13-User Access and Authentication Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R51xx)-6W10113-User Access and Authentication Command Reference
01-AAA commands
01-AAA commands 615.58 KB
AAA commands· 1
General AAA commands· 1
aaa session-limit 1
accounting command· 1
accounting default 2
accounting login· 4
authentication default 5
authentication login· 7
authentication super 8
authorization command· 9
authorization default 10
authorization login· 12
display domain· 14
domain· 17
domain default enable· 18
domain if-unknown· 19
local-server log change-password-prompt 20
nas-id· 21
session-time include-idle-time· 22
state (ISP domain view) 23
state block time-range name· 23
Local user commands· 24
access-limit 24
authorization-attribute (local user view/user group view) 25
display local-user 27
display user-group· 29
group· 30
local-user 31
password· 32
service-type· 33
state (local user view) 33
user-group· 34
RADIUS commands· 35
aaa device-id· 35
accounting-on enable· 35
attribute 15 check-mode· 36
attribute 25 car 37
attribute 31 mac-format 38
attribute convert 39
attribute reject 40
attribute remanent-volume· 41
attribute translate· 42
attribute vendor-id 2011 version· 42
data-flow-format (RADIUS scheme view) 43
display radius scheme· 44
display radius statistics· 48
display stop-accounting-buffer (for RADIUS) 49
key (RADIUS scheme view) 50
nas-ip (RADIUS scheme view) 51
primary accounting (RADIUS scheme view) 52
primary authentication (RADIUS scheme view) 54
radius attribute extended· 56
radius dscp· 57
radius nas-ip· 58
radius scheme· 59
radius session-control client 60
radius session-control enable· 61
radius source-ip· 61
radius-server test-profile· 63
reset radius statistics· 64
reset stop-accounting-buffer (for RADIUS) 64
response-pending-limit 65
retry· 66
retry realtime-accounting· 67
retry stop-accounting (RADIUS scheme view) 68
secondary accounting (RADIUS scheme view) 69
secondary authentication (RADIUS scheme view) 71
server-block-action· 73
server-load-sharing enable· 74
snmp-agent trap enable radius· 74
source-ip· 76
state primary· 77
state secondary· 78
stop-accounting-buffer enable (RADIUS scheme view) 79
stop-accounting-packet send-force· 80
threshold remanent-volume· 81
timer quiet (RADIUS scheme view) 81
timer realtime-accounting (RADIUS scheme view) 82
timer response-timeout (RADIUS scheme view) 83
user-name-format (RADIUS scheme view) 84
vpn-instance (RADIUS scheme view) 85
HWTACACS commands· 86
data-flow-format (HWTACACS scheme view) 86
display hwtacacs scheme· 87
display stop-accounting-buffer (for HWTACACS) 91
hwtacacs nas-ip· 92
hwtacacs scheme· 93
key (HWTACACS scheme view) 94
nas-ip (HWTACACS scheme view) 95
primary accounting (HWTACACS scheme view) 96
primary authentication (HWTACACS scheme view) 98
primary authorization· 99
reset hwtacacs statistics· 101
reset stop-accounting-buffer (for HWTACACS) 101
retry stop-accounting (HWTACACS scheme view) 102
secondary accounting (HWTACACS scheme view) 102
secondary authentication (HWTACACS scheme view) 104
secondary authorization· 105
stop-accounting-buffer enable (HWTACACS scheme view) 107
timer quiet (HWTACACS scheme view) 108
timer realtime-accounting (HWTACACS scheme view) 108
timer response-timeout (HWTACACS scheme view) 109
user-name-format (HWTACACS scheme view) 110
vpn-instance (HWTACACS scheme view) 111
LDAP commands· 112
attribute-map· 112
authentication-server 112
authorization-server 113
display ldap scheme· 114
ip· 115
ipv6· 116
ldap attribute-map· 117
ldap scheme· 118
ldap server 118
login-dn· 119
login-password· 120
map· 120
protocol-version· 121
search-base-dn· 122
search-scope· 123
server-timeout 123
user-parameters· 124
AAA commands
aaa session-limit
Use aaa session-limit to set the maximum number of concurrent users that can log on to the device through the specified method.
Use undo aaa session-limit to restore the default maximum number of concurrent users for the specified login method.
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh | telnet }
The maximum number of concurrent users is 32 for each user type.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
telnet: Telnet users.
max-sessions: Specifies the maximum number of concurrent login users, in the range of 1 to 64.
After the maximum number of concurrent login users for a user type exceeds the upper limit, the system denies the subsequent users of this type.
# Set the maximum number of concurrent FTP users to 4.
[Sysname] aaa session-limit ftp 4
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting methods of the ISP domain are used for command line accounting.
ISP domain view
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The command line accounting feature works with the accounting server to record valid commands that have been successfully executed on the device.
·     When the command line authorization feature is disabled, the accounting server records all valid commands that have been successfully executed.
·     When the command line authorization feature is enabled, the accounting server records only authorized commands that have been successfully executed.
Command line accounting can use only a remote HWTACACS server.
# In ISP domain test, perform command line accounting based on HWTACACS scheme hwtac.
[Sysname] domain name test
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
accounting default
command accounting (Fundamentals Command Reference)
hwtacacs scheme
accounting default
Use accounting default to specify default accounting methods for an ISP domain.
Use undo accounting default to restore the default.
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting method of an ISP domain is local.
ISP domain view
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
The default accounting method is used for all users that support this method and do not have an accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
You can specify one primary default accounting method and multiple backup default accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting default radius-scheme radius-scheme-name local none command specifies the primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
The remote accounting method is invalid in the following situations:
·     The specified accounting scheme does not exist.
·     Accounting packet sending fails.
·     The device does not receive any accounting response packets from an accounting server.
The local accounting method is invalid if the device fails to find the matching local user configuration.
When the primary accounting method is local, the following rules apply to the accounting of a user:
·     The device uses the backup accounting methods in sequence only if local accounting is invalid for one of the following reasons:
¡     An exception occurs in the local accounting process.
¡     The user account is not configured on the device or the user is not allowed to use the access service.
·     The device does not turn to the backup accounting methods if local accounting is invalid because of any other reason. Accounting fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default accounting method and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
accounting login
Use accounting login to specify accounting methods for login users.
Use undo accounting login to restore the default.
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default accounting methods of the ISP domain are used for login users.
ISP domain view
Accounting is not supported for FTP, SFTP, and SCP users.
You can specify one primary accounting method and multiple backup accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting login radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
¡     The user account is not configured on the device.
# In ISP domain test, perform local accounting for login users.
[Sysname-isp-test] accounting login local
# In ISP domain test, perform RADIUS accounting for login users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
accounting default
hwtacacs scheme
local-user
radius scheme
Use authentication default to specify default authentication methods for an ISP domain.
Use undo authentication default to restore the default.
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication method of an ISP domain is local.
ISP domain view
ldap-scheme ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters.
local: Performs local authentication.
none: Does not perform authentication.
The default authentication method is used for all users that support this method and do not have an authentication method configured.
You can specify one primary default authentication method and multiple backup default authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication default radius-scheme radius-scheme-name local none command specifies a primary default RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
The remote authentication method is invalid in the following situations:
·     The specified authentication scheme does not exist.
·     Authentication packet sending fails.
·     The device does not receive any authentication response packets from an authentication server.
The local authentication method is invalid if the device fails to find the matching local user configuration.
When the primary authentication method is local, the following rules apply to the authentication of a user:
·     The device uses the backup authentication methods in sequence only if local authentication is invalid for one of the following reasons:
¡     An exception occurs in the local authentication process.
·     The device does not turn to the backup authentication methods if local authentication is invalid because of any other reason. Authentication fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authentication method and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
Use authentication login to specify authentication methods for login users.
Use undo authentication login to restore the default.
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authentication methods of the ISP domain are used for login users.
ISP domain view
You can specify one primary authentication method and multiple backup authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication login radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
¡     The user account is not configured on the device or the user is not allowed to use the service for accessing the device.
# In ISP domain test, perform local authentication for login users.
[Sysname-isp-test] authentication login local
# In ISP domain test, perform RADIUS authentication for login users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
Use authentication super to specify a method for user role authentication.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
The default authentication methods of the ISP domain are used for user role authentication.
ISP domain view
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication. The device supports local and remote methods for user role authentication. For more information about user role authentication, see RBAC configuration in Fundamentals Configuration Guide.
You can specify one authentication method and one backup authentication method to use in case that the previous authentication method is invalid.
# In ISP domain test, perform user role authentication based on HWTACACS scheme tac.
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
hwtacacs scheme
radius scheme
Use authorization command to specify command authorization methods.
Use undo authorization command to restore the default.
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
The default authorization methods of the ISP domain are used for command authorization.
ISP domain view
local: Performs local authorization.
none: Does not perform authorization. The authorization server does not verify whether the entered commands are permitted by the user role. The commands are executed successfully if the user role has permission to the commands.
Command authorization restricts login users to execute only authorized commands by employing an authorization server to verify whether each entered command is permitted.
When local command authorization is configured, the device compares each entered command with the user's configuration on the device. The command is executed only when it is permitted by the user's authorized user roles.
The commands that can be executed are controlled by both the access permission of user roles and command authorization of the authorization server. Access permission only controls whether the authorized user roles have access to the entered commands, but it does not control whether the user roles have obtained authorization to these commands. If a command is permitted by the access permission but denied by command authorization, this command cannot be executed.
You can specify one primary command authorization method and multiple backup command authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization command hwtacacs-scheme hwtacacs-scheme-name local none command specifies the default HWTACACS authorization method and two backup methods (local authorization and no authorization). The device performs HWTACACS authorization by default and performs local authorization when the HWTACACS server is invalid. The device does not perform command authorization when both of the previous methods are invalid.
The remote authorization method is invalid in the following situations:
·     The specified authorization scheme does not exist.
·     Authorization packet sending fails.
·     The device does not receive any authorization response packets from an authorization server.
The local authorization method is invalid if the device fails to find the matching local user configuration.
# In ISP domain test, configure the device to perform local command authorization.
[Sysname-isp-test] authorization command local
# In ISP domain test, perform command authorization based on HWTACACS scheme hwtac and use local authorization as the backup.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
command authorization (Fundamentals Command Reference)
hwtacacs scheme
local-user
Use authorization default to specify default authorization methods for an ISP domain.
Use undo authorization default to restore the default.
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization method of an ISP domain is local.
ISP domain view
none: Does not perform authorization. The following default authorization information applies after users pass authentication:
·     Login users obtain the level-0 user role. Login users include the Telnet, FTP, SFTP, SCP, and terminal users. Terminal users can access the device through the console port. For more information about the level-0 user role, see RBAC configuration in Fundamentals Configuration Guide.
·     The working directory for FTP, SFTP, and SCP login users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The default authorization method is used for all users that support this method and do not have an authorization method configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
You can specify one primary authorization method and multiple backup authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization default radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
When the primary authorization method is local, the following rules apply to the authorization of a user:
·     The device uses the backup authorization methods in sequence only if local authorization is invalid for one of the following reasons:
¡     An exception occurs in the local authorization process.
·     The device does not turn to the backup authorization methods if local authorization is invalid because of any other reason. Authorization fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authorization method and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization login
Use authorization login to specify authorization methods for login users.
Use undo authorization login to restore the default.
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
The default authorization methods of the ISP domain are used for login users.
ISP domain view
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization login radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for login users.
[Sysname-isp-test] authorization login local
# In ISP domain test, perform RADIUS authorization for login users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
display domain
Use display domain to display ISP domain configuration.
display domain [ isp-name ]
isp-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. If you do not specify an ISP domain, this command displays the configuration of all ISP domains.
# Display the configuration of all ISP domains.
<Sysname> display domain
Total 2 domains
Domain: system
  Current state: Active
  State configuration: Active
  Default authentication scheme:  Local
  Default authorization  scheme:  Local
  Default accounting     scheme:  Local
  Accounting start failure action: Online
  Accounting update failure action: Online
  Accounting quota out policy: Offline
    Send accounting update:Yes
  Service type: HSI
  Session time: Exclude idle time
  DHCPv6-follow-IPv6CP timeout: Not configured
  Dual-stack accounting method: Merge
  NAS-ID: N/A
  Web server URL              : Not configured
  Web server URL parameters   : Not configured
  Web server IPv4 address     : Not configured
  Web server IPv6 address     : Not configured
  Authorization attributes:
    Idle cut: Disabled
    IGMP access limit: 4
    MLD access limit: 4
Domain: dm
  State configuration: Blocked during specific time ranges
    Time ranges:
      t1
      t2
    Online-user logoff: Disabled
  Login   authentication scheme:  RADIUS=rad
  Login   authorization  scheme:  HWTACACS=hw
  Super   authentication scheme:  RADIUS=rad
  Command authorization  scheme:  HWTACACS=hw
  Default authentication scheme:  RADIUS=rad, Local, None
  Default accounting     scheme:  None
  Service type: HSI
  Session time: Include idle time
  NAS-ID: test
    IP pool: appy
    User group: ugg
    VPN instance: vpn1
    MLD access limit: 4
Default domain name: system
Domain
ISP domain name.
Current state
Current state of the ISP domain:
·     Blocked.
·     Active.
State configuration
State settings of the ISP domain:
·     Active—The ISP domain is set to the active state.
·     Blocked during specific time ranges—The ISP domain is set to the blocked state during the listed time ranges.
·     Blocked—The ISP domain is set to the blocked state.
Time ranges
Time ranges during which the ISP domain is in blocked state.
Online-user logoff
Status for the feature of logging off online users when the state of the ISP domain changes to blocked:
·     Enabled.
·     Disabled.
Default authentication methods.
Default authorization methods.
Default accounting methods.
Authentication methods for login users.
Authorization methods for login users.
Login accounting scheme
Accounting methods for login users.
Authentication methods for obtaining another user role without reconnecting to the device.
Command line authorization methods.
Command accounting scheme
Command line accounting method.
RADIUS
RADIUS scheme.
HWTACACS
HWTACACS scheme.
LDAP
LDAP scheme.
Local
Local scheme.
None
No authentication, no authorization, or no accounting.
Access control for users that encounter accounting-start failures:
·     Online—Allows the users to stay online.
·     Offline—Logs off the users.
Accounting update failure max-times
Maximum number of consecutive accounting-update failures allowed by the device for each user in the domain.
Access control for users that have failed all their accounting-update attempts:
Access control for users that have used up their accounting quotas:
Whether to send accounting-update packets to refresh users' data quotas:
·     Yes.
·     No.
Service type
Service type of the ISP domain, including HSI, STB, and VoIP.
Session time
Online duration sent to the server for users that went offline due to connection failure or malfunction:
·     Include idle time—The online duration includes the idle timeout period.
·     Exclude idle time—The online duration does not include the idle timeout period.
IPv6 address wait timer (in seconds) that starts after IPv6CP negotiation for PPPoE and L2TP users.
This field displays Not Configured if no IPv6 address wait timer is set for PPPoE or L2TP users.
NAS-ID
NAS-ID of the device.
This field displays N/A if no NAS-ID is set in the ISP domain.
Web server URL
URL of the Web server.
Parameters added to the URL of the Web server.
IPv4 address of the Web server.
IPv6 address of the Web server.
Authorization attributes for users in the ISP domain.
Idle cut
Idle cut feature status:
·     Enabled—The feature is enabled. The device logs off users that do not meet the minimum traffic requirements in an idle timeout period.
·     Disabled—The feature is disabled. It is the default idle cut state.
IP pool
Name of the authorization IPv4 address pool.
User group
Authorization user group for users.
VPN instance
Name of the authorization VPN instance for users.
IGMP access limit
Maximum number of IGMP groups that an IPv4 user is authorized to join concurrently.
MLD access limit
Maximum number of MLD groups that an IPv6 user is authorized to join concurrently.
domain
Use domain to create an ISP domain and enter its view, or enter the view of an existing ISP domain.
Use undo domain to delete an ISP domain.
domain name isp-name
undo domain name isp-name
A system-defined ISP domain exists. The domain name is system.
name isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
All ISP domains are in active state when they are created.
You can modify settings for the system-defined ISP domain system, but you cannot delete this domain.
An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
Use short domain names to ensure that user names containing a domain name do not exceed the maximum name length required by different types of users.
# Create an ISP domain named test and enter ISP domain view.
[Sysname-isp-test]
display domain
domain if-unknown
Use domain default enable to specify the default ISP domain. Users without any domain name included in the usernames are considered in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system-defined ISP domain system.
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The ISP domain must already exist.
The system has only one default ISP domain.
# Create an ISP domain named test, and configure the domain as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
display domain
domain
domain if-unknown
Use domain if-unknown to specify an ISP domain to accommodate users that are assigned to nonexistent domains.
Use undo domain if-unknown to restore the default.
domain if-unknown isp-name
No ISP domain is specified to accommodate users that are assigned to nonexistent domains.
The device chooses an authentication domain for each user in the following order:
1.     The authentication domain specified for the access module.
2.     The ISP domain in the username.
3.     The default ISP domain of the device.
If the chosen domain does not exist on the device, the device searches for the ISP domain that accommodates users assigned to nonexistent domains. If no such ISP domain is configured, user authentication fails.
Support for the authentication domain configuration depends on the access module.
# Specify ISP domain test to accommodate users that are assigned to nonexistent domains.
[Sysname] domain if-unknown test
display domain
Use local-server log change-password-prompt to enable password change prompt logging.
Use undo local-server log change-password-prompt to disable password change prompt logging.
Password change prompt logging is enabled.
Use this feature to enhance the protection of passwords for Telnet, SSH, HTTP, HTTPS, NETCONF over SSH, and NETCONF over SOAP users and improve the system security.
This feature enables the device to generate logs to prompt users to change their weak passwords at an interval of 24 hours and at the users' login.
A password is a weak password if it does not meet the following requirements:
·     Password composition restriction configured by using the password-control composition command.
·     Minimum password length restriction set by using the password-control length command.
·     Password complexity checking policy configured by using the password-control complexity command.
For a NETCONF over SSH or NETCONF over SOAP user, the device also generates a password change prompt log if any of the following conditions exists:
·     The current password of the user is the default password or has expired.
·     The user logs in to the device for the first time or uses a new password to log in after global password control is enabled.
The device will no longer generate password change prompt logs for a user when one of the following conditions exists:
·     The password change prompt logging feature is disabled.
·     The user has changed the password and the new password meets the password control requirements.
·     The enabling status of a related password control feature has changed so the current password of the user meets the password control requirements.
·     The password composition policy, the minimum password length, or the password complexity checking policy has changed.
You can use the display password-control command to display password control configuration. For more information about password control commands, see "Password control commands."
# Enable password change prompt logging.
[Sysname] local-server log change-password-prompt
nas-id
Use nas-id to set the NAS-ID in an ISP domain.
Use undo nas-id to delete the NAS-ID from an ISP domain.
nas-id nas-identifier
undo nas-id
No NAS-ID is set in an ISP domain.
ISP domain view
nas-identifier: Specifies a NAS-ID, a case-sensitive string of 1 to 253 characters.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
# Set the NAS-ID to test for ISP domain test.
[Sysname-isp-test] nas-id test
Use session-time include-idle-time to configure the device to include the idle timeout period in the user online duration sent to the server.
Use undo session-time include-idle-time to restore the default.
The device does not include the idle timeout period in the user online duration sent to the server.
ISP domain view
Whether to configure the device to include the idle timeout period in the user online duration sent to the server, depending on the accounting policy in your network. The idle timeout period is assigned to users by the authorization server after the users pass authentication.
If the user goes offline due to connection failure or malfunction, the user online duration sent to the server is not the same as the actual online duration.
·     If the session-time include-idle-time command is used, the user's online duration sent to the server includes the idle timeout period. The online duration that is generated on the server is longer than the actual online duration of the user.
·     If the undo session-time include-idle-time command is used, the user's online duration sent to the server excludes the idle timeout period. The online duration that is generated on the server is shorter than the actual online duration of the user.
# Configure the device to include the idle timeout period in the online duration sent to the server for users in ISP domain test.
[Sysname-isp-test] session-time include-idle-time
display domain
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block [ time-range ] }
undo state
An ISP domain is in active state.
ISP domain view
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services. This keyword takes effect on all types of users except the SSH users that perform publickey authentication.
time-range: Places the ISP domain in blocked state based on time ranges. If you specify the block keyword but do not specify the time-range keyword, the ISP domain is always placed in blocked state.
To block an ISP domain based on time ranges, specify the time-range keyword in this command, and specify time ranges by using the state block time-range name command.
# Place ISP domain test in blocked state.
[Sysname-isp-test] state block
display domain
Use state block time-range name to specify time ranges during which an ISP domain is placed in blocked state.
Use undo state block time-range name to delete time ranges for placing an ISP domain in blocked state.
state block time-range name time-range-name
undo state block time-range { all | name time-range-name }
No time ranges are specified for placing an ISP domain in blocked state.
ISP domain view
time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 32 characters. The string must begin with a letter and cannot be all.
all: Specifies all time ranges.
The specified time ranges take effect only when the device is configured to block an ISP domain based on time ranges. To configure the device to block the ISP domain based on time ranges, use the state block time-range command.
You can repeat this command to specify multiple time ranges.
# Specify time ranges t1 and t2 for placing ISP domain test in blocked state.
[Sysname-isp-test] state block time-range name t1
[Sysname-isp-test] state block time-range name t2
state
time-range (ACL and QoS Command Reference)
Local user commands
access-limit
Use access-limit to set the maximum number of concurrent logins using the local user name.
Use undo access-limit to restore the default.
access-limit max-user-number
undo access-limit
The number of concurrent logins using the local user name is not limited.
Local user view
max-user-number: Specifies the maximum number of concurrent logins, in the range of 1 to 1024.
This command takes effect only when local accounting is configured for the local user. The command does not apply to FTP, SFTP, or SCP users. These users do not support accounting.
# Set the maximum number of concurrent logins to 5 for users using the local user name abc.
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
display local-user
Use authorization-attribute to configure authorization attributes for a local user or user group. After the local user or a local user in the user group passes authentication, the device assigns these attributes to the user.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { idle-cut minutes | user-role role-name | work-directory directory-name } *
undo authorization-attribute { idle-cut | user-role role-name | work-directory } *
The working directory for FTP, SFTP, and SCP users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The local users created by a network-admin or level-15 user are assigned the network-operator user role.
Local user view
User group view
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 120. An online user is logged out if its idle period exceeds the specified idle timeout period.
user-role role-name: Specifies an authorized user role. The role-name argument is a case-sensitive string of 1 to 63 characters. A maximum of 64 user roles can be specified for a user. For user role-related commands, see Fundamentals Command Reference for RBAC commands. This option is available only in local user view, and is not available in user group view.
work-directory directory-name: Specifies the working directory for FTP, SFTP, or SCP users. The directory-name argument is a case-insensitive string of 1 to 255 characters. The directory must already exist.
Configure authorization attributes according to the application environments and purposes. Support for authorization attributes depends on the service types of users.
For SSH, Telnet, and terminal users, only the authorization attributes idle-cut and user-role take effect.
For HTTP and HTTPS users, only the authorization attribute user-role takes effect.
For FTP users, only the authorization attributes user-role and work-directory take effect.
For other types of local users, no authorization attribute takes effect.
Authorization attributes configured for a user group are intended for all local users in the group. You can group local users to improve configuration and management efficiency. An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
To make sure FTP, SFTP, and SCP users can access the directory after an active/standby switchover, do not specify chassis or slot information for the working directory.
To make sure the user have only the user roles authorized by using this command, use the undo authorization-attribute user-role command to remove the default user role.
The security-audit user role has access to the commands for managing security log files and security log file system. To display all the accessible commands of the security-audit user role, use the display role name security-audit command. For more information about security log management, see configuring the information center in System Management Configuration Guide. For more information about file system management, see Fundamentals Configuration Guide.
You cannot delete a local user if the local user is the only user that has the security-audit user role.
The security-audit user role is mutually exclusive with other user roles.
·     When you assign the security-audit user role to a local user, the system requests confirmation for deleting all the other user roles of the user.
·     When you assign other user roles to a local user that has the security-audit user role, the system requests confirmation for deleting the security-audit user role for the local user.
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# Assign the security-audit user role to device management user xyz as the authorized user role.
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz] authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
display local-user
display user-group
display local-user
Use display local-user to display the local user configuration and online user statistics.
display local-user [ class manage | idle-cut { disable | enable } | service-type { ftp | http | https | ssh | telnet | terminal } | state { active | block } | user-name user-name class  manage | vlan vlan-id ]
class: Specifies the local user type.
manage: Device management user.
idle-cut { disable | enable }: Specifies local users by the status of the idle cut feature.
service-type: Specifies the local users that use a specific type of service.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
terminal: Terminal users that log in through console ports.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
·     The pure username is a case-sensitive string and must meet the following requirements:
¡     Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
¡     Cannot be a, al, or all.
·     The domain name is a case-insensitive string and cannot contain an at sign (@).
vlan vlan-id: Specifies all local users in a VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any parameters, this command displays information about all local users.
# Display information about all local users.
<Sysname> display local-user
Total 1 local users matched.
Device management user root:
  State:                      Active
  Service type:               SSH/Telnet/Terminal
  Access limit:               Enabled
  Max access number:          3
  Current access number:      1
  User group:                 system
  Bind attributes:
    Work directory:           flash:
    User role list:           network-admin
    Password aging:           3 days
  Password history was last reset: 0 days ago
  Password remaining lifetime: 2 days 12 hours 30 minutes 30 seconds
Status of the local user: active or blocked.
Service type
Service types that the local user can use.
Access limit
Whether the concurrent login limit is enabled.
Max access number
Maximum number of concurrent logins using the local user name.
Current number of concurrent logins using the local user name.
User group
Group to which the local user belongs.
Bind attributes
Binding attributes of the local user.
Authorization attributes of the local user.
Idle timeout
Idle timeout period of the user, in minutes.
Work directory
Directory that the FTP, SFTP, or SCP user can access.
User role list
Authorized roles of the local user.
IP pool
IPv4 address pool authorized to the local user.
VPN instance
Authorization VPN instance for the local user.
Password control attributes that are configured for the local user.
Password aging
Password expiration time.
Password length
Minimum number of characters that a password must contain.
Password composition policy:
·     Minimum number of character types that a password must contain.
·     Minimum number of characters from each type in a password.
Password complexity
Password complexity checking policy:
·     Reject a password that contains the username or the reverse of the username.
·     Reject a password that contains any character repeated consecutively three or more times.
Maximum login attempts
Maximum number of consecutive failed login attempts.
Action for exceeding login attempts
Action to take on the user that failed to log in after using up all login attempts.
The most recent time that the history password records were cleared.
Remaining aging time for the password.
display user-group
Use display user-group to display user group configuration.
display user-group { all | name group-name }
all: Specifies all user groups.
name group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
# Display the configuration of all user groups.
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
User group: jj
    Idle timeout:            2 minutes
    Work directory:          flash:/
    Password aging:          2 days
User group
User group name.
Authorization attributes of the user group.
Idle timeout
Idle timeout period, in minutes.
Work directory
Directory that FTP, SFTP, or SCP users in the group can access.
IP pool
IPv4 address pool authorized to the user group.
VPN instance
Authorization VPN instance for the user group.
Password control attributes that are configured for the user group.
Password aging
Password length
Password complexity
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to user group system.
Local user view
group-name: Specifies the user group name, a case-insensitive string of 1 to 32 characters.
# Assign device management user 111 to user group abc.
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
display local-user
local-user
Use local-user to add a local user and enter its view, or enter the view of an existing local user.
Use undo local-user to delete local users.
local-user user-name [ class  manage ]
undo local-user { user-name class manage | all [ class manage | service-type { ftp | http | https | ssh | telnet | terminal } ] }
No local users exist.
user-name: Specifies the username of the local user, a string of 1 to 80 characters. The specified username can be a pure username or contain a domain name (in the format of pure-username@domain-name).
¡     Cannot be a substring of all or auto-delete that starts with character a (for example, a, al, all, au, aut, auto, or auto-).
class: Specifies the local user type. If you do not specify this keyword, the command adds a device management user.
manage: Device management user that can configure and monitor the device after login. Device management users can use FTP, HTTP, HTTPS, Telnet, SSH, and terminal services.
all: Specifies all users.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
# Add a device management user named user1 and enter local user view.
[Sysname-luser-manage-user1]
display local-user
service-type
password
Use password to configure a password for a device management user.
Use undo password to restore the default.
password [ { hash | simple } string ]
undo password
A device management user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
Device management user view
hash: Specifies a password encrypted by the hash algorithm.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password string. This argument is case sensitive. The hashed form of the password is a string of 1 to 110 characters. The plaintext form of the password is a string of 1 to 63 characters.
If you do not specify any parameters, you enter the interactive mode to set a plaintext password.
A device management user for which no password is specified can pass authentication after entering the correct username and passing attribute checks. To enhance security, configure a password for each device management user.
# Set the password to 123456TESTplat&! in plaintext form for device management user user1.
# Configure the password in interactive mode for device management user test.
[Sysname-luser-manage-test] password
Password:
confirm :
display local-user
service-type
Use service-type to specify the service types that a local user can use.
Use undo service-type to remove service types configured for a local user.
service-type { ftp | { http | https | ssh | telnet | terminal } * }
undo service-type { ftp | { http | https | ssh | telnet | terminal } * }
A local user is not authorized to use any service.
Local user view
ftp: Authorizes the user to use the FTP service. The authorized directory can be modified by using the authorization-attribute work-directory command.
http: Authorizes the user to use the HTTP service.
https: Authorizes the user to use the HTTPS service.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service and log in from a console port.
You can assign multiple service types to a user.
# Authorize device management user user1 to use the Telnet and FTP services.
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
display local-user
Use state to set the status of a local user.
undo state
A local user is in active state.
Local user view
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
# Place device management user user1 in blocked state.
[Sysname-luser-manage-user1] state block
display local-user
user-group
Use user-group to create a user group and enter its view, or enter the view of an existing user group.
Use undo user-group to delete a user group.
user-group group-name
undo user-group group-name
A system-defined user group exists. The group name is system.
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group.
A user group that has local users cannot be deleted.
You can modify settings for the system-defined user group named system, but you cannot delete the user group.
# Create a user group named abc and enter user group view.
display user-group
RADIUS commands
aaa device-id
Use aaa device-id to configure the device ID.
Use undo aaa device-id to restore the default.
aaa device-id device-id
undo aaa device-id
The device ID is 0.
device-id: Specifies a device ID in the range of 1 to 255.
RADIUS uses the value of the Acct-Session-ID attribute as the accounting ID for a user. The device generates an Acct-Session-ID value for each online user based on the system time, random digits, and device ID.
If you modify the device ID, the new device ID does not take effect on users that have been online during the change.
# Configure the device ID as 1.
[Sysname] aaa device-id 1
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval interval | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
interval interval: Specifies the time interval for retransmitting an accounting-on packet in seconds. The value range for the interval argument is 1 to 15, and the default setting is 3.
send send-times: Specifies the maximum number of accounting-on packet transmission attempts. The value range for the send-times argument is 1 to 255, and the default setting is 50.
The accounting-on feature enables the device to automatically send an accounting-on packet to the RADIUS server after a device reboot. Upon receiving the accounting-on packet, the RADIUS server logs out all online users so they can log in again through the device.
Execute the save command to ensure that the accounting-on enable command takes effect at the next device reboot. For information about the save command, see Fundamentals Command Reference.
Parameters set by using the accounting-on enable command take effect immediately.
# Enable the accounting-on feature for RADIUS scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
Use attribute 15 check-mode to configure the Login-Service attribute check method for SSH, FTP, and terminal users.
Use undo attribute 15 check-mode to restore the default.
attribute 15 check-mode { loose | strict }
The strict check method applies for SSH, FTP, and terminal users.
RADIUS scheme view
loose: Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
strict: Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
Use the loose check method only when the server does not issue Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal users.
# Configure the Login-Service attribute check method as loose for SSH, FTP, and terminal users in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 25 car
Use attribute 25 car to configure the device to interpret the RADIUS class attribute (attribute 25) as CAR parameters.
Use undo attribute 25 car to restore the default.
attribute 25 car
The RADIUS class attribute is not interpreted as CAR parameters.
RADIUS scheme view
Configure the device to interpret the RADIUS class attribute if the RADIUS server uses the attribute to deliver CAR parameters for user-based traffic monitoring and control.
The device can interpret the RADIUS class attribute only in the format of string1string2string3string4 as CAR parameters. Each string contains eight characters and each character must be a digit from 0 to 9.
After the device interprets the RADIUS class attribute sent by a RADIUS server as CAR parameters, it carries the interpreted CAR parameters in the subsequent accounting packets sent to that server instead of carrying the original class attribute.
# In RADIUS scheme radius1, configure the device to interpret the RADIUS class attribute as CAR parameters.
[Sysname-radius-radius1] attribute 25 car
Use attribute 31 mac-format to configure the MAC address format for RADIUS attribute 31.
Use undo attribute 31 mac-format to restore the default.
attribute 31 mac-format section { six | three } separator separator-character { lowercase | uppercase }
A MAC address is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
section: Specifies the number of sections that a MAC address contains.
six: Specifies the six-section format HH-HH-HH-HH-HH-HH.
three: Specifies the three-section format HHHH-HHHH-HHHH.
separator separator-character: Specifies a case-sensitive character that separates the sections.
lowercase: Specifies the letters in a MAC address to be in lower case.
uppercase: Specifies the letters in a MAC address to be in upper case.
Configure the MAC address format for RADIUS attribute 31 to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify the MAC address format as hh:hh:hh:hh:hh:hh for RADIUS attribute 31.
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute convert
Use attribute convert to configure a RADIUS attribute conversion rule.
Use undo attribute convert to delete RADIUS attribute conversion rules.
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
No RADIUS attribute conversion rules exist. The system processes RADIUS attributes according to the principles of the standard RADIUS protocol.
RADIUS scheme view
src-attr-name: Specifies the source RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
dest-attr-name: Specifies the destination RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
access-accept: Specifies the RADIUS Access-Accept packets.
access-request: Specifies the RADIUS Access-Request packets.
accounting: Specifies the RADIUS accounting packets.
received: Specifies the received RADIUS packets.
sent: Specifies the sent RADIUS packets.
The device replaces the attribute in packets that match a RADIUS attribute conversion rule with the destination RADIUS attribute in the rule.
The conversion rules take effect only when the RADIUS attribute translation feature is enabled.
When you configure RADIUS attribute conversion rules, follow these restrictions and guidelines:
·     The source and destination RADIUS attributes in a rule must use the same data type.
·     The source and destination RADIUS attributes in a rule cannot use the same name.
·     A source RADIUS attribute can be converted only by one criterion, packet type or direction.
·     One source RADIUS attribute cannot be converted to multiple destination attributes.
If you do not specify a source RADIUS attribute, the undo attribute convert command deletes all RADIUS attribute conversion rules.
# In RADIUS scheme radius1, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute of received RADIUS packets with the Connect-Info attribute.
[Sysname-radius-radius1] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute reject
Use attribute reject to configure a RADIUS attribute rejection rule.
Use undo attribute reject to delete RADIUS attribute rejection rules.
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
undo attribute reject [ attr-name ]
No RADIUS attribute rejection rules exist.
RADIUS scheme view
attr-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
Configure RADIUS attribute rejection rules for the following purposes:
·     Delete attributes from the RADIUS packets to be sent if the destination RADIUS server does not identify the attributes.
·     Ignore unwanted attributes in the RADIUS packets received from a RADIUS server.
The RADIUS attribute rejection rules take effect only when the RADIUS attribute translation feature is enabled.
A RADIUS attribute can be rejected only by one criterion, packet type or direction.
If you do not specify a RADIUS attribute, the undo attribute reject command deletes all RADIUS attribute rejection rules.
# In RADIUS scheme radius1, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the RADIUS packets to be sent.
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute translate
attribute remanent-volume
Use attribute remanent-volume to set the data measurement unit for the Remanent_Volume attribute.
Use undo attribute remanent-volume to restore the default.
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
The data measurement unit is kilobyte for the Remanent_Volume attribute.
RADIUS scheme view
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
Make sure the measurement unit is the same as the user data measurement unit on the RADIUS server.
# In RADIUS scheme radius1, set the data measurement unit to kilobyte for the Remanent_Volume attribute.
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
display radius scheme
attribute translate
Use attribute translate to enable the RADIUS attribute translation feature.
Use undo attribute translate to disable the RADIUS attribute translation feature.
attribute translate
The RADIUS attribute translation feature is disabled.
RADIUS scheme view
To cooperate with RADIUS servers of different vendors, enable the RADIUS attribute translation feature. Configure RADIUS attribute conversion rules and rejection rules to ensure that RADIUS attributes in the packets exchanged between the device and the server are supported by both sides.
# Enable the RADIUS attribute translation feature for RADIUS scheme radius1.
[Sysname-radius-radius1] attribute translate
attribute convert
attribute reject
attribute vendor-id 2011 version
Use attribute vendor-id 2011 version to specify the version of the RADIUS servers with a vendor ID of 2011.
Use undo attribute vendor-id 2011 version to restore the default.
attribute vendor-id 2011 version { 1.0 | 1.1 }
The version is 1.0.
RADIUS scheme view
1.0: Specifies version 1.0.
1.1: Specifies version 1.1.
For the device to correctly interpret RADIUS attributes from the servers with a vendor ID of 2011, specify a server version the same as the actual version of the RADIUS servers.
The following table shows the differences in the way that the device interprets the vendor-specific RADIUS attributes assigned by different versions of RADIUS servers with vendor ID 2011.
RADIUS attribute
RADIUS server with version 1.0
RADIUS server with version 1.1
HW_ARRT_26_1
Upstream peak rate
Upstream burst size
HW_ARRT_26_2
Upstream average rate
HW_ARRT_26_3
N/A
Upstream peak rate
HW_ARRT_26_4
Downstream peak rate
Downstream burst size
HW_ARRT_26_5
Downstream average rate
HW_ARRT_26_6
N/A
# In RADIUS scheme radius1, specify the version of the RADIUS servers with a vendor ID of 2011 as version 1.1.
[Sysname-radius-radius1] attribute vendor-id 2011 version 1.1
data-flow-format (RADIUS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
RADIUS scheme view
data: Specifies the unit for data flows.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the RADIUS accounting servers. Otherwise, accounting results might be incorrect.
# In RADIUS scheme radius1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
Use display radius scheme to display RADIUS scheme configuration.
display radius scheme [ radius-scheme-name ]
radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a RADIUS scheme, this command displays the configuration of all RADIUS schemes.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
  Index : 0
  Primary authentication server:
    Host name: Not configured
    IP   : 2.2.2.2                                  Port: 1812
    VPN  : vpn1
    State: Active
    Test profile: 132
      Probe username: test
      Probe interval: 60 minutes
    Weight: 40
  Primary accounting server:
    IP   : 1.1.1.1                                  Port: 1813
    VPN  : Not configured
    State: Active
    Weight: 40
  Second authentication server:
    IP   : 3.3.3.3                                  Port: 1812
    State: Block
    Test profile: Not configured
    Weight: 40
  Second accounting server:
    IP   : 3.3.3.3                                  Port: 1813
    State: Block (Mandatory)
    Weight: 0
  Accounting-On function                     : Enabled
    extended function                        : Disabled
    retransmission times                     : 5
    retransmission interval(seconds)         : 2
  Timeout Interval(seconds)                  : 3
  Retransmission Times                       : 3
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(seconds)      : 22
  Stop-accounting packets buffering          : Enabled
    Retransmission times                     : 500
  NAS IP Address                             : 1.1.1.1
  Source IP Address                          : 1.1.1.1
  Username format                            : with-domain
  Data flow unit                             : Megabyte
  Packet unit                                : One
  Attribute 15 check-mode                    : Strict
  Attribute 25                               : CAR
  Remanent-Volume threshold                  : 0
  Attribute Remanent-Volume unit             : Mega
  server-load-sharing                        : Enabled
  Attribute 31 MAC format                    : hh:hh:hh:hh:hh:hh
  Stop-accounting-packet send-force          : Disabled
  RADIUS server version (vendor ID 2011)     : 1.0
  Authentication response pending limit      : Not configured
  Accounting response pending limit          : Not configured
  Username authorization                     : Applied
  All-server-block action                    : Attempt the top-priority server
Index
Index number of the RADIUS scheme.
Information about the primary authentication server.
Information about the primary accounting server.
Information about the secondary authentication server.
Information about the secondary accounting server.
Host name
Host name of the server.
This field displays Not configured in the following situations:
·     The server is not configured.
·     The server is specified by IP address.
IP
IP address of the server.
·     The server is specified by hostname, and the hostname is not resolved.
Port
Service port number of the server. If no port number is specified, this field displays the default port number.
VPN
MPLS L3VPN instance to which the server or the RADIUS scheme belongs. If no VPN instance is specified for the server, this field displays Not configured.
Status of the server:
·     Active—The server is in active state.
·     Block—The server is changed to blocked state automatically.
·     Block (Mandatory)—The server is set to blocked state manually.
Test profile
Test profile used for RADIUS server status detection.
Probe username
Username used for RADIUS server status detection.
Probe interval
Server status detection interval, in minutes.
Weight
Weight value of the RADIUS server.
Whether the accounting-on feature is enabled.
extended function
Whether the extended accounting-on feature is enabled.
Number of accounting-on packet transmission attempts.
Interval at which the device retransmits accounting-on packets, in seconds.
RADIUS server response timeout period, in seconds.
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Maximum number of accounting attempts.
Quiet period for the servers, in minutes.
Interval for sending real-time accounting updates, in seconds.
Whether buffering of nonresponded RADIUS stop-accounting requests is enabled.
Maximum number of transmission attempts for individual RADIUS stop-accounting requests.
NAS IP Address
 NAS IP address of RADIUS packets.
This field displays Not configured if no NAS IP addresses are specified for RADIUS packets.
Source IP address
Source IP address for outgoing RADIUS packets. This field displays Not configured if no source IP addresses are specified.
Username format
Format for the usernames sent to the RADIUS server:
·     with-domain—Includes the domain name.
·     without-domain—Excludes the domain name.
·     keep-original—Forwards the username as the username is entered.
Data flow unit
Measurement unit for data flow.
Packet unit
Measurement unit for packets.
RADIUS Login-Service attribute check method for SSH, FTP, and terminal users:
·     Strict—Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively.
·     Loose—Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services.
Attribute 25
RADIUS attribute 25 interpretation status:
·     Standard—The attribute is not interpreted as CAR parameters.
·     CAR—The attribute is interpreted as CAR parameters.
Available data threshold. The unit for the threshold is the same as the data measurement unit for the RADIUS Remanent_Volume attribute.
Data measurement unit for the RADIUS Remanent_Volume attribute.
server-load-sharing
Status of the RADIUS server load sharing feature:
·     Disabled—The feature is disabled. The device forwards traffic to the server selected based on primary and secondary server roles.
·     Enabled—The feature is enabled. The device distributes traffic among multiple servers for load sharing.
Whether the device is enabled to forcibly send stop-accounting packets when users for which no start-accounting packets are sent go offline.
Version of the RADIUS servers with a vendor ID of 2011.
Maximum number of pending authentication requests (requests for which no responses are received from the authentication server).
If the maximum number of pending authentication requests is not set, this field displays Not configured.
Maximum number of pending accounting requests (requests for which no responses are received from the accounting server).
If the maximum number of pending accounting requests is not set, this field displays Not configured.
Whether to allow the device to use the server-assigned usernames for AAA processes subsequent to authentication:
·     Applied—The device uses the server-assigned usernames for AAA processes subsequent to authentication.
·     Not applied—The device uses the usernames used in authentication for AAA processes subsequent to authentication.
Action to take for AAA requests when all servers in the scheme are blocked:
·     Attempt the top-priority server.
·     Skip all servers in the scheme.
display radius statistics
Use display radius statistics to display RADIUS packet statistics.
# Display RADIUS packet statistics.
<Sysname> display radius statistics
                                 Auth.         Acct.       SessCtrl.
          Request Packet:          0             0             0
            Retry Packet:          0             0             -
          Timeout Packet:          0             0             -
        Access Challenge:          0             -             -
           Account Start:          -             0             -
          Account Update:          -             0             -
            Account Stop:          -             0             -
       Terminate Request:          -             -             0
              Set Policy:          -             -             0
    Packet With Response:          0             0             0
 Packet Without Response:          0             0             -
          Access Rejects:          0             -             -
          Dropped Packet:          0             0             0
          Check Failures:          0             0             0
Table 5 Command output
Auth.
Authentication packets.
Acct.
Accounting packets.
SessCtrl.
Session-control packets.
Request Packet
Number of request packets.
Retry Packet
Number of retransmitted request packets.
Timeout Packet
Number of request packets timed out.
Access Challenge
Number of access challenge packets.
Account Start
Number of start-accounting packets.
Account Update
Number of accounting update packets.
Account Stop
Number of stop-accounting packets.
Terminate Request
Number of packets for logging off users forcibly.
Set Policy
Number of packets for updating user authorization information.
Number of packets for which responses were received.
Number of packets for which no responses were received.
Access Rejects
Number of Access-Reject packets.
Dropped Packet
Number of discarded packets.
Check Failures
Number of packets with checksum errors.
reset radius statistics
display stop-accounting-buffer (for RADIUS)
Use display stop-accounting-buffer to display information about buffered RADIUS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
session-id session-id: Specifies a session by its ID. The session-id argument is a string of 1 to 64 characters and cannot contain a letter. A session ID uniquely identifies an online user for a RADIUS scheme.
time-range start-time end-time: Specifies a time range. The start time and end time must be in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Specifies a user by its name, a case-sensitive string of 1 to 255 characters. Whether the user-name argument should include the domain name depends on the setting configured by using the user-name-format command for the RADIUS scheme.
# Display information about nonresponded RADIUS stop-accounting requests buffered for user abc.
<Sysname> display stop-accounting-buffer user-name abc
Total entries: 2
Scheme     Session ID          Username    First sending time   Attempts
rad1       1000326232325010    abc         23:27:16-08/03/2018  19
aaa        1000326232326010    abc         23:33:01-08/03/2018  20
Table 6 Command output
Session ID
Session ID, which is the value of attribute Acct-Session-Id.
First sending time
Time when the stop-accounting request was first sent.
Attempts
Number of attempts that were made to send the stop-accounting request.
reset stop-accounting-buffer (for RADIUS)
retry
retry stop-accounting (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
user-name-format (RADIUS scheme view)
key (RADIUS scheme view)
Use key to set the shared key for secure RADIUS authentication or accounting communication.
Use undo key to delete the shared key for secure RADIUS authentication or accounting communication.
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
No shared key is configured for secure RADIUS authentication or accounting communication.
RADIUS scheme view
accounting: Specifies the shared key for secure RADIUS accounting communication.
authentication: Specifies the shared key for secure RADIUS authentication communication.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
The shared keys configured by using this command apply to all servers in the scheme. Make sure the settings match the shared keys configured on the RADIUS servers.
The shared keys specified for specific RADIUS servers take precedence over the shared key specified with this command.
# In RADIUS scheme radius1, set the shared key to ok in plaintext form for secure accounting communication.
[Sysname-radius-radius1] key accounting simple ok
nas-ip (RADIUS scheme view)
Use nas-ip to specify a NAS IP address for RADIUS packets.
Use undo nas-ip to remove the NAS IP address of the specified type for RADIUS packets.
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip [ ipv6 ]
The NAS IP address of a RADIUS packet is that specified by using the radius nas-ip command in system view.
RADIUS scheme view
ipv4-address: Specifies an IPv4 address. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address and cannot be a loopback address or a link-local address.
Use this command to specify a NAS IP address for the NAS to carry in the NAS-IP-Address or NAS-IPv6-Address attribute in outgoing RADIUS packets. The NAS IP address must be unique for a RADIUS server to identify the NAS.
The NAS can also use the NAS IP address to match incoming RADIUS packets. For example, if the NAS receives a DAE request that contains a NAS IP address, it compares the NAS IP address in the request with the local NAS IP address. The NAS can process this request only when its NAS IP address is the same as the NAS IP address in the request.
You can specify the NAS IP address in both RADIUS scheme view and system view.
·     The NAS IP address specified by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
·     The NAS IP address specified by using the radius nas-ip command in system view applies to all RADIUS schemes.
·     The NAS IP address specified in RADIUS scheme view takes precedence over the NAS IP address specified in system view.
A RADIUS scheme can have only one NAS IPv4 address and one NAS IPv6 address for RADIUS packets.
If you do not specify the ipv6 keyword for the undo nas-ip command, the command removes the configured NAS IPv4 address for RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the NAS IPv4 address of RADIUS packets.
[Sysname-radius-radius1] nas-ip 10.1.1.1
radius nas-ip
primary accounting (RADIUS scheme view)
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to restore the default.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS accounting server is not specified.
RADIUS scheme view
host-name: Specifies the host name of the primary RADIUS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server.
port-number: Specifies the service port number of the primary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the primary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process accounting requests.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
The shared key configured by using this command takes precedence over the shared key configured with the key accounting command.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the RADIUS scheme.
If you use the primary accounting command to modify or delete the primary accounting server to which the device is sending a start-accounting request, communication with the primary server times out.
·     When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for accounting.
·     When the RADIUS server load sharing feature is enabled, the device returns an accounting failure message rather than searching for another active accounting server.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. It does not buffer the stop-accounting requests. The device can generate incorrect accounting results.
# In RADIUS scheme radius1, specify the primary accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456TESTacct&!.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
secondary accounting (RADIUS scheme view)
server-load-sharing enable
vpn-instance (RADIUS scheme view)
primary authentication (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication server.
Use undo primary authentication to restore the default.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS authentication server is not specified.
RADIUS scheme view
host-name: Specifies the host name of the primary RADIUS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication server.
port-number: Specifies the service port number of the primary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the primary RADIUS authentication server.
test-profile profile-name: Specifies a test profile for detecting the RADIUS server status. The profile-name argument is a case-sensitive string of 1 to 31 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process authentication requests.
Make sure the service port and shared key settings of the primary RADIUS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
The shared key configured by this command takes precedence over the shared key configured with the key authentication command.
The server status detection is triggered for the server if the specified test profile exists on the device.
If you use the primary authentication command to modify or delete the primary authentication server during an authentication process, communication with the primary server times out.
·     When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for authentication.
·     When the RADIUS server load sharing feature is enabled, the device performs the following operations:
a.     Checks the weight value and number of currently served users for each active server.
b.     Determines the most appropriate server in performance to receive an AAA request.
# In RADIUS scheme radius1, specify the primary authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key 123456TESTauth&!.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
radius-server test-profile
secondary authentication (RADIUS scheme view)
radius attribute extended
Use radius attribute extended to define an extended RADIUS attribute.
Use undo radius attribute extended to delete user-defined extended RADIUS attributes.
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
No user-defined extended RADIUS attributes exist.
attribute-name: Specifies the RADIUS attribute name, a case-insensitive string of 1 to 63 characters. The name must be unique among all RADIUS attributes, including the standard and extended RADIUS attributes.
vendor vendor-id: Specifies a vendor ID in the range of 1 to 65535. If you do not specify a vendor ID, the device processes the RADIUS attribute as a standard RADIUS attribute. Table 7 shows the vendor IDs of supported vendors.
Table 7 Supported vendors and vendor IDs
Vendor
Vendor ID
Vendor
Vendor ID
Vendor
Vendor ID
HUAWEI
2011
H3C
25506
Microsoft
311
3COM
43
DSL Forum
3561
China Telecom
20942
Wi-Fi Alliance
40808
Juniper
2636
CMCC
28357
Cisco
9
code attribute-code: Specifies the ID of the RADIUS attribute in the attribute set. The value range for the attribute-code argument is 1 to 255.
type: Specifies a data type for the attribute content.
binary: Binary type.
date: Date type.
integer: Integer type.
interface-id: Interface ID type.
ip: IPv4 address type.
ipv6: IPv6 address type.
ipv6-prefix: IPv6 address prefix type.
octets: Octet type.
string: String type.
To support the proprietary RADIUS attributes of other vendors, perform the following tasks:
1.     Use this command to define the attributes as extended RADIUS attributes.
2.     Use the attribute convert command to map the extended RADIUS attributes to attributes supported by the system.
3.     Use the attribute translate command to enable the RADIUS attribute translation feature for the mappings to take effect.
To cooperate with RADIUS servers of a third-party vendor, map attributes that cannot be identified by the server to server-supported attributes.
Two RADIUS attributes cannot have the same combination of attribute name, vendor ID, and attribute ID.
If you do not specify a RADIUS attribute name, the undo radius attribute extended command deletes all user-defined extended RADIUS attributes.
# Define a string-type extended RADIUS attribute with attribute name Owner-Password, vendor ID 122, and attribute ID 80.
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
attribute convert
attribute reject
attribute translate
radius dscp
Use radius dscp to change the DSCP priority of RADIUS packets.
Use undo radius dscp to restore the default.
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
The DSCP priority of RADIUS packets is 0.
ipv6: Specifies the IPv6 RADIUS packets. If you do not specify this keyword, the command sets the DSCP priority for the IPv4 RADIUS packets.
dscp-value: Specifies the DSCP priority of RADIUS packets, in the range of 0 to 63. A larger value represents a higher priority.
Use this command to set the DSCP priority in the ToS field of RADIUS packets for changing their transmission priority.
# Set the DSCP priority of IPv4 RADIUS packets to 10.
[Sysname] radius dscp 10
radius nas-ip
Use radius nas-ip to specify a NAS IP address for RADIUS packets.
Use undo radius nas-ip to remove the NAS IP address of the specified type for RADIUS packets.
radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The NAS IP address of RADIUS packets is the primary IPv4 address or the IPv6 address of the outbound interface.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the NAS IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network NAS IP address, do not specify this option.
You can specify a maximum of 16 NAS IP addresses in system view, including:
·     Zero or one public-network NAS IPv4 address.
·     Zero or one public-network NAS IPv6 address.
·     Private-network NAS IP addresses.
Each VPN instance can have only one private-network NAS IPv4 address and one private-network NAS IPv6 address in system view.
# Specify IP address 129.10.10.1 as the NAS IP address of RADIUS packets.
[Sysname] radius nas-ip 129.10.10.1
radius scheme
Use radius scheme to create a RADIUS scheme and enter its view, or enter the view of an existing RADIUS scheme.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS schemes exist.
radius-scheme-name: Specifies the RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be used by more than one ISP domain at the same time.
The device supports a maximum of 16 RADIUS schemes.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
radius session-control client
Use radius session-control client to specify a RADIUS session-control client.
Use undo radius session-control client to remove the specified RADIUS session-control clients.
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo radius session-control client { all | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
No RADIUS session-control clients are specified.
ip ipv4-address: Specifies a session-control client by its IPv4 address.
ipv6 ipv6-address: Specifies a session-control client by its IPv6 address.
key: Specifies the shared key for secure communication with the session-control client.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS session-control client belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the client is on the public network, do not specify this option.
all: Specifies all session-control clients.
To verify the session-control packets sent from a RADIUS server running on IMC, specify the RADIUS server as a session-control client to the device. The device matches a session-control packet to a session-control client based on the IP address and VPN instance, and then uses the shared key of the matched client to validate the packet.
The device searches the session-control client settings prior to searching all RADIUS scheme settings for a server with matching settings. This process narrows the search scope for finding the matched RADIUS server.
The session-control client settings take effect only when the RADIUS session-control feature is enabled.
The session-control client settings must be the same as the corresponding settings of the RADIUS server.
You can specify multiple session-control clients on the device.
# Specify a session-control client with IP address 10.110.1.2 and shared key 12345 in plaintext form.
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
radius session-control enable
Use radius session-control enable to enable the RADIUS session-control feature.
Use undo radius session-control enable to disable the RADIUS session-control feature.
The RADIUS session-control feature is disabled.
An H3C IMC RADIUS server uses session-control packets to deliver dynamic authorization change requests or disconnection requests to the device. The session-control feature enables the device to receive the RADIUS session-control packets on UDP port 1812.
This feature must work with H3C IMC servers.
# Enable the RADIUS session-control feature.
[Sysname] radius session-control enable
radius source-ip
Use radius source-ip to specify a source IP address for outgoing RADIUS packets.
Use undo radius source-ip to remove the source IP address of the specified type for outgoing RADIUS packets.
radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius source-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
No IP address is specified as the source IP address of outgoing RADIUS packets.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the source IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network source IP address, do not specify this option.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, a RADIUS server checks the source IP address of the packet.
·     If the source IP address belongs to a managed NAS, the server processes the packet.
·     If the source IP address does not belong to a managed NAS, the server drops the packet.
As a best practice to avoid RADIUS packet loss caused by physical port errors, specify a loopback interface address as the source IP address of outgoing RADIUS packets.
The device selects a source IP address for outgoing RADIUS packets in the following order:
1.     The source IP address specified by using the source-ip command in RADIUS scheme view.
2.     The source IP address specified by using the radius source-ip command in system view.
3.     The NAS IP address specified by using the nas-ip command in RADIUS scheme view.
4.     The NAS IP address specified by using the radius nas-ip command in system view.
5.     The IP address of the outbound interface for the outgoing RADIUS packets.
The source IP address specified in system view applies to all RADIUS schemes.
You can specify a maximum of 16 source IP addresses in system view, including:
·     Zero or one public-network source IPv4 address.
·     Zero or one public-network source IPv6 address.
·     Private-network source IP addresses.
Each VPN instance can have only one private-network source IPv4 address and one private-network source IPv6 address in system view.
# Specify IP address 129.10.10.1 as the source IPv4 address of outgoing RADIUS packets.
[Sysname] radius source-ip 129.10.10.1
radius nas-ip
source-ip (RADIUS scheme view)
Use radius-server test-profile to configure a test profile for detecting the RADIUS server status.
Use undo radius-server test-profile to delete a RADIUS test profile.
radius-server test-profile profile-name username name [ password { cipher | simple } string ] [ interval interval ]
undo radius-server test-profile profile-name
No RADIUS test profiles exist.
profile-name: Specifies the name of the test profile, which is a case-sensitive string of 1 to 31 characters.
username name: Specifies the username in the detection packets. The name argument is a case-sensitive string of 1 to 253 characters.
password: Specifies the user password in the detection packets. If you do not specify a user password, the device randomly generates a user password for each detection packet. As a best practice, specify a user password. RADIUS server might mistake detection packets that contain randomly generated passwords as attack packets.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
interval interval: Specifies the interval for sending a detection packet, in minutes. The value range for the interval argument is 1 to 3600, and the default value is 60.
The device starts detecting the status of a RADIUS server only if the test profile specified for the server exists. If you specify a nonexistent test profile for a RADIUS server, the device does not detect the status of the server until you create the test profile on the device.
When you delete a test profile, the device stops detecting the status of RADIUS servers that use the test profile.
You can execute this command multiple times to configure multiple test profiles.
# Configure a test profile named abc for RADIUS server status detection. A detection packet that uses username admin and plaintext password abc123 is sent every 10 minutes.
[Sysname] radius-server test-profile abc username admin password simple abc123 interval 10
Use reset radius statistics to clear RADIUS statistics.
# Clear RADIUS statistics.
<Sysname> reset radius statistics
Use reset stop-accounting-buffer to clear buffered RADIUS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
# Clear nonresponded RADIUS stop-accounting requests buffered for user user0001@test.
<Sysname> reset stop-accounting-buffer user-name user0001@test
# Clear nonresponded RADIUS stop-accounting requests buffered from 0:0:0 to 23:59:59 on August 31, 2015.
<Sysname> reset stop-accounting-buffer time-range 0:0:0-08/31/2015 23:59:59-08/31/2015
response-pending-limit
Use response-pending-limit to set the maximum number of pending RADIUS requests (requests for which no responses are received from the RADIUS server).
Use undo response-pending-limit to cancel the maximum number configuration for the specified type of pending RADIUS requests.
response-pending-limit { accounting | authentication } max-number
undo response-pending-limit { accounting | authentication }
The number of pending RADIUS requests is not restricted.
RADIUS scheme view
accounting: Specifies pending RADIUS accounting requests.
authentication: Specifies pending RADIUS authentication requests.
max-number: Specifies the maximum number of pending RADIUS requests, in the range of 1 to 255.
This command controls the rate of RADIUS requests that are sent to the RADIUS server. Use this command if the RADIUS server has a limited performance and cannot concurrently process too many RADIUS requests.
The device has two types of pending packet counters, one for the RADIUS authentication server and the other for the RADIUS accounting server. A pending packet counter is used to record the number of sent RADIUS requests for which no responses are received from the RADIUS server. The maximum value of a pending packet counter is determined by this command.
If you set the maximum number of pending authentication or accounting requests, a pending packet counter will be started for the RADIUS authentication or accounting server.
1.     The device starts a pending packet counter for a RADIUS authentication or accounting server after sending the first authentication or accounting request to the server.
2.     The device keeps sending the corresponding type of requests to the server before the counter reaches the maximum value. The number of requests that can be sent to the server is the difference between the counter value and the maximum number.
The counter increases by 1 each time the device sends a corresponding request.
The counter decreases by 1 each time the device receives a respond from the server or the respond timeout timer for a request expires.
3.     The device buffers the subsequent requests when the counter reaches the maximum value.
If the value of the counter falls below the maximum value, the device sends the buffered requests in the sequence the requests are buffered.
If you cancel this configuration, the number of pending RADIUS authentication or accounting requests is not restricted.
# In RADIUS scheme radius1, set the maximum number of pending RADIUS authentication requests to 100.
[Sysname-radius-radius1] response-pending-limit authentication 100
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
retries: Specifies the maximum number of RADIUS packet transmission attempts, in the range of 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable.
If the device does not receive a response to its request from the RADIUS server within the response timeout period, the device retransmits the RADIUS request. To set the response timeout period, use the timer response-timeout command.
If the device does not receive a response from the RADIUS server after the maximum number of transmission attempts is reached, the device considers the request a failure.
If the client times out during the authentication process, the user is immediately logged off. To avoid user logoffs, the value multiplied by the following items cannot be larger than the client timeout period defined by the access module:
·     The maximum number of RADIUS packet transmission attempts.
·     The RADIUS server response timeout period.
·     The number of RADIUS authentication servers in the RADIUS scheme.
When the device sends a RADIUS request to a new RADIUS server, it checks the total amount of time it has taken to transmit the RADIUS packet. If the amount of time has reached 300 seconds, the device stops sending the RADIUS request to the next RADIUS server. As a best practice, consider the number of RADIUS servers when you configure the maximum number of packet transmission attempts and the RADIUS server response timeout period.
# In RADIUS scheme radius1, set the maximum number of RADIUS packet transmission attempts to 5.
[Sysname-radius-radius1] retry 5
radius scheme
timer response-timeout (RADIUS scheme view)
retry realtime-accounting
Use retry realtime-accounting to set the maximum number of accounting attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retries
The maximum number of accounting attempts is 5.
RADIUS scheme view
retries: Specifies the maximum number of accounting attempts, in the range of 1 to 255.
Typically, a RADIUS accounting server checks whether a user is online by using a timeout timer. If the server does not receive a real-time accounting request for a user in the timeout period, it considers that a line or device failure has occurred. The server stops accounting for the user.
To work with the RADIUS server, the NAS needs to send real-time accounting requests to the server before the timer on the server expires and to keep pace with the server in disconnecting the user when a failure occurs. The NAS disconnects from a user according to the maximum number of accounting attempts and specific parameters.
For example, the following conditions exist:
·     The RADIUS server response timeout period is 3 seconds (set by using the timer response-timeout command).
·     The maximum number of RADIUS packet transmission attempts is 3 (set by using the retry command).
·     The real-time accounting interval is 12 minutes (set by using the timer realtime-accounting command).
·     The maximum number of accounting attempts is 5 (set by using the retry realtime-accounting command).
In the above case, the device generates an accounting request every 12 minutes, and retransmits the request if it sends the request but receives no response within 3 seconds. If the device receives no response after transmitting the request three times, it considers the accounting attempt a failure, and makes another accounting attempt. If five consecutive accounting attempts fail, the device cuts the user connection.
# In RADIUS scheme radius1, set the maximum number of accounting attempts to 10.
[Sysname-radius-radius1] retry realtime-accounting 10
retry
timer realtime-accounting (RADIUS scheme view)
Use retry stop-accounting to set the maximum number of transmission attempts for individual RADIUS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts is 500 for individual RADIUS stop-accounting requests.
RADIUS scheme view
retries: Specifies the maximum number of transmission attempts. The value range is 10 to 65535.
The maximum number of stop-accounting request transmission attempts controls the transmission of stop-accounting requests together with the following parameters:
·     RADIUS server response timeout timer (set by using the timer response-timeout command).
·     Maximum number of times to transmit a RADIUS packet per round (set by using the retry command).
For example, the following settings exist:
·     The RADIUS server response timeout timer is 3 seconds.
·     The maximum number of times to transmit a RADIUS packet per round is five.
·     The maximum number of stop-accounting request transmission attempts is 20.
A stop-accounting request is retransmitted if the device does not receive a response within 3 seconds. When all five transmission attempts in this round are used, the device buffers the request and starts another round of retransmission. If 20 consecutive rounds of attempts fail, the device discards the request.
# Set the maximum number of stop-accounting request transmission attempts to 1000 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry stop-accounting 1000
retry
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove a secondary RADIUS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS accounting servers are specified.
RADIUS scheme view
host-name: Specifies the host name of a secondary RADIUS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS accounting server.
port-number: Specifies the service port number of the secondary RADIUS accounting server. The value range for the UDP port number is 1 to 65535. The default setting is 1813.
key: Specifies the shared key for secure communication with the secondary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary RADIUS accounting server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The shared key configured by this command takes precedence over the shared key configured with the key accounting command.
If you use the secondary accounting command to modify or delete a secondary accounting server to which the device is sending a start-accounting request, communication with the secondary server times out.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. The device does not buffer the stop-accounting requests, either.
# In RADIUS scheme radius1, specify a secondary accounting server with IP address 10.110.1.1 and UDP port 1813.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# In RADIUS scheme radius2, specify two secondary accounting servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1813.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
Use secondary authentication to specify a secondary RADIUS authentication server.
Use undo secondary authentication to remove a secondary RADIUS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary RADIUS authentication servers are specified.
RADIUS scheme view
host-name: Specifies the host name of a secondary RADIUS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS authentication server.
port-number: Specifies the service port number of the secondary RADIUS authentication server. The value range for the UDP port number is 1 to 65535. The default setting is 1812.
key: Specifies the shared key for secure communication with the secondary RADIUS authentication server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary RADIUS authentication server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The server status detection is triggered for a server if the specified test profile exists on the device.
If you use the secondary authentication command to modify or delete a secondary authentication server during an authentication process, communication with the secondary server times out.
# In RADIUS scheme radius1, specify a secondary authentication server with IP address 10.110.1.2 and UDP port 1812.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# In RADIUS scheme radius2, specify two secondary authentication servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
server-block-action
Use server-block-action to specify the action to take for AAA requests if all servers in a RADIUS scheme are blocked.
Use undo server-block-action to restore the default.
server-block-action { attempt | skip }
The device attempts to connect to the server with the highest priority in a RADIUS scheme upon receiving AAA requests if all servers in the scheme are blocked.
RADIUS scheme view
attempt: Attempts to connect to a server in the scheme.
skip: Skips all servers in the scheme and turns to the backup method.
The attempt action gives the device a chance to use the scheme in case the server with the highest priority in the scheme might be available. However, the attempt to communicate with an unavailable server increases the response time for AAA requests. As a best practice, specify the skip action in scenarios that require quick responses to AAA requests.
When processing an AAA request, the device does not turn back to a skipped scheme even though the state of the servers in the scheme changes from blocked to active.
# In RADIUS scheme radius1, configure the device to skip all servers in the scheme upon receiving AAA requests if all servers in the scheme are blocked.
[Sysname] radius scheme hwt1
[Sysname-radius-radius1] server-block-action skip
retry
Use server-load-sharing enable to enable the RADIUS server load sharing feature.
Use undo server-load-sharing enable to disable the RADIUS server load sharing feature.
The RADIUS server load sharing feature is disabled.
RADIUS scheme view
Use the RADIUS server load sharing feature to dynamically distribute the workload over multiple servers regardless of their server roles. The device forwards an AAA request to the most appropriate server of all active servers in the scheme after it compares the weight values and numbers of currently served users. Specify a weight value for each RADIUS server based on the AAA capacity of the server. A larger weight value indicates a higher AAA capacity.
In RADIUS server load sharing, once the device sends a start-accounting request to a server for a user, it forwards all subsequent accounting requests of the user to the same server. If the accounting server is unreachable, the device returns an accounting failure message rather than searching for another active accounting server.
# Enable the RADIUS server load sharing feature for RADIUS scheme radius1.
[Sysname-radius-radius1] server-load-sharing enable
snmp-agent trap enable radius
Use snmp-agent trap enable radius to enable SNMP notifications for RADIUS.
Use undo snmp-agent trap enable radius to disable SNMP notifications for RADIUS.
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
All RADIUS SNMP notifications are disabled.
accounting-server-down: Specifies notifications to be sent when the RADIUS accounting server becomes unreachable.
accounting-server-up: Specifies notifications to be sent when the RADIUS accounting server becomes reachable.
authentication-error-threshold: Specifies notifications to be sent when the number of authentication failures exceeds the specified threshold. The threshold is represented by the ratio of the authentication failures to the total number of authentication attempts. The value range is 1 to 100, and the default value is 30. This threshold can only be configured through the MIB.
authentication-server-down: Specifies notifications to be sent when the RADIUS authentication server becomes unreachable.
authentication-server-up: Specifies notifications to be sent when the RADIUS authentication server becomes reachable.
If you do not specify any keywords, this command enables or disables all types of notifications for RADIUS.
When SNMP notifications for RADIUS are enabled, the device supports the following notifications generated by RADIUS:
·     RADIUS server unreachable notification—The RADIUS server cannot be reached. RADIUS generates this notification if it cannot receive any response to an accounting or authentication request within the specified RADIUS request transmission attempts.
·     RADIUS server reachable notification—The RADIUS server can be reached. RADIUS generates this notification for a previously blocked RADIUS server after the quiet timer expires.
·     Excessive authentication failures notification—RADIUS generates this notification when the number of authentication failures to the total number of authentication attempts exceeds the specified threshold.
# Enable the device to send RADIUS accounting server unreachable notifications.
[Sysname] snmp-agent trap enable radius accounting-server-down
source-ip
Use source-ip to specify a source IP address for outgoing RADIUS packets.
Use undo source-ip to remove the source IP address of the specified type for outgoing RADIUS packets.
undo source-ip [ ipv6 ]
The source IP address of an outgoing RADIUS packet is that specified by using the radius source-ip command in system view.
RADIUS scheme view
A RADIUS scheme can have only one source IPv4 address and one source IPv6 address for outgoing RADIUS packets.
If you do not specify the ipv6 keyword for the undo source-ip command, the command removes the configured source IPv4 address for outgoing RADIUS packets.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the source IPv4 address of outgoing RADIUS packets.
[Sysname-radius-radius1] source-ip 10.1.1.1
radius nas-ip
radius source-ip
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
A primary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies the primary RADIUS accounting server.
authentication: Specifies the primary RADIUS authentication server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
When the RADIUS server load sharing feature is disabled, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device performs the following operations:
·     Changes the status of the primary server to blocked.
·     Starts a quiet timer for the server.
·     Tries to communicate with a secondary server in active state.
When the quiet timer of the primary server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active.
When the RADIUS server load sharing feature is enabled, the device checks the weight value and number of currently served users only for servers in active state. The most appropriate active server is selected for communication.
When the primary server and all secondary servers are in blocked state, the device tries to communicate with the primary server.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a primary RADIUS authentication server.
·     If you set the status of the server to blocked, the device stops detecting the status of the server.
·     If you set the status of the server to active, the device starts to detect the status of the server.
# In RADIUS scheme radius1, set the status of the primary authentication server to blocked.
[Sysname-radius-radius1] state primary authentication block
state secondary
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
A secondary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies a secondary RADIUS accounting server.
authentication: Specifies a secondary RADIUS authentication server.
host-name: Specifies the host name of the secondary RADIUS server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS server.
port-number: Specifies the service port number of a secondary RADIUS server. The value range for the UDP port number is 1 to 65535. The default port numbers for authentication and accounting are 1812 and 1813, respectively.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
If you do not specify an IP address, this command changes the status of all configured secondary RADIUS servers.
If the device finds that a secondary server in active state is unreachable, the device performs the following operations:
·     Changes the status of the secondary server to blocked.
·     Tries to communicate with another secondary server in active state.
When the quiet timer of a server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a secondary RADIUS authentication server.
# In RADIUS scheme radius1, set the status of all the secondary authentication servers to blocked.
[Sysname-radius-radius1] state secondary authentication block
state primary
Use stop-accounting-buffer enable to enable buffering of RADIUS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable the buffering feature.
The device buffers the RADIUS stop-accounting requests to which no responses have been received.
RADIUS scheme view
This command enables the device to buffer a RADIUS stop-accounting request that has no response after the maximum transmission attempts (set by using the retry command) have been made. The device resends the buffered request until it receives a server response or when the number of stop-accounting request transmission attempts reaches the upper limit. If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of RADIUS stop-accounting requests to which no responses have been received.
[Sysname-radius-radius1] stop-accounting-buffer enable
stop-accounting-packet send-force
Use stop-accounting-packet send-force to enable forcibly sending stop-accounting packets. The device will send stop-accounting packets when users for which no start-accounting packets are sent go offline.
Use undo stop-accounting-packet send-force to disable forcibly sending stop-accounting packets.
Forcibly sending stop-accounting packets is disabled. The device does not send stop-accounting packets when users for which no start-accounting packets are sent go offline.
RADIUS scheme view
Typically, if the device does not send a start-accounting packet to the RADIUS server for an authenticated user, it does not send a stop-accounting packet when the user goes offline. If the server has generated a user entry for the user without start-accounting packets, it does not release the user entry when the user goes offline. This feature forces the device to send stop-accounting packets to the RADIUS server when the user goes offline for timely releasing the user entry on the server.
# In RADIUS scheme radius1, enable forcibly sending stop-accounting packets.
[Sysname-radius-radius1] stop-accounting-packet send-force
display radius scheme
threshold remanent-volume
Use threshold remanent-volume to set the available data threshold.
Use undo threshold remanent-volume to restore the default.
threshold remanent-volume threshold-value
The available data threshold is 0.
RADIUS scheme view
threshold-value: Specifies the available data threshold, in the range of 0 to 4294967295. The unit is set by using the attribute remanent-volume unit command.
Use this command if the RADIUS server divides the total data quota of an authenticated user into multiple equal portions and assigns one portion to the user each time. When the user's available data on the device reaches the threshold, the device sends a realtime accounting request to the RADIUS server to apply for a new portion. This process continues till the user uses up the total data quota.
# In RADIUS scheme radius1, set the available data threshold to 2048 MB.
[Sysname-radius-radius1] threshold remanent-volume 2048
[Sysname-radius-radius1] attribute remanent-volume unit mega-byte
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for the servers specified in a RADIUS scheme.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet timer period is 5 minutes in a RADIUS scheme.
RADIUS scheme view
minutes: Specifies the server quiet period in minutes, in the range of 1 to 255.
Make sure the server quiet timer is set correctly.
A timer that is too short might result in frequent authentication or accounting failures. This is because the device will continue to attempt to communicate with an unreachable server that is in active state.
A timer that is too long might temporarily block a reachable server that has recovered from a failure. This is because the server will remain in blocked state until the timer expires.
# In RADIUS scheme radius1, set the quiet timer to 10 minutes for the servers.
[Sysname-radius-radius1] timer quiet 10
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting interval [ second ]
The real-time accounting interval is 12 minutes.
RADIUS scheme view
interval: Specifies the real-time accounting interval in the range of 0 to 71582.
second: Specifies the measurement unit as second. If you do not specify this keyword, the real-time accounting interval is measured in minutes.
When the real-time accounting interval on the device is not zero, the device sends online user accounting information to the RADIUS accounting server at the configured interval.
When the real-time accounting interval on the device is zero, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server. If the real-time accounting interval is not configured on the server, the device does not send online user accounting information.
If a user uses RADIUS accounting but not RADIUS authentication and authorization, the device performs real-time accounting for that user only based on the real-time accounting interval set in the user's RADIUS accounting scheme. The real-time accounting interval assigned by the RADIUS accounting server does not take effect.
A short interval helps improve accounting precision but requires many system resources.
Table 8 Recommended real-time accounting intervals
Number of users
Real-time accounting interval
1 to 99
3 minutes
100 to 499
6 minutes
500 to 999
12 minutes
1000 or more
15 minutes or longer
# In RADIUS scheme radius1, set the real-time accounting interval to 51 minutes.
[Sysname-radius-radius1] timer realtime-accounting 51
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
seconds: Specifies the RADIUS server response timeout period, in the range of 1 to 10 seconds.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request, it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
·     The number of RADIUS servers in the RADIUS scheme.
# In RADIUS scheme radius1, set the RADIUS server response timeout timer to 5 seconds.
[Sysname-radius-radius1] timer response-timeout 5
retry
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
Use undo user-name-format to restore the default.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the usernames sent to a RADIUS server.
RADIUS scheme view
keep-original: Sends the username to the RADIUS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the RADIUS server will consider two users in different ISP domains but with the same userid as one user.
# In RADIUS scheme radius1, configure the device to remove the domain name from the usernames sent to the RADIUS servers.
[Sysname-radius-radius1] user-name-format without-domain
Use vpn-instance to specify an MPLS L3VPN instance for a RADIUS scheme.
Use undo vpn-instance to restore the default.
undo vpn-instance
The RADIUS scheme belongs to the public network.
RADIUS scheme view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
The VPN instance specified for a RADIUS scheme applies to all authentication and accounting servers in that scheme. If a VPN instance is also configured for an individual RADIUS server, the VPN instance specified for the RADIUS scheme does not take effect on that server.
# Specify VPN instance test for RADIUS scheme radius1.
[Sysname-radius-radius1] vpn-instance test
HWTACACS commands
data-flow-format (HWTACACS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
data: Specifies the unit for data flows.
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the HWTACACS accounting servers. Otherwise, accounting results might be incorrect.
# In HWTACACS scheme hwt1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs scheme
Use display hwtacacs scheme to display the configuration or statistics of HWTACACS schemes.
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an HWTACACS scheme, this command displays the configuration of all HWTACACS schemes.
statistics: Displays the HWTACACS service statistics. If you do not specify this keyword, the command displays the configuration of the specified HWTACACS scheme.
# Displays the configuration of all HWTACACS schemes.
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS Scheme Name  : hwtac
  Index : 0
  Primary Auth Server:
    Host name: Not configured
    IP  : 2.2.2.2         Port: 49     State: Active
    VPN Instance: 2
    Single-connection: Enabled
  Primary Author Server:
    VPN Instance: 2
    Single-connection: Disabled
  Primary Acct Server:
    IP  : Not Configured  Port: 49     State: Block
    VPN Instance: Not configured
  VPN Instance                          : 2
  NAS IP Address                        : 2.2.2.3
  Server Quiet Period(minutes)          : 5
  Realtime Accounting Interval(minutes) : 12
  Stop-accounting packets buffering     : Enabled
    Retransmission times                : 100
  Response Timeout Interval(seconds)    : 5
  Username Format                       : with-domain
  Data flow unit                        : Byte
  Packet unit                           : one
Table 9 Command output
Index
Index number of the HWTACACS scheme.
Primary Auth Server
Primary HWTACACS authentication server.
Primary HWTACACS authorization server.
Primary Acct Server
Primary HWTACACS accounting server.
Secondary Auth Server
Secondary HWTACACS authentication server.
Secondary Author Server
Secondary HWTACACS authorization server.
Secondary Acct Server
Secondary HWTACACS accounting server.
Host name
Host name of the server.
This field displays Not configured in the following situations:
·     The server is not configured.
·     The server is specified by IP address.
IP
IP address of the server.
·     The server is specified by hostname, and the hostname is not resolved.
Port
Service port of the HWTACACS server. If no port configuration is performed, this field displays the default port number.
Status of the HWTACACS server: active or blocked.
VPN Instance
MPLS L3VPN instance to which the HWTACACS server or scheme belongs. If no VPN instance is specified for the server or scheme, this field displays Not configured.
Single-connection
Single connection status:
·     Enabled—Establish only one TCP connection for all users to communicate with the server.
·     Disabled—Establish a TCP connection for each user to communicate with the server.
NAS IP Address
Source IP addresses for outgoing HWTACACS packets.
This field displays Not configured if no source IP addresses are specified for outgoing HWTACACS packets.
Quiet period for the primary servers, in minutes.
Real-time accounting interval, in minutes.
Whether buffering of nonresponded HWTACACS stop-accounting requests is enabled.
Maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
HWTACACS server response timeout period, in seconds.
Username Format
Format for the usernames sent to the HWTACACS server:
·     with-domain—Includes the domain name.
·     without-domain—Excludes the domain name.
·     keep-original—Forwards the username as the username is entered.
Data flow unit
Measurement unit for data flows.
Packet unit
Measurement unit for packets.
# Display statistics for HWTACACS scheme tac.
<Sysname> display hwtacacs scheme tac statistics
HWTACACS scheme name: tac
  Primary authentication server: 111.8.0.244
    Round trip time:                                20 seconds
    Request packets:                                1
    Login request packets:                          1
    Change-password request packets:                0
    Request packets including plaintext passwords:  0
    Request packets including ciphertext passwords: 0
    Response packets:                               2
    Pass response packets:                          1
    Failure response packets:                       0
    Get-data response packets:                      0
    Get-username response packets:                  0
    Get-password response packets:                  1
    Restart response packets:                       0
    Error response packets:                         0
    Follow response packets:                        0
    Malformed response packets:                     0
    Continue packets:                               1
    Continue-abort packets:                         0
    Pending request packets:                        0
    Timeout packets:                                0
    Unknown type response packets:                  0
    Dropped response packets:                       0
  Primary authorization server :111.8.0.244
    Round trip time:                               1 seconds
    Request packets:                               1
    Response packets:                              1
    PassAdd response packets:                      1
    PassReply response packets:                    0
    Timeout packets:                               0
  Primary accounting server :111.8.0.244
    Round trip time:                               0 seconds
    Request packets:                               2
    Accounting start request packets:              1
    Accounting stop request packets:               1
    Accounting update request packets:             0
    Response packets:                              2
    Success response packets:                      2
    Timeout response packets:                      0
Table 10 Command output
Secondary authentication server
Secondary authorization server
Secondary accounting server
Round trip time
The time interval during which the device processed a pair of request and response. The unit is second.
Request packets
Total number of sent request packets.
Number of sent login request packets.
Number of sent request packets for changing passwords.
Number of request packets that include plaintext passwords.
Number of request packets that include ciphertext passwords.
Response packets
Total number of received response packets.
Number of response packets indicating successful authentication.
Number of response packets indicating authentication or authorization failure.
Number of response packets for obtaining user data.
Number of response packets for obtaining usernames.
Number of response packets for obtaining passwords.
Number of response packets for reauthentication.
Number of error-type response packets.
Number of follow-type response packets.
Number of malformed response packets.
Continue packets
Number of sent Continue packets.
Number of sent Continue-abort packets.
Number of request packets waiting for a response.
Timeout packets/Timeout response packets
Number of timeout response packets.
Number of unknown-type response packets.
Number of dropped response packets.
Number of received PassAdd response packets. The packets indicate that all requested authorization attributes are assigned and additional authorization attributes are added.
Number of received PassReply response packets. The device uses the specified authorization attributes in the packets to replace the requested authorization attributes.
Number of accounting start request packets.
Number of accounting stop request packets.
Number of accounting update request packets.
Number of accounting success response packets.
reset hwtacacs statistics
display stop-accounting-buffer (for HWTACACS)
Use display stop-accounting-buffer to display information about buffered HWTACACS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
# Display information about nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total entries: 2
Scheme    IP address        Username      First sending time     Attempts
hwt1      192.168.100.1     abc           23:27:16-08/15/2018    19
hwt1      192.168.90.6      bob           23:33:01-08/15/2018    20
Table 11 Command output
First sending time
Time when the stop-accounting request was first sent.
Attempts
Number of attempts that were made to send the stop-accounting request.
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to delete the specified source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo hwtacacs nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
The source IP address of an HWTACACS packet sent to the server is the primary IPv4 address or the IPv6 address of the outbound interface.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, the HWTACACS server checks the source IP address of the packet.
·     If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
·     If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice to avoid HWTACACS packet loss caused by physical port errors, specify a loopback interface address as the source IP address for outgoing HWTACACS packets.
If you use both the nas-ip command and hwtacacs nas-ip command, the following guidelines apply:
·     The setting configured by using the nas-ip command in HWTACACS scheme view applies only to the HWTACACS scheme.
·     The setting configured by using the hwtacacs nas-ip command in system view applies to all HWTACACS schemes.
·     The setting in HWTACACS scheme view takes precedence over the setting in system view.
# Specify IP address 129.10.10.1 as the source IP address for HWTACACS packets.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip (HWTACACS scheme view)
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter its view, or enter the view of an existing HWTACACS scheme.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS schemes exist.
hwtacacs-scheme-name: Specifies the HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 HWTACACS schemes.
# Create an HWTACACS scheme named hwt1 and enter HWTACACS scheme view.
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
Use undo key to delete the shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
No shared key is configured for secure HWTACACS authentication, authorization, or accounting communication.
accounting: Specifies the shared key for secure HWTACACS accounting communication.
authentication: Specifies the shared key for secure HWTACACS authentication communication.
authorization: Specifies the shared key for secure HWTACACS authorization communication.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. The encrypted form of the key is a string of 1 to 373 characters. The plaintext form of the key is a string of 1 to 255 characters.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# In HWTACACS scheme hwt1, set the shared key to 123456TESTauth&! in plaintext form for secure HWTACACS authentication communication.
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# Set the shared key to 123456TESTautr&! in plaintext form for secure HWTACACS authorization communication.
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# Set the shared key to 123456TESTacct&! in plaintext form for secure HWTACACS accounting communication.
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
Use nas-ip to specify a source IP address for outgoing HWTACACS packets.
Use undo nas-ip to delete the specified source IP address for outgoing HWTACACS packets.
undo nas-ip [ ipv6 ]
The source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view.
If the hwtacacs nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
For an HWTACACS scheme, you can specify only one source IPv4 address and one source IPv6 address for outgoing HWTACACS packets.
If you do not specify any parameter for the undo nas-ip command, the command deletes the configured source IPv4 address for outgoing HWTACACS packets.
# In HWTACACS scheme hwt1, specify IP address 10.1.1.1 as the source address for outgoing HWTACACS packets.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
Use undo primary accounting to restore the default.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS accounting server is not specified.
host-name: Specifies the host name of the primary HWTACACS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies an IPv4 address of the primary HWTACACS accounting server.
ipv6 ipv6-address: Specifies an IPv6 address of the primary HWTACACS accounting server.
port-number: Specifies the service port number of the primary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS accounting server.
single-connection: The device and the primary HWTACACS accounting server use the same TCP connection to exchange accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the primary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
As a best practice, specify the single-connection keyword to reduce TCP connections for improving system performance if the HWTACACS server supports the single-connection method.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the HWTACACS scheme.
You can remove an accounting server only when it is not used for user accounting. Removing an accounting server affects only accounting processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
secondary accounting (HWTACACS scheme view)
vpn-instance (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
Use undo primary authentication to restore the default.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authentication server is not specified.
host-name: Specifies the host name of the primary HWTACACS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authentication server.
port-number: Specifies the service port number of the primary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authentication server.
single-connection: The device and the primary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authentication packets with the primary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
You can remove an authentication server only when it is not used for user authentication. Removing an authentication server affects only authentication processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
secondary authentication (HWTACACS scheme view)
primary authorization
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to restore the default.
primary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authorization server is not specified.
host-name: Specifies the host name of the primary HWTACACS authorization server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authorization server.
port-number: Specifies the service port number of the primary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authorization server.
single-connection: The device and the primary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the primary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authorization server are the same as those configured on the server.
Two authorization servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
You can remove an authorization server only when it is not used for user authorization. Removing an authorization server affects only authorization processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
secondary authorization (HWTACACS scheme view)
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting: Clears the HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears the HWTACACS authentication statistics.
authorization: Clears the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
Use reset stop-accounting-buffer to clear buffered HWTACACS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
# Clear nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
Use retry stop-accounting to set the maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
The maximum number of transmission attempts for individual HWTACACS stop-accounting requests is 100.
retries: Specifies the maximum number of transmission attempts for HWTACACS stop-accounting requests. The value range is 1 to 300.
# In HWTACACS scheme hwt1, set the maximum number of HWTACACS stop-accounting attempts to 300.
[Sysname-hwtacacs-hwt1] retry stop-accounting 300
timer response-timeout (HWTACACS scheme view)
Use secondary accounting to specify a secondary HWTACACS accounting server.
Use undo secondary accounting to remove a secondary HWTACACS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
No secondary HWTACACS accounting servers are specified.
host-name: Specifies the host name of a secondary HWTACACS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS accounting server.
port-number: Specifies the service port number of the secondary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS accounting server.
single-connection: The device and the secondary HWTACACS accounting server use the same TCP connection to exchange all accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges accounting packets with the secondary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS accounting server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary accounting command, the command removes all secondary accounting servers.
# In HWTACACS scheme hwt1, specify a secondary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
Use secondary authentication to specify a secondary HWTACACS authentication server.
Use undo secondary authentication to remove a secondary HWTACACS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
No secondary HWTACACS authentication servers are specified.
host-name: Specifies the host name of a secondary HWTACACS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authentication server.
port-number: Specifies the service port number of the secondary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authentication server.
single-connection: The device and the secondary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authentication packets with the secondary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary HWTACACS authentication server are the same as those configured on the corresponding server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authentication command, the command removes all secondary authentication servers.
# In HWTACACS scheme hwt1, specify a secondary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove a secondary HWTACACS authorization server.
secondary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS authorization servers are specified.
host-name: Specifies the host name of a secondary HWTACACS authorization server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authorization server.
port-number: Specifies the service port number of the secondary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authorization server.
single-connection: The device and the secondary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection each time it exchanges authorization packets with the secondary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS authorization server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authorization servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authorization command, the command removes all secondary authorization servers.
# In HWTACACS scheme hwt1, specify a secondary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
primary authorization (HWTACACS scheme view)
Use stop-accounting-buffer enable to enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable buffering of HWTACACS stop-accounting requests to which no responses have been received.
The device buffers HWTACACS stop-accounting requests to which no responses have been received.
This command enables the device to buffer an HWTACACS stop-accounting request to which no response has been received. The device resends the buffered request until it receives a server response or when the number of transmission attempts reaches the maximum (set by using the retry stop-accounting command). If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an HWTACACS scheme.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
# In HWTACACS scheme hwt1, set the server quiet timer to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting minutes
minutes: Specifies the real-time accounting interval in minutes, in the range of 0 to 60. Setting this interval to 0 disables the device from sending online user accounting information to the HWTACACS accounting server.
For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is used to set the interval.
Table 12 Recommended real-time accounting intervals
Number of users
1 to 99
3 minutes
100 to 499
6 minutes
500 to 999
12 minutes
1000 or more
# In HWTACACS scheme hwt1, set the real-time accounting interval to 51 minutes.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
seconds: Specifies the HWTACACS server response timeout time, in the range of 1 to 300 seconds.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
The client timeout period of the associated access module cannot be shorter than the total response timeout timer of all HWTACACS servers in the scheme. Any violation will result in user logoffs before the authentication, authorization, or accounting process is complete.
# In HWTACACS scheme hwt1, set the HWTACACS server response timeout timer to 30 seconds.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
The ISP domain name is included in the usernames sent to an HWTACACS server.
keep-original: Sends the username to the HWTACACS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. However, some HWTACACS servers cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the HWTACACS server will consider two users in different ISP domains but with the same userid as one user.
# In HWTACACS scheme hwt1, configure the device to remove the ISP domain name from the usernames sent to the HWTACACS servers.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
Use vpn-instance to specify an MPLS L3VPN instance for an HWTACACS scheme.
undo vpn-instance
The HWTACACS scheme belongs to the public network.
The VPN instance specified for an HWTACACS scheme applies to all servers in that scheme. If a VPN instance is also configured for an individual HWTACACS server, the VPN instance specified for the HWTACACS scheme does not take effect on that server.
# Specify VPN instance test for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] vpn-instance test
LDAP commands
attribute-map
Use attribute-map to specify the LDAP attribute map in an LDAP scheme.
Use undo attribute-map to restore the default.
attribute-map map-name
undo attribute-map
An LDAP scheme does not use an LDAP attribute map.
LDAP scheme view
map-name: Specifies an LDAP attribute map by its name, a case-insensitive string of 1 to 31 characters.
When the LDAP scheme used for authorization contains an LDAP attribute map, the device converts server-assigned LDAP attributes to device-recognizable AAA attributes based on the mapping entries.
You can specify only one LDAP attribute map in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
If you specify another attribute map or change the mapping entries, the new settings take effect only on the LDAP authorization that occurs after your operation.
# Specify LDAP attribute map map1 in LDAP scheme test.
[Sysname] ldap scheme test
[Sysname-ldap-test] attribute-map map1
display ldap-scheme
ldap attribute-map
Use authentication-server to specify the LDAP authentication server for an LDAP scheme.
Use undo authentication-server to restore the default.
authentication-server server-name
No LDAP authentication server is specified for an LDAP scheme.
LDAP scheme view
server-name: Specifies the name of an LDAP server, a case-insensitive string of 1 to 64 characters.
You can specify only one LDAP authentication server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authentication server as ccc.
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] authentication-server ccc
display ldap scheme
ldap server
authorization-server
Use authorization-server to specify the LDAP authorization server for an LDAP scheme.
Use undo authorization-server to restore the default.
authorization-server server-name
No LDAP authorization server is specified for an LDAP scheme.
LDAP scheme view
You can specify only one LDAP authorization server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authorization server as ccc.
[Sysname-ldap-ldap1] authorization-server ccc
display ldap scheme
ldap server
display ldap scheme
Use display ldap scheme to display LDAP scheme configuration.
display ldap scheme [ ldap-scheme-name ]
ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an LDAP scheme, this command displays the configuration of all LDAP schemes.
# Display the configuration of all LDAP schemes.
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name             : aaa
  Authentication server      : aaa
    IP                       : 1.1.1.1
    Port                     : 111
    VPN instance             : Not configured
    LDAP protocol version    : LDAPv3
    Server timeout interval  : 10 seconds
    Login account DN         : Not configured
    Base DN                  : Not configured
    Search scope             : all-level
    User searching parameters:
      User object class      : Not configured
      Username attribute     : cn
      Username format        : with-domain
  Authorization server       : aaa
    IP                       : 1.1.1.1
    Port                     : 111
  Attribute map              : map1
Table 13 Command output
Name of the LDAP authentication server. If no server is configured, this field displays Not configured.
Name of the LDAP authorization server. If no server is configured, this field displays Not configured.
IP
IP address of the LDAP server. If no server is specified, this field displays Not configured.
Port
Port number of the server. If no port number is specified, this field displays the default port number.
VPN instance
MPLS L3VPN instance to which the LDAP server belongs. If no VPN instance is specified, this field displays Not configured.
LDAP version, LDAPv2 or LDAPv3.
LDAP server timeout period, in seconds.
Login account DN
DN of the administrator.
Base DN
Base DN for user search.
Search scope
User DN search scope, including:
·     all-level—All subdirectories.
·     single-level—Next lower level of subdirectories under the base DN.
User search parameters.
User object class
User object class for user DN search. If no user object class is configured, this field displays Not configured.
Username attribute
User account attribute for login.
Username format
Format for the username sent to the server.
Attribute map
LDAP attribute map used by the scheme. If no LDAP attribute map is used, this field displays Not configured.
ip
Use ip to configure the IP address of the LDAP server.
Use undo ip to restore the default.
ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ip
An LDAP server does not have an IP address.
LDAP server view
ip-address: Specifies the IP address of the LDAP server.
port port-number: Specifies the TCP port number of the LDAP server. The value range for the port-number argument is 1 to 65535, and the default value is 389.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the LDAP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
The LDAP service port configured on the device must be consistent with the service port of the LDAP server.
If you change the IP address and port number of the LDAP server, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the IP address and port number as 192.168.0.10 and 4300 for LDAP server ccc.
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
ldap server
ipv6
Use ipv6 to configure the IPv6 address of the LDAP server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6
An LDAP server does not have an IPv6 address.
LDAP server view
ipv6-address: Specifies the IPv6 address of the LDAP server.
# Specify the IPv6 address and port number as 1:2::3:4 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
ldap server
ldap attribute-map
Use ldap attribute-map to create an LDAP attribute map and enter its view, or enter the view of an existing LDAP attribute map.
Use undo ldap attribute-map to delete an LDAP attribute map.
ldap attribute-map map-name
undo ldap attribute-map map-name
No LDAP attribute maps exist.
map-name: Specifies the name of the LDAP attribute map, a case-insensitive string of 1 to 31 characters.
Execute this command multiple times to create multiple LDAP attribute maps. You can add multiple mapping entries to an LDAP attribute map. Each entry defines the mapping between an LDAP attribute and an AAA attribute.
# Create an LDAP attribute map named map1 and enter LDAP attribute map view.
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
attribute-map
ldap scheme
map
ldap scheme
Use ldap scheme to create an LDAP scheme and enter its view, or enter the view of an existing LDAP scheme.
Use undo ldap scheme to delete an LDAP scheme.
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
No LDAP schemes exist.
ldap-scheme-name: Specifies the LDAP scheme name, a case-insensitive string of 1 to 32 characters.
An LDAP scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 LDAP schemes.
# Create an LDAP scheme named ldap1 and enter LDAP scheme view.
display ldap scheme
ldap server
Use ldap server to create an LDAP server and enter its view, or enter the view of an existing LDAP server.
Use undo ldap server to delete an LDAP server.
ldap server server-name
undo ldap server server-name
No LDAP servers exist.
server-name: Specifies the LDAP server name, a case-insensitive string of 1 to 64 characters.
# Create an LDAP server named ccc and enter LDAP server view.
display ldap scheme
login-dn
Use login-dn to specify the administrator DN.
Use undo login-dn to restore the default.
login-dn dn-string
undo login-dn
No administrator DN is specified.
LDAP server view
dn-string: Specifies the administrator DN for binding with the server, a case-insensitive string of 1 to 255 characters.
The administrator DN specified on the device must be consistent with the administrator DN configured on the LDAP server.
If you change the administrator DN, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the administrator DN as uid=test, ou=people, o=example, c=city for LDAP server ccc.
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
display ldap scheme
login-password
Use login-password to configure the administrator password for binding with the LDAP server during LDAP authentication.
Use undo login-password to restore the default.
login-password { cipher | simple } string
undo login-password
No administrator password is configured.
LDAP server view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 128 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
This command takes effect only after the login-dn command is used.
# Specify the administrator password as abcdefg in plaintext form for LDAP server ccc.
[Sysname-ldap-server-ccc] login-password simple abcdefg
display ldap scheme
login-dn
map
Use map to configure a mapping entry in an LDAP attribute map.
Use undo map to delete the specified mapping entries from the LDAP attribute map.
map ldap-attribute ldap-attribute-name [ prefix prefix-value delimiter delimiter-value ] aaa-attribute user-group
undo map [ ldap-attribute ldap-attribute-name ]
An LDAP attribute map does not contain mapping entries.
ldap-attribute ldap-attribute-name: Specifies an LDAP attribute by its name. The ldap-attribute-name argument is a case-insensitive string of 1 to 63 characters.
prefix prefix-value delimiter delimiter-value: Specifies a partial value string of the LDAP attribute for attribute mapping. The prefix-value argument represents the position where the partial string starts. The prefix is a case-insensitive string of 1 to 7 characters, such as cn=. The delimiter-value argument represents the position where the partial string ends, such as a comma (,). If you do not specify the prefix prefix-value delimiter delimiter-value option, the mapping entry uses the entire value string of the LDAP attribute.
aaa-attribute: Specifies an AAA attribute.
user-group: Specifies the user group attribute.
Because the device ignores unrecognized LDAP attributes, configure the mapping entries to include important LDAP attributes that should not be ignored.
An LDAP attribute can be mapped only to one AAA attribute. Different LDAP attributes can be mapped to the same AAA attribute.
If you do not specify an LDAP attribute for the undo map command, the command deletes all mapping entries from the LDAP attribute map.
# In LDAP attribute map map1, map a partial value string of the LDAP attribute named memberof to AAA attribute named user-group.
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
ldap attribute-map
user-group
protocol-version
Use protocol-version to specify the LDAP version.
Use undo protocol-version to restore the default.
protocol-version { v2 | v3 }
The LDAP version is LDAPv3.
LDAP server view
v2: Specifies the LDAP version LDAPv2.
v3: Specifies the LDAP version LDAPv3.
For successful LDAP authentication, the LDAP version used by the device must be consistent with the version used by the LDAP server.
If you change the LDAP version, the change takes effect only on the LDAP authentication that occurs after the change.
A Microsoft LDAP server supports only LDAPv3.
# Specify the LDAP version as LDAPv2 for LDAP server ccc.
[Sysname-ldap-server-ccc] protocol-version v2
display ldap scheme
search-base-dn
Use search-base-dn to specify the base DN for user search.
Use undo search-base-dn to restore the default.
search-base-dn base-dn
undo search-base-dn
No base DN is specified for user search.
LDAP server view
base-dn: Specifies the base DN for user search, a case-insensitive string of 1 to 255 characters.
# Specify the base DN for user search as dc=ldap,dc=com for LDAP server ccc.
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
display ldap scheme
ldap server
search-scope
Use search-scope to specify the user search scope.
Use undo search-scope to restore the default.
search-scope { all-level | single-level }
undo search-scope
The user search scope is all-level.
LDAP server view
all-level: Specifies that the search goes through all subdirectories of the base DN.
single-level: Specifies that the search goes through only the next lower level of subdirectories under the base DN.
# Specify the search scope for the LDAP authentication as all subdirectories of the base DN for LDAP server ccc.
[Sysname-ldap-server-ccc] search-scope all-level
display ldap scheme
ldap server
server-timeout
Use server-timeout to set the LDAP server timeout period, the maximum time that the device waits for an LDAP response.
Use undo server-timeout to restore the default.
server-timeout time-interval
undo server-timeout
The LDAP server timeout period is 10 seconds.
LDAP server view
time-interval: Specifies the LDAP server timeout period in the range of 5 to 20 seconds.
If you change the LDAP server timeout period, the change takes effect only on the LDAP authentication that occurs after the change.
# Set the LDAP server timeout period to 15 seconds for LDAP server ccc.
[Sysname-ldap-server-ccc] server-timeout 15
display ldap scheme
user-parameters
Use user-parameters to configure LDAP user attributes, including the username attribute, username format, and user-defined user object class.
Use undo user-parameters to restore the default of an LDAP user attribute.
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
The LDAP username attribute is cn and the username format is without-domain. No user object class is specified and the default user object class of the LDAP server is used.
LDAP server view
user-name-attribute { name-attribute | cn | uid }: Specifies the username attribute. The name-attribute argument represents an attribute value, a case-insensitive string of 1 to 64 characters. The cn keyword represents the user account attribute of common name, and the uid keyword represents the user account attribute of user ID.
user-name-format { with-domain | without-domain }: Specifies the format of the username to be sent to the server. The with-domain keyword means that the username contains the domain name, and the without-domain keyword means that the username does not contain the domain name.
user-object-class object-class-name: Specifies the user object class for user search. The object-class-name argument represents a class value, a case-insensitive string of 1 to 64 characters.
If the username on the LDAP server does not contain the domain name, specify the without-domain keyword. If the username contains the domain name, specify the with-domain keyword.
# Set the user object class to person for LDAP server ccc.
[Sysname-ldap-server-ccc] user-parameters user-object-class person
display ldap scheme
login-dn
