- 18-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-SNMP commands
- 04-RMON commands
- 05-NETCONF commands
- 06-EAA commands
- 07-Process monitoring and maintenance commands
- 08-Flow log commands
- 09-Packet capture commands
- 10-Mirroring commands
- 11-Fast log output commands
- 12-UCC commands
- 13-SQA commands
| 12-UCC commands | 82.16 KB |
UCC commands
application enable
Use application enable to enable UCC for an audio or video application.
Use undo application enable to disable UCC for an audio or video application.
application app-name enable
undo application app-name enable
UCC is disabled for audio and video applications.
UCC profile view
app-name: Specifies an application name.
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
This feature is available only in local forwarding mode.
# Enable UCC for Skype applications.
[Sysname] ucc profile ssidcompany
[Sysname-ucc-profile-ssidcompany] application skype enable
ucc profile
application flow-mark
Use application flow-mark to configure priority marking for traffic from an audio or video application.
Use undo application flow-mark to restore the default.
application app-name flow-mark
undo application app-name flow-mark
Priority marking is not configured for traffic from audio and video applications.
UCC profile view
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured. For example, after the priority of packets from an audio or video application is notified to the EoSRv6 tunnel, the tunnel adds the priority to the packets for the uplink device to identify and forward the packets preferentially.
# Configure priority marking for Tencent Meeting traffic.
[Sysname-ucc-profile-ssidcompany] application tencentmeeting flow-mark
ucc profile
display ucc profile
Use display ucc profile to display configuration information for UCC profiles.
display ucc profile [ profile-name ]
profile-name: Specifies a UCC profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a UCC profile, this command displays configuration information for all UCC profiles.
# Display configuration information for all UCC profiles.
<Sysname> display ucc profile
UCC profile name: ssidcompany1
SIP: Enabled
Skype4B: Disabled
App sharing DSCP priority : 2
App sharing 802.1p priority : 2
Video DSCP priority : 2
Video 802.1p priority : 2
Voice DSCP priority : 2
Voice 802.1p priority : 2
UCC-enabled applications: tencentmeeting
Traffic-marking enabled applications: tencentmeeting
Total UCC profiles: 1
SIP |
Status of SIP-based UCC for the UCC profile: · Enabled. · Disabled. |
Skype4B |
Status of Skype4B-based UCC for the UCC profile: · Enabled. · Disabled. |
App sharing DSCP priority |
DSCP priority for Skype4B application sharing packets. |
App sharing 802.1p priority |
802.1p priority for Skype4B application sharing packets. |
Video DSCP priority |
DSCP priority for Skype4B video packets. |
Video 802.1p priority |
802.1p priority for Skype4B video packets. |
Voice DSCP priority |
DSCP priority for Skype4B voice packets. |
Voice 802.1p priority |
802.1p priority for Skype4B voice packets. |
UCC-enabled applications |
List of audio and video applications with UCC enabled |
Traffic-marking enabled applications |
List of audio and video applications with Traffic-marking enabled |
application enable
sip enable
skype4b enable
display ucc table
Use display ucc table to display UCC entries.
display ucc table
# Display UCC entries.
<Sysname> display ucc table
UCC tuple5 entry info:
Source IP/port : 2.1.1.2/11111
Destination IP/port : 2.1.1.3/22222
Transport layer protocol : UDP
Flow type : SIP
Media type : Audio
Lifetime : 280
Source IP/port : 2.1.1.4/11113
Destination IP/port : 2.1.1.5/22224
Flow type : SIP
Media type : Video
Lifetime : 260
UCC tuple3 entry info:
Client IP/port : 10.1.1.145/13454
Transport layer protocol : TCP
Flow type : SKYPE4B
Media type : App-Share
Lifetime : 62
Client IP/port : 10.1.1.155/8020
Flow type : SKYPE4B
Lifetime : 62
Total tuple5 entries found : 2
Total tuple3 entries found : 2
Total entries found: 4
UCC tuple5 entry info |
5-tuple entry information for UCC. |
Source IP/port |
Source IP address and port number in a UCC entry. |
Destination IP/port |
Destination IP address and port number in the UCC entry. |
Flow type |
Flow type: · SIP. · SKYPE4B. |
Media type |
Media type: · App-Share. · Audio. · Video. |
Lifetime |
Lifetime of the UCC entry, in seconds. |
UCC tuple3 entry info |
Triple entry information for UCC. |
Client IP/port |
Client IP address and port number in a UCC entry. |
reset ucc table
sip enable
ucc profile
ucc-profile
reset ucc table
Use reset ucc table to clear UCC entries.
reset ucc table [ sip | skype4b ]
sip: Specifies the SIP protocol.
skype4b: Specifies the Skype4B protocol.
If you do not specify any keywords, this command clears all UCC entries.
# Clear all UCC entries.
<Sysname> reset ucc table
display ucc table
sip enable
Use sip enable to enable SIP-based UCC in a UCC profile.
Use undo sip enable to disable SIP-based UCC in a UCC profile.
sip enable
undo sip enable
SIP-based UCC is disabled in a UCC profile.
UCC profile view
With this command configured, the service template bound to a UCC profile can preferentially forward audio and video traffic to provide high-quality audio and video services.
This command takes effect only on audio and video services for wireless clients.
# Enable SIP-based UCC in UCC profile ssidcompany.
[Sysname-ucc-profile-ssidcompany] sip enable
ucc profile
skype4b app-share remark
Use skype4b app-share remark to configure priority marking for Skype4B application sharing packets.
Use undo skype4b app-share remark to restore the default.
skype4b app-share remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b app-share remark { dscp | dot1p }
Priority marking is not configured for Skype4B application sharing packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B application sharing packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B application sharing packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B application sharing packets.
# Mark DSCP priority 6 for Skype4B application sharing packets.
[Sysname-ucc-profile-ssidcompany] skype4b app-share remark dscp 6
skype4b enable
Use skype4b enable to enable Skype4B-based UCC.
Use undo skype4b enable to disable Skype4B-based UCC.
skype4b enable
undo skype4b enable
Skype4B-based UCC is disabled.
UCC profile view
This command enables the service template or Layer 3 interface bound to a UCC profile to preferentially forward audio, video, and application sharing traffic, providing high-quality audio, video, and application sharing services.
This command takes effect only on audio, video, and application sharing services for wireless clients.
# Enable Skype4B-based UCC.
[Sysname-ucc-profile-ssidcompany] skype4b enable
display ucc profile
ucc profile
skype4b listener
Use skype4b listener to enable the device to communicate with the Skype4B server and specify the port number.
Use undo skype4b listener to disable the device from communicating with the Skype4B server.
skype4b listener { http-port http-port-num | https-port https-port-num ssl-policy ssl-policy-name }
undo skype4b enable { http-port | https-port }
The device is disabled from communicating with the Skype4B server.
http-port http-port-num: Specifies the HTTP service port number in the range of 1025 to 55535.
https-port https-port-num: Specifies the HTTPS service port number in the range of 1025 to 55535.
ssl-policy ssl-policy-name: Specifies an SSL server policy name, a case-insensitive string of 1 to 31 characters.
You cannot use this command to edit the HTTP or HTTPS service port number or SSL server policy. To do so, you must execute the undo skype4b listener command first to disable the device from communicating with the Skype4B server.
If you specify both the HTTP and HTTPS services, make sure they use different port numbers.
# Enable the device to communicate with the Skype4B server and specify the port number as 3000.
[Sysname] skype4b listener http-port 3000
ssl server-policy (Security Command Reference)
skype4b video remark
Use skype4b video remark to configure priority marking for Skype4B video packets.
Use undo skype4b video remark to restore the default.
skype4b video remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b video remark { dscp | dot1p }
The DSCP value is 34 and the 802.1p priority is 4 for Skype4B video packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B video packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B video packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B video packets.
# Mark DSCP priority 6 for Skype4B video packets.
[Sysname-ucc-profile-ssidcompany] skype4b video remark dscp 6
skype4b voice remark
Use skype4b voice remark to configure priority marking for Skype4B voice packets.
Use undo skype4b voice remark to restore the default.
skype4b voice remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b voice remark { dscp | dot1p }
The DSCP value is 46 and the 802.1p priority is 6 for Skype4B voice packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B voice packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B voice packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B voice packets.
# Mark DSCP priority 6 for Skype4B voice packets.
[Sysname-ucc-profile-ssidcompany] skype4b voice remark dscp 6
ucc profile
Use ucc profile to create a UCC profile and enter its view, or enter the view of an existing UCC profile.
Use undo ucc profile to delete a UCC profile.
ucc profile profile-name
undo ucc profile profile-name
No UCC profiles exist.
profile-name: Specifies the name of a UCC profile, a case-insensitive string of 1 to 31 characters. The UCC profile name can contain hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create UCC profile ssidcompany and enter its view.
display ucc profile
ucc-profile
ucc-profile
Use ucc-profile to bind a UCC profile to a service template.
Use undo ucc-profile to unbind a UCC profile from a service template.
ucc-profile profile-name
undo ucc-profile
No UCC profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one UCC profile to a service template. To bind a different UCC profile to the service template, first unbind the existing UCC profile from the service template.
# Bind UCC profile ssidcompany to service template service.
[Sysname-ucc-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] ucc-profile ssidcompany
sip enable
ucc profile
