17-EVPN Configuration Guide
HomeSupportSwitchesS6550XE-HI SeriesConfigure & DeployConfiguration GuidesH3C S6550XE-HI & S6525XE-HI Switch Series Configuration Guides-R60xx-6W10017-EVPN Configuration Guide
05-MVXLAN configuration
05-MVXLAN configuration 979.03 KB
MVXLAN overview·· 1
Restrictions: Underlay network restriction· 1
MVXLAN modes· 1
Ingress replication MVXLAN· 1
Network model 1
Working mechanism·· 2
MDT MVXLAN· 3
Benefits· 3
Network model 3
Basic concepts· 3
MP-BGP extension for MVXLAN· 4
Automatic MVXLAN tunnel establishment and assignment 4
Default MDT establishment 4
Default MDT-based transmission· 5
MDT switchover 6
Layer 3 multicast in DCI scenarios· 7
Configuring ingress replication MVXLAN·· 10
Restrictions and guidelines: Multicast source location· 10
Ingress replication MVXLAN tasks at a glance· 10
Enabling IP multicast routing for a VPN instance· 10
Creating an MVXLAN· 11
Configuring a VSI interface as a distributed DR interface· 11
Ingress replication MVXLAN configuration examples· 12
Example: Configuring an ingress replication MVXLAN· 12
Configuring MDT-based MVXLAN·· 17
Restrictions and guidelines: MDT-based MVXLAN configuration· 17
MDT-based MVXLAN tasks at a glance· 17
Enabling IP multicast routing for a VPN instance· 18
Creating an MVXLAN· 18
Configuring a default group· 18
Specifying the MVXLAN source interface· 19
Configuring MDT switchover parameters· 19
Configuring a VSI interface as a distributed DR interface· 20
Configuring an MVXLAN extranet RPF selection policy· 20
Configuring DCI Layer 3 multicast 22
About this task· 22
Restrictions and guidelines· 22
Configuring an ED·· 22
Configuring a VTEP· 23
Display and maintenance commands for MDT-based MVXLAN· 23
MDT-based MVXLAN configuration examples· 24
Example: Configuring intra-VPN MVXLAN Layer 3 multicast forwarding· 24
Example: Configuring MVXLAN extranet on the receiver VPN instance for symmetrically configured extranet 36
Example: Configuring MVXLAN extranet on the receiver VPN instance for asymmetrically configured extranet 50
Example: Configuring MVXLAN extranet on the source VPN instance for asymmetrically configured extranet 64
Example: Configuring MVXLAN extranet on the multicast source-side border node of an MVXLAN network  77
Example: Configuring MVXLAN extranet with receivers on both VPNs and the public network· 91
Example: Configuring DCI Layer 3 multicast without L3 VXLAN ID mapping· 104
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to the same intermediate L3 VXLAN ID·· 119
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to different intermediate L3 VXLAN IDs· 142
MVXLAN overview
Multicast VXLAN (MVXLAN) transmits multicast traffic from a multicast source to multicast receivers in a VXLAN or EVPN VXLAN network.
The device supports only the following MVXLAN configuration methods:
·     Configure only Layer 2 multicast on all VSIs.
·     Configure both Layer 2 multicast and Layer 3 multicast on all VSIs.
ACs do not support the Ethernet access mode when you map them to VSIs by using the xconnect vsi command. For more information about this command, see VXLAN Command Reference.
ACs do not support the encapsulation s-vid { vlan-id | vlan-id-list } c-vid { vlan-id-list | all } criterion.
MVXLAN supports only IPv4 underlay networks in the current software version.
MVXLAN modes
MVXLAN supports the following traffic transmission modes:
·     Ingress replication—Used for forwarding multicast traffic of multiple VPN instances in a VXLAN network.
·     Multicast distribution tree (MDT)—Used for forwarding multicast traffic in an EVPN VXLAN network.
Network model
Figure 1 shows a typical MVXLAN network that uses ingress replication. In the network, the border device is attached to multiple sources, and the VTEPs are attached to multicast receivers. VXLAN tunnels are manually established between the border device and the VTEPs and assigned to VXLANs. When receiving multicast packets, the border device identifies the VPN instance to which the packets belong and forwards them to the VTEPs configured with the VPN instance. Then, the VTEPs forward the multicast packets to the attached multicast receivers in the VPN instance.
Figure 1 Ingress replication MVXLAN network model
Working mechanism
Ingress replication MVXLAN requires the following configuration on the border device and VTEPs:
·     On the border device, create VSI interfaces, associate them with VPN instances, and enable IGMP on the VSI interfaces.
·     On the border device, associate the multicast source-facing interfaces with VPN instances.
·     On the border device and VTEPs, enable IGMP snooping on VSIs.
The border device and VTEPs learn multicast forwarding entries as follows:
1.     On the border device, VSI interfaces broadcast IGMP queries in their respective VXLANs after they are enabled with IGMP.
2.     The VTEPs mark the VXLAN tunnel interfaces where the IGMP queries are received as IGMP snooping router ports, remove VXLAN encapsulation from the IGMP queries, and forward them to local hosts.
3.     Multicast receivers reply with IGMP membership reports.
4.     The VTEPs mark the ACs where the IGMP membership reports are received as IGMP snooping member ports and forward the reports to the border device through VXLAN tunnels.
5.     The border device receives the IGMP membership reports on a VXLAN tunnel interface and marks the VXLAN tunnel interface as an IGMP snooping member port.
Having learned multicast forwarding entries, the border device and VTEPs forward multicast traffic as follows:
1.     When receiving multicast packets, the border device identifies their VPN instance by the incoming interface and forwards them based on the multicast forwarding table of the VPN instance.
2.     If the traffic outgoing interface is a VSI interface, the border device forwards the multicast packets through the IGMP snooping member ports in the VXLAN associated with the VSI interface. The IGMP snooping member ports are VXLAN tunnel interfaces.
3.     The VTEPs decapsulate the multicast packets and forward them out of member ports to multicast receivers.
MDT MVXLAN
On the public network, MVXLAN multicast traffic is forwarded along an MDT rooted at the multicast source-side VTEP to leaf receiver-side VTEPs through unidirectional MVXLAN tunnels. MDT-based transmission ensures that multicast traffic is forwarded along optimal paths.
Benefits
MDT MVXLAN provides the following benefits:
·     On-demand multicast forwarding—Creates multicast distribution trees and manages multicast group members by using BGP EVPN routes and PIM.
·     Inter-VXLAN multicast forwarding—Uses distributed EVPN gateways to forward Layer 3 multicast traffic between VXLANs.
Network model
As shown in Figure 2, distributed EVPN gateways are collocated with the VTEPs, and MVXLANs are created on the VTEPs to direct multicast traffic forwarding. When receiving multicast packets, a VTEP forwards them through ACs and MVXLAN tunnels to multicast receivers.
For more information about VTEPs, VSIs, and VXLANs, see VXLAN Configuration Guide. For more information about EVPN configuration, see "Configuring EVPN."
Figure 2 MDT MVXLAN network model
Basic concepts
The following are the basic concepts in MVXLAN:
·     MDT—An MDT is a multicast distribution tree constructed by all VTEPs in the same MVXLAN. MDTs include the default MDT and the data MDT.
·     Default group—A default group is a unique multicast address assigned to each MVXLAN on the public network. It is the unique identifier of an MVXLAN on the public network and helps build the default MDT for an MVXLAN on the public network. Packets of the private multicast groups in an MVXLAN are encapsulated into packets of the default group before they are transmitted on the public network.
·     Default MDT—A default MDT uses a default group address as its group address. The default MDT of an MVXLAN is uniquely identified by the default group and transmits all private multicast packets of the MVXLAN. A default MDT is automatically created after the default group is specified and will always exist on the public network, regardless of whether multicast services exist on the public network or MVXLAN.
·     Data MDT—A data MDT is an MDT that uses a data group as it group address. At MDT switchover, VTEPs with downstream receivers join a data group to build a data MDT. The ingress VTEP forwards the encapsulated MVXLAN multicast traffic along the data MDT over the public network.
To support MVXLAN, MP-BGP introduces the following routes for creating MDTs under the EVPN address family:
·     Supplementary broadcast domain selective multicast Ethernet tag (SBD-SMET) route—Contains private multicast source address and private multicast group address information. A receiver-side VTEP uses the SBD-SMET route to advertise its interest in a specific (*, G) or (S, G). An SBD-SMET route carries the RD configured in VPN instance view and export targets configured in VPN instance IPv4 address family view.
·     Selective provider multicast service interface route—Also known as S-PMSI A-D route. An S-PMSI A-D route contains the private multicast source address, private multicast group address, default or data group address, and MVXLAN source interface address. S-PMSI A-D routes are used by the multicast source-side VTEP and its BGP peers to establish the default MDT and switch traffic from the default MDT to a data MDT. An S-PMSI A-D route carries the RD configured in VPN instance view and export targets configured in VPN instance IPv4 address family view.
In an MVXLAN network, VTEPs automatically establish MVXLAN tunnels and assign them to MVXLANs to forward Layer 3 multicast traffic. The tunnel source is the MVXLAN source interface address, and the tunnel destination is the default or data group address. An MVXLAN tunnel is a unidirectional tunnel from the multicast source-side VTEP to a multicast receiver-side VTEP.
The multicast routing protocol running on the public network can be PIM-SM or PIM-SSM. The process of creating a default MDT is the same in these PIM modes. All VTEPs in an MVXLAN join the default MDT of the MVXLAN. The private multicast packets of the MVXLAN are forwarded along the default MDT to the VTEPs, no matter whether the site attached to a VTEP contains receivers.
Figure 3 Default MDT establishment in a PIM-SM network
As shown in Figure 3, PIM-SM runs on the public network, and MVXLAN is configured on all VTEPs. The process for establishing a default MDT is as follows:
1.     VTEP 1 sends an S-PMSI A-D route that contains (*, *) to VTEP 2 and VTEP 3.
2.     VTEP 2 and VTEP 3 receive the route and join a multicast group according to the PMSI tunnel attribute of the route. The PMSI tunnel attribute contains the following information:
¡     The multicast source is the IP address of the MVXLAN source interface on VTEP 1.
¡     The multicast group is the default group configured on VTEP 1.
3.     Multicast forwarding entries are created on each device along the paths on the public network, and a shortest path tree (SPT) with VTEP 1 as the root and VTEP 2 and VTEP 3 as leaves is created. The SPT is the default MDT.
After the default MDT is established, the multicast source sends the private multicast traffic to the receivers in each site along the default MDT. The private multicast packets are encapsulated into public multicast packets on the local VTEP and transmitted along the default MDT. Then, they are decapsulated on the remote VTEPs and transmitted in remote VXLAN sites.
Figure 4 Multicast data packet transmission
As shown in Figure 4, PIM-SM runs on the public network, the multicast source is attached to VTEP 1, and the multicast receiver is attached to VTEP 2. The multicast forwarding process is as follows:
1.     The multicast source sends private multicast packets (192.1.1.1, 225.1.1.1) to VTEP 1.
2.     VTEP 1 creates a multicast forwarding entry for (192.1.1.1, 225.1.1.1).
3.     VTEP 1 processes the packets based on whether the receiver has joined the private multicast group:
¡     If the receiver has sent an IGMP join message to VTEP 2, VTEP 1 has an SBD-SMET route sent by VTEP 1 that contains (*, G). VTEP 1 adds VXLAN encapsulation to the packets according to the route and forwards them to VTEP 2 and VTEP 3 along the default MDT. In the outer IP header of the VXLAN packets, the source IP address is the IP address of the MVXLAN source interface, and the destination IP address is the default group address.
¡     If no receiver exists, VTEP 1 drops the packets.
4.     VTEP 2 decapsulates the VXLAN packets and forwards the private multicast packets to the receiver.
5.     VTEP 3 decapsulates the VXLAN packets and drops the private multicast packets because no local receiver exists.
MDT switchover
An MVXLAN can use the default MDT or a data MDT for multicast traffic forwarding. The default MDT is uniquely identified by the default group, and a data MDT is uniquely identified by a data group. Each default group is associated with a data group range.
Switching from the default MDT to a data MDT
When a multicast packet of an MVXLAN is transmitted through the default MDT on the public network, the packet is forwarded to all VTEPs configured with the VPN instance of the MVXLAN. This occurs whether or not any active receivers exist in the sites attached to the VTEPs. When the rate of the multicast traffic of that MVXLAN is high, multicast traffic might be flooded on the public network. This increases the bandwidth use and brings extra burden on the VTEPs.
To optimize multicast transmission, the MDT-based MVXLAN solution introduces a dedicated data MDT. The data MDT is built between the VTEPs that are attached to MVXLAN multicast receivers and multicast sources. When specific network criteria are met, multicast traffic is switched from the default MDT to the data MDT.
A switchover from the default MDT to the data MDT is initiated as follows:
1.     The source-side VTEP periodically examines MVXLAN multicast traffic. The default MDT switches to the data MDT if the private multicast traffic has passed the ACL rule filtering for default MDT to data MDT switchover.
2.     The source-side VTEP selects a least-used address from the data group range and sends an S-PMSI A-D route to all the other VTEPs down the default MDT. This route contains the private multicast source address, private multicast group address, IP address of the MVXLAN source interface, and data group address.
3.     Each VTEP that receives the route examines whether it has receivers of that private multicast stream.
If so, it joins the data MDT rooted at the source-side VTEP. Otherwise, it caches the route and will join the data MDT when it has attached receivers.
4.     After sending the S-PMSI A-D route, the source-side VTEP starts the data-delay timer. When the timer expires, the source-side VTEP uses the data group address to encapsulate the private multicast traffic. The multicast traffic is then forwarded down the data MDT.
5.     After the multicast traffic is switched from the default MDT to the data MDT, a downstream VTEP can leave the data MDT by sending a PIM prune message if it no longer has active receivers attached to it.
Switching from the data MDT to the default MDT
After the MXVLAN multicast traffic is switched to the data MDT, the multicast traffic conditions might change and no longer meet the switchover criterion. In this case, the source-side VTEP initiates a backward MDT switchover process when any of the following criteria are met:
·     The associated data group range is changed, and the data group address for encapsulating the MVXLAN multicast traffic is not in the new address range.
·     The ACL rule for controlling the switchover from the default MDT to the data MDT has changed, and the MVXLAN multicast traffic fails to pass the new ACL rule.
Features
DCI Layer 3 multicast in an MDT-based MVXLAN network has the following features:
·     On-demand multicast forwarding—An ED forwards multicast traffic over VXLAN-DCI tunnels only when it detects multicast receivers in remote data centers through BGP EVPN routes.
·     Inter-L3 VXLAN ID multicast forwarding—You can configure L3 VXLAN ID mappings on EDs to enable inter-data center multicast for a VPN instance that uses different L3 VXLAN IDs at multiple data centers.
Working mechanism
As shown in Figure 5, inter-data center Layer 3 multicast traffic is forwarded through the VXLAN-DCI tunnels set up among EDs.
An ED operates as follows after receiving SBD-SMET and S-PMSI A-D routes from a remote ED:
·     For an SBD-SMET route, the ED finds a VXLAN-DCI tunnel interface based on the nexthop for the route and uses the interface as the outgoing interface for multicast traffic.
·     For an S-PMSI A-D route, the ED replaces the multicast source address in the PMSI tunnel attribute of the route with the address of the local MVXLAN source interface. Then, a default-MDT or data-MDT with the ED as the multicast source is set up in the local data center.
Within a data center, EDs and VTEPs advertise BGP EVPN routes and set up MVXLAN tunnels in the same way they do in a non-DCI environment.
As shown in Figure 5, after BGP EVPN route advertisement and tunnel setup are finished, VTEPs and EDs forward traffic as follows:
1.     When VTEP 1 receives multicast traffic in a VPN, it forwards the traffic over MVXLAN tunnels to local VTEPs and ED in the VPN.
2.     VTEP 2 forwards the multicast traffic to the attached receivers, and ED 1 forwards the multicast traffic over the VXLAN-DCI tunnel to DC 2.
3.     ED 3 forwards the multicast traffic to VTEP 3, and VTEP 3 forwards the multicast traffic to the attached receiver.
Figure 5 Network model for DCI Layer 3 multicast in an MDT-based MVXLAN network
L3 VXLAN ID mapping
If a VPN instance uses different L3 VXLAN IDs at two data centers, perform the following tasks for multicast traffic of the VPN instance to be transmitted between the data centers:
1.     Create an intermediate VPN instance on both EDs.
2.     Configure L3 VXLAN ID mappings on the EDs and associate the non-local L3 VXLAN ID in the mapping with the intermediate VPN instance. You can map L3 VXLAN IDs by using one of the following methods
¡     On each ED, map the local L3 VXLAN ID to an intermediate L3 VXLAN ID. The following is an example of intermediate L3 VXLAN ID mapping:
Data center
ED
Local L3 VXLAN ID
Mapped L3 VXLAN ID
DC 1
ED 1
1
12
DC 2
ED 2
2
12
¡     On each ED, map the local L3 VXLAN ID to the remote L3 VXLAN ID. The following is an example of non-intermediate L3 VXLAN ID mapping:
Data center
ED
Local L3 VXLAN ID
Mapped L3 VXLAN ID
DC 1
ED 1
10
20
DC 2
ED 2
20
10
3.     Configure VTEPs and EDs to reoriginate S-PMSI and SMET routes and modify the RDs, route targets, and L3 VXLAN ID in the routes.
As shown in Figure 6, DC 1 uses L3 VXLAN ID 1, and DC 2 uses L3 VXLAN ID 2. Both L3 VXLAN IDs are mapped to L3 VXLAN ID 12 on the EDs. The multicast forwarding entry learning and multicast forwarding processes are as follows:
1.     After the default group is configured on VTEP 3, VTEP 3 advertises an S-PMSI route that carries the (*, *) entry and L3 VXLAN ID 2.
2.     ED 2 receives the S-PMSI route and imports it to the local VPN instance and intermediate VPN instance. ED 2 then reoriginates an S-PMSI route with the intermediate L3 VXLAN ID included for the intermediate VPN instance and advertises it to ED 1.
3.     ED 1 receives the S-PMSI route and imports it to the local VPN instance and intermediate VPN instance. ED 1 then reoriginates an S-PMSI route for the local VPN instance and advertises it to VTEP 1 and VTEP 2.
4.     Receiver 3 sends an IGMP membership report to join the multicast group.
5.     VTEP 3 creates a (*, G) entry and advertises an SMET route for the multicast group.
6.     ED 2 performs the following actions after receiving the SMET route:
a.     Imports it to the local VPN instance and intermediate VPN instance.
b.     Reoriginates an SMET route for the intermediate VPN instance and advertises it to ED 1.
c.     Creates a (*, G) entry for the local VPN instance.
7.     ED 1 performs the following actions after receiving the SMET route:
b.     Reoriginates an SMET route for the local VPN instance and advertises it to VTEP 1 and VTEP 2.
c.     Creates a (*, G) entry with a VSI interface as the outgoing interface for the intermediate VPN instance.
8.     VTEP 1 and VTEP 2 receive the SMET route, import it to the local VPN instance, and create a (*, G) entry.
9.     When VTEP 1 receives multicast traffic, it advertises an S-PMSI route that carries default group information and (S, G) multicast source information.
10.     ED 1 receives the S-PMSI route, reoriginates an S-PMSI route, and creates the following entries:
¡     A (S, G) entry for the local VPN instance, in which the intermediate VPN instance is the outgoing interface.
¡     A (S, G) entry for the intermediate VPN instance, in which the local VPN instance is the incoming interface and a VSI interface is the outgoing interface. The traffic sent out of the VSI interface is forwarded through a VXLAN-DCI tunnel interface.
11.     ED 2 receives the S-PMSI route, reoriginates an S-PMSI route, and creates the following entries:
¡     A (S, G) entry for the intermediate VPN instance, in which a VSI interface is the incoming interface and the local VPN instance is the outgoing interface.
¡     A (S, G) entry for the local VPN instance, in which the intermediate VPN instance is the incoming interface and an MTunnel interface is the outgoing interface.
12.     After the multicast source sends multicast traffic, the VTEPs and EDs forward the traffic based on the learned multicast forwarding entries.
Figure 6 L3 VXLAN ID mapping
You can attach a multicast source only to a border device in an ingress replication MVXLAN network.
To configure ingress replication MVXLAN, perform the following tasks:
1.     Configuring VXLAN
a.     Configuring a VXLAN on a VSI
b.     Configuring a VXLAN tunnel
c.     Manually assigning VXLAN tunnels to a VXLAN
d.     Assigning customer frames to a VSI
For more information about VXLAN configuration, see VXLAN Configuration Guide.
2.     Configuring IGMP and IGMP snooping
a.     Enabling IGMP on a VSI interface on a border device
b.     Enabling IGMP snooping on a VSI on a border device or VTEP
For more information about IGMP and IGMP snooping configuration, see IP Multicast Configuration Guide.
3.     Configuring a VPN instance
a.     Creating a VPN instance
b.     Associating a VSI interface with a multicast source-facing interface on a border device
For more information about VPN instance configuration, see MPLS L3VPN configuration in MPLS Configuration Guide.
4.     Configuring MVXLAN
a.     Enabling IP multicast routing for a VPN instance
b.     Creating an MVXLAN
c.     Configuring a VSI interface as a distributed DR interface
You must perform this task on a VTEP if the VTEP acts as a distributed VXLAN IP gateway.
2.     Enable IP multicast routing for a VPN instance and enter MRIB view.
multicast routing vpn-instance instance-name
By default, IP multicast routing is disabled for VPN instances.
For more information about this command, see multicast routing and forwarding commands in IP Multicast Command Reference.
Creating an MVXLAN
You can create one or multiple ingress replication MVXLANs on a VTEP to provide services for different VPN instances and the public instance.
Creating an MVXLAN for a VPN instance
2.     Create an ingress replication MVXLAN and enter MVXLAN view.
multicast-vpn vxlan vpn-instance instance-name mode ingress-replication
3.     Create the MVXLAN IPv4 address family and enter its view.
address-family ipv4
Creating an MVXLAN for the public instance
multicast-vpn vxlan public-instance mode ingress-replication
address-family ipv4
On the VTEPs configured with MVXLAN, you must specify the VSI interfaces that act as distributed EVPN gateways as distributed designated router (DR) interfaces. This operation ensures that a distributed EVPN gateway can forward multicast traffic to the local site.
2.     Enter VSI interface view.
interface vsi-interface interface-number
3.     Configure the VSI interface as a distributed DR interface.
pim distributed-dr
By default, a VSI interface is not a distributed DR interface.
As shown in Figure 7, the border device is attached to a multicast source in VPN A. Configure an ingress replication MVXLAN to forward the multicast traffic from the source to the receivers, and configure VTEP 1 as a centralized VXLAN IP gateway.
Figure 7 Network diagram
1.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 7. (Details not shown.)
# Configure OSPF on the border device and VTEPs for them to reach one another. (Details not shown.)
2.     Configure the border device:
# Enable L2VPN and IGMP snooping.
<Border> system-view
[Border] l2vpn enable
[Border] igmp-snooping
[Border-igmp-snooping] quit
# Enable IP multicast routing.
[Border] multicast routing vpn-instance vpna
[Border-mrib] quit
# Set up VXLAN tunnels to the VTEPs.
[Border] interface tunnel 1 mode vxlan
[Border-Tunnel1] source 2.2.2.2
[Border-Tunnel1] destination 1.1.1.1
[Border-Tunnel1] quit
[Border] interface tunnel 2 mode vxlan
[Border-Tunnel2] source 2.2.2.2
[Border-Tunnel2] destination 3.3.3.3
[Border-Tunnel2] quit
# Create VSI vpna and VXLAN 10, and enable IGMP snooping on VSI vpna.
[Border] vsi vpna
[Border-vsi-vpna] igmp-snooping enable
[Border-vsi-vpna] vxlan 10
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[Border-vsi-vpna-vxlan-10] tunnel 1
[Border-vsi-vpna-vxlan-10] tunnel 2
[Border-vsi-vpna-vxlan-10] quit
[Border-vsi-vpna] quit
# Create VPN instance vpna.
[Border] ip vpn-instance vpna
[Border-vpn-instance-vpna] quit
# Configure VSI-interface 1, associate it with VPN instance vpna, and enable IGMP on it.
[Border] interface vsi-interface vsi 1
[Border-Vsi-interface] ip binding vpn-instance vpna
[Border-Vsi-interface] ip address 100.1.1.2 255.255.255.0
[Border-Vsi-interface] igmp enable
[Border-Vsi-interface] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[VTEP1] vsi vpna
[VTEP1-vsi-vpna] gateway vsi-interface 1
[VTEP1-vsi-vpna] quit
# Associate multicast source-facing interface VLAN-interface 30 with VPN instance vpna, and enable PIM SM on VLAN-interface 30.
[Border] interface vlan-interface 30
[Border-Vlan-interface30] ip binding vpn-instance vpna
[Border-Vlan-interface30] ip address 100.2.2.2 255.255.255.0
[Border-Vlan-interface30] pim sm
[Border-Vlan-interface30] quit
# Create an ingress replication MVXLAN, and create the MVXLAN IPv4 address family and enter its view.
[Border] multicast-vpn vxlan vpn-instance vpna mode ingress-replication
[Border-mvxlan-vpna] address-family ipv4
3.     Configure VTEP 1:
<VTEP1> system-view
[VTEP1] l2vpn enable
[VTEP1] igmp-snooping
[VTEP1-igmp-snooping] quit
# Set up a VXLAN tunnel to the border device.
[VTEP1] interface tunnel 2 mode vxlan
[VTEP1-Tunnel2] source 1.1.1.1
[VTEP1-Tunnel2] destination 2.2.2.2
[VTEP1-Tunnel2] quit
[VTEP1] vsi vpna
[VTEP1-vsi-vpna] igmp-snooping enable
[VTEP1-vsi-vpna] vxlan 10
# Assign Tunnel 2 to VXLAN 10.
[VTEP1-vsi-vpna-vxlan-10] tunnel 2
[VTEP1-vsi-vpna-vxlan-10] quit
# On Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2, create Ethernet service instance 1000 to match VLAN 2 and map Ethernet service instance 1000 to VSI vpna.
[VTEP1] interface twenty-fivegige 1/0/1
[VTEP1-Twenty-FiveGigE1/0/1] service-instance 1000
[VTEP1-Twenty-FiveGigE1/0/1-srv1000] encapsulation s-vid 2
[VTEP1-Twenty-FiveGigE1/0/1-srv1000] xconnect vsi vpna
[VTEP1-Twenty-FiveGigE1/0/1-srv1000] quit
[VTEP1-Twenty-FiveGigE1/0/1] quit
[VTEP1] interface twenty-fivegige 1/0/2
[VTEP1-Twenty-FiveGigE1/0/2] service-instance 1000
[VTEP1-Twenty-FiveGigE1/0/2-srv1000] encapsulation s-vid 2
[VTEP1-Twenty-FiveGigE1/0/2-srv1000] xconnect vsi vpna
[VTEP1-Twenty-FiveGigE1/0/2-srv1000] quit
[VTEP1-Twenty-FiveGigE1/0/2] quit
4.     Configuring VTEP 2:
<VTEP2> system-view
[VTEP2] l2vpn enable
[VTEP2] igmp-snooping
[VTEP2-igmp-snooping] quit
[VTEP2] interface tunnel 2 mode vxlan
[VTEP2-Tunnel2] source 3.3.3.3
[VTEP2-Tunnel2] destination 2.2.2.2
[VTEP2-Tunnel2] quit
[VTEP2] vsi vpna
[VTEP2-vsi-vpna] igmp-snooping enable
[VTEP2-vsi-vpna] vxlan 10
[VTEP2-vsi-vpna-vxlan-10] tunnel 2
[VTEP2-vsi-vpna-vxlan-10] quit
[VTEP2-vsi-vpna] quit
[VTEP2] interface twenty-fivegige 1/0/1
[VTEP2-Twenty-FiveGigE1/0/1] service-instance 1000
[VTEP2-Twenty-FiveGigE1/0/1-srv1000] encapsulation s-vid 2
[VTEP2-Twenty-FiveGigE1/0/1-srv1000] xconnect vsi vpna
[VTEP2-Twenty-FiveGigE1/0/1-srv1000] quit
[VTEP2-Twenty-FiveGigE1/0/1] quit
[VTEP2] interface twenty-fivegige 1/0/2
[VTEP2-Twenty-FiveGigE1/0/2] service-instance 1000
[VTEP2-Twenty-FiveGigE1/0/2-srv1000] encapsulation s-vid 2
[VTEP2-Twenty-FiveGigE1/0/2-srv1000] xconnect vsi vpna
[VTEP2-Twenty-FiveGigE1/0/2-srv1000] quit
[VTEP2-Twenty-FiveGigE1/0/2] quit
1.     Verify the MVXLAN settings on the border device:
# Verify that the VXLAN tunnel interfaces are up on the border device.
[Border] display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 2.2.2.2, destination 1.1.1.1
# Verify that VSI-interface 1 is up.
[Border] display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi1                  UP    UP        10.1.1.1
# Verify that the border device has multicast routing entries.
[Border] display pim vpn-instance vpna routing-table
Total 17 (*, G) entries; 18 (S, G) entries
(10.1.2.99, 225.0.1.1)
     RP: 10.1.2.88 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT 2MVPN
     UpTime: 21:24:27
     Upstream interface: Vlan-interface30
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 07:08:26, Expires: -
2.     Verify the MVXLAN settings on VTEP 1:
# Verify that the interfaces that host ACs are member ports.
[VTEP1] display igmp-snooping group
Total 1 entries.
VSI vpna: Total 1 entries.
  (0.0.0.0, 225.0.1.1)
    Host ports (1 in total):
      WGE1/0/1 (Link ID 0)                        (00:04:20)
      WGE1/0/2 (Link ID 1)                        (00:04:20)
# Verify that Tunnel 2 is a router port.
[VTEP1] display igmp-snooping router-port
VSI vpna:
  Router ports (1 in total):
    Tun2 (VXLAN ID 10)                            (00:03:23)
3.     Verify that the multicast receivers can receive the multicast traffic sent by the multicast source. (Details not shown.)
MDT-based MVXLAN is not supported for a multicast source if the following conditions exist:
·     The upstream interface in the multicast entry is a multicast tunnel.
·     The downstream interface list contains more than two interfaces.
To display multicast entries, use the display multicast routing-table command.
To configure MDT-based MVXLAN, perform the following tasks:
1.     Configuring EVPN
b.     Mapping ACs to a VSI
c.     Configuring an EVPN instance
d.     Configuring BGP to advertise BGP EVPN routes
e.     Configuring a distributed EVPN gateway
c.     Configuring IGMP snooping proxying
3.     Configuring PIM on the transport-facing interfaces of VTEPs
¡     Configuring PIM-SM
¡     Configuring PIM-SSM
For more information about PIM configuration, see IP Multicast Configuration Guide.
c.     Configuring a default group
d.     Specifying the MVXLAN source interface
e.     Configuring MDT switchover parameters
f.     Configuring a VSI interface as a distributed DR interface
g.     Configuring an MVXLAN extranet RPF selection policy
h.
Creating an MVXLAN
You can create one or multiple MDT-based MVXLANs on a VTEP to provide services for different VPN instances and the public instance.
2.     Create an MDT-based MVXLAN and enter MVXLAN view.
multicast-vpn vxlan vpn-instance instance-name mode mdt
multicast-vpn vxlan public-instance mode mdt
When adding VXLAN encapsulation to private multicast packets, the VTEP uses the default group as the destination IP address in the outer IP header.
The default group address of an MVXLAN must be unique among MVXLANs, and it cannot be the same as a data group address of any MVXLAN.
2.     Enter MVXLAN view.
address-family ipv4
4.     Configure the default group.
default-group group-address
By default, no default group exists.
When adding VXLAN encapsulation to private multicast packets, the VTEP uses the IP address of the MVXLAN source interface as the source IP address in the outer IP header.
You must configure the same MVXLAN source interface for all MVXLAN instances on the device.
For the VTEP to obtain correct routing information, you must specify the interface used for establishing BGP peer relationships as the MVXLAN source interface.
3.     Enter MVXLAN IPv4 address family view.
address-family ipv4
4.     Specify the MVXLAN source interface.
source interface-type interface-number
By default, no MVXLAN source interface is specified.
On a VTEP, the data group range of an MVXLAN cannot include the default group or data groups of any other MVXLAN.
All VPN instances share the data group resources. As a best practice to avoid data group resource exhaustion, specify a reasonable data group range for a VPN instance.
address-family ipv4
4.     Configure the data group range and the switchover criteria.
data-group group-address { mask-length | mask } [ { acl acl-number | name acl-name } | threshold threshold-value ] *
By default, no data group range exists, and the default MDT to data MDT switchover never occurs.
5.     Set the data-delay period.
data-delay delay
By default, the data-delay period is 3 seconds.
pim distributed-dr
A VSI instance is not a distributed DR interface.
MVXLAN extranet RPF routing policies are used for multicast transmission when multicast sources and receivers are located in different VPNs.
MVXLAN extranet RPF selection policies identify the multicast traffic to forward between VPN instances based on the L3 VXLAN ID or VPN instance of traffic.
·     L3 VXLAN ID-based RPF selection policy—A policy of this kind specifies the L3 VXLAN ID of the VPN instance where a multicast source resides, a multicast source address, and a multicast group address.
A multicast source-side VTEP matches the L3 VXLAN ID, multicast source address, and multicast group address in multicast packets with RPF selection policies. If a match is found, the VTEP forwards the packets to the receiver VPN instance.
With RPF selection policies configured, a multicast receiver-side VTEP forwards multicast traffic as follows:
a.     Removes the VXLAN header added by the multicast source-side VTEP from received multicast packets. The VXLAN header includes the L3 VXLAN ID of the source VPN instance.
b.     Matches the L3 VXLAN ID, multicast source address, and multicast group address of the packets with RPF selection policies.
c.     Forwards the packets in the receiver VPN instance if a match is found.
·     VPN instance-based RPF selection policy—A policy of this kind specifies the VPN instance where a multicast source resides, a multicast source address, and a multicast group address.
A multicast source-side VTEP matches the VPN instance, multicast source address, and multicast group address in multicast packets with RPF selection policies. If a match is found, the VTEP forwards the packets to the receiver VPN instance.
b.     Matches the VPN instance, multicast source address, and multicast group address of the packets with RPF selection policies.
You can use RPF selection policies on the following networks:
·     Asymmetrically configured extranet—The source VPN instance is not configured on the multicast receiver-side VTEP.
¡     On the multicast source-side VTEP, you can configure either L3 VXLAN ID-based or VPN instance-based RPF selection policies.
¡     On the multicast receiver-side VTEP, you can configure only L3 VXLAN ID-based RPF selection policies.
·     Symmetrically configured extranet—The source VPN instance is configured on the multicast receiver-side VTEP. You can configure either L3 VXLAN ID-based or VPN instance-based RPF selection policies on the multicast source-side and receiver-side VTEPs.
If some of the multicast receivers reside on the public network, specify only the multicast source address and multicast group address in the related RPF selection policies. On the multicast receiver-side VTEP, perform the following tasks for the VTEP to forward multicast traffic in both the receiver VPN instance and the public network:
1.     Assign an L3 VXLAN ID to the public instance.
2.     Configure an RPF selection policy that does not include an L3 VXLAN ID or VPN instance for the receiver VPN instance.
The PIM mode in the source VPN instance and the receiver VPN instance must be the same. Only PIM-SM and PIM-SSM are supported.
When you use PIM-SM, use one of the following schemes as a best practice:
·     Specifying only the multicast source address—Configure two RPF selection policies as follows:
¡     In one policy, configure the multicast source address as the RP address of the multicast group that requires inter-VPN transmission.
¡     In the other policy, specify the multicast source address of the source VPN instance.
If multiple multicast groups require inter-VPN transmission, configure a dedicated RP for the multicast groups and specify the multicast source address as the RP address in RPF selection policies.
·     Specifying only the multicast group address—Configure one RPF selection policy that specifies the multicast group address of the source VPN instance.
When you use PIM-SSM, configure one RPF selection policy that contains both the multicast source address and multicast group address as a best practice.
Multicast packets can only be forwarded between two VPNs. The receiver VPN instance cannot also be the source VPN instance.
You cannot specify both an L3 VXLAN ID and an MPLS L3VPN instance for a multicast source address and multicast group address pair.
·     In PIM-SM mode, you can configure one RPF selection policy that specifies an L3 VXLAN ID or VPN instance for a multicast group address.
·     In PIM-SSM mode, you can configure one RPF selection policy that specifies an L3 VXLAN ID or VPN instance for a multicast source address and multicast group address pair.
For a receiver VPN instance, you must configure the same types of RPF selection policies for all multicast traffic from the same source VPN instance.
If an IPv4 MVPN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the multicast traffic for the intra-VPN transmission will be interrupted.
Multicast source addresses in different MVXLAN extranet RPF routing policies cannot be the same, but they can overlap. The same restriction applies to the multicast group addresses in different MVXLAN extranet RPF routing policies. If multiple routing policies exist for an (S, G) entry, the device selects the policy in which the multicast group address has the longest mask. If multiple policies have the same mask length, the device selects the policy in which the multicast source address has the longest mask.
2.     Enter MRIB view.
3.     Configure an IPv4 MVXLAN extranet RPF selection policy.
multicast extranet select-rpf [ l3-vni vxlan-id | vpn-instance vpn-instance-name ] { source source-address { mask | mask-length } | group group-address { mask | mask-length } } *
When the multicast source and multicast receivers reside in different data centers, configure both MDT-based MVXLAN and DCI Layer 3 multicast for multicast traffic to be transmitted between the data centers.
Do not attach a multicast source or multicast receiver to an ED.
Inter-data center multicast source migration is not supported.
If you use dynamic VXLAN-DCI tunnels, execute the dci enable command on the Layer 3 interfaces that interconnect the EDs. This restriction does not apply to static VXLAN-DCI tunnels.
If you use intermediate L3 VXLAN ID mapping, make sure the route targets of different intermediate VPN instances do not overlap. For example, the export route targets of one intermediate VPN instance cannot overlap with the import route targets of another intermediate VPN instance.
Configuring an ED
address-family ipv4
4.     Enable DCI multicast.
dci enable
By default, DCI multicast is disabled.
5.     (Optional.) Configure the device to modify the information in received BGP EVPN routes.
a.     Execute the following commands in sequence to return to system view.
b.     Enter BGP instance view.
c.     Enter BGP EVPN address family view.
address-family l2vpn evpn
d.     Configure the device to modify the information in received BGP EVPN routes.
peer { group-name | ipv4-address [ mask-length ] } re-originated [ smet | s-pmsi ] [ replace-rt ]
By default, the device does not modify the BGP EVPN routes that are received from peers or peer groups.
Execute this command if a VPN instance uses different L3 VXLAN IDs at two data centers.
For more information about this command, see EVPN Command Reference.
Configuring a VTEP
address-family ipv4
4.     Enable the device to advertise active multicast sources through S-PMSI routes.
s-pmsi advertise source-active
By default, the device does not advertise active multicast sources through S-PMSI routes.
This command enables the VTEP to advertise an S-PMSI route for a (S, G) entry after it receives multicast traffic for the entry. The S-PMSI routes carry information about active multicast sources and allow other VTEPs and EDs in the MVXLAN network to be aware of multicast source location changes.
Display received data group information in an MVXLAN.
display multicast-vpn vxlan { vpn-instance instance-name | public-instance } data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
Display sent data group information in an MVXLAN.
display multicast-vpn vxlan { vpn-instance instance-name | public-instance } data-group send [ group group-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
Display information about default groups.
display multicast-vpn vxlan [ vpn-instance instance-name | public-instance ] default-group { local | remote }
As shown in Figure 8, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure VXLAN 10 and VXLAN 20 on Switch A and Switch B to extend VLAN 2 and VLAN 3 across the sites.
·     Configure Switch A and Switch B as distributed EVPN gateways to provide gateway services. Configure Switch C as a border gateway to provide access to the connected Layer 3 network.
·     Configure Switch D as an RR to reflect BGP EVPN routes between Switch A, Switch B, and Switch C.
·     Configure PIM-SM on the transport-facing interfaces of Switches A through D. Configure IGMP snooping on Switches A through C for multicast forwarding entry creation.
Figure 8 Network diagram
1.     On VM 1 and VM 3, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
2.     Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 8. (Details not shown.)
# Configure OSPF on all transport network switches (Switches A through D) for them to reach one another. (Details not shown.)
3.     Configure Switch A:
# Enable L2VPN and IP multicast routing.
[SwitchA] l2vpn enable
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Enable the IGMP snooping feature.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Create VLAN-interface 11 and enter its view.
[SwitchA] vlan 11
[SwitchA-vlan11] quit
# Enable PIM-SM on VLAN-interface 11.
[SwitchA-Vlan-interface11] pim sm
# Create an EVPN instance on VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Enable IGMP snooping and IGMP snooping proxying on VSI vpna.
[SwitchA-vsi-vpna] igmp-snooping enable
[SwitchA-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] evpn encapsulation vxlan
[SwitchA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpnb-evpn-vxlan] quit
# Enable IGMP snooping and IGMP snooping proxying on VSI vpnb.
[SwitchA-vsi-vpnb] igmp-snooping enable
[SwitchA-vsi-vpnb] igmp-snooping proxy enable
# Create VXLAN 20.
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan-20] quit
[SwitchA-vsi-vpnb] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 4.4.4.4 as-number 200
[SwitchA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# Create VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] quit
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA-vlan3] quit
# Configure Twenty-FiveGigE 1/0/1 as a trunk port and assign it to VLAN 2 and VLAN 3.
[SwitchA] interface twenty-fivegige 1/0/1
[SwitchA-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchA-Twenty-FiveGigE1/0/1] port trunk permit vlan 2 3
# On Twenty-FiveGigE 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA-Twenty-FiveGigE1/0/1] service-instance 1000
[SwitchA-Twenty-FiveGigE1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-Twenty-FiveGigE1/0/1-srv1000] xconnect vsi vpna
[SwitchA-Twenty-FiveGigE1/0/1-srv1000] quit
# On Twenty-FiveGigE 1/0/1, create Ethernet service instance 2000 to match VLAN 3.
[SwitchA-Twenty-FiveGigE1/0/1] service-instance 2000
[SwitchA-Twenty-FiveGigE1/0/1-srv2000] encapsulation s-vid 3
# Map Ethernet service instance 2000 to VSI vpnb.
[SwitchA-Twenty-FiveGigE1/0/1-srv2000] xconnect vsi vpnb
[SwitchA-Twenty-FiveGigE1/0/1-srv2000] quit
[SwitchA-Twenty-FiveGigE1/0/1] quit
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 1:1
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] pim sm
[SwitchA-Vsi-interface1] pim distributed-dr
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Configure VSI-interface 2.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchA-Vsi-interface2] igmp enable
[SwitchA-Vsi-interface2] pim distributed-dr
[SwitchA-Vsi-interface2] mac-address 2-2-2
[SwitchA-Vsi-interface2] distributed-gateway local
[SwitchA-Vsi-interface2] local-proxy-arp enable
[SwitchA-Vsi-interface2] quit
# Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] pim sm
[SwitchA-Vsi-interface3] quit
# Enable IP multicast routing for VPN instance vpna.
[SwitchA] multicast routing vpn-instance vpna
[SwitchA-mrib-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings.
[SwitchA] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchA-mvxlan-vpna] address-family ipv4
[SwitchA-mvxlan-vpna-ipv4] default-group 236.0.0.1
[SwitchA-mvxlan-vpna-ipv4] source loopback 0
[SwitchA-mvxlan-vpna-ipv4] data-group 239.0.1.0 24
[SwitchA-mvxlan-vpna-ipv4] quit
[SwitchA-mvxlan-vpna] quit
# Configure Loopback 1.
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] ip binding vpn-instance vpna
[SwitchA-LoopBack1] ip address 12.12.12.12 32
[SwitchA-LoopBack1] pim sm
[SwitchA-LoopBack1] quit
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpna.
[SwitchA] pim vpn-instance vpna
[SwitchA-pim-vpna] c-bsr 12.12.12.12
[SwitchA-pim-vpna] c-rp 12.12.12.12
[SwitchA-pim-vpna] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] gateway vsi-interface 2
4.     Configure Switch B:
[SwitchB] l2vpn enable
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
# Create VLAN-interface 12 and enter its view.
[SwitchB] vlan 12
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
# Enable PIM-SM on VLAN-interface 12.
[SwitchB-Vlan-interface12] pim sm
[SwitchB-Vlan-interface12] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
[SwitchB-vsi-vpna] igmp-snooping enable
[SwitchB-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] evpn encapsulation vxlan
[SwitchB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpnb-evpn-vxlan] quit
[SwitchB-vsi-vpnb] igmp-snooping enable
[SwitchB-vsi-vpnb] igmp-snooping proxy enable
# Create VXLAN 20.
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan-20] quit
[SwitchB-vsi-vpnb] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 4.4.4.4 as-number 200
[SwitchB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# Create VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] quit
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-vlan3] quit
[SwitchB] interface twenty-fivegige 1/0/1
[SwitchB-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchB-Twenty-FiveGigE1/0/1] port trunk permit vlan 2 3
[SwitchB-Twenty-FiveGigE1/0/1] service-instance 1000
[SwitchB-Twenty-FiveGigE1/0/1-srv1000]encapsulation s-vid 2
[SwitchB-Twenty-FiveGigE1/0/1-srv1000] xconnect vsi vpna
[SwitchB-Twenty-FiveGigE1/0/1-srv1000] quit
[SwitchB-Twenty-FiveGigE1/0/1] service-instance 2000
[SwitchB-Twenty-FiveGigE1/0/1-srv2000] encapsulation s-vid 3
[SwitchB-Twenty-FiveGigE1/0/1-srv2000] xconnect vsi vpnb
[SwitchB-Twenty-FiveGigE1/0/1-srv2000] quit
[SwitchB-Twenty-FiveGigE1/0/1] quit
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:1
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 1:1
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] igmp enable
[SwitchB-Vsi-interface1] mac-address 1-1-1
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpna
[SwitchB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchB-Vsi-interface2] igmp enable
[SwitchB-Vsi-interface2] mac-address 2-2-2
[SwitchB-Vsi-interface2] distributed-gateway local
[SwitchB-Vsi-interface2] local-proxy-arp enable
[SwitchB-Vsi-interface2] quit
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] pim sm
[SwitchB-Vsi-interface3] quit
[SwitchB] multicast routing vpn-instance vpna
[SwitchB-mrib-vpna] quit
# Create an MDT-based MVXLAN for VPN instance vpna and enter MVXLAN IPv4 address family view. Configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchB-mvxlan-vpna] address-family ipv4
[SwitchB-mvxlan-vpna-ipv4] source loopback 0
[SwitchB-mvxlan-vpna-ipv4] quit
[SwitchB-mvxlan-vpna] quit
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] ip binding vpn-instance vpna
[SwitchB-LoopBack1] ip address 12.12.12.12 32
[SwitchB-LoopBack1] pim sm
[SwitchB-LoopBack1] quit
[SwitchB] pim vpn-instance vpna
[SwitchB-pim-vpna] c-bsr 12.12.12.12
[SwitchB-pim-vpna] c-rp 12.12.12.12
[SwitchB-pim-vpna] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] gateway vsi-interface 2
5.     Configure Switch C:
[SwitchC] l2vpn enable
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
# Create VLAN-interface 13 and enter its view.
[SwitchC] vlan 13
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
# Enable PIM-SM on VLAN-interface 13.
[SwitchC-Vlan-interface13] pim sm
[SwitchC-Vlan-interface13] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:1
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 1:1
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] pim sm
[SwitchC-Vsi-interface3] quit
# Enable IP multicast routing on VPN instance vpna.
[SwitchC] multicast routing vpn-instance vpna
[SwitchC-mrib-vpna] quit
[SwitchC] multicast-vpn vxlan vpn-instance vpna mode mdt
[SwitchC-mvxlan-vpna] address-family ipv4
[SwitchC-mvxlan-vpna-ipv4] source loopback 0
[SwitchC-mvxlan-vpna-ipv4] quit
[SwitchC-mvxlan-vpna] quit
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] ip binding vpn-instance vpna
[SwitchC-LoopBack1] ip address 12.12.12.12 32
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
[SwitchC] pim vpn-instance vpna
[SwitchC-pim-vpna] c-bsr 12.12.12.12
[SwitchC-pim-vpna] c-rp 12.12.12.12
[SwitchC-pim-vpna] quit
# Configure a default route. Specify the next hop as 20.1.1.100, the IP address of a device in the Layer 3 network.
[SwitchC] ip route-static vpn-instance vpna 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of VPN instance vpna.
[SwitchC] bgp 200
[SwitchC-bgp-default] ip vpn-instance vpna
[SwitchC-bgp-default-vpna] address-family ipv4 unicast
[SwitchC-bgp-default-ipv4-vpna] default-route imported
[SwitchC-bgp-default-ipv4-vpna] import-route static
[SwitchC-bgp-default-ipv4-vpna] quit
[SwitchC-bgp-default-vpna] quit
# Associate Twenty-FiveGigE 1/0/2 with VPN instance vpna.
[SwitchC] interface twenty-fivegige 1/0/2
[SwitchC-Twenty-FiveGigE1/0/2] ip binding vpn-instance vpna
[SwitchC-Twenty-FiveGigE1/0/2] ip address 20.1.1.3 24
[SwitchC-Twenty-FiveGigE1/0/2] pim sm
[SwitchC-Twenty-FiveGigE1/0/2] quit
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure VLAN-interface 20 that connects to the Layer 3 network and associate the interface with VPN instance vpna.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip binding vpn-instance vpna
[SwitchC-Vlan-interface20] ip address 20.1.1.3 24
[SwitchC-Vlan-interface20] pim sm
[SwitchC-Vlan-interface20] quit
6.     Configure Switch D:
<SwitchD> system-view
[SwitchD] multicast routing
[SwitchD-mrib] quit
# Enter PIM view, and configure Loopback 0 as a candidate-BSR and candidate-RP in the public network.
[SwitchD] pim
[SwitchD-pim] c-bsr 4.4.4.4
[SwitchD-pim] c-rp 4.4.4.4
[SwitchD-pim] quit
[SwitchD] interface vlan-interface11
[SwitchD-Vlan-interface11] pim sm
[SwitchD-Vlan-interface11] quit
[SwitchD] interface vlan-interface12
[SwitchD-Vlan-interface12] pim sm
[SwitchD-Vlan-interface12] quit
[SwitchD] interface vlan-interface13
[SwitchD-Vlan-interface13] pim sm
[SwitchD-Vlan-interface13] quit
# Establish BGP connections with other transport network switches.
[SwitchD] bgp 200
[SwitchD-bgp-default] group evpn
[SwitchD-bgp-default] peer 1.1.1.1 group evpn
[SwitchD-bgp-default] peer 2.2.2.2 group evpn
[SwitchD-bgp-default] peer 3.3.3.3 group evpn
[SwitchD-bgp-default] peer evpn as-number 200
[SwitchD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering of received BGP EVPN routes.
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer evpn enable
[SwitchD-bgp-default-evpn] undo policy vpn-target
# Configure Switch D as an RR.
[SwitchD-bgp-default-evpn] peer evpn reflect-client
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
1.     Verify the multicast routing information on Switch A:
# Verify that Switch A has multicast routing entries for VPN instance vpna.
<SwitchA> display pim vpn-instance vpna routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.0.0)
     RP: 12.12.12.12 (local)
     Protocol: pim-sm, Flag: WC RC
     UpTime: 02:57:31
     Upstream interface: Register-Tunnel0
         1: MTunnel0
             Protocol: MD, UpTime: 02:57:31, Expires: -
(10.1.1.10, 225.0.0.0)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT SQ RC 2MVPN
     UpTime: 04:44:08
     Upstream interface: Vsi-interface1
         1: MTunnel1
             Protocol: MD, UpTime: 02:00:27, Expires: -
# Verify that Switch A has multicast routing entries for the public network.
<SwitchA> display pim routing-table
 Total 0 (*, G) entries; 2 (S, G) entries
(1.1.1.1, 236.0.0.1)
     RP: 4.4.4.4
     Protocol: pim-sm, Flag: SPT LOC VXLAN_L3
     UpTime: 02:09:52
     Upstream interface: MTunnel0 (VPN: vpna)
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 01:16:34, Expires: 00:03:10
(1.1.1.1, 239.0.1.0)
     RP: 4.4.4.4
     UpTime: 02:08:52
     Upstream interface: MTunnel1 (VPN: vpna)
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 01:15:34, Expires: 00:03:11
2.     Verify the multicast routing information on Switch B:
# Verify that Switch B has multicast routing entries for VPN instance vpna.
<SwitchB> display pim vpn-instance vpna routing-table
(*, 225.0.0.0)
     UpTime: 05:04:06
         1: Vsi-interface1
             Protocol: igmp, UpTime: 05:04:06, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ FROMVXLAN
     UpTime: 01:57:12
     Upstream interface: MVXLAN-UPE0 (0.0.0.0)
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 01:57:12, Expires: -
# Verify that Switch B has multicast routing entries for the public network.
<SwitchB> display pim routing-table
     RP: 4.4.4.4
     UpTime: 01:59:46
     Upstream interface: Vlan-interface12
         Upstream neighbor: 12.1.1.4
         RPF prime neighbor: 12.1.1.4
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:59:46, Expires: -
     RP: 4.4.4.4
     UpTime: 01:58:46
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:58:46, Expires: -
As shown in Figure 9, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1, VM 2, and VM 3 belong to VPN instance vpna, and VM 4 belongs to VPN instance vpnb. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb based on the L3 VXLAN ID on Switch B.
Figure 9 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 9. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 10.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA-mvxlan-vpna-ipv4] data-group 239.0.1.0 25
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto import-extcommunity
# Enable IGMP snooping and IGMP snooping proxying on VSI vpnc
# Create VXLAN 10.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto export-extcommunity
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto import-extcommunity
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
# Configure Twenty-FiveGigE 1/0/1 as a trunk port and assign it to VLAN 2.
# Configure Twenty-FiveGigE 1/0/2 as a trunk port and assign it to VLAN 3.
[SwitchB] interface twenty-fivegige 1/0/2
[SwitchB-Twenty-FiveGigE1/0/2] port link-type trunk
[SwitchB-Twenty-FiveGigE1/0/2] port trunk permit vlan 3
# On Twenty-FiveGigE 1/0/2, create Ethernet service instance 2000 to match VLAN 3.
[SwitchB-Twenty-FiveGigE1/0/2] service-instance 2000
[SwitchB-Twenty-FiveGigE1/0/2-srv2000] encapsulation s-vid 3
[SwitchB-Twenty-FiveGigE1/0/2-srv2000] xconnect vsi vpnb
[SwitchB-Twenty-FiveGigE1/0/2-srv2000] quit
[SwitchB-Twenty-FiveGigE1/0/2] quit
# Configure RD and route target settings for VPN instance vpnb.
[SwitchB] ip vpn-instance vpnb
[SwitchB-vpn-instance-vpnb] route-distinguisher 2:2
[SwitchB-vpn-instance-vpnb] address-family ipv4
[SwitchB-vpn-ipv4-vpnb] vpn-target 1:1
[SwitchB-vpn-ipv4-vpnb] quit
[SwitchB-vpn-instance-vpnb] address-family evpn
[SwitchB-vpn-evpn-vpnb] vpn-target 1:1
[SwitchB-vpn-evpn-vpnb] quit
[SwitchB-vpn-instance-vpnb] quit
[SwitchB-Vsi-interface2] ip binding vpn-instance vpnb
# Enable IP multicast routing for VPN instance vpnb.
[SwitchB] multicast routing vpn-instance vpnb
[SwitchB-mrib-vpnb] quit
# Create an MDT-based MVXLAN for VPN instance vpna, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
# Configure Loopback 2.
[SwitchB] interface loopback 2
[SwitchB-LoopBack2] ip binding vpn-instance vpnb
[SwitchB-LoopBack2] ip address 13.13.13.13 32
[SwitchB-LoopBack2] pim sm
[SwitchB-LoopBack2] quit
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpnb.
[SwitchB] pim vpn-instance vpnb
[SwitchB-pim-vpnb] c-bsr 13.13.13.13
[SwitchB-pim-vpnb] c-rp 13.13.13.13
[SwitchB-pim-vpnb] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
# Enable IP multicast routing for VPN instance vpnb, and import the traffic of VPN instance vpna to VPN instance vpnb.
[SwitchB-mrib-vpnb] multicast extranet select-rpf l3-vni 1000 group 225.0.0.0 16
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC] ip vpn-instance vpnb
[SwitchC-vpn-instance-vpnb] route-distinguisher 2:2
[SwitchC-vpn-instance-vpnb] address-family ipv4
[SwitchC-vpn-ipv4-vpnb] vpn-target 1:1
[SwitchC-vpn-ipv4-vpnb] quit
[SwitchC-vpn-instance-vpnb] address-family evpn
[SwitchC-vpn-evpn-vpnb] vpn-target 1:1
[SwitchC-vpn-evpn-vpnb] quit
[SwitchC-vpn-instance-vpnb] quit
[SwitchC] multicast routing vpn-instance vpnb
[SwitchC-mrib-vpnb] quit
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] ip binding vpn-instance vpnb
[SwitchC-LoopBack2] ip address 13.13.13.13 32
[SwitchC-LoopBack2] pim sm
[SwitchC-LoopBack2] quit
[SwitchC] pim vpn-instance vpnb
[SwitchC-pim-vpnb] c-bsr 13.13.13.13
[SwitchC-pim-vpnb] c-rp 13.13.13.13
[SwitchC-pim-vpnb] quit
[SwitchC] ip route-static vpn-instance vpnb 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of VPN instance vpnb.
[SwitchC] bgp 200
[SwitchC-bgp-default] ip vpn-instance vpnb
[SwitchC-bgp-default-vpnb] address-family ipv4 unicast
[SwitchC-bgp-default-ipv4-vpnb] default-route imported
[SwitchC-bgp-default-ipv4-vpnb] import-route static
[SwitchC-bgp-default-ipv4-vpnb] quit
[SwitchC-bgp-default-vpnb] quit
# Create VLAN 20.
[SwitchC] vlan 20
# Configure VLAN-interface 20 that connects to the Layer 3 network and associate the interface with VPN instance vpnb.
[SwitchC-Vlan-interface20] ip binding vpn-instance vpnb
[SwitchC-mrib-vpnb] multicast extranet select-rpf l3-vni 1000 group 225.0.0.0 16
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 03:01:20
         1: MTunnel0
2: Vsi-interface2
             Protocol: igmp, UpTime: 03:01:22, Expires: -
     UpTime: 03:01:20
         1: MTunnel1
             Protocol: MD, UpTime: 02:56:31, Expires: -
2: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 04:09:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 04:09:40, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 03:00:20
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 03:00:20, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 03:01:20
     Total number of downstream interfaces: 2
         1: Extranet (VPN: vpnb)
             Protocol: MD, UpTime: 03:01:20, Expires: -
2: Vsi-interface1
             Protocol: igmp, UpTime: 03:01:20, Expires: -
     Protocol: pim-sm, Flag: SPT ACT FROMVXLAN
     UpTime: 03:00:20
             Protocol: MD, UpTime: 03:00:20, Expires: -
2: Vsi-interface1
             Protocol: pim-sm, UpTime: 03:00:20, Expires: -
# Verify that Switch B has multicast routing entries for VPN instance vpnb.
<SwitchB> display pim vpn-instance vpnb routing-table
(*, 225.0.0.0)
     RP: 13.13.13.13 (local)
     UpTime: 03:01:20
     Upstream interface: Extranet (VPN: vpna, l3-vni: 1000)
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
         1: Vsi-interface2
             Protocol: igmp, UpTime: 05:04:11, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ 2MVPN
     UpTime: 03:00:20
         1: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 04:09:00
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 04:09:40, Expires: -
     RP: 4.4.4.4
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 03:00:20
         1: MVXLAN-UPE0
Example: Configuring MVXLAN extranet on the receiver VPN instance for asymmetrically configured extranet
As shown in Figure 10, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1 and VM 2 belong to VPN instance vpna, VM 3 belongs to VPN instance vpnb, and VM 4 belongs to vpnc. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb and VPN instance vpnc based on the L3 VXLAN ID on Switch B.
Figure 10 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 10. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
# Configure RD and route target settings for VPN instance vpnc.
[SwitchB] ip vpn-instance vpnc
[SwitchB-vpn-instance-vpnc] route-distinguisher 3:3
[SwitchB-vpn-instance-vpnc] address-family ipv4
[SwitchB-vpn-ipv4-vpnc] vpn-target 1:1
[SwitchB-vpn-ipv4-vpnc] quit
[SwitchB-vpn-instance-vpnc] address-family evpn
[SwitchB-vpn-evpn-vpnc] vpn-target 1:1
[SwitchB-vpn-evpn-vpnc] quit
[SwitchB-vpn-instance-vpnc] quit
[SwitchB-Vsi-interface1] ip binding vpn-instance vpnb
[SwitchB-Vsi-interface2] ip binding vpn-instance vpnc
# Configure the L3 VXLAN ID as 1000 for VSI-interface 3.
# Enable IP multicast routing for VPN instance vpnc.
[SwitchB] multicast routing vpn-instance vpnc
[SwitchB-mrib-vpnc] quit
# Create an MDT-based MVXLAN for VPN instance vpnb, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpnb mode mdt
[SwitchB-mvxlan-vpnb] address-family ipv4
[SwitchB-mvxlan-vpnb-ipv4] source loopback 0
[SwitchB-mvxlan-vpnb-ipv4] quit
[SwitchB-mvxlan-vpnb] quit
# Create an MDT-based MVXLAN for VPN instance vpnc, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
[SwitchB] multicast-vpn vxlan vpn-instance vpnc mode mdt
[SwitchB-mvxlan-vpnc] address-family ipv4
[SwitchB-mvxlan-vpnc-ipv4] source loopback 0
[SwitchB-mvxlan-vpnc-ipv4] quit
[SwitchB-mvxlan-vpnc] quit
[SwitchB-LoopBack1] ip binding vpn-instance vpnb
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpnb.
[SwitchB-pim-vpnb] c-bsr 12.12.12.12
[SwitchB-pim-vpnb] c-rp 12.12.12.12
[SwitchB-LoopBack2] ip binding vpn-instance vpnc
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpnc.
[SwitchB] pim vpn-instance vpnc
[SwitchB-pim-vpnc] c-bsr 13.13.13.13
[SwitchB-pim-vpnc] c-rp 13.13.13.13
[SwitchB-pim-vpnc] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
# Enable IP multicast routing for VPN instance vpnb and VPN instance vpnc, and import the traffic of VPN instance vpna to VPN instance vpnb and VPN instance vpnc.
[SwitchB-mrib-vpnc] multicast extranet select-rpf l3-vni 1000 group 225.0.0.0 16
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC-vpn-instance-vpnb] route-distinguisher 1:1
[SwitchC] multicast-vpn vxlan vpn-instance vpnb mode mdt
[SwitchC-mvxlan-vpnb] address-family ipv4
[SwitchC-mvxlan-vpnb-ipv4] source loopback 0
[SwitchC-mvxlan-vpnb-ipv4] quit
[SwitchC-mvxlan-vpnb] quit
[SwitchC-LoopBack1] ip binding vpn-instance vpnb
[SwitchC-pim-vpnb] c-bsr 12.12.12.12
[SwitchC-pim-vpnb] c-rp 12.12.12.12
[SwitchC] bgp 200
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 02:57:31
         1: MTunnel0
2: Vsi-interface2
             Protocol: igmp, UpTime: 02:57:31, Expires: -
     UpTime: 02:56:31
         1: MTunnel1
             Protocol: MD, UpTime: 02:56:21, Expires: -
2: Vsi-interface2
             Protocol: igmp, UpTime: 02:56:31, Expires: -
     RP: 4.4.4.4
     UpTime: 03:09:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 03:08:52, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 02:55:31
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 02:55:20, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 02:56:32
     Upstream interface: Extranet (public instance, l3-vni: 1000)
         1: Vsi-interface1
             Protocol: igmp, UpTime: 02:56:32, Expires: -
     UpTime: 02:55:20
         1: Vsi-interface1
             Protocol: pim-sm, UpTime: 02:55:20, Expires: -
# Verify that Switch B has multicast routing entries for VPN instance vpnc.
<SwitchB> display pim vpn-instance vpnc routing-table
(*, 225.0.0.0)
     UpTime: 02:56:32
         1: Vsi-interface2
     UpTime: 02:55:20
         1: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 03:08:52
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 03:08:52, Expires: -
     RP: 4.4.4.4
     UpTime: 02:55:31
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 02:55:31, Expires: -
Example: Configuring MVXLAN extranet on the source VPN instance for asymmetrically configured extranet
As shown in Figure 11, VM 1 and VM 2 the multicast sources of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1 belongs to VPN instance vpna, VM 2, VM 3, and VM 4 belong to VPN instance vpnb. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb based on the source VPN instance on Switch A.
Figure 11 Network diagram
1.     On VM 1 and VM 2, specify 10.1.1.1 as the gateway address. On VM 3 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 11. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA] ip vpn-instance vpnb
[SwitchA-vpn-instance-vpnb] route-distinguisher 2:2
[SwitchA-vpn-instance-vpnb] address-family ipv4
[SwitchA-vpn-ipv4-vpnb] vpn-target 1:1
[SwitchA-vpn-ipv4-vpnb] quit
[SwitchA-vpn-instance-vpnb] address-family evpn
[SwitchA-vpn-evpn-vpnb] vpn-target 1:1
[SwitchA-vpn-evpn-vpnb] quit
[SwitchA-vpn-instance-vpnb] quit
[SwitchA-Vsi-interface2] ip binding vpn-instance vpnb
[SwitchA-Vsi-interface2] pim sm
# Associate VSI-interface 4 with VPN instance vpnb, and configure the L3 VXLAN ID as 2000 for the VPN instance.
[SwitchA] interface vsi-interface 4
[SwitchA-Vsi-interface4] ip binding vpn-instance vpnb
[SwitchA-Vsi-interface4] l3-vni 2000
[SwitchA-Vsi-interface4] pim sm
[SwitchA-Vsi-interface4] quit
[SwitchA] multicast routing vpn-instance vpnb
[SwitchA-mrib-vpnb] quit
# Create an MDT-based MVXLAN for VPN instance vpnb and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings.
[SwitchA] multicast-vpn vxlan vpn-instance vpnb mode mdt
[SwitchA-mvxlan-vpnb] address-family ipv4
[SwitchA-mvxlan-vpnb-ipv4] default-group 236.0.0.1
[SwitchA-mvxlan-vpnb-ipv4] source loopback 0
[SwitchA-mvxlan-vpnb-ipv4] data-group 239.0.1.0 25
[SwitchA-mvxlan-vpnb-ipv4] quit
[SwitchA-mvxlan-vpnb] quit
[SwitchA] interface loopback 2
[SwitchA-LoopBack1] ip binding vpn-instance vpnb
[SwitchA-LoopBack1] ip address 13.13.13.13 32
[SwitchA] pim vpn-instance vpnb
[SwitchA-pim-vpnb] c-bsr 13.13.13.13
[SwitchA-pim-vpnb] c-rp 13.13.13.13
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchA-mrib-vpnb] multicast extranet select-rpf vpn-instance vpna group 225.0.0.0 16
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
# Associate VSI-interface 3 with VPN instance vpnb, and configure the L3 VXLAN ID as 2000 for the VPN instance.
[SwitchB-Vsi-interface3] ip binding vpn-instance vpnb
[SwitchB-Vsi-interface3] l3-vni 2000
# Associate VSI-interface 4 with VPN instance vpnb, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchB] interface vsi-interface 4
[SwitchB-Vsi-interface4] ip binding vpn-instance vpnb
[SwitchB-Vsi-interface4] l3-vni 1000
[SwitchB-Vsi-interface4] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC-Vsi-interface3] ip binding vpn-instance vpnb
[SwitchC-Vsi-interface3] l3-vni 2000
# Associate VSI-interface 4 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchC] interface vsi-interface 4
[SwitchC-Vsi-interface4] ip binding vpn-instance vpna
[SwitchC-Vsi-interface4] l3-vni 1000
[SwitchC-Vsi-interface4] quit
[SwitchC] bgp 200
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 02:57:31
     Protocol: pim-sm, Flag: SPT LOC ACT 2MVPN
     UpTime: 02:56:31
# Verify that Switch A has multicast routing entries for VPN instance vpnb.
<SwitchA> display pim vpn-instance vpnb routing-table
 (*, 225.0.0.0)
     UpTime: 02:57:31
     Upstream interface: Extranet (VPN: vpna)
         1: MTunnel0
     RP: 13.13.13.13(local)
     Protocol: pim-sm, Flag: SPT ACT SQ RC 2MVPN
     UpTime: 02:56:31
         1: MTunnel1
     RP: 4.4.4.4
     UpTime: 04:09:52
     Upstream interface: MTunnel0 (VPN: vpnb)
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 04:09:50, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 02:55:52
     Upstream interface: MTunnel1 (VPN: vpnb)
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 02:55:34, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 02:56:30
         1: Vsi-interface1
             Protocol: igmp, UpTime: 02:56:30, Expires: -
2: Vsi-interface2
     Protocol: pim-sm, Flag: SPT ACT RQ 2MVPN FROMVXLAN
     UpTime: 02:55:32
         1: Vsi-interface1
             Protocol: igmp, UpTime: 02:55:32, Expires: -
2: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 01:59:46
         1: MVXLAN-UPE0
     RP: 4.4.4.4
     UpTime: 02:55:32
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 02:55:32, Expires: -
Example: Configuring MVXLAN extranet on the multicast source-side border node of an MVXLAN network
As shown in Figure 12, Switch C is attached to a multicast source, and the VMs are multicast receivers. The multicast source belongs to VPN instance vpna, and the VMs belong to VPN instance vpnb. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb based on the L3 VXLAN ID on Switch C.
Figure 12 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 12. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 13
[SwitchA-vlan13] quit
[SwitchA] interface vlan-interface 13
[SwitchA-Vlan-interface13] pim sm
[SwitchA-Vlan-interface13] quit
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA-Vsi-interface1] ip binding vpn-instance vpnb
[SwitchA-Vsi-interface1] igmp enable
# Associate VSI-interface 3 with VPN instance vpnb, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA-Vsi-interface3] ip binding vpn-instance vpnb
[SwitchA-pim-vpnb] c-bsr 12.12.12.12
[SwitchA-pim-vpnb] c-rp 12.12.12.12
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-Vsi-interface4] ip binding vpn-instance vpna
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchC-mrib] quit
[SwitchC] vlan 11
[SwitchC-vlan11] quit
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] pim sm
[SwitchC-Vlan-interface11] quit
[SwitchC] bgp 200
[SwitchC-Vsi-interface4] ip binding vpn-instance vpnb
[SwitchC-Vsi-interface4] l3-vni 2000
[SwitchC-Vsi-interface4] pim sm
[SwitchC-mvxlan-vpnb-ipv4] default-group 236.0.0.1
[SwitchC-mvxlan-vpnb-ipv4] data-group 239.0.1.0 25
[SwitchC-LoopBack1] ip address 13.13.13.13 32
[SwitchC] ip route-static vpn-instance vpna 100.100.100.1 24 20.1.1.100
[SwitchC] bgp 200
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
1.     Verify the multicast routing information on Switch C:
# Verify that Switch C has multicast routing entries for VPN instance vpna.
<SwitchC> display pim vpn-instance vpna routing-table
 (*, 225.0.0.0)
     UpTime: 02:57:31
(20.1.1.10, 225.0.0.0)
     UpTime: 02:56:31
     Upstream interface: Vlan-interface20
# Verify that Switch C has multicast routing entries for VPN instance vpnb.
<SwitchC> display pim vpn-instance vpnb routing-table
 (*, 225.0.0.0)
     UpTime: 02:57:31
         1: MTunnel0
     UpTime: 02:56:31
         1: MTunnel1
# Verify that Switch C has multicast routing entries for the public instance.
<SwitchC> display pim routing-table
     RP: 4.4.4.4
     UpTime: 04:09:52
         1: Vlan-interface11
     RP: 4.4.4.4
     UpTime: 02:55:52
         1: Vlan-interface11
(*, 225.0.0.0)
     UpTime: 02:56:30
         1: Vsi-interface1
2: Vsi-interface2
     UpTime: 02:55:32
         1: Vsi-interface1
2: Vsi-interface2
     RP: 4.4.4.4
     UpTime: 01:59:46
         1: MVXLAN-UPE0
     RP: 4.4.4.4
     UpTime: 02:55:32
         1: MVXLAN-UPE0
Example: Configuring MVXLAN extranet with receivers on both VPNs and the public network
As shown in Figure 13, VM 1 is the multicast source of multicast group 225.0.0.0, and the other VMs are multicast receivers. VM 1 and VM 2 belong to VPN instance vpna, VM 3 belongs to the public instance, and VM 4 belongs to VPN instance vpnb. VM 1 and VM 3 are in VXLAN 10, and VM 2 and VM 4 are in VXLAN 20. Configure MVXLAN to forward the multicast traffic from the source to the receivers.
·     Configure MVXLAN extranet to import the traffic of VPN instance vpna to VPN instance vpnb and the public instance.
Figure 13 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 13. (Details not shown.)
[SwitchA-mrib] quit
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Create VLAN 2.
[SwitchA] vlan 2
# Create VLAN 3.
[SwitchA] vlan 3
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Create VLAN 2.
[SwitchB] vlan 2
# Create VLAN 3.
[SwitchB] vlan 3
[SwitchB-vpn-instance-vpnb] route-distinguisher 1:1
# Configure RD and route target settings for the public instance.
[SwitchB] ip public-instance
[SwitchB-public-instance] route-distinguisher 2:2
[SwitchB-public-instance] address-family ipv4
[SwitchB-public-instance-ipv4] vpn-target 1:1
[SwitchB-public-instance-ipv4] quit
[SwitchB-public-instance] address-family evpn
[SwitchB-public-instance-evpn] vpn-target 1:1
[SwitchB-public-instance-evpn] quit
[SwitchB-public-instance] quit
# Create VSI-interface 4 and configure its L3 VXLAN ID as 1000.
[SwitchB-Vsi-interface4] pim sm
# Create IPv4 basic ACL 2000 and enter its view. Create a rule in the ACL to permit only packets from 225.0.0.0/8.
[SwitchB-acl-ipv4-basic-2000] acl basic 2000
[SwitchB-acl-ipv4-basic-2000] rule permit source 225.0.0.0 0.255.255.255
[SwitchB-acl-ipv4-basic-2000] quit
# Enter public instance PIM view, configure Loopback 2 as a candidate-BSR and candidate-RP in the public instance, and specify a candidate-RP policy.
[SwitchB] pim
[SwitchB-pim] c-bsr 13.13.13.13
[SwitchB-pim] c-rp 13.13.13.13 group-policy 2000
[SwitchB-pim] quit
[SwitchB] vsi vpnc
[SwitchB] vsi vpnc
[SwitchB-mrib-vpnb] multicast extranet select-rpf group 225.0.0.0 16
[SwitchC-mrib] quit
[SwitchC] vlan 13
[SwitchC] bgp 200
[SwitchC] ip public-instance
[SwitchC-public-instance] route-distinguisher 1:1
[SwitchC-public-instance] address-family ipv4
[SwitchC-public-instance] vpn-target 1:1
[SwitchC-public-instance] quit
[SwitchC-public-instance] address-family evpn
# Create an MDT-based MVXLAN for the public instance, enter MVXLAN IPv4 address family view, and configure the MVXLAN source interface.
[SwitchC] multicast-vpn vxlan public-instance mode mdt
[SwitchC-mvxlan-public-instance] address-family ipv4
[SwitchC-mvxlan-public-instance-ipv4] source loopback 0
[SwitchC-mvxlan-public-instance-ipv4] quit
[SwitchC-mvxlan-public-instance] quit
[SwitchC-acl-ipv4-basic-2000] acl basic 2000
[SwitchC-acl-ipv4-basic-2000] rule permit source 225.0.0.0 0.255.255.255
[SwitchC-acl-ipv4-basic-2000] qui
# Enter PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in the public network.
[SwitchC] pim
[SwitchC-pim] c-bsr 12.12.12.12
[SwitchC-pim] c-rp 12.12.12.12 group-policy 2000
[SwitchC-pim] quit
[SwitchC] ip route-static 0.0.0.0 0 20.1.1.100
# Import the default route to the BGP IPv4 unicast routing table of the public instance.
[SwitchC] bgp 200
[SwitchC-bgp-default-ipv4] default-route imported
[SwitchC-bgp-default-ipv4] import-route static
# Create VLAN 20.
[SwitchC] vlan 20
# Configure VLAN-interface 20 that connects to the Layer 3 network and associate the interface with the public instance.
[SwitchD-mrib] quit
[SwitchD] pim
[SwitchD-pim] quit
[SwitchD] bgp 200
 (*, 225.0.0.0)
     UpTime: 02:57:31
         1: MTunnel0
     UpTime: 02:56:31
         1: MTunnel1
     RP: 4.4.4.4
     UpTime: 03:09:52
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 03:09:50, Expires: 00:03:10
     RP: 4.4.4.4
     UpTime: 02:55:31
         1: Vlan-interface11
             Protocol: pim-sm, UpTime: 02:55:28, Expires: 00:03:11
(*, 225.0.0.0)
     UpTime: 02:56:35
     Upstream interface: Extranet (public instance)
     Total number of downstream interfaces: 11: Vsi-interface2
             Protocol: igmp, UpTime: 02:56:35, Expires: -
     UpTime: 02:56:31
     Total number of downstream interfaces: 1  1: Vsi-interface2
Total 1 (*, G) entries; 3 (S, G) entries
(*, 225.0.0.0)
     UpTime: 02:56:31
       1: Vsi-interface 1
         2: Extranet (VPN: vpnb)
     UpTime: 02:56:30
         1: Vsi-interface 1
     RP: 4.4.4.4
     UpTime: 03:00:46
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 03:00:46, Expires: -
     RP: 4.4.4.4
     UpTime: 02:56:31
         1: MVXLAN-UPE0
Example: Configuring DCI Layer 3 multicast without L3 VXLAN ID mapping
As shown in Figure 14, the multicast source of multicast group 225.0.0.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B and Switch E. Configure DCI Layer 3 multicast as follows:
·     For DC 1, configure Switch A and Switch B as VTEPs, and configure Switch C as an ED.
·     For DC 2, configure Switch E as a VTEP, and configure Switch D as an ED.
·     Assign L3 VXLAN ID to DC 1 and DC 2.
·     On Switch A through Switch E, configure PIM SM on the public-network interfaces used for intra-data center connection. Enable IGMP snooping on Switch E.
Figure 14 Network diagram
1.     On the multicast source, specify 192.168.10.1 as the gateway address. On Receiver 1, specify 192.168.20.1 as the gateway address. On Receiver 2, specify 192.168.40.1 as the gateway address. (Details not shown.)
2.     Configure IP addresses, PIM SM, and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 14. (Details not shown.)
# Configure OSPF in each data center for the switches in a data center to reach one another. (Details not shown.)
# Enable PIM SM on the VLAN interfaces that interconnect the devices in a data center. (Details not shown.)
# Verify that PIM SM is disabled on the VLAN interfaces that interconnect the EDs. If PIM SM is enabled on such a VLAN interface on an ED, execute the pim bsr-boundary command to configure the ED as a PIM-SM domain border. (Details not shown.)
# Enable L2VPN and IP multicast routing, and create VLAN 11.
[SwitchA-mrib] quit
[SwitchA] vlan 11
# Configure Loopback 0.
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] pim sm
[SwitchA-LoopBack0] ospf 1 area 0.0.0.0
[SwitchA-LoopBack0] quit
[SwitchA] vsi vpna
# Create VXLAN 11.
[SwitchA-vsi-vpna] vxlan 11
[SwitchA-vsi-vpna-vxlan-11] quit
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 77.77.77.77 as-number 100
[SwitchA-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchA-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchA-bgp-default-evpn] peer 77.77.77.77 next-hop-local
# On Twenty-FiveGigE 1/0/1, create Ethernet service instance 100 to match VLAN 11.
[SwitchA-Twenty-FiveGigE1/0/1] port trunk permit vlan 1 11
[SwitchA-Twenty-FiveGigE1/0/1-srv100] encapsulation s-vid 11
# Map Ethernet service instance 100 to VSI vpna.
[SwitchA-Twenty-FiveGigE1/0/1-srv100] xconnect vsi vpna
[SwitchA-Twenty-FiveGigE1/0/1-srv100] quit
# Configure RD and route target settings for VPN instance vpn1.
[SwitchA] ip vpn-instance vpn1
[SwitchA-vpn-instance-vpn1] route-distinguisher 1:1
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchA-vpn-instance-vpn1] quit
[SwitchA-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface1] ip address 192.168.10.1 255.255.255.0
# Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface2] l3-vni 1000
# Enable IP multicast routing for VPN instance vpn1.
[SwitchA] multicast routing vpn-instance vpn1
[SwitchA-mrib-vpn1] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings. Enable advertising active multicast sources through S-PMSI routes.
[SwitchA] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchA-mvxlan-vpn1] address-family ipv4
[SwitchA-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchA-mvxlan-vpn1-ipv4] source loopback 0
[SwitchA-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchA-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchA-mvxlan-vpn1-ipv4] quit
[SwitchA-mvxlan-vpn1] quit
[SwitchA-LoopBack1] ip binding vpn-instance vpn1
[SwitchA-LoopBack1] ip address 1.1.1.1 32
# Enter VPN instance PIM view, and configure Loopback 1 as a candidate-BSR and candidate-RP in VPN instance vpn1.
[SwitchA] pim vpn-instance vpn1
[SwitchA-pim-vpn1] c-bsr 1.1.1.1
[SwitchA-pim-vpn1] c-rp 1.1.1.1
[SwitchA-pim-vpn1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchA] vsi vpna
# Enable L2VPN and IP multicast routing, and create VLAN 12.
[SwitchB-mrib] quit
[SwitchB] vlan 12
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] pim sm
[SwitchB-LoopBack0] ospf 1 area 0.0.0.0
[SwitchB-LoopBack0] quit
[SwitchB] vsi vpna
# Create VXLAN 12.
[SwitchB-vsi-vpna] vxlan 12
[SwitchB-vsi-vpna-vxlan-12] quit
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 77.77.77.77 as-number 100
[SwitchB-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchB-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchB-bgp-default-evpn] peer 77.77.77.77 next-hop-local
# On Twenty-FiveGigE 1/0/1, create Ethernet service instance 100 to match VLAN 12.
[SwitchB-Twenty-FiveGigE1/0/1] port trunk permit vlan 1 12
[SwitchB-Twenty-FiveGigE1/0/1-srv100] encapsulation s-vid 12
[SwitchB-Twenty-FiveGigE1/0/1-srv100] xconnect vsi vpna
[SwitchB-Twenty-FiveGigE1/0/1-srv100] quit
[SwitchB] ip vpn-instance vpn1
[SwitchB-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchB-vpn-instance-vpn1] quit
[SwitchB-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface1] ip address 192.168.20.1 255.255.255.0
[SwitchB-Vsi-interface1] pim sm
[SwitchB-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface2] l3-vni 1000
[SwitchB-Vsi-interface2] pim sm
[SwitchB] multicast routing vpn-instance vpn1
[SwitchB-mrib-vpn1] quit
[SwitchB] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchB-mvxlan-vpn1] address-family ipv4
[SwitchB-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchB-mvxlan-vpn1-ipv4] source loopback 0
[SwitchB-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchB-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchB-mvxlan-vpn1-ipv4] quit
[SwitchB-mvxlan-vpn1] quit
[SwitchB-LoopBack1] ip binding vpn-instance vpn1
[SwitchB-LoopBack1] ip address 2.2.2.2 32
[SwitchB] pim vpn-instance vpn1
[SwitchB-pim-vpn1] c-bsr 2.2.2.2
[SwitchB-pim-vpn1] c-rp 2.2.2.2
[SwitchB-pim-vpn1] quit
[SwitchB] vsi vpna
# Enable L2VPN, IP multicast routing, and RIP process 1.
[SwitchC-mrib] quit
[SwitchC] rip 1
[SwitchC-rip-1] quit
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
[SwitchC]vxlan tunnel mac-learning disable
[SwitchC]vxlan tunnel arp-learning disable
[SwitchC-LoopBack0] ip address 77.77.77.77 32
[SwitchC-LoopBack0] pim sm
[SwitchC-LoopBack0] rip 1 enable
[SwitchC-LoopBack0] ospf 1 area 0.0.0.0
[SwitchC-LoopBack0] quit
# Configure RIP and enable DCI on the interface connected to a remote ED.
[SwitchC] interface vlan-interface 70
[SwitchC-Vlan-interface70] ip address 78.1.1.1 255.255.255.0
[SwitchC-Vlan-interface70] rip 1 enable
[SwitchC-Vlan-interface70] dci enable
# Configure BGP to advertise BGP EVPN routes, and configure Switch C as an RR.
[SwitchC] bgp 100
[SwitchC-bgp-default] group group1 internal
[SwitchC-bgp-default] peer group1 connect-interface loopback 0
[SwitchC-bgp-default] peer 1.1.1.1 group group1
[SwitchC-bgp-default] peer 2.2.2.2 group group1
[SwitchC-bgp-default] peer 88.88.88.88 as-number 200
[SwitchC-bgp-default] peer 88.88.88.88 connect-interface LoopBack0
[SwitchC-bgp-default] peer 88.88.88.88 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] peer group1 enable
[SwitchC-bgp-default-evpn] peer group1 next-hop-local
[SwitchC-bgp-default-evpn] peer group1 reflect-client
[SwitchC-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchC-bgp-default-evpn] peer 88.88.88.88 router-mac-local
[SwitchC] ip vpn-instance vpn1
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:3
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity
[SwitchC-vpn-instance-vpn1] quit
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchC-Vsi-interface2] l3-vni 1000
[SwitchC-Vsi-interface2] pim sm
[SwitchC-Vsi-interface2] quit
[SwitchC] multicast routing vpn-instance vpn1
[SwitchC-mrib-vpn1] quit
# Create an MDT-based MVXLAN for VPN instance vpn1 and enter MVXLAN IPv4 address family view. Configure the default group, MVXLAN source interface, and data group range settings, and enable multicast DCI.
[SwitchC] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchC-mvxlan-vpn1] address-family ipv4
[SwitchC-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchC-mvxlan-vpn1-ipv4] source loopback 0
[SwitchC-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchC-mvxlan-vpn1-ipv4] dci enable
[SwitchC-mvxlan-vpn1-ipv4] quit
[SwitchC-mvxlan-vpn1] quit
[SwitchC-LoopBack1] ip binding vpn-instance vpn1
[SwitchC-LoopBack1] ip address 77.77.77.77 32
[SwitchC] pim vpn-instance vpn1
[SwitchC-pim-vpn1] c-bsr 77.77.77.77
[SwitchC-pim-vpn1] c-rp 77.77.77.77
[SwitchC-pim-vpn1] quit
[SwitchD] l2vpn enable
[SwitchD-mrib] quit
[SwitchD] rip 1
[SwitchD-rip-1] quit
[SwitchD] igmp-snooping
[SwitchD-igmp-snooping] quit
[SwitchD]vxlan tunnel mac-learning disable
[SwitchD]vxlan tunnel arp-learning disable
[SwitchD] interface loopback 0
[SwitchD-LoopBack0] ip address 88.88.88.88 32
[SwitchD-LoopBack0] pim sm
[SwitchD-LoopBack0] rip 1 enable
[SwitchD-LoopBack0] ospf 1 area 0.0.0.0
[SwitchD-LoopBack0] quit
[SwitchD] interface vlan-interface 70
[SwitchD-Vlan-interface70] ip address 78.1.1.2 255.255.255.0
[SwitchD-Vlan-interface70] rip 1 enable
[SwitchD-Vlan-interface70] dci enable
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 4.4.4.4 as-number 200
[SwitchD-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchD-bgp-default] peer 77.77.77.77 as-number 100
[SwitchD-bgp-default] peer 77.77.77.77 connect-interface loopback 0
[SwitchD-bgp-default] peer 77.77.77.77 ebgp-max-hop 64
[SwitchD-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchD-bgp-default-evpn] peer 4.4.4.4 next-hop-local
[SwitchD-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchD-bgp-default-evpn] peer 77.77.77.77 router-mac-local
[SwitchD] ip vpn-instance vpn1
[SwitchD-vpn-instance-vpn1] route-distinguisher 2:1
[SwitchD-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchD-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity
[SwitchD-vpn-instance-vpn1] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchD-Vsi-interface2] l3-vni 1000
[SwitchD-Vsi-interface2] pim sm
[SwitchD-Vsi-interface2] quit
[SwitchD] multicast routing vpn-instance vpn1
[SwitchD-mrib-vpn1] quit
[SwitchD] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchD-mvxlan-vpn1] address-family ipv4
[SwitchD-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchD-mvxlan-vpn1-ipv4] source loopback 0
[SwitchD-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchD-mvxlan-vpn1-ipv4] dci enable
[SwitchD-mvxlan-vpn1-ipv4] quit
[SwitchD-mvxlan-vpn1] quit
[SwitchD] interface loopback 1
[SwitchD-LoopBack1] ip binding vpn-instance vpn1
[SwitchD-LoopBack1] ip address 88.88.88.88 32
[SwitchD-LoopBack1] pim sm
[SwitchD-LoopBack1] quit
[SwitchD] pim vpn-instance vpn1
[SwitchD-pim-vpn1] c-bsr 88.88.88.88
[SwitchD-pim-vpn1] c-rp 88.88.88.88
[SwitchD-pim-vpn1] quit
7.     Configure Switch E:
# Enable L2VPN and IP multicast routing, and create VLAN 21.
<SwitchE> system-view
[SwitchE] l2vpn enable
[SwitchE] multicast routing
[SwitchE-mrib] quit
[SwitchE] vlan 21
[SwitchE-vlan21] quit
[SwitchE] igmp-snooping
[SwitchE-igmp-snooping] quit
[SwitchE] vxlan tunnel mac-learning disable
[SwitchE] vxlan tunnel arp-learning disable
[SwitchE] interface loopback 0
[SwitchE-LoopBack0] ip address 4.4.4.4 32
[SwitchE-LoopBack0] pim sm
[SwitchE-LoopBack0] ospf 1 area 0.0.0.0
[SwitchE-LoopBack0] quit
[SwitchE] vsi vpna
[SwitchE-vsi-vpna] evpn encapsulation vxlan
[SwitchE-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchE-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchE-vsi-vpna-evpn-vxlan] quit
[SwitchE-vsi-vpna] igmp-snooping enable
[SwitchE-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 21.
[SwitchE-vsi-vpna] vxlan 21
[SwitchE-vsi-vpna-vxlan-21] quit
[SwitchE-vsi-vpna] quit
[SwitchE] bgp 200
[SwitchE-bgp-default] peer 88.88.88.88 as-number 200
[SwitchE-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchE-bgp-default] address-family l2vpn evpn
[SwitchE-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchE-bgp-default-evpn] peer 88.88.88.88 next-hop-local
[SwitchE-bgp-default-evpn] quit
[SwitchE-bgp-default] quit
# On Twenty-FiveGigE 1/0/1, create Ethernet service instance 100 to match VLAN 21.
[SwitchE] interface twenty-fivegige 1/0/1
[SwitchE-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchE-Twenty-FiveGigE1/0/1] port trunk permit vlan 1 21
[SwitchE-Twenty-FiveGigE1/0/1] service-instance 100
[SwitchE-Twenty-FiveGigE1/0/1-srv100] encapsulation s-vid 21
[SwitchE-Twenty-FiveGigE1/0/1-srv100] xconnect vsi vpna
[SwitchE-Twenty-FiveGigE1/0/1-srv100] quit
[SwitchE] ip vpn-instance vpn1
[SwitchE-vpn-instance-vpn1] route-distinguisher 2:3
[SwitchE-vpn-instance-vpn1] vpn-target 10:10 20:20 30:30 import-extcommunity
[SwitchE-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity
[SwitchE-vpn-instance-vpn1] quit
[SwitchE] interface vsi-interface 1
[SwitchE-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchE-Vsi-interface1] ip address 192.168.40.1 255.255.255.0
[SwitchE-Vsi-interface1] pim sm
[SwitchE-Vsi-interface1] igmp enable
[SwitchE-Vsi-interface1] distributed-gateway local
[SwitchE-Vsi-interface1] quit
[SwitchE] interface vsi-interface 2
[SwitchE-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchE-Vsi-interface2] l3-vni 1000
[SwitchE-Vsi-interface2] pim sm
[SwitchE-Vsi-interface2] quit
[SwitchE] multicast routing vpn-instance vpn1
[SwitchE-mrib-vpn1] quit
[SwitchE] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchE-mvxlan-vpn1] address-family ipv4
[SwitchE-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchE-mvxlan-vpn1-ipv4] source loopback 0
[SwitchE-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchE-mvxlan-vpn1-ipv4] s-pmsi advertise source-active
[SwitchE-mvxlan-vpn1-ipv4] quit
[SwitchE-mvxlan-vpn1] quit
[SwitchE] interface loopback 1
[SwitchE-LoopBack1] ip binding vpn-instance vpn1
[SwitchE-LoopBack1] ip address 4.4.4.4 32
[SwitchE-LoopBack1] pim sm
[SwitchE-LoopBack1] quit
[SwitchE] pim vpn-instance vpn1
[SwitchE-pim-vpn1] c-bsr 4.4.4.4
[SwitchE-pim-vpn1] c-rp 4.4.4.4
[SwitchE-pim-vpn1] quit
[SwitchE] vsi vpna
[SwitchE-vsi-vpna] gateway vsi-interface 1
1.     Verify the multicast routing information on Switch A, Switch B, and Switch E. This step uses Switch A as an example.
# Verify that Switch A has multicast routing entries for VPN instance vpn1.
<SwitchA> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: 1.1.1.1 (local)
     UpTime: 01:19:10
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: MTunnel0
             Protocol: MD, UpTime: 01:19:10, Expires: -
 (192.168.10.2, 225.0.0.1)
     RP: 1.1.1.1 (local)
     UpTime: 03:27:40
         1: MTunnel1
             Protocol: MD, UpTime: 01:19:06, Expires: -
 Total 0 (*, G) entries; 4 (S, G) entries
 (1.1.1.1, 239.0.0.1)
     RP: NULL
     UpTime: 03:43:30
     Upstream interface: MTunnel0 (VPN: vpn1)
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:19:18, Expires: 00:03:15
 (2.2.2.2, 239.0.0.1)
     RP: NULL
     UpTime: 01:18:42
     Upstream interface: Vlan-interface10
         Upstream neighbor: 11.1.1.2
         RPF prime neighbor: 11.1.1.2
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:42, Expires: -
 (77.77.77.77, 239.0.0.1)
     RP: NULL
     UpTime: 01:19:16
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:19:16, Expires: -
 (1.1.1.1, 239.1.1.0)
     RP: NULL
     UpTime: 01:19:16
     Upstream interface: MTunnel1 (VPN: vpn1)
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:19:01, Expires: 00:02:30
2.     Verify the multicast routing information on the EDs. This step uses Switch C as an example.
# Verify that Switch C has multicast routing entries for VPN instance vpn1.
<SwitchC> display pim vpn-instance vpn1 routing-table
 (*, 225.0.0.1)
     RP: 77.77.77.77 (local)
     UpTime: 01:18:39
         1: Vsi-interface2
             Protocol: MD, UpTime: 01:18:39, Expires: -
         2: MTunnel0
             Protocol: MD, UpTime: 01:18:05, Expires: -
     Protocol: pim-sm, Flag: SPT ACT RQ SRC-ACT 2MVPN FROMVXLAN
     UpTime: 01:18:39
         1: Vsi-interface2
# Verify that Switch C has multicast routing entries for the public network.
     RP: NULL
     UpTime: 01:18:46
         Upstream neighbor: 11.1.1.1
         RPF prime neighbor: 11.1.1.1
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 01:18:11, Expires: 00:03:17
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:44, Expires: -
     RP: NULL
     UpTime: 01:18:11
         Upstream neighbor: 12.1.1.1
         RPF prime neighbor: 12.1.1.1
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:18:11, Expires: 00:03:15
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:11, Expires: -
     RP: NULL
     UpTime: 01:19:30
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:18:44, Expires: 00:02:42
         2: Vlan-interface20
     RP: NULL
     UpTime: 01:18:46
         1: Vlan-interface20
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:18:30, Expires: -
# Verify that IGMP snooping has learned multicast group entries through EVPN on Switch C.
<SwitchC> display igmp-snooping evpn-group
Total 2 entries.
VSI Auto_L3VNI1000_2: Total 2 entries.
  (0.0.0.0, 225.0.0.1)
    Host ports (1 in total):
      Tun0 (VXLAN ID 1000)
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to the same intermediate L3 VXLAN ID
As shown in Figure 15, the multicast source of multicast group 225.0.0.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B, Switch E, and Switch G. Configure DCI Layer 3 multicast as follows:
·     For DC 3, configure Switch G as a VTEP, and configure Switch F as an ED.
·     On Switch A, Switch B, Switch E, and Switch G, configure PIM SM on the public-network interfaces. Enable IGMP snooping on Switch B, Switch E, and Switch G.
·     For DC 1, assign L3 VXLAN ID 1001 to VPN instance vpn1. For DC 2, assign L3 VXLAN ID 1002 to VPN instance vpn1. For DC 3, assign L3 VXLAN ID 1003 to VPN instance vpn1.
·     On Switch C, Switch D, and Switch F, create intermediate VPN instance vpn2 and assign L3 VXLAN ID 1000 to it.
Figure 15 Network diagram
1.     On the multicast source, specify 192.168.10.1 as the gateway address. On Receiver 1, specify 192.168.20.1 as the gateway address. On Receiver 2, specify 192.168.40.1 as the gateway address. On Receiver 3, specify 192.168.60.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 15. (Details not shown.)
[SwitchA-mrib] quit
# Create VLAN 11 and enter its view.
[SwitchA] vlan 11
[SwitchA] vsi vpna
# Create VXLAN 11.
[SwitchA] bgp 100
[SwitchA-vpn-instance-vpn1] vpn-target 10:10 import-extcommunity
# Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1001 for the VPN instance.
[SwitchA-Vsi-interface3] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface3] l3-vni 1001
[SwitchA] vsi vpna
# Enable L2VPN and IP multicast routing.
[SwitchB-mrib] quit
# Enable the IGMP snooping feature.
# Disable remote MAC address learning and remote ARP learning.
# Create VLAN 12 and enter its view.
[SwitchB] vlan 12
[SwitchB] vsi vpna
# Create VXLAN 12.
[SwitchB] bgp 100
[SwitchB-vpn-instance-vpn1] vpn-target 10:10 import-extcommunity
[SwitchB-Vsi-interface2] l3-vni 1001
[SwitchB] vsi vpna
[SwitchC-mrib] quit
# Configure a route policy to disable Switch C from forwarding the SMET and S-PMSI routes received from Switch D to Switch F and from forwarding the SMET and S-PMSI routes received from Switch F to Switch D.
[SwitchC] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchC] ip prefix-list 8 index 10 permit 99.99.99.99 32
[SwitchC] ip prefix-list 9 index 10 permit 88.88.88.88 32
[SwitchC] route-policy 8 deny node 0
[SwitchC-route-policy-8-0] if-match ip route-source prefix-list 8
[SwitchC-route-policy-8-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-8-0] quit
[SwitchC] route-policy 8 permit node 1
[SwitchC-route-policy-8-1] if-match ip route-source prefix-list 1
[SwitchC-route-policy-8-1] quit
[SwitchC] route-policy 9 deny node 0
[SwitchC-route-policy-9-0] if-match ip route-source prefix-list 9
[SwitchC-route-policy-9-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchC-route-policy-9-0] quit
[SwitchC] route-policy 9 permit node 1
[SwitchC-route-policy-9-1] if-match ip route-source prefix-list 1
[SwitchC-route-policy-9-1] quit
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 88.88.88.88 connect-interface loopback 0
[SwitchC-bgp-default] peer 99.99.99.99 as-number 300
[SwitchC-bgp-default] peer 99.99.99.99 connect-interface loopback 0
[SwitchC-bgp-default] peer 99.99.99.99 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] peer group1 re-originated replace-rt
[SwitchC-bgp-default-evpn] peer group1 re-originated mac-ip replace-rt
[SwitchC-bgp-default-evpn] peer group1 re-originated imet replace-rt
[SwitchC-bgp-default-evpn] peer group1 advertise original-route
[SwitchC-bgp-default-evpn] peer group1 re-originated smet replace-rt
[SwitchC-bgp-default-evpn] peer group1 re-originated s-pmsi replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 route-policy 8 export
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated mac-ip replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated imet replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated smet replace-rt
[SwitchC-bgp-default-evpn] peer 88.88.88.88 re-originated s-pmsi replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 enable
[SwitchC-bgp-default-evpn] peer 99.99.99.99 route-policy 9 export
[SwitchC-bgp-default-evpn] peer 99.99.99.99 router-mac-local
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated mac-ip replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated imet replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated smet replace-rt
[SwitchC-bgp-default-evpn] peer 99.99.99.99 re-originated s-pmsi replace-rt
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 export-extcommunity [SwitchC-vpn-instance-vpn1] quit
# Configure RD and route target settings for VPN instance vpn2.
[SwitchC] ip vpn-instance vpn2
[SwitchC-vpn-instance-vpn2] route-distinguisher 1:13
[SwitchC-vpn-instance-vpn2] vpn-target 10:10 200:200 300:300 import-extcommunity
[SwitchC-vpn-instance-vpn2] vpn-target 100:100 export-extcommunity [SwitchC-vpn-instance-vpn2] quit
# Associate VSI-interface 1 with VPN instance vpn1, and configure the L3 VXLAN ID as 1001 for the VPN instance.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchC-Vsi-interface1] l3-vni 1001
[SwitchC-Vsi-interface1] pim sm
[SwitchC-Vsi-interface1] quit
# Associate VSI-interface 2 with VPN instance vpn2, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchC-Vsi-interface2] ip binding vpn-instance vpn2
# Enable IP multicast routing for VPN instance vpn2.
[SwitchC] multicast routing vpn-instance vpn2
[SwitchC-mrib-vpn2] quit
# Configure VLAN-interface 70 that is connected to remote EDs.
[SwitchC-Vlan-interface70] ospf 1 area 0.0.0.0
[SwitchC-Vlan-interface70] quit
# Configure VLAN-interface 90 that is connected to remote EDs.
[SwitchC] interface vlan-interface 90
[SwitchC-Vlan-interface90] ip address 79.1.1.1 255.255.255.0
[SwitchC-Vlan-interface90] ospf 1 area 0.0.0.0
[SwitchC-Vlan-interface90] dci enable
[SwitchC-Vlan-interface90] quit
[SwitchC-LoopBack2] ip binding vpn-instance vpn2
[SwitchC-LoopBack2] ip address 77.77.77.77 32
# Enter VPN instance PIM view, and configure Loopback 2 as a candidate-BSR and candidate-RP in VPN instance vpn2.
[SwitchC] pim vpn-instance vpn2
[SwitchC-pim-vpn2] c-bsr 77.77.77.77
[SwitchC-pim-vpn2] c-rp 77.77.77.77
[SwitchC-pim-vpn2] quit
[SwitchD-mrib] quit
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
# Configure a route policy to disable Switch D from forwarding the SMET and S-PMSI routes received from Switch C to Switch F and from forwarding the SMET and S-PMSI routes received from Switch F to Switch C.
[SwitchD] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchD] ip prefix-list 7 index 10 permit 99.99.99.99 32
[SwitchD] ip prefix-list 9 index 10 permit 77.77.77.77 32
[SwitchD] route-policy 7 deny node 0
[SwitchD-route-policy-7-0] if-match ip route-source prefix-list 7
[SwitchD-route-policy-7-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-7-0] quit
[SwitchD] route-policy 7 permit node 1
[SwitchD-route-policy-7-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-7-1] quit
[SwitchD] route-policy 9 deny node 0
[SwitchD-route-policy-9-0] if-match ip route-source prefix-list 9
[SwitchD-route-policy-9-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchD-route-policy-9-0] quit
[SwitchD] route-policy 9 permit node 1
[SwitchD-route-policy-9-1] if-match ip route-source prefix-list 1
[SwitchD-route-policy-9-1] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 4.4.4.4 connect-interface LoopBack0
[SwitchD-bgp-default] peer 77.77.77.77 connect-interface LoopBack0
[SwitchD-bgp-default] peer 99.99.99.99 as-number 300
[SwitchD-bgp-default] peer 99.99.99.99 connect-interface LoopBack0
[SwitchD-bgp-default] peer 99.99.99.99 ebgp-max-hop 64
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 4.4.4.4 re-originated s-pmsi replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 route-policy 7 export
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 77.77.77.77 re-originated s-pmsi replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 enable
[SwitchD-bgp-default-evpn] peer 99.99.99.99 route-policy 9 export
[SwitchD-bgp-default-evpn] peer 99.99.99.99 router-mac-local
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated mac-ip replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated imet replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated smet replace-rt
[SwitchD-bgp-default-evpn] peer 99.99.99.99 re-originated s-pmsi replace-rt
[SwitchD-vpn-instance-vpn1] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchD-vpn-instance-vpn1] vpn-target 20:20 export-extcommunity [SwitchD-vpn-instance-vpn1] quit
[SwitchD] ip vpn-instance vpn2
[SwitchD-vpn-instance-vpn2] route-distinguisher 2:11
[SwitchD-vpn-instance-vpn2] vpn-target 20:20 100:100 300:300 import-extcommunity
[SwitchD-vpn-instance-vpn2] vpn-target 200:200 export-extcommunity [SwitchD-vpn-instance-vpn2] quit
# Associate VSI-interface 1 with VPN instance vpn1, and configure the L3 VXLAN ID as 1002 for the VPN instance.
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchD-Vsi-interface1] l3-vni 1002
[SwitchD-Vsi-interface1] pim sm
[SwitchD-Vsi-interface1] quit
[SwitchD-Vsi-interface2] ip binding vpn-instance vpn2
[SwitchD] multicast routing vpn-instance vpn2
[SwitchD-mrib-vpn2] quit
[SwitchD-Vlan-interface70] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface70] quit
# Configure VLAN-interface 80 that is connected to remote EDs.
[SwitchD] interface vlan-interface 80
[SwitchD-Vlan-interface80] ip address 89.1.1.1 255.255.255.0
[SwitchD-Vlan-interface80] ospf 1 area 0.0.0.0
[SwitchD-Vlan-interface80] dci enable
[SwitchD-Vlan-interface80] quit
# Configure Loopback 1.
[SwitchD] interface loopback 2
[SwitchD-LoopBack2] ip binding vpn-instance vpn2
[SwitchD-LoopBack2] ip address 88.88.88.88 32
[SwitchD-LoopBack2] pim sm
[SwitchD-LoopBack2] quit
[SwitchD] pim vpn-instance vpn2
[SwitchD-pim-vpn2] c-bsr 88.88.88.88
[SwitchD-pim-vpn2] c-rp 88.88.88.88
[SwitchD-pim-vpn2] quit
[SwitchE-mrib] quit
# Create VLAN 21 and enter its view.
[SwitchE] vlan 21
[SwitchE-vlan12] quit
# Create an EVPN instance on VSI vpna.
[SwitchE] vsi vpna
# Enable IGMP snooping and IGMP snooping proxying on VSI vpna.
# Create VXLAN 21.
[SwitchE] bgp 200
[SwitchE-vpn-instance-vpn1] vpn-target 20:20 import-extcommunity
# Configure VSI-interface 1.
# Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1002 for the VPN instance.
[SwitchE-Vsi-interface2] l3-vni 1002
[SwitchE] vsi vpna
8.     Configure Switch F:
<SwitchF> system-view
[SwitchF] l2vpn enable
[SwitchF] multicast routing
[SwitchF-mrib] quit
[SwitchF] vxlan tunnel mac-learning disable
[SwitchF] vxlan tunnel arp-learning disable
# Configure a route policy to disable Switch F from forwarding the SMET and S-PMSI routes received from Switch C to Switch D and from forwarding the SMET and S-PMSI routes received from Switch D to Switch C.
[SwitchF] ip prefix-list 1 index 10 permit 0.0.0.0 0 less-equal 32
[SwitchF] ip prefix-list 7 index 10 permit 88.88.88.88 32
[SwitchF] ip prefix-list 8 index 10 permit 77.77.77.77 32
[SwitchF] route-policy 7 deny node 0
[SwitchF-route-policy-7-0] if-match ip route-source prefix-list 7
[SwitchF-route-policy-7-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-7-0] quit
[SwitchF] route-policy 7 permit node 1
[SwitchF-route-policy-7-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-7-1] quit
[SwitchF] route-policy 8 deny node 0
[SwitchF-route-policy-8-0] if-match ip route-source prefix-list 8
[SwitchF-route-policy-8-0] if-match route-type bgp-evpn-smet bgp-evpn-s-pmsi
[SwitchF-route-policy-8-0] quit
[SwitchF] route-policy 8 permit node 1
[SwitchF-route-policy-8-1] if-match ip route-source prefix-list 1
[SwitchF-route-policy-8-1] quit
[SwitchF] bgp 300
[SwitchF-bgp-default] peer 6.6.6.6 as-number 300
[SwitchF-bgp-default] peer 6.6.6.6 connect-interface LoopBack0
[SwitchF-bgp-default] peer 77.77.77.77 as-number 100
[SwitchF-bgp-default] peer 77.77.77.77 connect-interface LoopBack0
[SwitchF-bgp-default] peer 77.77.77.77 ebgp-max-hop 64
[SwitchF-bgp-default] peer 88.88.88.88 as-number 200
[SwitchF-bgp-default] peer 88.88.88.88 connect-interface LoopBack0
[SwitchF-bgp-default] peer 88.88.88.88 ebgp-max-hop 64
[SwitchF-bgp-default] address-family l2vpn evpn
[SwitchF-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchF-bgp-default-evpn] peer 6.6.6.6 next-hop-local
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 6.6.6.6 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 enable
[SwitchF-bgp-default-evpn] peer 77.77.77.77 route-policy 7 export
[SwitchF-bgp-default-evpn] peer 77.77.77.77 router-mac-local
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 77.77.77.77 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 enable
[SwitchF-bgp-default-evpn] peer 88.88.88.88 route-policy 8 export
[SwitchF-bgp-default-evpn] peer 88.88.88.88 router-mac-local
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated mac-ip replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated imet replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated smet replace-rt
[SwitchF-bgp-default-evpn] peer 88.88.88.88 re-originated s-pmsi replace-rt
[SwitchF-bgp-default-evpn] quit
[SwitchF-bgp-default] quit
[SwitchF] ip vpn-instance vpn1
[SwitchF-vpn-instance-vpn1] route-distinguisher 3:1
[SwitchF-vpn-instance-vpn1] vpn-target 30:30 100:100 200:200 import-extcommunity
[SwitchF-vpn-instance-vpn1] vpn-target 30:30 export-extcommunity [SwitchF-vpn-instance-vpn1] quit
[SwitchF] ip vpn-instance vpn2
[SwitchF-vpn-instance-vpn2] route-distinguisher 3:11
[SwitchF-vpn-instance-vpn2] vpn-target 30:30 100:100 200:200 import-extcommunity
[SwitchF-vpn-instance-vpn2] vpn-target 300:300 export-extcommunity [SwitchF-vpn-instance-vpn2] quit
# Associate VSI-interface 1 with VPN instance vpn1, and configure the L3 VXLAN ID as 1003 for the VPN instance.
[SwitchF] interface vsi-interface 1
[SwitchF-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchF-Vsi-interface1] l3-vni 1003
[SwitchF-Vsi-interface1] pim sm
[SwitchF-Vsi-interface1] quit
[SwitchF] interface vsi-interface 2
[SwitchF-Vsi-interface2] ip binding vpn-instance vpn2
[SwitchF-Vsi-interface2] l3-vni 1000
[SwitchF-Vsi-interface2] pim sm
[SwitchF-Vsi-interface2] quit
[SwitchF] multicast routing vpn-instance vpn1
[SwitchF-mrib-vpn1] quit
[SwitchF] multicast routing vpn-instance vpn2
[SwitchF-mrib-vpn2] quit
[SwitchF] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchF-mvxlan-vpn1] address-family ipv4
[SwitchF-mvxlan-vpn1-ipv4] source loopback 0
[SwitchF-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchF-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchF-mvxlan-vpn1-ipv4] dci enable
[SwitchF-mvxlan-vpn1-ipv4] quit
[SwitchF-mvxlan-vpn1] quit
[SwitchF] interface vlan-interface 80
[SwitchF-Vlan-interface80] ip address 89.1.1.2 255.255.255.0
[SwitchF-Vlan-interface80] ospf 1 area 0.0.0.0
[SwitchF-Vlan-interface80] dci enable
[SwitchF-Vlan-interface80] quit
[SwitchF] interface vlan-interface 90
[SwitchF-Vlan-interface90] ip address 79.1.1.2 255.255.255.0
[SwitchF-Vlan-interface90] ospf 1 area 0.0.0.0
[SwitchF-Vlan-interface90] dci enable
[SwitchF-Vlan-interface90] quit
[SwitchF] interface loopback 0
[SwitchF-LoopBack0] ip address 99.99.99.99 32
[SwitchF-LoopBack0] ospf 1 area 0.0.0.0
[SwitchF-LoopBack0] pim sm
[SwitchF-LoopBack0] quit
[SwitchF] interface loopback 1
[SwitchF-LoopBack1] ip binding vpn-instance vpn1
[SwitchF-LoopBack1] ip address 99.99.99.99 32
[SwitchF-LoopBack1] pim sm
[SwitchF-LoopBack1] quit
[SwitchF] interface loopback 2
[SwitchF-LoopBack2] ip binding vpn-instance vpn2
[SwitchF-LoopBack2] ip address 99.99.99.99 32
[SwitchF-LoopBack2] pim sm
[SwitchF-LoopBack2] quit
[SwitchF] pim vpn-instance vpn1
[SwitchF-pim-vpn1] c-bsr 99.99.99.99
[SwitchF-pim-vpn1] c-rp 99.99.99.99
[SwitchF-pim-vpn1] quit
[SwitchF] pim vpn-instance vpn2
[SwitchF-pim-vpn2] c-bsr 99.99.99.99
[SwitchF-pim-vpn2] c-rp 99.99.99.99
[SwitchF-pim-vpn2] quit
9.     Configure Switch G:
<SwitchG> system-view
[SwitchG] l2vpn enable
[SwitchG] multicast routing
[SwitchG-mrib] quit
[SwitchG] igmp-snooping
[SwitchG-igmp-snooping] quit
[SwitchG] vxlan tunnel mac-learning disable
[SwitchG] vxlan tunnel arp-learning disable
# Create VLAN 31 and enter its view.
[SwitchG] vlan 31
[SwitchG-vlan31] quit
[SwitchG] vsi vpna
[SwitchG-vsi-vpna] evpn encapsulation vxlan
[SwitchG-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchG-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchG-vsi-vpna-evpn-vxlan] quit
[SwitchG-vsi-vpna] igmp-snooping enable
[SwitchG-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 31.
[SwitchG-vsi-vpna] vxlan 31
[SwitchG-vsi-vpna-vxlan-31] quit
[SwitchG-vsi-vpna] quit
[SwitchG] bgp 300
[SwitchG-bgp-default] peer 99.99.99.99 as-number 200
[SwitchG-bgp-default] peer 99.99.99.99 connect-interface loopback 0
[SwitchG-bgp-default] address-family l2vpn evpn
[SwitchG-bgp-default-evpn] peer 99.99.99.99 enable
[SwitchG-bgp-default-evpn] peer 99.99.99.99 next-hop-local
[SwitchG-bgp-default-evpn] quit
[SwitchG-bgp-default] quit
# On Twenty-FiveGigE 1/0/1, create Ethernet service instance 100 to match VLAN 31.
[SwitchG] interface twenty-fivegige 1/0/1
[SwitchG-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchG-Twenty-FiveGigE1/0/1] port trunk permit vlan 1 31
[SwitchG-Twenty-FiveGigE1/0/1] service-instance 100
[SwitchG-Twenty-FiveGigE1/0/1-srv100] encapsulation s-vid 31
[SwitchG-Twenty-FiveGigE1/0/1-srv100] xconnect vsi vpna
[SwitchG-Twenty-FiveGigE1/0/1-srv100] quit
[SwitchG] ip vpn-instance vpn1
[SwitchG-vpn-instance-vpn1] route-distinguisher 3:2
[SwitchG-vpn-instance-vpn1] vpn-target 30:30 import-extcommunity
[SwitchG-vpn-instance-vpn1] vpn-target 30:30 export-extcommunity
[SwitchG-vpn-instance-vpn1] quit
[SwitchG] interface vsi-interface 1
[SwitchG-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchG-Vsi-interface1] ip address 192.168.60.1 255.255.255.0
[SwitchG-Vsi-interface1] igmp enable
[SwitchG-Vsi-interface1] pim sm
[SwitchG-Vsi-interface1] distributed-gateway local
[SwitchG-Vsi-interface1] quit
[SwitchG] interface vsi-interface 2
[SwitchG-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchG-Vsi-interface2] l3-vni 1003
[SwitchG-Vsi-interface2] pim sm
[SwitchG-Vsi-interface2] quit
[SwitchG] multicast routing vpn-instance vpn1
[SwitchG-mrib-vpn1] quit
[SwitchG] multicast-vpn vxlan vpn-instance vpn1 mode mdt
[SwitchG-mvxlan-vpn1] address-family ipv4
[SwitchG-mvxlan-vpn1-ipv4] source loopback 0
[SwitchG-mvxlan-vpn1-ipv4] default-group 239.0.0.1
[SwitchG-mvxlan-vpn1-ipv4] data-group 239.1.1.0 24
[SwitchG-mvxlan-vpn1-ipv4] quit
[SwitchG-mvxlan-vpn1] quit
[SwitchG] interface loopback 0
[SwitchG-LoopBack0] ip address 6.6.6.6 32
[SwitchG-LoopBack0] ospf 1 area 0.0.0.0
[SwitchG-LoopBack0] pim sm
[SwitchG-LoopBack0] quit
[SwitchG] interface loopback 1
[SwitchG-LoopBack1] ip binding vpn-instance vpn1
[SwitchG-LoopBack1] ip address 6.6.6.6 32
[SwitchG-LoopBack1] pim sm
[SwitchG-LoopBack1] quit
[SwitchG] pim vpn-instance vpn1
[SwitchG-pim-vpn1] c-bsr 6.6.6.6
[SwitchG-pim-vpn1] c-rp 6.6.6.6
[SwitchG-pim-vpn1] quit
[SwitchG] vsi vpna
[SwitchG-vsi-vpna] gateway vsi-interface 1
1.     Verify the multicast routing information on Switch A, Switch B, Switch E, and Switch G. This step uses Switch A as an example.
<SwitchA> display pim vpn-instance vpn routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 225.0.1.1)
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: WC RC
     UpTime: 02:57:31
     Upstream interface: Register-Tunnel0
         1: MTunnel0
             Protocol: MD, UpTime: 02:57:31, Expires: -
(192.168.10.10, 225.0.1.1)
     RP: 1.1.1.1 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP LOC ACT SQ RC 2MVPN
     UpTime: 04:44:08
     Upstream interface: Vsi-interface1
         1: MTunnel1
             Protocol: MD, UpTime: 02:00:27, Expires: -
# Verify that Switch A has multicast routing entries for the public network.
<SwitchA> display pim routing-table
     RP: NULL
     Protocol: pim-sm, Flag: SPT LOC VXLAN_L3
     UpTime: 01:08:58
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:08:06, Expires: 00:03:26
     RP: NULL
     UpTime: 01:07:53
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:07:53, Expires: -
     RP: NULL
     UpTime: 01:08:06
         1: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:08:06, Expires: -
     RP: NULL
     UpTime: 01:07:53
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:07:53, Expires: 00:02:39
 (*, 225.0.1.1)
     UpTime: 01:29:29
         1: MTunnel0
             Protocol: MD, UpTime: 01:29:29, Expires: -
     UpTime: 01:29:42
     Upstream interface: MVXLAN-UPE0 (0.0.0.0)
         1: Extranet (VPN: vpn2)
             Protocol: MD, UpTime: 01:29:37, Expires: -
# Verify that Switch C has multicast routing entries for VPN instance vpn2.
<SwitchC> display  pim vpn-instance vpn2 routing-table
 (*, 225.0.1.1)
     UpTime: 01:39:28
         1: Vsi-interface3
             Protocol: MD, UpTime: 01:39:28, Expires: -
     UpTime: 01:39:24
     Upstream interface: Extranet (VPN: vpn1)
         1: Vsi-interface3
             Protocol: MD, UpTime: 01:39:24, Expires: -
     RP: NULL
     UpTime: 01:29:21
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 01:29:07, Expires: 00:03:25
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:29:21, Expires: -
     RP: NULL
     UpTime: 01:29:08
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:29:07, Expires: 00:03:20
         2: MVXLAN-UPE0
             Protocol: MD, UpTime: 01:29:08, Expires: -
     RP: NULL
     UpTime: 01:30:55
         1: Vlan-interface10
             Protocol: pim-sm, UpTime: 01:29:21, Expires: 00:03:07
         2: Vlan-interface20
     RP: NULL
     UpTime: 01:29:08
         1: Vlan-interface20
         2: MVXLAN-UPE0
Example: Configuring DCI Layer 3 multicast with multiple L3 VXLAN IDs mapped to different intermediate L3 VXLAN IDs
As shown in Figure 16, the multicast source of multicast group 225.0.1.1 is attached to Switch A, and the receivers of the multicast group are attached to Switch B, Switch E, and Switch G. All receivers reside in VPN instance vpn1. Configure DCI Layer 3 multicast as follows:
·     On Switch C and Switch D, create intermediate VPN instance vpn2 and assign L3 VXLAN ID 1122 to it.
·     On Switch C and Switch F, create intermediate VPN instance vpn4 and assign L3 VXLAN ID 1133 to it.
Figure 16 Network diagram
# Assign IP addresses to interfaces, as shown in Figure 16. (Details not shown.)
3.     Configure Switch A:
[SwitchA] l2vpn enable
[SwitchA-mrib] quit
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
[SwitchA] vlan 11
[SwitchA-vlan11] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
[SwitchA-vsi-vpna] igmp-snooping enable
[SwitchA-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 11.
[SwitchA-vsi-vpna] quit
[SwitchA] bgp 100
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
[SwitchA] interface twenty-fivegige 1/0/1
[SwitchA-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchA-Twenty-FiveGigE1/0/1] service-instance 100
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] pim sm
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface3] pim sm
[SwitchA-Vsi-interface3] quit
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] pim sm
[SwitchA-LoopBack1] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
4.     Configure Switch B:
[SwitchB] l2vpn enable
[SwitchB-mrib] quit
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vlan 12
[SwitchB-vlan12] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
[SwitchB-vsi-vpna] igmp-snooping enable
[SwitchB-vsi-vpna] igmp-snooping proxy enable
# Create VXLAN 12.
[SwitchB-vsi-vpna] quit
[SwitchB] bgp 100
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
[SwitchB] interface twenty-fivegige 1/0/1
[SwitchB-Twenty-FiveGigE1/0/1] port link-type trunk
[SwitchB-Twenty-FiveGigE1/0/1] service-instance 100
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] igmp enable
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] quit
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] pim sm
[SwitchB-LoopBack1] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
5.     Configure Switch C:
[SwitchC] l2vpn enable
[SwitchC-mrib] quit
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
[SwitchC] bgp 100
[SwitchC-bgp-default] peer group1 connect-interface LoopBack0
[SwitchC-bgp-default] peer 99.99.99.99 connect-interface LoopBack0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:1
[SwitchC-vpn-instance-vpn1] vpn-target 10:10 200:200 3000:3000 import-extcommunity
[SwitchC-vpn-instance-vpn2] route-distinguisher 1:11
[SwitchC-vpn-instance-vpn2] vpn-target 10:10 200:200 import-extcommunity
# Configure RD and route target settings for VPN instance vpn4.
[SwitchC] ip vpn-instance vpn4
[SwitchC-vpn-instance-vpn4] route-distinguisher 1:111
[SwitchC-vpn-instance-vpn4] vpn-target 10:10 3000:3000 import-extcommunity
[SwitchC-vpn-instance-vpn4] vpn-target 1000:1000 export-extcommunity [SwitchC-vpn-instance-vpn4] quit
# Associate VSI-interface 2 with VPN instance vpn2, and configure the L3 VXLAN ID as 1122 for the VPN instance.
[SwitchC-Vsi-interface2] l3-vni 1122
# Associate VSI-interface 4 with VPN instance vpn4, and configure the L3 VXLAN ID as 1133 for the VPN instance.
[SwitchC-Vsi-interface4] ip binding vpn-instance vpn4
[SwitchC-Vsi-interface4] l3-vni 1133
# Enable IP multicast routing for VPN instance vpn4.
[SwitchC] multicast routing vpn-instance vpn4
[SwitchC-mrib-vpn4] quit
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
# Configure Loopback 2.
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] pim sm
[SwitchC-LoopBack2] quit
# Configure Loopback 4.
[SwitchC] interface loopback 4
[SwitchC-LoopBack4] ip binding vpn-instance vpn4
[SwitchC-LoopBack4] ip address 77.77.77.77 32
[SwitchC-LoopBack4] pim sm
[SwitchC-LoopBack4] quit
# Enter VPN instance PIM view, and configure Loopback 4 as a candidate-BSR and candidate-RP in VPN instance vpn4.
[SwitchC] pim vpn-instance vpn4
[SwitchC-pim-vpn4] c-bsr 77.77.77.77
[SwitchC-pim-vpn4] c-rp 77.77.77.77
[SwitchC-pim-vpn4] quit
6.     Configure Switch D:
<SwitchD> system-view
[SwitchD-mrib] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 99.99.99.99 connect-interface loopback 0
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
[SwitchD-vpn-instance-vpn2] vpn-target 20:20 100:100 import-extcommunity
# Configure RD and route target settings for VPN instance vpn3.
[SwitchD] ip vpn-instance vpn3
[SwitchD-vpn-instance-vpn3] route-distinguisher 2:111
[SwitchD-vpn-instance-vpn3] vpn-target 20:20 300:300 import-extcommunity
[SwitchD-vpn-instance-vpn3] vpn-target 2000:2000 export-extcommunity [SwitchD-vpn-instance-vpn3] quit
[SwitchD-Vsi-interface2] l3-vni 1122
# Associate VSI-interface 3 with VPN instance vpn3, and configure the L3 VXLAN ID as 2233 for the VPN instance.
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpn3
[SwitchD-Vsi-interface3] l3-vni 2233
[SwitchD-Vsi-interface3] pim sm
[SwitchD-Vsi-interface3] quit
# Enable IP multicast routing for VPN instance vpn3.
[SwitchD] multicast routing vpn-instance vpn3
[SwitchD-mrib-vpn3] quit
# Configure Loopback 3.
[SwitchD] interface loopback 3
[SwitchD-LoopBack3] ip binding vpn-instance vpn3
[SwitchD-LoopBack3] ip address 88.88.88.88 32
[SwitchD-LoopBack3] pim sm
[SwitchD-LoopBack3] quit
# Enter VPN instance PIM view, and configure Loopback 3 as a candidate-BSR and candidate-RP in VPN instance vpn3.
[SwitchD] pim vpn-instance vpn3
[SwitchD-pim-vpn3] c-bsr 88.88.88.88
[SwitchD-pim-vpn3] c-rp 88.88.88.88
[SwitchD-pim-vpn3] quit
[SwitchE-mrib] quit
[SwitchE] vlan 21
[SwitchE] vsi vpna
# Create VXLAN 21.
[SwitchE] bgp 200
[SwitchE] vsi vpna
[SwitchF-mrib] quit
[SwitchF] bgp 300
[SwitchF-vpn-instance-vpn1] vpn-target 30:30 1000:1000 2000:2000 import-extcommunity
[SwitchF] ip vpn-instance vpn3
[SwitchF-vpn-instance-vpn3] route-distinguisher 3:11
[SwitchF-vpn-instance-vpn3] vpn-target 30:30 2000:2000 import-extcommunity
[SwitchF-vpn-instance-vpn3] vpn-target 300:300 export-extcommunity [SwitchF-vpn-instance-vpn3] quit
[SwitchF] ip vpn-instance vpn4
[SwitchF-vpn-instance-vpn4] route-distinguisher 3:111
[SwitchF-vpn-instance-vpn4] vpn-target 30:30 1000:1000 import-extcommunity
[SwitchF-vpn-instance-vpn4] vpn-target 3000:3000 export-extcommunity [SwitchF-vpn-instance-vpn4] quit
[SwitchF] interface vsi-interface 3
[SwitchF-Vsi-interface3] ip binding vpn-instance vpn3
[SwitchF-Vsi-interface3] l3-vni 2233
[SwitchF-Vsi-interface3] pim sm
[SwitchF-Vsi-interface3] quit
[SwitchF] interface vsi-interface 4
[SwitchF-Vsi-interface4] ip binding vpn-instance vpn4
[SwitchF-Vsi-interface4] l3-vni 1133
[SwitchF-Vsi-interface4] pim sm
[SwitchF-Vsi-interface4] quit
[SwitchF] multicast routing vpn-instance vpn3
[SwitchF-mrib-vpn3] quit
[SwitchF] multicast routing vpn-instance vpn4
[SwitchF-mrib-vpn4] quit
[SwitchF] interface loopback 3
[SwitchF-LoopBack3] ip binding vpn-instance vpn3
[SwitchF-LoopBack3] ip address 99.99.99.99 32
[SwitchF-LoopBack3] pim sm
[SwitchF-LoopBack3] quit
[SwitchF] interface loopback 4
[SwitchF-LoopBack4] ip binding vpn-instance vpn4
[SwitchF-LoopBack4] ip address 99.99.99.99 32
[SwitchF-LoopBack4] pim sm
[SwitchF-LoopBack4] quit
[SwitchF] pim vpn-instance vpn3
[SwitchF-pim-vpn3] c-bsr 99.99.99.99
[SwitchF-pim-vpn3] c-rp 99.99.99.99
[SwitchF-pim-vpn3] quit
[SwitchF] pim vpn-instance vpn4
[SwitchF-pim-vpn4] c-bsr 99.99.99.99
[SwitchF-pim-vpn4] c-rp 99.99.99.99
[SwitchF-pim-vpn4] quit
[SwitchG-mrib] quit
[SwitchG] vlan 31
[SwitchG] vsi vpna
# Create VXLAN 31.
[SwitchG] bgp 300
[SwitchG] vsi vpna
 (*, 225.0.1.1)
     RP: 1.1.1.1 (local)
     UpTime: 02:57:31
         1: MTunnel0
     RP: 1.1.1.1 (local)
     UpTime: 04:44:08
         1: MTunnel1
     RP: NULL
     UpTime: 01:08:58
         1: Vlan-interface10
     RP: NULL
     UpTime: 01:07:53
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 01:08:06
         1: MVXLAN-UPE0
     RP: NULL
     UpTime: 01:07:53
         1: Vlan-interface10
 (*, 225.0.1.1)
     UpTime: 01:09:14
         1: MTunnel0
             Protocol: MD, UpTime: 01:09:14, Expires: -
     UpTime: 00:58:36
     Total number of downstream interfaces: 2
             Protocol: MD, UpTime: 00:58:36, Expires: -
         2: Extranet (VPN: vpn4)
 (*, 225.0.1.1)
     UpTime: 01:39:28
         1: Vsi-interface3
     UpTime: 01:39:24
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
         1: Vsi-interface3
# Verify that Switch C has multicast routing entries for VPN instance vpn4.
<SwitchC> display pim vpn-instance vpn4 routing-table
 (*, 225.0.1.1)
     UpTime: 01:04:54
         1: Vsi-interface4
             Protocol: MD, UpTime: 01:04:54, Expires: -
     UpTime: 01:00:09
         1: Vsi-interface4
             Protocol: MD, UpTime: 01:00:09, Expires: -
     RP: NULL
     UpTime: 01:29:21
         1: Vlan-interface20
         2: MVXLAN-UPE0
     RP: NULL
     UpTime: 01:29:08
         1: Vlan-interface10
         2: MVXLAN-UPE0
     RP: NULL
     UpTime: 01:30:55
         1: Vlan-interface10
         2: Vlan-interface20
     RP: NULL
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 01:29:08
         1: Vlan-interface20
         2: MVXLAN-UPE0
