- 16-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-NTP commands
- 05-SNMP commands
- 06-RMON commands
- 07-Event MIB commands
- 08-Sampler commands
- 09-Mirroring commands
- 10-NetStream commands
- 11-IPv6 NetStream commands
- 12-sFlow commands
- 13-CWMP commands
- 14-PTP commands
| 02-System debugging commands | 42.23 KB |
debugging
Use debugging to enable debugging for a module.
Use undo debugging to disable debugging for a module or for all modules.
debugging module-name [ option ]
undo debugging { all | module-name [ option ] }
Debugging is disabled for all modules.
module-name: Specifies a module by its name, such as arp or device. For a list of supported modules, use the debugging ? command.
option: Specifies the debugging option for a module. Available options vary by module. To display the debugging options supported by a module, use the debugging module-name ? command.
all: Specifies all modules.
CAUTION: Output of excessive debugging messages increases the CPU usage and downgrades the system performance. To guarantee system performance, enable debugging only for modules that are in an exceptional condition. |
The system sends generated debug messages to the device information center, which then sends the messages to appropriate destinations based on the log output configuration. For more information about the information center, see System Management Configuration Guide.
# Enable debugging for the device management module.
<Sysname> debugging dev
display debugging
display debugging
Use display debugging to display the enabled debugging features for a module or for all modules.
display debugging [ module-name ]
module-name: Specifies a module by its name. For a list of supported modules, use the display debugging ? command. If you do not specify a module name, this command displays the enabled debugging features for all modules.
# Display all enabled debugging features.
<Sysname> display debugging
DEV debugging switch is on
debugging
