| 01-RESTful configuration | 44.61 KB |
Configuring RESTful
About RESTful
The device provides the Representational State Transfer application programming interface (RESTful API). Based on this API, you can use programming languages such as Python, Ruby, or Java to write programs to perform the following tasks:
· Send RESTful requests to the device to pass authentication.
· Use RESTful API operations to configure and manage the device. RESTful API operations include Get, Put, Post, and Delete.
The device supports using HTTP or HTTPS to transfer RESTful packets.
Configuring RESTful over HTTP
1. Enter system view.
2. Enable RESTful over HTTP.
restful http enable
By default, RESTful over HTTP is disabled.
3. Create a local user and enter local user view.
4. Configure a password for the local user.
5. (Optional.) Assign a user role to the local user.
The default user role is network-operator for a RESTful user.
6. Specify the HTTP service for the local user.
service-type http
By default, no service type is specified for a local user.
Configuring RESTful over HTTPS
2. Enable RESTful over HTTPS.
restful https enable
By default, RESTful over HTTPS is disabled.
6. Specify the HTTPS service for the local user.
service-type https
