- 12-WLAN Advanced Features Configuration Guide
- 01-WLAN optimization configuration
- 02-Hotspot 2.0 configuration
- 03-WLAN probe configuration
- 04-WSA configuration
- 05-Wireless location configuration
- 06-WLAN process maintenance configuration
- 07-Bonjour gateway configuration
- 08-WLAN mesh configuration
- 09-AC hierarchy configuration
| 00-Preface | 100.04 KB |
Preface
The access controllers documentation set describes the software features for the access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The WLAN Advanced Features Configuration Guide describes WLAN advanced feature configurations.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
