02-Fundamentals Configuration Guide
HomeSupportWirelessWBC Series Multiservice Access ControllersConfigure & DeployConfiguration GuidesH3C WBC Series Multservice Access Controllers Configuration Guides(E5448)-6W10002-Fundamentals Configuration Guide
01-CLI configuration
01-CLI configuration 189.27 KB
Using the CLI
About the CLI
At the command-line interface (CLI), you can enter text commands to configure, manage, and monitor the device.
You can use different methods to log in to the CLI. For example, you can log in through Telnet. For more information about login methods, see "Login overview."
Using CLI views
About CLI views
Commands are grouped in different views by feature. To use a command, you must enter its view.
CLI views are hierarchically organized, as shown in Figure 1. Each view has a unique prompt, from which you can identify where you are and what you can do. For example, the prompt [Sysname-vlan100] shows that you are in VLAN 100 view and can configure attributes for that VLAN.
Figure 1 CLI views
You are placed in user view immediately after you log in to the CLI.
In user view, you can perform the following tasks:
·     Perform basic operations including display, debug, file management, FTP, Telnet, clock setting, and reboot.
·     Enter system view.
In system view, you can perform the following tasks:
·     Configure settings that affect the device as a whole, such as the daylight saving time, banners, and hotkeys.
·     Enter feature views.
For example, you can perform the following tasks:
¡     Enter interface view to configure interface parameters.
¡     Enter VLAN view to add ports to the VLAN.
¡     Enter user line view to configure login user attributes.
A feature view might have child views. For example, NQA operation view has the child view HTTP operation view.
To display all commands available in a view, enter a question mark (?) at the view prompt.
Entering system view from user view
To enter system view from user view, execute the following command:
Returning to the upper-level view from a view
Executing the quit command in user view terminates your connection to the device.
To return from public key view to system view, you must use the peer-public-key end command.
To return to the upper-level view from a view, execute the following command:
Returning to user view
This feature enables you to return to user view from any view except Tcl configuration view and Python shell view by performing a single operation. You do not need to execute the quit command multiple times.
To return to user view from Tcl configuration view, use the tclquit command. To return to user view from Python shell view, use the exit() command.
To return directly to user view from any other view except Tcl configuration view and Python shell view, use one of the following methods:
·     Execute the return command.
·     Press Ctrl+Z.
Accessing the CLI online help
The CLI online help is context sensitive. Enter a question mark at any prompt or in any position of a command to display all available options.
To access the CLI online help, use one of the following methods:
·     Enter a question mark at a view prompt to display the first keyword of every command available in the view. For example:
<Sysname> ?
User view commands:
  archive             Archive configuration
  backup              Backup operation
  boot-loader         Software image file management
·     Enter a space and a question mark after a command keyword to display all available keywords and arguments.
¡     If the question mark is in the place of a keyword, the CLI displays all possible keywords, each with a brief description. For example:
<Sysname> terminal ?
  debugging  Enable to display debugging logs on the current terminal
  logging    Display logs on the current terminal
  monitor    Enable to display logs on the current terminal
¡     If the question mark is in the place of an argument, the CLI displays the description for the argument. For example:
[Sysname] interface vlan-interface ?
  <1-4094>  Vlan-interface interface number
[Sysname] interface vlan-interface 1 ?
  <cr>
<1-4094> is the value range for the argument. <cr> indicates that the command is complete and you can press Enter to execute the command.
·     Enter an incomplete keyword string followed by a question mark to display all keywords starting with that string. The CLI also displays the descriptions for the keywords. For example:
<Sysname> f?
  fdisk    Partition a storage medium
  fixdisk   Check and repair a storage medium
  format    Format a storage medium
  free      Release a connection
  ftp       Open an FTP connection
<Sysname> display ftp?
  ftp         FTP module
  ftp-server  FTP server information
  ftp-user    FTP user information
Using the undo form of a command
Most configuration commands have an undo form for the following tasks:
·     Canceling a configuration.
·     Restoring the default.
·     Disabling a feature.
For example, the info-center enable command enables the information center. The undo info-center enable command disables the information center.
Entering a command
When you enter a command, you can perform the following tasks:
·     Use keys or hotkeys to edit the command line.
·     Use abbreviated keywords or keyword aliases.
Editing a command line
To edit a command line, use the keys listed in Table 1 or the hotkeys listed in Table 4. When you are finished, you can press Enter to execute the command.
Table 1 Command line editing keys
Keys
Function
Common keys
If the edit buffer is not full, pressing a common key inserts a character at the cursor and moves the cursor to the right. The edit buffer can store up to 511 characters. Unless the buffer is full, all common characters that you enter before pressing Enter are saved in the edit buffer.
Backspace
Deletes the character to the left of the cursor and moves the cursor back one character.
Left arrow key ()
Moves the cursor one character to the left.
Right arrow key ()
Moves the cursor one character to the right.
Up arrow key ()
Displays the previous command in the command history buffer.
Down arrow key ()
Displays the next command in the command history buffer.
Tab
If you press Tab after typing part of a keyword, the system automatically completes the keyword.
·     If a unique match is found, the system displays the complete keyword.
·     If there is more than one match, press Tab multiple times to pick the keyword you want to enter.
·     If there is no match, the system does not modify what you entered but displays it again in the next line.
The device supports the following special commands:
·     #–Used by the system in a configuration file as separators for adjacent sections.
·     version–Used by the system in a configuration file to indicate the software version information. For example, version 7.1. xxx , Release xxx .
These commands are special because of the following reasons:
·     These commands are not intended for you to use at the CLI.
·     You can enter the # command in any view or the version command in system view, or enter any values for them. For example, you can enter # abc or version abc. However, the settings do not take effect.
·     The device does not provide any online help information for these commands.
Entering a text or string type value for an argument
A text type argument value can contain any characters except question marks (?).
A string type argument value can contain any printable characters except question marks (?).
·     To include a quotation mark (") or backward slash (\) in a string type argument value, prefix the character with an escape key (\), for example, \" and \\.
·     To include a blank space in a string type argument value, enclose the value in quotation marks, for example, ''my device''.
A specific argument might have more requirements. For more information, see the relevant command reference.
To enter a printable character, you can enter the character or its ASCII code in the range of 32 to 126.
Entering an interface type
You can enter an interface type in one of the following formats:
·     Full spelling of the interface type.
·     An abbreviation that uniquely identifies the interface type.
·     Acronym of the interface type.
For a command line, all interface types are case insensitive. Table 2 shows the full spellings and acronyms of interface types.
For example, to use the interface command to enter the view of interface GigabitEthernet 1/0/2, you can enter the command line in the following formats:
·     interface gigabitethernet 1/0/2
·     interface g 1/0/2
·     interface ge 1/0/2
Spaces between the interface types and interfaces are not required.
Table 2 Full spellings and acronyms of interface types
Full spelling
Acronym
LoopBack
Loop
GigabitEthernet
GE
Ten-GigabitEthernet
XGE
Tunnel
Tun
Vlan-interface
Vlan-int
Virtual-Template
VT
Bridge-Aggregation
BAGG
Abbreviating commands
You can enter a command line quickly by entering incomplete keywords that uniquely identify the complete command. In user view, for example, commands starting with an s include startup saved-configuration and system-view. To enter the command system-view, you need to type only sy. To enter the command startup saved-configuration, type st s.
You can also press Tab to complete an incomplete keyword.
Configuring and using command aliases
You can configure one or more aliases for a command or the starting keywords of commands. Then, you can use the aliases to execute the command or commands. If the command or commands have undo forms, you can also use the aliases to execute the undo command or commands.
For example, if you configure the shiprt alias for display ip routing-table, you can enter shiprt to execute the display ip routing-table command. If you configure the ship alias for display ip, you can use ship to execute all commands starting with display ip, including:
·     Enter ship routing-table to execute the display ip routing-table command.
·     Enter ship interface to execute the display ip interface command.
The device provides a set of system-defined command aliases, as listed in Table 3.
Table 3 System-defined command aliases
Command alias
Command or command keyword
access-list
acl
end
return
erase
delete
exit
hostname
sysname
logging
info-center
no
undo
show
display
write
save
A command alias can be used only as the first keyword of a command or the second keyword of the undo form of a command.
After you successfully execute a command by using an alias, the system saves the command, instead of the alias, to the running configuration.
The command string can include up to nine parameters. Each parameter starts with the dollar sign ($) and a sequence number in the range of 1 to 9. For example, you can configure the alias shinc for the display ip $1 | include $2 command. Then, to execute the display ip routing-table | include Static command, you need to enter only shinc routing-table Static.
To use an alias for a command that has parameters, you must specify a value for each parameter. If you fail to do so, the system informs you that the command is incomplete and displays the command string represented by the alias.
System-defined command aliases cannot be deleted.
2.     Configure a command alias.
alias alias command
By default, the device has a set of command aliases, as listed in Table 3.
3.     (Optional.) Display command aliases.
display alias [ alias ]
This command is available in any view.
Configuring and using hotkeys
The system defines the hotkeys shown in Table 4 and provides a set of configurable command hotkeys. Pressing a command hotkey is the same as entering a command.
Table 4 System-reserved hotkeys
Hotkey
Function
Ctrl+A
Moves the cursor to the beginning of a line.
Ctrl+B
Ctrl+C
Stops the current command.
Ctrl+D
Deletes the character at the cursor.
Ctrl+E
Moves the cursor to the end of a line.
Ctrl+F
Ctrl+H
Deletes the character to the left of the cursor.
Ctrl+K
Aborts the connection request.
Ctrl+N
Displays the next command in the history buffer.
Ctrl+P
Displays the previous command in the history buffer.
Ctrl+R
Redisplays the current line.
Ctrl+V
Pastes text from the clipboard.
Ctrl+W
Deletes the word to the left of the cursor.
Ctrl+X
Deletes all characters to the left of the cursor.
Ctrl+Y
Deletes all characters from the cursor to the end of the line.
Ctrl+Z
Returns to user view.
Ctrl+]
Terminates the current connection.
Esc+B
Moves the cursor back one word.
Esc+D
Deletes all characters from the cursor to the end of the word.
Esc+F
Moves the cursor forward one word.
Esc+N
Moves the cursor down one line. You can use this hotkey before pressing Enter.
Esc+P
Moves the cursor up one line. You can use this hotkey before pressing Enter.
Esc+<
Moves the cursor to the beginning of the clipboard.
Esc+>
Moves the cursor to the end of the clipboard.
A hotkey can correspond to only one command or function. If you assign multiple commands or functions to the same hotkey, the most recently assigned command or function takes effect.
A command or function can be assigned to multiple hotkeys. You can use any of the hotkeys to execute the command or function.
If a hotkey is also defined by the terminal software you are using to interact with the device, the terminal software definition takes effect.
2.     Assign a command to a configurable command hotkey.
hotkey { ctrl_g | ctrl_l | ctrl_o | ctrl_t | ctrl_u } command
The following are the defaults:
¡     Ctrl+G is assigned the display current-configuration command.
¡     Ctrl+L is assigned the display ip routing-table command.
¡     Ctrl+O is assigned the undo debugging all command.
¡     No command is assigned to Ctrl+T or Ctrl+U.
3.     (Optional.) Display hotkeys.
display hotkey
Enabling redisplaying entered-but-not-submitted commands
Your input might be interrupted by system information output. If redisplaying entered-but-not-submitted commands is enabled, the system redisplays your input after finishing the output. You can then continue entering the command line.
2.     Enable redisplaying entered-but-not-submitted commands.
info-center synchronous
By default, the system does not redisplay entered-but-not-submitted commands.
For more information about this command, see Device Management Command Reference.
Understanding command-line syntax error messages
After you press Enter to submit a command, the command line interpreter examines the command syntax.
·     If the command passes syntax check, the CLI executes the command.
·     If the command fails syntax check, the CLI displays an error message.
Table 5 Common command-line syntax error messages
Error message
Cause
% Unrecognized command found at '^' position.
The keyword in the marked position is invalid.
% Incomplete command found at '^' position.
One or more required keywords or arguments are missing.
% Ambiguous command found at '^' position.
The entered character sequence matches more than one command.
% Too many parameters found at '^' position.
The entered character sequence contains excessive keywords or arguments.
% Wrong parameter found at '^' position.
The argument in the marked position is invalid.
Using the command history feature
About command history buffers
The system automatically saves commands successfully executed by a login user to the following two command history buffers:
·     Command history buffer for the user line.
·     Command history buffer for all user lines.
Table 6 Comparison between the two types of command history buffers
Item
Command history buffer for a user line
Which commands are saved in the buffer?
Commands successfully executed by the current user of the user line.
Commands successfully executed by all login users.
Can commands in the buffer be displayed?
Yes.
Yes.
Can commands in the buffer be recalled?
Yes.
No.
Are buffered commands cleared when the user logs out?
Yes.
No.
Is the buffer size adjustable?
Yes.
No. The buffer size is fixed at 1024.
Command buffering rules
The system follows these rules when buffering commands:
·     If you use incomplete keywords when entering a command, the system buffers the command in the exact form that you used.
·     If you use an alias when entering a command, the system transforms the alias to the represented command or command keywords before buffering the command.
·     If you enter a command in the same format multiple times in succession, the system buffers the command only once. If you enter a command in different formats multiple times, the system buffers each command format. For example, display cu and display current-configuration are buffered as two entries but successive repetitions of display cu create only one entry.
·     To buffer a new command when a buffer is full, the system deletes the oldest command entry in the buffer.
Managing and using the command history buffers
Displaying the commands in command history buffers
To display the commands in command history buffers, execute the following commands in any view:
·     Display the commands in command history buffers for a user line.
display history-command
·     Display the commands in command history buffers for all user lines.
display history-command all
Recalling commands in the command history buffer for a user line
Use up and down arrow keys to navigate to the command and press Enter.
Setting the size of the command history buffer for a user line
Use the history-command max-size command in user line or user line class view. For more information, see Fundamentals Command Reference.
Repeating commands in the command history buffer for a user line
You can recall and execute commands in the command history buffer for the current user line multiple times.
The repeat command is available in any view. However, to repeat a command, you must first enter the view for the command. To repeat multiple commands, you must first enter the view for the first command.
The repeat command executes commands in the order they were executed.
The system waits for your interaction when it repeats an interactive command.
To repeat commands in the command history buffer for the current user line, execute the following command:
repeat [ number ] [ count times ] [ delay seconds ]
Controlling the CLI output
This section describes the CLI output control features that help you identify the desired output.
Pausing between screens of output
The device can automatically pause after displaying a specific number of lines if the output is too long to fit on one screen. At a pause, the device displays ----more----. You can use the keys described in Table 7 to display more information or stop the display.
You can also disable pausing between screens of output for the current session. Then, all output is displayed at one time and the screen is refreshed continuously until the final screen is displayed.
Table 7 Output controlling keys
Keys
Function
Space
Displays the next screen.
Enter
Displays the next line.
Ctrl+C
Stops the display and cancels the command execution.
<PageUp>
Displays the previous page.
<PageDown>
Displays the next page.
Disabling pausing between screens of output
To disable pausing between screens of output, execute the following command in user view:
screen-length disable
The default depends on the settings of the screen-length command in user line view. The following are the default settings for the screen-length command:
·     Pausing between screens of output is enabled.
·     The maximum number of lines to be displayed at a time is 24.
For more information about the screen-length command, see Fundamentals Command Reference.
This command is a one-time command and takes effect only for the current CLI session.
Numbering each output line from a display command
For easy identification, you can use the | by-linenum option to display a number for each output line from a display command.
Each line number is displayed as a 5-character string and might be followed by a colon (:) or hyphen (-). If you specify both | by-linenum and | begin regular-expression for a display command, a hyphen is displayed for all lines that do not match the regular expression.
To number each output line from a display command, execute the following command in any view:
display command | by-linenum
Example
# Display information about VLAN 100, numbering each output line.
<Sysname> display vlan 100 | by-linenum
    1:  VLAN ID: 100
    2:  VLAN type: Static
    3:  Route interface: Configured
    4:  IPv4 address: 192.168.2.1
    5:  IPv4 subnet mask: 255.255.255.0
    6:  Description: For LAN Access
    7:  Name: VLAN 0100
    8:  Tagged ports:   None
    9:  Untagged ports: None
   10:
Filtering the output from a display command
You can use the | { begin | exclude | include } regular-expression option to filter the output from a display command.
·     begin—Displays the first line matching the specified regular expression and all subsequent lines.
·     exclude—Displays all lines not matching the specified regular expression.
·     include—Displays all lines matching the specified regular expression.
·     regular-expression—A case-sensitive string of 1 to 256 characters, which can contain the special characters described in Table 8.
Table 8 Special characters supported in a regular expression
Characters
Meaning
Matches the beginning of a line.
"^u" matches all lines beginning with "u". A line beginning with "Au" is not matched.
Matches the end of a line.
"u$" matches all lines ending with "u". A line ending with "uA" is not matched.
. (period)
Matches any single character.
".s" matches "as" and "bs".
Matches the preceding character or string zero, one, or multiple times.
"zo*" matches "z" and "zoo", and "(zo)*" matches "zo" and "zozo".
Matches the preceding character or string one or multiple times.
"zo+" matches "zo" and "zoo", but not "z".
Matches the preceding or succeeding string.
"def|int" matches a line containing "def" or "int".
Matches the string in the parentheses, usually used together with the plus sign (+) or asterisk sign (*).
"(123A)" matches "123A".
"408(12)+" matches "40812" and "408121212", but not "408".
\N
Matches the preceding strings in parentheses, with the Nth string repeated once.
"(string)\1" matches a string containing "stringstring".
"(string1)(string2)\2" matches a string containing "string1string2string2".
"(string1)(string2)\1\2" matches a string containing " string1string2string1string2".
Matches a single character in the brackets.
"[16A]" matches a string containing 1, 6, or A; "[1-36A]" matches a string containing 1, 2, 3, 6, or A (- is a hyphen).
To match the character "]", put it immediately after "[", for example, []abc]. There is no such limit on "[".
Matches a single character that is not in the brackets.
"[^16A]" matches a string that contains one or more characters except for 1, 6, or A, such as "abc". A match can also contain 1, 6, or A (such as "m16"), but it cannot contain these three characters only (such as 1, 16, or 16A).
{n}
Matches the preceding character n times. The number n must be a nonnegative integer.
"o{2}" matches "food", but not "Bob".
{n,}
Matches the preceding character n times or more. The number n must be a nonnegative integer.
"o{2,}" matches "foooood", but not "Bob".
{n,m}
Matches the preceding character n to m times or more. The numbers n and m must be nonnegative integers and n cannot be greater than m.
" o{1,3}" matches "fod", "food", and "foooood", but not "fd".
Matches a string that starts with the pattern following \<. A string that contains the pattern is also a match if the characters preceding the pattern are not digits, letters, or underscores.
"\<do" matches "domain" and "doa".
Matches a string that ends with the pattern preceding \>. A string that contains the pattern is also a match if the characters following the pattern are not digits, letters, or underscores.
"do\>" matches "undo" and "cdo".
\b
Matches a word that starts with the pattern following \b or ends with the pattern preceding \b.
"er\b" matches "never", but not "verb" or "erase".
"\ber" matches "erase", but not "verb" or "never".
\B
Matches a word that contains the pattern but does not start or end with the pattern.
"er\B" matches "verb", but not "never" or "erase".
\w
Same as [A-Za-z0-9_], matches a digit, letter, or underscore.
"v\w" matches "vlan" and "service".
\W
Same as [^A-Za-z0-9_], matches a character that is not a digit, letter, or underscore.
"\Wa" matches "-a", but not "2a" or "ba".
Escape character. If a special character listed in this table follows \, the specific meaning of the character is removed.
"\\" matches a string containing "\", "\^" matches a string containing "^", and "\\b" matches a string containing "\b".
The required filtering time increases with the complexity of the regular expression. To abort the filtering process, press Ctrl+C.
# Display the running configuration, starting from the first configuration line that contains line.
<Sysname> display current-configuration | begin line
dot1x re-authenticate server-unreachable keep-online
 dot1x smarton
 mac-authentication
 mac-authentication max-user 32
 mac-authentication domain aaa
 mac-authentication re-authenticate server-unreachable keep-online
 mac-authentication guest-vlan 100
 mac-authentication guest-vlan auth-period 150
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
line vty 0 31
 authentication-mode none
# Display brief information about interfaces in up state.
<Sysname> display interface brief | exclude DOWN
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
InLoop0              UP   UP(s)    --
NULL0                UP   UP(s)    --
Vlan1                UP   UP       192.168.1.83
# Display SNMP-related running configuration lines.
<Sysname> display current-configuration | include snmp
snmp-agent
 snmp-agent community write private
 snmp-agent community read public
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.1.26 params securityname public
Saving the output from a display command to a file
A display command shows certain configuration and operation information of the device. Its output might vary over time or with user configuration or operation. You can save the output to a file for future retrieval or troubleshooting.
Use one of the following methods to save the output from a display command:
·     Save the output to a separate file. Use this method if you want to use one file for a single display command.
·     Append the output to the end of a file. Use this method if you want to use one file for multiple display commands.
To save the output from a display command to a file, use one of the following commands in any view:
·     Save the output from a display command to a separate file.
display command > filename
·     Append the output from a display command to the end of a file.
display command >> filename
# Save the VLAN 1 settings to a separate file named vlan.txt.
<Sysname> display vlan 1 > vlan.txt
# Verify that the VLAN 1 settings are saved to the file vlan.txt.
<Sysname> more vlan.txt
VLAN ID: 1
 VLAN type: Static
 Description: VLAN 0001
 Tagged ports:   None
# Append the VLAN 100 settings to the end of the file vlan.txt.
<Sysname> display vlan 100 >> vlan.txt
# Verify that the VLAN 999 settings are appended to the end of the file vlan.txt.
VLAN ID: 1
 VLAN type: Static
 Tagged ports:   None
 VLAN ID: 100
 VLAN type: Static
 Tagged ports:   None
Viewing and managing the output from a display command effectively
You can use the following methods in combination to filter and manage the output from a display command:
·     Numbering each output line from a display command
·     Filtering the output from a display command
·     Saving the output from a display command to a file
To use multiple measures to view and manage the output from a display command effectively, execute the following command in any view:
display command [ | [ by-linenum ] { begin | exclude | include } regular-expression ] [ > filename | >> filename ]
# Save the running configuration to a separate file named test.txt, with each line numbered.
<Sysname> display current-configuration | by-linenum > test.txt
# Append lines including snmp in the running configuration to the file test.txt.
<Sysname> display current-configuration | include snmp >> test.txt
# Display the first line that begins with user-group in the running configuration and all the following lines.
<Sysname> display current-configuration | by-linenum begin user-group
  114:  user-group system
  115-  #
  116-  return
// The colon (:) following a line number indicates that the line contains the string user-group. The hyphen (-) following a line number indicates that the line does not contain the string user-group.
