04-Policies
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W60004-Policies
25-Server connection detection
25-Server connection detection 99.27 KB
This help contains the following topics:
·     Introduction
·     Configure SCD
¡     Configure SCD learning
¡     Configure an SCD policy
Introduction
Server connection detection (SCD) enables the device to identify and classify legal and illegal connections initiated by given servers based on user-defined rules. This helps the administrators to monitor internal servers and prevent them from becoming part of a botnet and launching attacks or performing internal network penetration.
Configure SCD
SCD configuration involves the following tasks:
·     Configure SCD learning—Configure the device to learn connections initiated by given servers. The learning results provide the basis for administrators to create SCD policies to monitor and log illegal connections initiated by the servers.
·     Configure SCD policies—Create an SCD policy for a server and configure SCD rules to define the legal connections initiated by the server. The device can then log connections initiated by the server that do not match the SCD rules.
Perform this task to enable the device to learn connections initiated by given servers.
1.     Click the Policies tab.
2.     In the navigation pane, select Server Connection Detection.
3.     Click the SCD Learning tab.
4.     Enter the IP addresses of the servers for server-initiated connection learning and set the learning period.
5.     Click Start.
The device starts to learn the connections initiated by the specified servers for the specified learning period and displays the learning results in a list.
6.     To set a server-initiated connection as a legal connection, select the connection and click Create SCD rule.
The device automatically creates an SCD policy for the server and creates an SCD rule for the selected server connection in the policy.
Perform this task to create an SCD policy.
3.     Click the SCD Policy tab.
4.     Click Create.
5.     Create an SCD policy.
Table 1 SCD policy configuration items
Item
Policy name
Enter a name for the SCD policy.
Server address
Enter a server IP address. The SCD policy will monitor connections initiated by the server.
Enable policy
Select whether to enable the SCD policy.
Logging
Select whether to log connections initiated by the server that do not match any SCD rules.
SCD rules
Each SCD rule defines a set of legal connections initiated by the server. Connections initiated by the server that do not match any SCD rules are considered illegal.
To create an SCD rule:
1.     Click Create.
2.     Enter the destination IP address for the connections.
3.     Set the protocols and port numbers for the connections.
·     A minimum of one protocol must be configured for an SCD rule.
4.     Click OK.
