Transaction Layer Packet
U
UEFI
Unified Extensible Firmware Interface
UMC
Unified Memory Controllers
UID
Unit Identification
V
VGA
Video Graphics Array
X
XHCI
eXtensible Host Controller Interface
