| 03-Flow group commands | 49.28 KB |
Flow group commands
display telemetry flow-group
Use display telemetry flow-group to display the configuration and application status of flow groups.
display telemetry flow-group [ system-defined [ ip | vxlan ] ] [ slot slot-number ]
system-defined: Specifies a system-defined flow group.
· ip: Specifies the system-defined IP flow group.
· vxlan: Specifies the system-defined VXLAN flow group.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the configuration and application status on the active MPU.
# Display the configuration and application status of the system-defined VXLAN flow group.
<Sysname> display telemetry flow-group system-defined ip slot 1
Flow group named system-defined-ip (Inactive, System-defined)
Template:
destination-ip
destination-port
protocol
source-ip
source-port
Aging time: 100 minutes
Flow group named system-defined-ip (Successful, System-defined) |
Name and application status of the flow group. Values for the application status include: · Successful—The flow group is applied successfully. · Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration. · Inactive—The flow group has not been administratively applied. · Incomplete—The flow group fails to be applied because its configuration is incomplete. |
telemetry apply flow-group
Use telemetry apply flow-group to apply a flow group.
Use undo telemetry apply flow-group to remove the application of a flow group.
telemetry apply flow-group system-defined { ip | vxlan }
undo telemetry apply flow-group system-defined { ip | vxlan }
No flow group is applied.
The device has two system-defined flow groups: one IP flow group named system-defined-ip and one VXLAN flow group named system-defined-vxlan. The two flow groups are not configurable.
The IP flow group generates flow entries based on the 5-tuple.
The VXLAN flow group generates flow entries based on the VXLAN ID and the inner 5-tuple.
The two flow groups take effect on all traffic.
# Apply the system-defined IP flow group.
[Sysname] telemetry apply flow-group system-defined ip
telemetry flow-group aging-time
Use telemetry flow-group aging-time to set the aging time for flow entries.
Use undo telemetry flow-group aging-time to restore the default.
telemetry flow-group aging-time aging-time
The aging time for flow entries is 15 minutes.
aging-time: Specifies the aging time for flow entries in minutes. The value range for this argument is 1 to 100.
# Set the aging time for flow entries to 20 minutes.
[Sysname] telemetry flow-group aging-time 20
